jaybird3rd Posted November 8, 2013 Author Share Posted November 8, 2013 Here is something to get you started (from an Aquarius User magazine). Thanks for posting those listings! I had forgotten that Erik posted them on GeekVintage. I took the liberty of repackaging them as a ZIP archive, in case anyone who wants to use them doesn't have any RAR tools installed: TypeIns.zip 2 Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted November 8, 2013 Author Share Posted November 8, 2013 Can you inject assembly routines from BASIC? Yes! Aquaman already linked to Martin's example hand controller code, and there are other routines that would be much faster to implement in assembly as well (such as changing the screen color). Of course, using assembly in a BASIC program could cause problems when the program is converted to ROM format, since the code is being relocated in the process, but that might not matter if the assembly code uses only relative addressing. (Martin provided clarification on the use of Assembly in BASIC a few posts down. Thanks, Martin!) Getting back to Extended BASIC (and the 1541 version of Extended BASIC in the Aquaricart): it's important to remember that everything that can be done with the commands added by these versions of BASIC can also be done in Regular BASIC, with the use of assembly (they're all written in assembly, after all). Perhaps it would be a good idea to prepare a "library" of useful assembly routines that can be dropped into any Aquarius BASIC program. 2 Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 8, 2013 Share Posted November 8, 2013 (edited) II have the follwoing in my collection: "The Aquarius and how to get the most of it" by Ian Sinclair, "30 Dynamic Games for the Aquarius by Tim hardwell" and finally "The Aquarius program book" by Peter Goode. There should be one out there named "Mattel Aquarius Ideabook" by David H. Ahl, but I have never seen anyone having it? Good collection of books! I am missing the 30 Dynamic games, maybe you were the one who snatched it from the ebay auction several years ago I have heared about the ideabook, but I haven't seen it. I do have a French book called "Jouez avec Aquarius" (Playing with Aquarius), which seems to contains BASIC listenings printed on an Aquarius printer. The back is glued, but it looks that it will fall apart when you open the pages. Your best guess is to look into Aquarius user magazine. I have put some scanned images on the net a while ago at http://www.vdsteenoven.com/aquarius/books.php but I just noticed that it is not working correctly on an Internet Explorer (Firefox will work) Regs, Martin Edited November 8, 2013 by mvdsteenoven 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 8, 2013 Share Posted November 8, 2013 Good collection of books! I am missing the 30 Dynamic games, maybe you were the one who snatched it from the ebay auction several years ago I have heared about the ideabook, but I haven't seen it. I do have a French book called "Jouez avec Aquarius" (Playing with Aquarius), which seems to contains BASIC listenings printed on an Aquarius printer. The back is glued, but it looks that it will fall apart when you open the pages. Your best guess is to look into Aquarius user magazine. I have put some scanned images on the net a while ago at http://www.vdsteenoven.com/aquarius/books.php but I just noticed that it is not working correctly on an Internet Explorer (Firefox will work) Regs, Martin Not FoundThe requested URL /aquarius/books.php but I just noticed that it is not working correctly on an Internet Explorer (Firefox will work) was not found on this server. That's the message I got from your link using Waterfox (64-bit derivative of Firefox.) Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 8, 2013 Share Posted November 8, 2013 Thanks, the editor took the whole line as the url. It is corrected now. The url should be http://www.vdsteenoven.com/aquarius/books.php Regs, Martin 3 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 8, 2013 Share Posted November 8, 2013 (edited) That's why I probably have missed this link! Thanks! Edited November 8, 2013 by Aquaman Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 8, 2013 Share Posted November 8, 2013 Getting back to Extended BASIC (and the 1541 version of Extended BASIC in the Aquaricart): it's important to remember that everything that can be done with the commands added by these versions of BASIC can also be done in Regular BASIC, with the use of assembly (they're all written in assembly, after all). Perhaps it would be a good idea to prepare a "library" of useful assembly routines that can be dropped into any Aquarius BASIC program.I really like that idea, because Basic is in most cases sufficient, but some things just can't be done or not fast enough! Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 9, 2013 Share Posted November 9, 2013 That makes me wonder, if the conversion still would work when parts of the programming is being done in assembly? (Martin could you please answer this?)Sorry, I did not saw your question earlier.I assume that you are talking about converting your BASIC program to a ROM cartridge? Yes, the assembly would still work. The conversion will only place your BASIC program into the ROM memory area and execute it from there. Useally one would put his machine code into a fixed memory address in RAM, somewhere after the program but still with enough space for the BASIC variables that your program uses. But when you convert your BASIC program you will have more RAM available so you can also use a lower address to store your machine code. This way a 16k program should even work on a standard Aquarius. Note: you cannot use two ROM cartridges in one mini expander, so you cannot use the bootloader together with the 1541 ROM. Even if you would use it in an Aquarius II (which has Extended Basic build in) then the bootloader will become the primary ROM and Extended Basic commands will be disabled. Regs, Martin 1 Quote Link to comment Share on other sites More sharing options...
voltron Posted November 9, 2013 Share Posted November 9, 2013 Indeed there are a few books available. At the time I got my Aquarius in the earlie eighties I didn't have more than the basic manual, but at this point I have the follwoing in my collection: "The Aquarius and how to get the most of it" by Ian Sinclair, "30 Dynamic Games for the Aquarius by Tim hardwell" and finally "The Aquarius program book" by Peter Goode. There should be one out there named "Mattel Aquarius Ideabook" by David H. Ahl, but I have never seen anyone having it? I have a scanned version of the first book "The Aquarius and how to get the most of it" for you if you want, but because of the size I cannot post it here. So if you want it I can send it to you by general E-mail. Furthermore I would recommend you to become a member of the Mattel Aquarius Yahoo user group, because in the file segment, there is also a lot to be found which may come in handy! OK kewl I will pm my email. Im a bit confuse about extended basic. Is that already apart of aquarius emulator or something different? I was wondering about other commands that may not have been listed in the aquarius guide book. I was comparing the functions and commands of ms basic and found a few commands I couldnt find in the guide book, and I wasnt sure if it was in the extended basic manual, wish I dont have and i am not sure if its part of the emulator I downloaded. Thanks Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 9, 2013 Share Posted November 9, 2013 Perhaps it would be a good idea to prepare a "library" of useful assembly routines that can be dropped into any Aquarius BASIC program. I really like that idea, because Basic is in most cases sufficient, but some things just can't be done or not fast enough!I could incorporate some of the 1541 commands into the bootloader, but this will decrease the size of the BASIC program that you can store in the ROM area. Regs, Martin 1 Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 9, 2013 Share Posted November 9, 2013 I was comparing the functions and commands of ms basic and found a few commands I couldnt find in the guide book, and I wasnt sure if it was in the extended basic manual, wish I dont have and i am not sure if its part of the emulator I downloaded. The Aquarius set of BASIC commands is very limited, even with the Extended Basic. You can find the Extended Basic manual also at Yahoo! GroupsBy default the virtual aquarius starts without Extended Basic, you will have to insert the cartridge which you can find in the ROM area of the emulator. Try the command CLS; without Extended Basic it will give a syntax error, if EB is active it will clear the screen. Regs, Martin 1 Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted November 9, 2013 Author Share Posted November 9, 2013 I could incorporate some of the 1541 commands into the bootloader, but this will decrease the size of the BASIC program that you can store in the ROM area. Thanks, Martin (thanks also for the clarification about assembly and the relocation of BASIC code to the cartridge). I don't want the bootloader to become a maintenance headache for you (requests for additional features, and so forth), so perhaps it's best to keep it as simple and as small as possible. I'm sure that small bits of inline assembly would do the job for the most common tasks: clearing the screen, changing the screen colors, using the PSG and hand controllers, etc. (I'm speaking only for myself in this, of course.) 1 Quote Link to comment Share on other sites More sharing options...
voltron Posted November 9, 2013 Share Posted November 9, 2013 (edited) im curious is this a possibility. I know with a commodore i was able fool the computer into making game levels. so lets say a game is made with one level and you have just enough memory for that one level. With the commodore i remember that I could add a special code at the end of the source code and it would automatically load from the floopy drive level two and run it. I noticed that with the aquarius if i put run with out any numbers at the beggining of the source code it runs the code. but not sure if there is a way to make it load new code on the emulator automatically, with out having to manually do it. I can kind of visualize doing it on a cassette, by giving the person a que when to hit play on the cassette player, but i cant see how to do it on the emulator. Edited November 9, 2013 by voltron 1 Quote Link to comment Share on other sites More sharing options...
jaybird3rd Posted November 9, 2013 Author Share Posted November 9, 2013 im curious is this a possibility. I know with a commodore i was able fool the computer into making game levels. so lets say a game is made with one level and you have just enough memory for that one level. With the commodore i remember that I could add a special code at the end of the source code and it would automatically load from the floopy drive level two and run it. I noticed that with the aquarius if i put run with out any numbers at the beggining of the source code it runs the code. but not sure if there is a way to make it load new code on the emulator automatically, with out having to manually do it. I can kind of visualize doing it on a cassette, by giving the person a que when to hit play on the cassette player, but i cant see how to do it on the emulator.If I understand what you're after (loading the program and then loading additional data later), it can't easily be done with "quick typing", which is really meant to load an entire program at once. You'd need to use a recognized storage device that you can access from BASIC, like the cassette (which is emulated in Virtual Aquarius). If you look at the cassette game images provided with Virtual Aquarius, you'll see that many of them are in two parts: a BASIC "bootstrap" program which starts the loading process, and an "array" of machine language code (the "main body" of the game) which is loaded into RAM by the BASIC program and then executed. So it's certainly possible to load content into RAM from the cassette within a BASIC program. I wouldn't worry about that, though, until your programs get too large to fit into 16K of RAM. Regarding line numbers: you can run a simple program entirely in "immediate mode" without using line numbers, but you won't be able to do any branching or looping. Remember also that every statement in your program will require line numbers; BASIC won't allow you to use numbers with some lines but not with others. 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 9, 2013 Share Posted November 9, 2013 I could incorporate some of the 1541 commands into the bootloader, but this will decrease the size of the BASIC program that you can store in the ROM area. Regs, Martin I would certainly love to have these into the bootloader if possible, these features (Joystick, sound and maybe screen colour) are in my opinion necesities for making good games! We wouldn't need extended basic then and I am sure there will still be a sufficient amount of RAM to program the general game process. Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 9, 2013 Share Posted November 9, 2013 (edited) Thanks, Martin (thanks also for the clarification about assembly and the relocation of BASIC code to the cartridge). I don't want the bootloader to become a maintenance headache for you (requests for additional features, and so forth), so perhaps it's best to keep it as simple and as small as possible. I'm sure that small bits of inline assembly would do the job for the most common tasks: clearing the screen, changing the screen colors, using the PSG and hand controllers, etc.I don't want the bootloader to be a maintenance headache either, so after the 1541 features (which should have been possible in the first place) the rest should indeed being done by small bits of inline assembly. A kind of assembly database(in basic data) were everyone can put in his programmed features, would be nice though! Edited November 9, 2013 by Aquaman 1 Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 9, 2013 Share Posted November 9, 2013 For the end-user how would this work? I would use the Extended BASIC cart and save the .CAS file as usual. Then, by your magic the .CAS to ROM convertor would handle those extra commands? 1 Quote Link to comment Share on other sites More sharing options...
Pset Posted November 9, 2013 Share Posted November 9, 2013 (edited) I think Yahoo requires a phone number for a new account these days, so everyone might not be hip to the old Yahoo group. Here's the Aquarius Extended Basic Manual PDF I'll try to keep this hosted. But grab it while you can and make it available. The Get and Put graphics commands were the very beginnings of cut/paste and sprites. Extended Basic had a some great potential. Edited November 9, 2013 by Pset 2 Quote Link to comment Share on other sites More sharing options...
mvdsteenoven Posted November 10, 2013 Share Posted November 10, 2013 For the end-user how would this work? I would use the Extended BASIC cart and save the .CAS file as usual. Then, by your magic the .CAS to ROM convertor would handle those extra commands?Just as Aquaman suggested, I was thinking about some 1541 commands like PSG, JOYPAD and FILL. The Extended Basic commands can easilly be done with standard Basic(except def fn, but these are hard to port anyway).You would develop using the virtual aquarius with the 1541 rom (optional) and you could use the 3 additional commands. Next, convert .caq to rom as useall. But I might be able to create an easier solution. Let me fiddle a bit..... Regs, Martin 3 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 10, 2013 Share Posted November 10, 2013 I think Yahoo requires a phone number for a new account these days, so everyone might not be hip to the old Yahoo group.Didn't know that! Why is this? By the way, welcome to Atari Age and the Aquarius thread!! Quote Link to comment Share on other sites More sharing options...
Pset Posted November 10, 2013 Share Posted November 10, 2013 Didn't know that! Why is this? By the way, welcome to Atari Age and the Aquarius thread!! Its pretty recent, Yahoo says its for account security and password retrieval. Anyway, back to programming, another topical item from the yahoo group. Here's a maze generator from James L. Dean from back 1995. Seems to need at least 16k for RAM to run. Really shows the speed of the Aquarius. You'll think its not working, but it is just taking a long time. BASIC Code is in the >> 10 REM DISPLAY A MAZE. 20 REM SEED WILL PRODUCE A DIFFERENT MAZE. 30 REM posted to comp.lang.basic.misc 1995/06/23 40 REM WRITTEN BY JAMES L. DEAN 50 REM http://www.geocities.com/jdean284/ 60 REM 70 REM DEFINT A-Z command not available on Aquarius 80 PRINT 90 PRINT "Number of columns"; 100 INPUT C 110 IF C > 1 THEN 140 120 PRINT "? The number of columns must be at least 2" 130 GOTO 90 140 PRINT 150 O=2*C 160 P=O+1 170 PRINT "Number of rows"; 180 INPUT R 190 IF R > 1 THEN 220 200 PRINT "? The number of rows must be at least 2" 210 GOTO 170 220 PRINT 230 W=2*R+1 240 DIM Z(P*W+2*C*R+200) 250 PRINT "Seed"; 260 INPUT S 270 PRINT 280 S=ABS(S) 290 FOR T=1 TO 8 300 G=INT(S/29) 310 H=S-29*G 320 S=G 330 IF H <> 0 THEN 350 340 H=19 350 Z(T)=H 360 NEXT T 370 Z(9)=-1 380 Z(105)=0 390 Z(10)=0 400 Z(106)=1 410 Z(11)=1 420 Z(107)=0 430 Z(12)=0 440 Z(108)=-1 450 V=8 460 N=104 470 FOR A=1 TO 4 480 FOR B=1 TO 4 490 IF A = B THEN 690 500 FOR D=1 TO 4 510 IF A = D THEN 680 520 IF B = D THEN 680 530 FOR E=1 TO 4 540 IF A = E THEN 670 550 IF B = E THEN 670 560 IF D = E THEN 670 570 Z(A+V)=Z(9) 580 Z(A+N)=Z(105) 590 Z(B+V)=Z(10) 600 Z(B+N)=Z(106) 610 Z(D+V)=Z(11) 620 Z(D+N)=Z(107) 630 Z(E+V)=Z(12) 640 Z(E+N)=Z(108) 650 N=N+4 660 V=V+4 670 NEXT E 680 NEXT D 690 NEXT B 700 NEXT A 710 T=201 720 FOR U=1 TO W 730 FOR M=1 TO P 740 Z(T)=1 750 T=T+1 760 NEXT M 770 NEXT U 780 T=INT(C/2) 790 T=C-2*T 800 IF T <> 0 THEN 830 810 X=C 820 GOTO 840 830 X=C+1 840 T=INT(R/2) 850 T=R-2*T 860 IF T <> 0 THEN 890 870 Y=R 880 GOTO 900 890 Y=R+1 900 V=200+P*W 910 F=V 920 GOTO 1300 930 Z(202)=0 940 Z(200+P*(W-1)+O)=0 950 PRINT ". "; 960 T=1 970 FOR M=3 TO P 980 IF T = 0 THEN 1010 990 PRINT "."; 1000 GOTO 1020 1010 PRINT "_"; 1020 T=1-T 1030 NEXT M 1040 PRINT 1050 U=3 1060 V=200+P 1070 N=V+P 1080 IF U > W THEN 1760 1090 T=1 1100 FOR M=1 TO P 1110 N=N+1 1120 V=V+1 1130 IF T <> 0 THEN 1190 1140 IF Z(N) = 1 THEN 1170 1150 PRINT " "; 1160 GOTO 1230 1170 PRINT "_"; 1180 GOTO 1230 1190 IF Z(V) = 1 THEN 1220 1200 PRINT "."; 1210 GOTO 1230 1220 PRINT "!"; 1230 T=1-T 1240 NEXT M 1250 PRINT 1260 U=U+2 1270 N=N+P 1280 V=V+P 1290 GOTO 1080 1300 Z(200+P*(Y-1)+X)=0 1310 I=1 1320 J=Z(1) 1330 G=1 1340 FOR H=2 TO 8 1350 T=Z(H) 1360 Z(G)=T 1370 J=J+T 1380 IF J <= 29 THEN 1400 1390 J=J-29 1400 G=H 1410 NEXT H 1420 Z(=J 1430 IF J > 24 THEN 1320 1440 IF I > 4 THEN 1700 1450 N=I+4*(J-1) 1460 K=X+2*Z(8+N) 1470 IF K <= 1 THEN 1680 1480 IF K >= P THEN 1680 1490 Q=Y+2*Z(104+N) 1500 IF Q <= 1 THEN 1680 1510 IF Q >= W THEN 1680 1520 IF Z(200+P*(Q-1)+K) <> 1 THEN 1680 1530 IF X <> K THEN 1560 1540 Z(200+P*(((Y+Q)/2)-1)+K)=0 1550 GOTO 1570 1560 Z(200+P*(Q-1)+(X+K)/2)=0 1570 X=K 1580 Y=Q 1590 V=V+1 1600 Z(V)=I 1610 V=V+1 1620 Z(V)=J 1630 GOTO 1300 1640 N=I+4*(J-1) 1650 X=X-2*Z(8+N) 1660 Y=Y-2*Z(104+N) 1670 GOTO 1440 1680 I=I+1 1690 GOTO 1440 1700 J=Z(V) 1710 V=V-1 1720 I=Z(V) 1730 V=V-1 1740 IF F = V THEN 930 1750 GOTO 1640 1760 END 1760 END Have fun. Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 10, 2013 Share Posted November 10, 2013 I think Yahoo requires a phone number for a new account these days, so everyone might not be hip to the old Yahoo group. Here's the Aquarius Extended Basic Manual PDF I'll try to keep this hosted. But grab it while you can and make it available. The Get and Put graphics commands were the very beginnings of cut/paste and sprites. Extended Basic had a some great potential. Yeah. I tried to get James the Animal Tamer's OK to use his Aquarius font. I think the Yahoo group was the last known contact point. Unbeknownst to me posting is blocked on my account. Probably wants more details like blood type, toe fungus, etc.. Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 11, 2013 Share Posted November 11, 2013 Yeah. I tried to get James the Animal Tamer's OK to use his Aquarius font. I think the Yahoo group was the last known contact point. Unbeknownst to me posting is blocked on my account. Probably wants more details like blood type, toe fungus, etc..So this E-Mail address is also not working anymore: emucompboy@yahoo.com ? Quote Link to comment Share on other sites More sharing options...
+Gemintronic Posted November 11, 2013 Share Posted November 11, 2013 So this E-Mail address is also not working anymore: emucompboy@yahoo.com ? I'd love for you to prove me wrong This prompted me to try his email address again. Happy thoughts/Crossed fingers! 1 Quote Link to comment Share on other sites More sharing options...
Aquaman Posted November 11, 2013 Share Posted November 11, 2013 (edited) First is the most recent version of the Virtual Aquarius emulator for Windows, version 0.72a: VirtualAquarius.zip This distribution archive includes the emulator itself, the OS ROM, several cartridge and cassette images, and a few sample BASIC programs in ASCII text format to get you started (more on these later). This is the primary emulator that I will be writing my instructions for in this thread, since it has a few features which are especially useful for BASIC programming but which other Aquarius emulators (such as MESS) presently lack. (There is no "installer" for this emulator; just unpack the ZIP archive into a folder, move the folder to a convenient place, and open the "aquarius.exe" executable inside the folder to start the emulator. It's a few years old now, but I've used Virtual Aquarius under every version of Windows from XP through Windows 8 (in Desktop mode), and it appeared to function perfectly.) This is indeed a very good emulator! However it's also a pity James lost interest to bring out a new and improved version, which removes some of the bugs that are still inside or even incorporates the original character rom image for that matter! Edited November 11, 2013 by Aquaman 1 Quote Link to comment Share on other sites More sharing options...
