Any interest in a Colecovision arcade controller PCB for DIY builds?
grips03
Can you put me down for 4 pcbs please.
updated
Batch 1 - ordered on 1/4/2014
2 frank_c
1 adamchevy
Batch 2 - will ship (3) weeks after batch 1 arrives and is tested
2 chart45
1 Hyperboy
1 SiLic0ne t0aD85
2 evg2000
1 hardhat
Batch 3 -
2 colecovisionfanforever
4 Electric Adventures
grips03 Colecovision Arcade Controller PCB wiring directions
Joystick and left button
lower right side JST-XH connector (from the bottom and working up)
Up - wire this to up
Down - wire this to down
Left - wire this to left
Right - wire this to right
A - wire this to left button, or A/1
GND - wire GND to the other side of the above switches. Use daisy chain type wire.
No Connection (NC) - do not wire
Right and other buttons
upper right side JST-XH connector (from the bottom and working up)
B - wire this to right button, B/2
C - wire this to button C/3
D - wire this to button D/4
KP1- wire this only if you want another Keypad 1 button, I wire this to select on NeoGeo controller
KP* - wire this only is you wan another Keypad * button, I wire this to start on NeoGeo controller
Common - wire this common to the other side of the above buttons. Use daisy chain type wire.
No Connection - do not wire
Colecovision DB9 cable
Top Connector with 9 pins wires to Colecovision cable
Color code is for Coleco brand cable from SAC or standard controller. On Rev2 boards I added color code for Retro-bit as well
pin 1 to 1, 2 to 2, etc.
Pin 7 and Pin 9 are not used, I solder them anyway - just to keep wire in place
Coleco color code:
1 = Brown
2 = Red
3= Orange
4=Yellow
5=Green - common
6=Blue
7= NC
8= Gray- GND
9= NC
RetroBit Color code:
1 = Brown
2 = Orange
3=Gray
4=Black
5=Red - common
6=Yellow
7=Blue - NC
8=White - GND
9=Green - NC
Keypad (KP-12)
bottom of board connectors connect to a common ground type keypad, please note keypad uses common signal wire, not the GND wire.
left JST-XH right JST-XH
3 6 9 # 2 5 8 0 1 4 7 * NC COM
NC = no connection
COM = Common
Mounting Holes on right are 2.75 inches center to center, from left to right 1.625 inches
PCB is 1.79 inches wide and 2.9 inches tall
Parts to order as the do not come with the bare PCB:
(34) 1N4148 small signal diodes, Digikey.com p/n = 1N4148FS-ND qty 50 is $2.56
KP-12 keypad - $4.95 at the site below
http://www.allelectr...N-KEYPAD/1.html
DB9 cable - Retro-Bit Sega Genesis extension cable works well, ~$10 on eBay
wiring, can use JST-XH 6S cables (qty 4) - these are 7 pin. 2 for keypad, 1 for direction, 1 for additional buttons
If you go this route then buy qty (4) 455-2240-ND from Digikey.com - qty 4 is $1.72
I like Alpha wire 26awg from Mouser.com 602-3049-100-01 / 3049 WH005
Quick Connects (QC)
crimp tool is needed, such as Hozan P-706 Open Barrel Crimper - Amazon sells
order QC connectors from focusattack.com
order min 12 .110 - these are 1 time use (buttons)
order min 8 .187 - these are 1 time use (joystick)
Sanwa QC covers, order qty 12 .110 and qty .187 - these are reusable
cut wire to length, solder wire, crimp QC to wire, solder QC to wire, install hard cover (Sanwa brand)
Edited by grips03
updated
Batch 1
2 frank_c - shipped
1 adamchevy - shipping soon
Batch 2 - ordered
2 chart45
1 Hyperboy
2 evg2000
1 hardhat
Batch 3 -
Please only order if you know electronics (diodes, switches, wiring, pinouts, etc.) and how to solder, etc. As this is a bare DIY PCB.
Edited by grips03
Batch 1
2 frank_c - arrived
1 adamchevy - arrived
Batch 2 - ordered
2 chart45 - shipped 1/31/2014
1 Hyperboy - shipping 2/1/2014
2 evg2000 - shipped 1/31/2014
1 hardhat - shipping 2/1/2014
Batch 3 - ordered 1/31/2014
4 skosh
2 - still for sale
prices:
$23 for first pcb shipped in US, 2nd pcb is $20, 3+ pcbs are $18 each
Add $4 to above for shipping to Canada
$4 if you want diodes pre-installed per pcb
$7 for keypad + $2 extra shipping for US and $4 for Canada
Edited by grips03
Batch 1
2 frank_c - arrived
Batch 2 - ordered
1 Hyperboy - shipped 2/1/2014
1 hardhat - shipped 2/1/2014
4 skosh
2 - still for sale
prices:
  • 2 weeks later...
PMs sent. I will be shipping Batch 3 on 2/15 or 2/17
Batch 3
4 skosh
2 - chart45 - waiting for NTT Data mini PCB
prices:
Batch 3
2 colecovisionfanforever - shipped 2/18/2014
4 Electric Adventures - paid, waiting on keypads
4 skosh - shipped 2/18/2014
2 - chart45 - shipped 2/18/2014
Batch 4 - 3 pcbs have been ordered 2/17/2014, let me know if you want one.
Edited by grips03
