In-place Ultimate 1MB / Incognito ROM editor and flash tool
Ultimate 1MB Incognito
311 replies to this topic
#26 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:01 PM
yes..
-1.loads from SIDE II - empty screen
-2.q-meg - not load
-3.loads from apt - cursor without range..
-4.loads WITHOUT u1mb from APT - that same
maybe STOCK OS required? :) - i reflashed it with Q-MEG 5 :D
Edited by w1k, Thu Jan 16, 2014 3:01 PM.
#27 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:02 PM
Yeah... please use the Stock OS. This is hardly the time for riddles...
#28 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:08 PM
ee..
something wrong..
i disconecct SIDE II (hw SIDE II) and loads uflash via SIO2PC with that same config and reflash back STOCK OS.. now o trying loads uflash.xex from APT - and again cursor out of range..
#29 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:11 PM
Why is so chaotic? :D
  • w1k likes this
#30 rdea6 ONLINE
rdea6
  • 2,804 posts
Incognito loads a pretty blue screen with a white square box with the Menu title .... but nothing else...OK cancel this... using the stock xl os it is loading the screen program properly..
Edited by rdea6, Thu Jan 16, 2014 3:13 PM.
#31 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:14 PM
Can't edit posts, so, addendum:
USE STOCK OS...
#32 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:19 PM
yes yes..i have STOCK OS..
that same problem
#33 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:22 PM
that same problem
Are you absolutely sure it's the stock XL/XE OS? Something's badly screwed up if the program won't even launch, I'm afraid.
#34 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:24 PM
100%.. trying boot with everything disabled - normaly start BASIC, then switch HI-SPEED - hi-speed sounds and BASIC..
hmmm, i have good load via SIO2PC, Q-MEG 4.4 ..(SDX ENABLED, 1MB, SIDE DISABLED)
i tryed use first release of this tool - that same problem now..strange..empty screen
hmm..maybe its conflict with SIDE II.. uflash works with sio2pc (with disconnected side)
Edited by w1k, Thu Jan 16, 2014 3:35 PM.
#35 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:33 PM
I'm using this configuration on a 1200XL as we speak:
SIO2PC on D2: (uFlash loads fine from there), and APT partition on D3: (uFlash loads fine from there). Tried running some other applications first to test for undefined memory, etc; no problems.
SDX is booting with no CONFIG.SYS here, so I don't know whether you have some other conflicting stuff installed. Try a clean SDX boot.
#36 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:37 PM
SIO2PC on D1:, APT on D3 - load fail from d1, d3..
on config.sys flashed on SIDE II i add only this:
DEVICE C:>SDOS>RC_GR8.SYS
SET SC=C:>SDOS>SCMAIN.OVL
SET PROMPT=$L$P\
Edited by w1k, Thu Jan 16, 2014 3:39 PM.
#37 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:40 PM
on config.sys flashed on u1mb i add only this:
SET PROMPT=$L$P\
That's not a "clean" boot, now, is it? Immediately I would suggest removing RC_GR8.SYS. UI in uFlash still supports this, and tries to switch to 80 column mode when the driver is present. However, there'll be a memory conflict since we're leaving the cartridge enabled. I'll remove all 80 column support from this application.
So - get rid of DEVICE C:>SDOS>RC_GR8.SYS, and I think your problems will be over.
EDIT: Here's a fixed version which ignores RC_GR8 and S_VBXE:
Attached File  uflash.xex   15.95KB   133 downloads
Edited by flashjazzcat, Thu Jan 16, 2014 3:46 PM.
#38 w1k OFFLINE
w1k
  • 1,669 posts
Posted Thu Jan 16, 2014 3:51 PM
now its works.
i loads uflash via side loader..and works.. i cant edit my SIDE config.sys, because i use sparta commander, etc..
Edited by w1k, Thu Jan 16, 2014 3:52 PM.
#39 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 3:53 PM
Good - glad we finally got to the root cause. My mistake for not removing the 80 column code... I should have guessed some people would have the driver installed. Thanks for your test results. ;)
  • w1k likes this
#40 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Thu Jan 16, 2014 4:44 PM
Hi Jon,
  It loads fine on my Incognito.  One thing I have noticed is that when dumping the Colleen OS ROMs, I get $800 bytes of $20 at the beginning of the file, and a total size of $3000.  If I look at a proper 800 type .ROM file, it is $2800 in length, and does not have all those $20s at the start of the file.  There is one $20 at the start, but that one belongs there.
  XL/XE ROMs seem to dump ok.
Hope this helps you in debugging.
-K
#41 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 4:52 PM
Thanks Kyle. That'll be correct about the 800 OS ROM dumps. I forgot to strip the 2K padding off them. I'll just adjust the offsets to suit; I'm glad you spotted that.
Of course, in the meantime, a dumped 12KB padded 800 OS will flash back to the same slot nicely. Nevertheless, I'll get this fixed. I also want to provide support for PBI ROMs without the 6KB or 2KB padding (for Ultimate and Incognito respectively); there's really no need for the padding to be in the distributed ROM, but that's the way they've typically been issued until now, and that's what The ROM Generator works with.
Anyway: I'll fix these issues shortly. Thanks again!
#42 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
Posted Thu Jan 16, 2014 5:03 PM
What happens if I try to flash a proper OS ROM file (without padding)?  Also, may I flash only one slot without fear of erasing the others?  Example, suppose I only wanted to change the BASIC image, may I load and flash just that one?
#43 greblus OFFLINE
greblus
    Moonsweeper
  • 270 posts
Posted Thu Jan 16, 2014 5:53 PM
Hi.
I've just updated my pbi rom by running uflasher from sdx and every time i tried the file selector was showing some garbage in the file list (hearts in most cases). Changing drive from D1: to some other and then back to D1: returned file list to normal and after selecting rom file flashing went fine.
Thank you for a great tool!
#44 AtariGeezer ONLINE
AtariGeezer
  • 2,890 posts
Posted Thu Jan 16, 2014 5:58 PM
Think I'll change The ROM Generator so that the 800/Colleen OS Slots only saves the proper 10k block so that the 2k padding and 1/4th (4k) SIDE/Fat32 Loader is stripped out of it.  This should avoid some confusion...
#45 rdea6 ONLINE
rdea6
  • 2,804 posts
Posted Thu Jan 16, 2014 6:58 PM
Just a quick query will modified os roms like the ones with Hias hisio every be able to run the UFLASH.XEX file..  I had to drop back to using QMEG4.4 to correct a blunder I did testing this file..
#46 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 7:01 PM
The OS will be misaligned by 2K. Best wait until I fix it up.
Absolutely - this was the primary aim of uFlash: to be able to change the contents of any slot without disturbing the others, even when using 64KB sector flash ROMs (although only earlier Ultimates have those). One of the reasons I never changed the contents of any of the BASIC or OS slots until I developed this tool was that I couldn't be bothered with the rigmarole of preparing and then laboriously flashing (either via SIO, or by pulling the PLCC out and putting it into the programmer) the entire 512KB.
Many thanks! As mentioned, the file selector (which I originally developed for a stalled SDX text editor project) is somewhat unfinished and not very robust. However, once the the flashing function is proven 100 per cent reliable, it'll be pleasant work to tidy up some of the other aspects of the program. Certainly at the moment, the file selector produces a list of hearts when it fails to open the target drive, when of course it should pop up an error message. Thanks for pointing this out, though. ;)
Yeah that would make sense. It's a shame that these "special cases" exist (i.e. the PBI BIOS, Incognito SIDE loader and Colleen OS ROM slots), since everything else can be neatly described in terms of 4KB banks. In particular, the Incognito's SIDE loader is interleaved with the Colleen OS slots, which necessitated a special "sector list", rather than calculated linear sectors. But at least that lines up on sector boundaries.
Since the Colleen OS slots and unpadded PBI BIOSes (the latter for both Ultimate and Incognito) require further offsets which don't line up on sector boundaries, I'll either write special code which intervenes and adds padding during the load process, or create a further byte-aligned offset table for the actual load offset. This will allow for unpadded PBI BIOSes (which currently come in at only 6KB) and Colleen OS ROMs. The padded PBI BIOSes are 32KB, so I think this is a change worth making. The padding was really only needed when we had only simplistic, bank-bound flashing tools.
An additional question of compatibility which I raised earlier is whether the main BIOS and SIDE loader for each interface should be delivered as a single 32KB package, or as two discreet 16KB files. Right now, uFlash expects the Ultimate BIOS and SIDE loader in a single contiguous 32KB chunk, which makes sense because they are contiguous in the ROM. Conversely, the Incognito SIDE loader (as mentioned previously) is interleaved with the Colleen OS ROMs, and uFlash expects the Incognito BIOS and SIDE loader as two separate 16KB files. It's very easy to choose one scheme and apply it to both interfaces. I suppose it depends on how things tend to be delivered. I would imagine SIDE loader changes would happen more frequently than BIOS changes, but it might be best to simply consult with Candle on whether BIOS and SIDE loader should be considered a single entity.
I'm sure uFlash works fine with the High-Speed OS, but I can certainly test again to be sure. The application makes no undocumented calls to the OS, of course. I know little to nothing about Q-Meg, meanwhile; I'd rather stipulate the use of a stock OS if there are major incompatibilities, but then again I can't see why there would be any.
Edited by flashjazzcat, Thu Jan 16, 2014 7:08 PM.
#47 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
Posted Thu Jan 16, 2014 7:23 PM
I'll be eagerly waiting :)
This is absolutely awesome!  Thanks for this incredible tool!
#48 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 7:29 PM
Of course I was wrong when I said the unpadded Colleen OS would be misaligned by 2K. What'll actually happen (because of sanity checks) is that the application would tell you that the ROM image was short and abort the flash. ;)
#49 Kyle22 OFFLINE
Kyle22
  • 3,899 posts
Posted Thu Jan 16, 2014 7:36 PM
Sanity checks are a good safeguard against insane users :)
One other thing, could the default drive in the flasher be set to the default SDX drive?  It always starts on D2: now, even if I load it from C:\ROMUTIL.  Once I change to D3: in the drop down list, it shows D3:\ROMUTIL> at the top of the file selector box.  This is a VERY minor detail.
-K
#50 flashjazzcat ONLINE
flashjazzcat
  • 14,439 posts
Posted Thu Jan 16, 2014 7:45 PM
And developers: I'd have already bricked one of my boards were it not for the magic byte and file size checks. ;) Speaking of which: I'll add code to ensure image files aren't too long as well.
Not so minor. The default is D2: only because that's the drive I used for testing. As I said, I'll set it to the SDX current drive in the next update. ;)
Also tagged with one or more of these keywords: Ultimate 1MB, Incognito
