SpartaDos programming question
ebiguy
Hi everybody,
I tried to use symbol U_LOAD of SpartaDos 4.46 to run another program but I don't understand how to deal with FLAG symbol.
I don't see the solution in the documentation (translated by Google).
Basically, I am doing something like this:
ldy #0
lda #<executable_filename
sta FILE_P,y
iny
lda #>executable_filename
sta FILE_P,y
sty FLAG
jsr U_LOAD
It does not run anything.
Of course, all uppercase labels (FILE_P, FLAG and U_LOAD are binded at runtime). I can see the value in Altirra ($0CE3 for FILE_P,...)
The filename is also correct. When I place in executable_filename a wrong filename I got an error. With a right filename, the call to U_LOAD returns but nothing is run.
Maybe the problem is with FLAG symbol ?
I am not sure about 1) the way to fill it and 2) the value to set to run the executable.
I don't know if I should store something in FLAG or consider FLAG as a pointer and if I can/must change FLAG to point to a byte inside my program ?
And which value to use (the doc says bit 7 should be cleared but what is the use of the other bits, if any) ?
Thank you for your help.
FLAG must be zeroed here, this selects the proper function of U_LOAD (i.e. load & execute).
EDIT: also note that constructs like "lda #<some_address" are forbidden in a relocatable binary file. Example:
ldx #$02
fn lda namep-1,x
sta FILE_P-1,x
dex
bne fn
stx FLAG
jsr U_LOAD
namep .word name
name .byte 'FOOBAR.COM',$9b
Edited by drac030
Hi drac030, I put zero (was 1 with my previous code) and now it works !
I should have try it before posting...sorry.
Thank you for your lightning fast answer !!!
BTW, porgramming for SpartaDOs is a real pleasure.
Using SpartaDos is just a new experience on the Atari.
Many thanks to all SpartaDos contributors and keep up the good work.
Bye.
