Are the PCF 554 Disk Drives Compatible?
PCF 554 disk drive compatibility
7 replies to this topic
#1 fadix OFFLINE
fadix
    Space Invader
  • 48 posts
Posted Sun Feb 2, 2014 3:11 PM
The question is in the title. Are PCF 554 drives compatible with 8-bit Atari systems? What I've read so far points to the drive being only compatible with the PC line, but I can't find a definitive answer.
#2 Mathy OFFLINE
Mathy
  • 2,894 posts
Posted Sun Feb 2, 2014 4:29 PM
Hello fadix
I googled "Atari PCF554" and found, among other things, this picture:
I guess that means it not compatible. Remember, the PCF554 is a PC drive which connects to a PC. The XF551 is a PC drive which connects to an Atari 8 bit computer. The latter needs hardware to translate signals from the drive to the computer and vice versa, the first doesn't.
Sincerely
Mathy
#3 BillC OFFLINE
BillC
  • 1,905 posts
Posted Sun Feb 2, 2014 4:51 PM
I don't have any knowledge about the PCF554 drive, but it's likely that in addition to the different interface board that it also uses a 720KB drive mechanism.
#4 Larry OFFLINE
Larry
  • 4,091 posts
Posted Sun Feb 2, 2014 5:15 PM
No.  This was supposedly almost compatible with the ST (68000 cpu) line.  You had to do a minor mod to use them.  Might pose this question in the ST forum and you might get more info.
Notice the round-type drive connectors (yes, hard to see, but not nearly wide enough to be SIO connectors).
-Larry
#5 Mathy OFFLINE
Mathy
  • 2,894 posts
Posted Sun Feb 2, 2014 6:12 PM
Hello guys
After finding out that "atari PCF 554" gives different results then "atari PCF554", I found the page with the pictures again:
Sincerely
Mathy
PS http://www.amibay.co...read.php?t=8758
#6 Fletch OFFLINE
Fletch
  • 1,062 posts
Posted Sun Feb 2, 2014 7:50 PM
I believe this was made for the Atari PC-1.  An MS-DOS clone made by Atari.  Looked like the Mega ST.
http://www.tietokone...eita/atari-pc1/
Edited by Fletch, Sun Feb 2, 2014 7:51 PM.
#7 charliecron OFFLINE
charliecron
    Moonsweeper
  • 413 posts
Posted Sun Feb 2, 2014 8:01 PM
Pretty sure you could use standard external ST floppy drives on the PC-1 as well...
#8 fadix OFFLINE
fadix
    Space Invader
  • 48 posts
Posted Mon Feb 3, 2014 7:20 AM
Thank you everyone who responded. Definitely not compatible with 8-bit Ataris.
Also tagged with one or more of these keywords: PCF 554, disk drive, compatibility
