Horizon RAMdisk ROS and CFG
ROS CFG RAMDISK
207 replies to this topic
#51 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Sun Jul 26, 2015 5:36 AM
P-Code 4.0:   (>1F00)
Attached File  061-PCode-RS.jpg   103.37KB   5 downloadsAttached File  062-PCode-RS.jpg   138.36KB   5 downloads
#52 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Sun Jul 26, 2015 5:37 AM
...ready... hope it helps a bit :)
#53 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Sun Jul 26, 2015 5:42 PM
P-Code 4.0:   (>1F00)
Very nice posts!
I didn't know you could activate a PCODE card and not run the PCODE software ;)
For the Foundation card, I seem to recall it responds to "DSKX." .  Is that correct?
I believe Fred's Disk Utility program show the DSR headers for the cards in the system.
What I need is a unique Device name or unique subprogram that can be used to identify each card.  If a DSR is not loaded, it will not be identified.   I might consider adding some code to test for CRU responses and memory paging, but that is currently beyond the scope of this release.   So, if you have screenshot of the DSR for these cards I can take a look.  Or if you have an EPROM dump I can look at it directly.  Many options ;)
#54 Gazoo OFFLINE
Gazoo
  • 1,507 posts
Posted Sun Jul 26, 2015 6:24 PM
Very nice posts!
The Foundation card will be difficult to identify. It was originally sold without an eprom. There was also a hacked eprom that made it work as a Myarc 128k card so it could run Myarc Extended Basic 2. It might be best to leave that one alone and let it be reported as undefinable.
Gazoo
#55 Gazoo OFFLINE
Gazoo
  • 1,507 posts
Posted Sun Jul 26, 2015 6:29 PM
The Corcomp Ramdisk responds as 'DSKR.'. I think there's also a CALL to bring up the resident disk manager, but I don't recall what it is. It would probably be better to identify it by the CALL since 'DSKR.' can also be a valid device for a Horizon Ramdisk.
Gazoo
#56 Ksarul OFFLINE
Ksarul
  • 5,028 posts
Posted Sun Jul 26, 2015 6:52 PM
The earliest Foundation cards were actually a 32K card--that worked just like the TI card. Then came the DSR-free 128K card, with a DSR that came out very soon thereafter (initially as an upgrade, but later it was standard). Last came the hack to make it run the Myarc 128K OS (and their XB 2.11). The hack also included instructions to upgrade the card to 512K (I think I have one that has all of this done to it--but I also have a standard 32K and a 128K (with DSR) version of the card).
#57 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Sun Jul 26, 2015 7:35 PM
Gazoo
Agreed.  A unique subprogram is preferred ;)   I could probably do a secondary test for a RAMdisk ROS subprogram to rule out ROS at a detected "DSKR" or "DSKX" device; however, if there is no DSR then the only other method would be to twiddle the CRU bits and look for memory banking in defined areas.  If schmitzi can provide the dsr info, we can get one step closer for these cards.
#58 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 1:15 AM
yes, I will try to bring up the DSRs tonight.
#59 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 9:55 AM
Very nice posts!
thanks.
With the P-CODE-4.0 (CRU >1F00) that was an easy idea. Just set the switch to OFF, start the PEB, and the TI to the startscreen.
Then switch the P-CODE to ON, and boot the wanted tool from disk, or whatever  :)
The card is available there, showing her address (but no DSR, as there seems to be none)
Maybe this is a way for testing the P-CODE with a diag-tool ? (Is there any Diag-Tool for the P-CODE ?)
Attached File  063-PCode-RS.jpg   87.77KB   2 downloadsAttached File  062-PCode-RS.jpg   138.36KB   2 downloadsAttached File  064-PCode-RS.jpg   95.58KB   2 downloads
#60 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 10:12 AM
Cool, thanks Gazoo.  I've never looked at the documentation because I do not own one... YET... but it's on my list of future acquisitions!
Hi,
which RamDisk do you have ? Here some jumpers from my manuals:
HRD2000:
Attached File  HRD2000-DIP-CRU.JPG   58.31KB   6 downloads
HRD3000:
Attached File  HRD3000-DIP-CRU.JPG   37.14KB   3 downloadsAttached File  HRD3000-RMS-DIP-CRU.JPG   34.75KB   3 downloads
HRD4000:
Attached File  HRD4000-DIP-CRU.JPG   38.75KB   3 downloads
#61 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 10:23 AM
OkeyDokey.
I have rechecked all cards - and pulled my TripleTech in addition - once more with Fred Kaal´s great DU2K Disk Utility Tool.
Here are the results:
MECHATRONIK 128K:   NO CRU, NO DSR:
Attached File  001-Mechatronik-128K.jpg   158.52KB   3 downloadsAttached File  005-Mechatronik-128K.jpg   114.26KB   2 downloadsAttached File  006-Mechatronik-128K.jpg   112.05KB   2 downloads
#62 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 10:25 AM
CORCOMP MEMORY PLUS (512K):  CRU >1000
Attached File  011-CorComp-RAMplus-512K.jpg   118.94KB   2 downloadsAttached File  015-CorComp-RAMplus-512K.jpg   96.91KB   4 downloadsAttached File  017-CorComp-RAMplus-512K.jpg   130.3KB   2 downloads
#63 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 10:28 AM
FOUNDATION 128K:  CRU >1E00
Attached File  031-Foundation-128K.jpg   72.24KB   3 downloadsAttached File  035-Foundation-128K.jpg   121.36KB   3 downloads
#64 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
MYARC 512K: CRUs  >1000  &  >1900
Attached File  041-Myarc-512K.jpg   96.36KB   3 downloadsAttached File  044-Myarc-512K.jpg   119.15KB   4 downloads
#65 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
GRAM-1.1:  CRU >1700
Attached File  021-GRAM1.1.jpg   170.33KB   3 downloadsAttached File  024-GRAM1.1.jpg   91.43KB   2 downloadsAttached File  025-GRAM1.1.jpg   119.54KB   2 downloads
#66 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
CORCOMP TRIPLETECH:  CRU >1D00
Attached File  071-CC-TripleTech-RS.jpg   169.96KB   2 downloadsAttached File  072-CC-TripleTech-RS.jpg   149.3KB   2 downloadsAttached File  073-CC-TripleTech-RS.jpg   112.13KB   2 downloads
#67 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Mon Jul 27, 2015 10:29 AM
thats all ;) have fun
...and many thanks to Fred !!!!
http://www.ti99-geek.nl/
Attached File  EA5-DSK1.DU2K.jpg   108.87KB   6 downloadsAttached File  SuperTool-Press1here.jpg   96.61KB   4 downloadsAttached File  Press-3-forDSRs.jpg   102.84KB   3 downloads
#68 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Mon Jul 27, 2015 12:38 PM
From this it looks like we could do the following:
1. CorComp I think we can use RAMGR and/or LOWER to detect.   (As a side note, the HFDC and SCSI use >2x routines, so this card may not play nicely with either of those two cards).
2.  Foundation 128K card :  MEMINIT or MEM96 plus CRU 0x1E00
3.  GRAM 1.1:  EDITMEM?
4.  Triple Tech: already detected via CLOCK.
5.  SAMS / AMS / Mechatronix 128,  other non-DSR memory cards:  requires a different method.
Gazoo - is EDITMEM also found on a PGRAM?  Any other similar calls you see that would cause problems?
I will make some changes and return with an updated version.
#69 Gazoo OFFLINE
Gazoo
  • 1,507 posts
Posted Mon Jul 27, 2015 4:06 PM
EDITMEM is not in the Pgram DSR. CLOCK is though. You may want to have the Pgram identifiable by CALL PG and leave CLOCK for the Triple Tech.
RAMGR would probably be the best bet for the Corcomp ramdisk.
Gazoo
#70 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Mon Jul 27, 2015 5:43 PM
Gazoo
Good point.  The way CFG works is it looks for unique items first, so that duplicates can be weeded out.  I'll verify clock comes after the PGRAM :)
#71 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Mon Jul 27, 2015 7:15 PM
Done ;)
Added the GRAM 1.1, Foundation card, and CorComp card to the detection routine.  I will give it a test or two before posting.  There are a few other cards I want to play with before I wrap this up.
#72 atrax27407 ONLINE
atrax27407
  • 1,178 posts
Posted Mon Jul 27, 2015 7:52 PM
Do you need a copy of the QUEST 5.12K RAMdisk DSR?
#73 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,318 posts
Posted Mon Jul 27, 2015 8:08 PM
My SAMS is packed away so I cannot test on the real hardware.  ;)
Attached File  cfg832b ams.PNG   3.87KB   4 downloads
#74 Schmitzi ONLINE
Schmitzi
  • 4,424 posts
  • ToXiC
Posted Tue Jul 28, 2015 1:45 AM
Do you have the standard CRU, for my list ? Is is changable ?
(Do you have a manual ?)
#75 atrax27407 ONLINE
atrax27407
  • 1,178 posts
Posted Tue Jul 28, 2015 6:07 AM
My SAMS isn't packed away and I'll test it for you.
Also tagged with one or more of these keywords: ROS, CFG, RAMDISK
