What's the state of C development for the 7800?
Gemintronic
  • 3 weeks later...
GroovyBee was working on a C complier for the 7800 some time ago, but I think it's been a couple of years since there was any news on it. I suppose, sadly, we could call it 'deadware' now. :( As far as I know, that was the only C development library made for the 7800 - which saddens me immensely.
  • 1 month later...
I don't know, today I'm in the mood where words in quotes such as 'deadware' make me mad.
I'm pretty sure cc65 was the compiler 'GroovyBee was working on'. Ok, so Ullrich von Bassewitz has stopped maintaining it, but it's still available. That's all you need, as far as the toolchain is concerned.
The rfk7800 source is here: http://sourceforge.net/projects/rfk7800/files/rfk7800/. It can get you nicely started. It's using cc65 and gives you startup code and a linker script that produce Atari 7800 ROMs with cc65. I can't remember, but I can't believe GroovyBee didn't make his stuff available. And then there's the technical information made available by people such as Dan Boris, and the official programmer's manual has been available for quite some time as well.
Sorry, but that's just the usual whining. Documentation, tools and example sources are available, people just have to make use of them. Instead of crying.
Besides, I have no idea what you expect from a 'C development library made for the 7800'. Atari 7800 programming is all about putting together display lists and display list lists. This is all explained in the programmer's manual, which you simply have to read until you understand it. There's no way around this. And then your display management code is highly specific to your game and probably you'll end up writing it in assembly anyway.
Edited by Tom
What build process? Do you want to build cc65 yourself or what?
Actually, I'm just getting started in C. I do have familiarity with batch files and whatnot. I was going to try and get a simple "hello world" compiled with cc65 and your library. Just wondered if you were OK with me asking you some questions if I get stuck.
I never made a library. I can't remember in all details what I did years ago. Either I downloaded cc65 binaries or compiled my own. Then I read ist documents and figured out how to build startup code and a linker script. Lazy how I am I figured it wasn't necessary to build a special C standard library for the 7800. rfk7800 links to the c64 library and I simply paid attention not to use any function that actually does C64 specific stuff. That's usually the IO related functions. Also, I didn't set up a heap, so malloc/free won't work either. I don't consider this much of a problem. You just don't want to use a heap on something with as little RAM as the 7800.
If you have questions, ask them on the forum. There are People hanging around here who know a lot.
  • 5 months later...
  • 2 weeks later...
