Strips, Reference Cards, Manuals, Labels and more! (HQ)
.pdf Strips Cards Books Labels 3D Print Files
271 replies to this topic
#251 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Thu Jan 17, 2019 6:37 PM
Here are a few more keyboard strips. I try to make sure I get one of each strip in the beige and white backgrounds, as that way they will work with pretty much any unmodified console.
#252 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Fri Jan 18, 2019 1:31 AM
Interesting that they translated OOPS! with NEIN! in German. It is certainly difficult to find a matching expression; the usual "Huch" would be more a surprise about the situation, maybe even in a positive sense. A better choice would be "oh nein!" - or the ubiquitous "Sch..." word. But you would not print it on a strip. :-)
#253 blackbox OFFLINE
blackbox
    Chopper Commander
  • 188 posts
Posted Fri Jan 18, 2019 7:12 AM
While I am working on Programming Aids manuals for
http://atariage.com/...-lost-found/...
Here are a few labels. Most of my disk labels seem to have fallen off, or the glue has etched through the paper (sigh) but here is what I have in reasonably good condition-  as I am not permitted to upload tif files I have zipped them all together into a zip, which is permitted!
Zip contents-
Attached File  softwarelabels.zip   9.87MB   14 downloads
disk labels for:
Events Calendar (Gaskill),  SXB (J&KH), TI Base Vn 2.01 (Inscebot)
NOTUNG:  Disk of Horrors archived disk; Son of the disk of dinosaurs (two labels), disk of the old west(4 disks)
Jim Peterson:  Nuts and Bolts 3, Tips from the Tigercub 2,3, and 4 (3 labelsl)
Cassette labels for:
TI Logo Sampler
Speak and Math
regards
Stephen
#254 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Fri Jan 18, 2019 8:00 AM
I was having fun thinking about the Orange and Blue consoles, and wanted to see what a keyboard strip for them would look like, so I did a quick hack to a TI Writer keystrip to see what would happen. Here are the results. . .
#255 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Sun Jan 20, 2019 6:47 PM
I dug out my original TI Writer keyboard strip in French today and input it into my blank template. Here are the results in beige and white. These keystrips exposed some bugs in my English TI Writer keystrips. Here are the corrected versions of them as well.   :)
Edited by Ksarul, Sun Jan 20, 2019 7:25 PM.
#256 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Wed Jan 23, 2019 7:21 PM
And a few more keyboard strips to play with. . .I included a few more orange and blue ones.
#257 twoodland OFFLINE
twoodland
    Chopper Commander
  • 196 posts
Posted Wed Jan 23, 2019 8:32 PM
AWESOME!!!
#258 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Thu Jan 24, 2019 7:16 PM
Here are some more keyboard strips that I had time to work on at lunch today. . .Ciro, please look at the one in Italian to see if everything makes sense.
You'll see what I mean when you look at how I rearranged the Chess keyboard strip to help make it much easier to use. The English and Italian strips now have identical formats--and I'll do some in German, French, Dutch, Swedish, and Spanish once I get time to play some more with them.
#259 Schmitzi OFFLINE
Schmitzi
  • 4,476 posts
  • ToXiC
Posted Fri Jan 25, 2019 4:00 PM
Ksarul, so you had a very good run, thanks   :thumbsup: :lust:
#260 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Wed Feb 6, 2019 7:04 PM
Here are a few more I had time to play with. . .and do me a favor and sanity check the Schachmeister keystrip if you would, Schmitzi.  :)
#261 arcadeshopper OFFLINE
arcadeshopper
  • 4,178 posts
Posted Fri Feb 8, 2019 5:47 PM
any suggestions for printing these out? I had to do some trial and error to get one close to the right size printing from winders10
#262 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Fri Feb 8, 2019 9:54 PM
I've found that just about every printer out there is just enough different that I have to do some initial experimentation to get the size right. Some of them come out exactly right without modification (Minolta photocopiers), others I have to play with. The important bit is that all of them are scaled exactly the same, so once you find the magic value that works for one of them, it will print them all.
#263 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,623 posts
Posted Fri Feb 8, 2019 11:19 PM
I've found that if you save it as the correct size in a PDF it comes out perfect on any printer. Some times there is a little trial and error involved in making the PDF document, but in the end it's worth it.
#264 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Sat Feb 9, 2019 1:24 PM
That just moves the trial and error to the front end, as the PDF file IS the printer you are adjusting the output to. I give you raw files to use as you see fit--if you want to play with them and figure out the settings to get them to fit perfectly by using a PDF, I say go for it! I'll keep doing what I do in a way that makes my hobby a fun thing for me in any event.  :)  If others find the output to be useful, that's good too, but that output is done to fit my use cases (in this case, creating files that I can convert to vinyl strips to put onto original TI keyboard strips), and my use case requires that I make the files just right for that purpose--the cut lines are the template boundaries I need and the file is adjusted to fit them then.
#265 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,623 posts
Posted Wed Feb 13, 2019 9:02 AM
PART 1 - Editor Assembler
I scanned the "Editor Assembler" manual in last night, but it's too big to load it up as one file here on Atari Age due to the 50 megabyte limit, so it's in three pieces.
The blue covers and pages 001-200 are in this first post.  Pages 201-470 will be in the next post.
(I may get to editing the blue cover pages in the next day or two, but until then, they are not 100%)
#266 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,623 posts
Posted Wed Feb 13, 2019 9:12 AM
Part 2 - Editor Assembler
Pages 201 - 470 of the Editor Assembler manual
#267 Vorticon ONLINE
Vorticon
  • 3,535 posts
Posted Wed Feb 13, 2019 10:54 AM
Schachmeister? Is it a German chess game?
#268 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,623 posts
Posted Wed Feb 13, 2019 11:43 AM
That or music maybe?
#269 Schmitzi OFFLINE
Schmitzi
  • 4,476 posts
  • ToXiC
Posted Wed Feb 13, 2019 12:04 PM
yes, it´s the german "Video Chess" (PHM3008)
The french version is the "Echecs",
and the spanish one is "Ajedrez", (but I never saw that one)
#270 Schmitzi OFFLINE
Schmitzi
  • 4,476 posts
  • ToXiC
Posted Wed Feb 13, 2019 12:14 PM
A quick list ;)
(I don´t know if it´s complete, I never worked on that topic in my list)
Attached File  TI-99-4A-SW-CHESS-v1.00.JPG   264.53KB   0 downloads
#271 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Wed Feb 13, 2019 6:00 PM
The Spanish version of Video Chess (Ajedrez) only has a Spanish manual--the cartridge is the standard English version. I have the Argentine Spanish manual.
#272 Schmitzi OFFLINE
Schmitzi
  • 4,476 posts
  • ToXiC
Posted Thu Feb 14, 2019 1:57 PM
Saved :)
Also tagged with one or more of these keywords: .pdf, Strips, Cards, Books, Labels, 3D Print Files
