ATR-8000 (and other) CP/M System disks here
atr-8000 cp/m system disk atr-8000 cp/m system disks
211 replies to this topic
#1 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
  • broadway1.lorexddns.net 10001
Posted Sat Dec 28, 2013 6:04 PM
For those who are still looking for ATR-8000 CP/M system disks, I found them here: http://www.retroarch...tari/index.html
Link for other CP/M bootdisks: http://www.retroarchive.org/maslin/
Here is all of Don Maslin's stuff: http://www.classiccm...oftware/maslin/
You need an old MS-DOS machine with a 360K floppy drive (and a good controller), and the TeleDisk program here: http://www.classiccm...06/teledisk.htm
Hope this helps.
-Kyle
#2 a8isa1 OFFLINE
a8isa1
  • 1,566 posts
Posted Sat Dec 28, 2013 7:07 PM
Hope this helps.
-Kyle
Not sure I had the exact same teledisk images but years ago I had some images.  Unfortunately I never did own a machine that could produce bootable disks for the ATR8000.  Sure I can do it with the ATR8000 itself but the last time I tried to mail real disks to someone the data was scrambled. (I won't blame the postal service).
I assumed the floppy controller necessary to make this process work needs to support FM but I don't know that is the issue.
Data disks were no problem but bootable disks are generally what new owners of an ATR8000 need first.
It would be nice if people had a reliable way to generate the disks themselves.
Edited by a8isa1, Sat Dec 28, 2013 7:08 PM.
#3 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
Posted Sat Dec 28, 2013 11:00 PM
IIRC, most people tried to copy the ATR-8000 CP/M disk with Atari copy programs, and, between the drive and the copy program, they wouldn't accept 256 bytes in the first 3 sectors.
These teledisc images should be correct.  I HAVE NOT tried them, though. My ATR-8000 died a number of years ago :(
I always wanted to write a high-speed ROM for it.  It uses a Z80 to bitbang, just like Indus.
#4 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Sat Dec 28, 2013 11:13 PM
http://www.gaby.de/edownl.htm
MyZ80.ZIP
is a cp/m emulator that should let you work with image files but
http://www.hp9845.ne...lities/#ima2hpi
Using Ima2hpi tdunp found here I get file sizes of
145,777 for ATR8000.ZD0
and
37,095 for ATR8KBIO.ZD0
Which could be explained by my lack of familiarity with the tools except when I load the resulting ATR8KBIO.ZD0 into a word processor, it seems to be be a fairly complete bios source file with a lot of unprintable characters scattered here and there.
MyZ80 can mount the files but gets nonsense trying to get a directory.  I would kind of think the uncompressed images would be either 180k or 360k.
#5 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
Posted Sat Dec 28, 2013 11:15 PM
I am fairly sure that TeleDisk images use some form of compression. The files should be .TD0, NOT .ZD0.
Edited by Kyle22, Sat Dec 28, 2013 11:16 PM.
#6 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Sat Dec 28, 2013 11:23 PM
Right, the output is those files using the T(ele)D(isk)unp(acker) are the ZD0 images. Using the .BAT files that came with the converters I get a number of errors and it bails.
Which may explain why everyone gets bad images using Teledisk. Teledisk probably wouldn't bail out if you stuck a paper plate in your drive. *If* the images everyone is using are bad archives, Teledisk will just make a bad image.
#7 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
Posted Sat Dec 28, 2013 11:31 PM
TeleDisk is VERY funny about different disk controller chips, and even different TD versions.  It sucks, but, some strange combinations work.  Use the oldest computer you can find. A 386 would be fine.  A separate ISA card floppy controller would also be good.  An old one with a real FDC on it.  I think the 765 should work.  279x may also.
It's been a long time, now, I must build one :)
#8 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Sat Dec 28, 2013 11:57 PM
That's not what I am doing yet <maybe never??> though. All I am doing is using unpacker or converter type software to convert the .TD0 files into raw non compressed images suitable for running on an emulator. Analogous to making an .ATR image from a zip file or Disk Communicator. Once I have that decompressed file, I run an emulator and mount the file. The sizes of the files don't make no sense and the emulators can't touch them.
I'll attach the bios source or at least what I was able to pull out. I did hit return/reduced the line length on the garbage but left everything in the file there so you could see it. To me it really looks like a corrupted file since the good stuff comes and goes with no rhyme nor reason.
It does have a few bits of info you can glean, for instance it says 1k byte sectors for the ATR8000. That could help explain one of the reasons the files got munged in initial copies. Source seems to bail at the print routines but much useful stuff is there. I didn't bother trying to run it though an assembler to see how much is missing. Too much work. :)
#9 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
Posted Sun Dec 29, 2013 12:33 AM
That's a shame.  That text file certainly has garbage characters in it.  I was hoping this would finally be a good image.
#10 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Sun Dec 29, 2013 12:50 AM
I noticed all the binary files I created still had TD as the first two bytes => T(ele)D(isk) id bytes/header is still intact => conversion to raw binary did not work right. Getting late tonight but I have all the tools I need to attempt a real conversion. I still have my Compatacard, couple of USB floppies, 40 meg DRDOS hd, assortment of other junk that hasn't run in years, Kind of late tonight and busy tomorrow but I will make at least a half hearted effort to get it going. Heck, sectors 1-5 being 1,024 bytes on an ATR is something I didn't know yesterday.
#11 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 887 posts
Posted Sun Dec 29, 2013 6:28 AM
The atr disk have 512 byte sectors. I have tried teledisk images onto some disks but it kakes the first sector at 128 bytes but then makes the rest at 512 bytes. I cannot get anadisk to see my 360k drive as one. It insists it is a 1.2m despite selecting 360 when installed. It always double steps grrrrrrrrrr. I finally found a tool that converts tdo to fdi ajd have been able to extract enough to dissemble the boot sector, cpm, atr bios and an overlay that overwrites a small part of the atari bios loaded into high ram from the atr rom. The bios source disk doesnt appear to be correct in some areras. I am hoping to get the atr to format the required disk structor then write cpm out. Will require much work. The atr has a Z device which can be used to do this via custom programs. As the init program calls the cpm bios, i need to see what is happening before i can even hope to start.
James
#12 hashy OFFLINE
hashy
    Combat Commando
  • 7 posts
Posted Sun Dec 29, 2013 8:05 AM
thanks for the links  the retro archive is awesome
#13 redman OFFLINE
redman
    Chopper Commander
  • 116 posts
Posted Sun Dec 29, 2013 8:46 AM
I got the teledisk images from Don Maslin many years ago.  He told me that they probably wouldn't work.  He was right.
#14 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Sun Dec 29, 2013 12:02 PM
James
I am confident you know what you are doing. Kind of makes the problem a bit more curious. That broken file I attached has this in it:
"BIOS source code for SWP ATR8000 SSDD 1024 byte sector, 1-5, 3:1"
It could be the remains of 8" DD drive code.
#15 Subby OFFLINE
Subby
    Moonsweeper
  • 259 posts
Posted Sun Dec 29, 2013 12:11 PM
Bring floppies to VCFSE 2.0 and we'll make copies there.
I hope to have an 8" drive also, but no promises. I'm borrowing one and haven't got it to test with my 8" floppies yet.
#16 Sikor OFFLINE
Sikor
  • 1,478 posts
Posted Sun Dec 29, 2013 12:12 PM
http://trub.atari8.i...ef=indus_cpm_en
#17 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 887 posts
Posted Sun Dec 29, 2013 2:44 PM
Indus cpm tho the same version is a different location. There is a device specific bios at the end of cpm it self to handle consol, printer ,disk etc. So the indus cpm wont work for the ATR.
I would love to go to VCFSE but there is a little puddle in the way called the pacific ocean. Oh and $$$$.
James
#18 Subby OFFLINE
Subby
    Moonsweeper
  • 259 posts
Posted Sun Dec 29, 2013 5:03 PM
James, for you, I'll leave a free entry pass and a free t-shirt at the door!
Edited by Subby, Sun Dec 29, 2013 5:03 PM.
#19 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 887 posts
Posted Mon Dec 30, 2013 12:35 AM
Thank you. I do expect you to keep the dust and cobwebs off them. I don't want them dirty by the time i get to pick them up :grin: :grin:
Re the bios listing above. It is screwed up. The sector order is wrong so chunks are all over the place. Is what I found when i used a couple of image converters for the same result. Deblock.mac file doesn't appear to be correct (older code?) as well as same sector order problem.
What i have found, is the disk named atr8000.tdo doesn't have all the boot sector there, also there is a hole in the code (bad sector?) it is also 512 bytes higher in memory then the disk marked atr8k484.td0. Same version tho.
as a side note. the indus cpm starts at $E400. the cpm on atr8k484 disk starts at $D200. The indus cpm has more free memory if that counts for anything.
James
Edited by sup8pdct, Mon Dec 30, 2013 12:36 AM.
#20 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Mon Dec 30, 2013 11:06 AM
Burning brain cells trying to remember all the problems with early drives. It should not have made a difference since .TD0 images should be pretty raw, but I seem to recall there were formats that would switch between head 1 & 2<or is it 0 & 1?> for even and odd sectors and others where it would fill up an entire side before it started using the second head.
I have a couple of CP/M disks for systems other then Atari floating around. I'll spend some time reading up on basic structure. I'm really not much of a CP/M guy and same for Z80. I'm assuming the OS that loads from disk is hardware independent and just gets the I/O routines  passed to it from the boot ROM. I don't think I have a MS DOS flavor on any computer right now. Slight edge to DEBUG over SID in that you can read/write raw sectors with Debug. Pretty sure I have a few W/95 installs on half a dozen hard drives, they should have Debug on them.
#21 Kyle22 OFFLINE
Kyle22
  • 4,106 posts
Posted Mon Dec 30, 2013 12:42 PM
CP/M on disk is composed of three parts, the CCP (console command processor), the BDOS (basic disk operating system) and BIOS (basic input output system).  The CCP and BDOS are hardware independent, but the BIOS is COMPLETELY hardware DEPENDENT.  The boot ROM causes the initial system boot from disk.
#22 flashjazzcat OFFLINE
flashjazzcat
  • 14,620 posts
Posted Mon Dec 30, 2013 12:47 PM
I looked into the filesystem spec last night (good description here). Yikes. More than sixteen blocks in a file and it consumes more than one directory entry... no crazier than FAT LFNs, I suppose, but imagine CP/M upscaled beyond the limits of its design (i.e. multi-gigabyte volumes) the way FAT eventually was. FAT would then start to look pretty sane. :)
Edited by flashjazzcat, Mon Dec 30, 2013 12:48 PM.
#23 ACML OFFLINE
ACML
    Dragonstomper
  • 931 posts
Posted Mon Dec 30, 2013 2:04 PM
You can substitute a 1.2MB 5.25" for an 8" floppy drive.  You can format the 5.25" 1.2Mb as a 77 track DSDD drive and it will format as an 8" on CP/M.
#24 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 887 posts
Posted Wed Jan 1, 2014 4:54 PM
After messing around for a while, I have a disassembly listing of CP/M including BIOS and Overlay for the atr8000. I also managed to create a disk that hopefully has a boot-able CP/M on it. I went to test it in my ATR only to discover it won't read any disk :(. Before you ask, it is the same mech i had connected to my PC to create the disk. (360k)). I also won't format either, but will boot and step drive to track zero. Now for the long process to try and find out why....
Re the disk images. They are for the most part screwed. Teledisk will create the images with errors on track 1. The sector order however from track 2 on are all messed up so getting any info off is hard. Teledisk also creates the boot disks with 1 128 byte sector on track 0, the other 8 at 512 bytes. track 1 has errors, from track 2 on has 1024 byte sectors!! :-o  I have found a teledisk to FDI converter that i managed to get a file for the source listing below. If anyone wants the image to test, let my know and please tell me what file type.
James
#25 ricortes OFFLINE
ricortes
    Dragonstomper
  • 689 posts
Posted Thu Jan 2, 2014 12:06 PM
The 16k version of SYSTEM.SWP seems to have a good copy of CP/M starting at offset 1900. The 8k versions floating around seem to be seriously munged. I'll go into town today and pick up some disks so I can try writing it out with DEBUG.
