+grips03 Posted December 19, 2013 Share Posted December 19, 2013 (edited) I'm making a kit to add db9 ports to first model Intellivision (2609). This would make it more like Sears. This is mainly for a person on the forum that wants to add Zoe RGB upgrade to PAL Intellvision that uses the same case as 2609. First picture shows front top center of case. Second picture shows bottom left of case. Zoe RGB installs near here as well, so might be an issue. Any other spots you guys think would be good? I should mention that user wants to keep stock controllers too, so I did not want to install near them. Edited December 19, 2013 by grips03 2 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 19, 2013 Author Share Posted December 19, 2013 here is pic of Zoe pcb in the bottom case Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted December 19, 2013 Share Posted December 19, 2013 IIRC "The Best Intellivision In The World " from a German eBay seller places DB9 connectors on the bottom part of the housing, on the inset area below the front woodgrain panel. Been awhile since I've cracked open a unit. I think such a layout would at the minimum require routing the cable a few inches. 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 19, 2013 Author Share Posted December 19, 2013 (edited) IIRC "The Best Intellivision In The World " from a German eBay seller places DB9 connectors on the bottom part of the housing, on the inset area below the front woodgrain panel. Been awhile since I've cracked open a unit. I think such a layout would at the minimum require routing the cable a few inches. I remember that one I kind of like this area, but would reverse mount. Edited December 20, 2013 by grips03 Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted December 20, 2013 Share Posted December 20, 2013 I remember that one I kind of like this area, but would reverse mount. Yeah, that's the one, and I agree that a reverse mount is definitely cosmetically superior. Ultimately neither would seem to have any mechanical advantage. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 20, 2013 Author Share Posted December 20, 2013 MC010M-5-ND - 3M ribbon cable - digikey 1658611-4 - db9 male with threaded insert Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 20, 2013 Author Share Posted December 20, 2013 (edited) Here is a quick hack. Good news is the Intv2 Arcade Controller works fine on the 2609. I should have mounted a little to the left, so that 2 ports would fit without touching the transformer. I'll post proper measurements over the weekend. Screw heads will be gold in color to match Intellivision White wires will be replaced by a 26 awg ribbon cable ~14 inches. 1.27mm pitch. db9 port will have threaded inserts and IDC10 for the ribbon cable. The way the wires are soldered to the PCB the wired controller would still work too. I would just turn off the Intv2 Arcade Controller when doing this. Edited December 20, 2013 by grips03 3 Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted December 20, 2013 Share Posted December 20, 2013 Looks really good! 1 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 20, 2013 Author Share Posted December 20, 2013 thanks the plastic is nice and thick in this area, so I can see why the chose it use it. Also it kind of hides itself when not in use. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2013 Author Share Posted December 21, 2013 (edited) more pics, I like the black screws more Added led too Edited December 21, 2013 by grips03 1 Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted December 21, 2013 Share Posted December 21, 2013 The only downside I see to putting the connectors so low is that attaching Intellivision II or Wico Controllers is not an option (90-degree angle plug would extend below the bottom of the Intellivision). Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2013 Author Share Posted December 21, 2013 The only downside I see to putting the connectors so low is that attaching Intellivision II or Wico Controllers is not an option (90-degree angle plug would extend below the bottom of the Intellivision). Great point. The Sears Super Video Arcade controllers would fit, but the Intellivision 2 controllers with the right angle db9 connector would not. The end user in this case wants to keep the stock Intellivision controllers on the top, so its not likely they would plug in either one of those. Do you have a picture of the Wico db9 port? Quote Link to comment Share on other sites More sharing options...
+Lathe26 Posted December 21, 2013 Share Posted December 21, 2013 The Wico for the Intellivision has a replaceable cable so it has 3 different cabling options. To switch cables, you need to unscrew and remove a tiny plastic panel on the Wico. The Intellivision II cable. This is what Wico shipped with and is the most common cable option seen on eBay. This is the black spiral cable with the 90 degree bend at the end for the 9-pin connector. The original Intellivision cable. This is the black spiral cable. Typically, the Intellivision is still hardwired attached to the other end. You have to disassemble the original Intellivision controller to free up the cable. The Sears Intellivision cable. This is the black straight cable with a straight 9-pin connector at the other end. You have to disassemble a Sears Intellivision controller to free up the cable. I've never seen one in the wild like this but I'm sure some exist. WARNING: Wico also released a near identical controller for the ColecoVision. It is not compatible and I've heard rumors that it can permanently electrically damage the port on an Intellivision II, Sears Intellivision, or ECS (rumor not confirmed). The Wico for the ColecoVision is far more commonly seen on eBay. The way you tell the difference is that it black spiral cable with a straight 9-pin connector at the other end. Because of all this mess, I'm writing up "The Missing Manual" for the Intellivision Wico controller. It took me a while (and some purchases) to figure out some of this information. It shouldn't be long before I post it. Anyways, here are 3 photos. The 1st is the Intellivision Wico with the Intellivision II cable. The 2nd is a Sears Intellivision controller (while not the Wico, you can see the cable the Wico can use). The 3rd is the ColecoVision Wico to avoid. 2 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted December 21, 2013 Author Share Posted December 21, 2013 thanks for adding the photos. The Wico cable looks exactly like the Intellivision 2 controller cable, hence no good for ports on bottom left of case. Quote Link to comment Share on other sites More sharing options...
+intvsteve Posted December 22, 2013 Share Posted December 22, 2013 My experience thus far is that the Intellivision II and Wico controllers are awful, so not being able to connect them is not an issue. I like the Sears ones much, much better for this sort of thing, short of one of grips' gems. 1 Quote Link to comment Share on other sites More sharing options...
fandenivoldsk Posted December 23, 2013 Share Posted December 23, 2013 more pics, I like the black screws more Added led too Black screws looks awesome! Quote Link to comment Share on other sites More sharing options...
+grips03 Posted January 5, 2014 Author Share Posted January 5, 2014 (edited) I was search through digikey.com and found: H7MXH-0906M <--$2.31 might be a low cost way to add db9 ports to the Intellivision 1 (2609 model) I bought one to check it out. Edited January 5, 2014 by grips03 3 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted January 18, 2014 Author Share Posted January 18, 2014 (edited) I was search through digikey.com and found: H7MXH-0906M <--$2.31 might be a low cost way to add db9 ports to the Intellivision 1 (2609 model) I bought one to check it out. These cables are ok, but the TE / AMP ones have a little bit nicer connector, that holds the db9 cable in place better. These are good for the price. They are really like the drawing above. Here are some photos with two ports installed. Port on left is player 1 and port on right is 2. Edited January 18, 2014 by grips03 Quote Link to comment Share on other sites More sharing options...
fandenivoldsk Posted January 18, 2014 Share Posted January 18, 2014 Very nice! Quote Link to comment Share on other sites More sharing options...
+grips03 Posted January 20, 2014 Author Share Posted January 20, 2014 (edited) I used qty (2) H7MXH-0906M (digikey) on another 2609 and its not as good as TE parts, but still work perfectly fine. Just add a little hot glue to the 2nd player, so the ribbon cable does not rub on the transformer mount tab. Edited January 20, 2014 by grips03 Quote Link to comment Share on other sites More sharing options...
+grips03 Posted January 31, 2017 Author Share Posted January 31, 2017 still working awesome, adding db9 ports to Intv 1 is a great upgrade 1 Quote Link to comment Share on other sites More sharing options...
+stupus Posted February 1, 2017 Share Posted February 1, 2017 You could still use wico and inty 2 controllers with low mounted ports if a controller extension cable was used Quote Link to comment Share on other sites More sharing options...
Intymike Posted February 1, 2017 Share Posted February 1, 2017 (edited) The hidden controller ports. Edited February 1, 2017 by Intymike 4 Quote Link to comment Share on other sites More sharing options...
+-^CrossBow^- Posted February 1, 2017 Share Posted February 1, 2017 The hidden controller ports. That looks like a pretty awesome way to do this?! However, what is the reasoning for adding AV ports and these joystick ports on the left half of the console? Is it because there is more space? I get that, but you do realize that empty space on the left is where you push the AC cord and store it when the Inty isn't in use? This is why when I did the AV mod on my Inty, I installed the ports on the back right side of the case to keep the left hand empty area...empty for the AC cord to still fit for storage. Quote Link to comment Share on other sites More sharing options...
+grips03 Posted February 1, 2017 Author Share Posted February 1, 2017 I like the left front corner as its hidden and out of the way, plus easy to access as its in the front of console. Top case can still be removed with no issue. Plastic is nice and thick so ports are supported very well. If installing in the front left corner just make sure to provide enough space for two db9 ports and ensure the right most ribbon cable does not rub on the transformer case. Quote Link to comment Share on other sites More sharing options...
