Do you use a "Homebrew Joystick"? - Post your pics!
263 replies to this topic
#251 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Tue Mar 20, 2018 9:31 AM
<< THIS LINK >> Has some great joystick case ideas for you guys who've not yet built one.  One example I found really cool was the transparent case.
Anyway check it out... it just might inspire you to build one... or another!  :grin:
#252 SIO2 OFFLINE
SIO2
  • 1,155 posts
Posted Fri Jan 11, 2019 10:16 PM
Has a 4 way gate so now I finally have a propper Pac-Man stick. :)
#253 Kosmic Stardust OFFLINE
Kosmic Stardust
    Cyborg Bounty Hunter
  • 18,430 posts
  • It's a secret to everyone...
Posted Sat Jan 12, 2019 4:51 AM
I can kinda vouch for this method:
Sanding and finishing can be a bit labor intensive however. :thumbsup:
#254 Kosmic Stardust OFFLINE
Kosmic Stardust
  • 18,430 posts
Posted Sat Jan 12, 2019 5:03 AM
Congrats. Having a proper baffle for 4-way games such as Pacman is essential. Got a few too many extra buttons on that thing however! :lol:
These are really great sticks if you need something you can convert easily in less than one minute with a Phillips head screwdriver.
https://paradisearca...ck-top-joystick
Cost far less than a Sanwa (Sanwas also feel a bit loose need tuning out of the box imo, which adds to the cost) and while they have similar appearance to the Zippy sticks, they are much better IMO. The switches are heavy enough that it gives you tactile feedback as you slide into the corners, pretty much goes where you want it and don't get as many unintended diagonals in 8-way mode. It's the only Japanese style square gate stick I can really game comfortably on.
Happ/IL are also good for 8-ways if you want bats and round baffles. Better use a heavier box though as they are stiffer and extend further under the control panel.
#255 jdgabbard OFFLINE
jdgabbard
    Moonsweeper
  • 291 posts
Posted Sat Jan 12, 2019 12:56 PM
Here is one I did. Its a modified NES controller for use on a PC. Digital to Analog board consists of a few transistors and resistors. Wiring was done with a Ethernet cable (stranded, not solid core). It supports Analog 1&2, and 4 Buttons (Select=4 Start=3 B=1 A=2). Im looking at converting a SNES controller as well (can use analog 3&4 for use as HAT buttons) with a second converter board, but I cant seem to find any 10 wire cable that is small enough to fit the SNES hole. If anyone has a suggestion on cable selection, Id love to hear it.
Edited by jdgabbard, Sat Jan 12, 2019 12:57 PM.
#256 Jess Ragan OFFLINE
Jess Ragan
    Phanto of the Opera
  • 10,236 posts
  • Keys and Thank You
Posted Sat Jan 19, 2019 10:01 PM
A little late to mention this, but that joystick I bought from Groovy Game Gear has two settings for the restrictor gate. Loosen the screws underneath, then turn the gate and tighten them back up, and it becomes a quite competent fighting game stick. Apparently it must have had 4-way and 8-way settings, and I didn't even realize it.
I haven't done much with the homemade stick since I, uh, home made it, but maybe over the summer I'll dive back into it, or transfer the buttons to a better box. The underside of the housing was shredded by my power tools and is rather uneven... I should put a thin piece of wood inside to reinforce it. Maybe that'll dampen the clunking it makes when buttons are pressed too.
#257 Kosmic Stardust OFFLINE
Kosmic Stardust
  • 18,430 posts
Posted Sun Jan 20, 2019 6:10 AM
(1) A little late to mention this, but that joystick I bought from Groovy Game Gear has two settings for the restrictor gate. Loosen the screws underneath, then turn the gate and tighten them back up, and it becomes a quite competent fighting game stick. Apparently it must have had 4-way and 8-way settings, and I didn't even realize it.
(2) I haven't done much with the homemade stick since I, uh, home made it, but maybe over the summer I'll dive back into it, or transfer the buttons to a better box. The underside of the housing was shredded by my power tools and is rather uneven... I should put a thin piece of wood inside to reinforce it. Maybe that'll dampen the clunking it makes when buttons are pressed too.
1 - I've stopped using the Zippy sticks myself as they sometimes have QC issues with the restrictor gates and has swapped suppliers for the micro switches on multiple occasions. The levered switches from certain brands have a deeper throw to actuate the microswitch with the result that the lever is pitched rather than straight at the point of actuation. This can result in missed diagonals occasionally. For instance, moving from D to DL might actuate a down/left diagonal but moving from L to DL results in a miss for the D direction, because the tab may need to travel slightly beyond the square gate on one side before it actuates.
The Paradise Arcade stick has a similar design to the restrictor plates compared to Zippys but you won't feel "bumps" on the edge of the square gate like the Zippy, and the restrictor plate is a superior plastic construction that won't curl upwards when over-tightened. Also the PAS switches don't have levered tabs on them as the round actuator presses the tab directly.
2 - Anytime you drill into wood with a spade bit, you gotta place a board underneath the control panel to prevent blowout. Especially true for ready made wood boxes with thin lids. Clamp a 3/4" piece of scrap underneath the lid before drilling. You may have to cut the scrap to fit under the lid. The same scrap can be used multiple times as well. As always, measure twice and cut once.
It is possible to cut cleaner holes without need for a backing piece by using a Forstner bit, however these bits are designed for use in drill presses and may drift if used with a handheld drill.
#258 Iwantgames:) ONLINE
Iwantgames:)
  • 2,471 posts
Posted Thu Jan 24, 2019 8:00 PM
Not finished yet (needs paint and wiring) but here's my new computer controller :) I'm wiring it up for my MSX which uses the same plug as Atari, TI, ect. So with adapters it can be used with most of my computer's :)
#259 Iwantgames:) ONLINE
Iwantgames:)
  • 2,471 posts
Posted Sat Jan 26, 2019 6:34 AM
Finished :D
#260 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Wed Feb 13, 2019 3:43 PM
Where did you find that joystick case?
#261 Kosmic Stardust OFFLINE
Kosmic Stardust
  • 18,430 posts
Posted Thu Feb 14, 2019 4:31 AM
I think he drilled directly into a desk top.
#262 Shift838 OFFLINE
Shift838
  • 2,566 posts
  • SHIFT838
Posted Thu Feb 14, 2019 8:09 AM
I was referring to the picture here
#263 Kosmic Stardust OFFLINE
Kosmic Stardust
  • 18,430 posts
Posted Thu Feb 14, 2019 12:25 PM
oh my bad. I thought you meant this one.
#264 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,924 posts
Posted Sun Feb 17, 2019 9:15 PM
That's kind of neat!  I suppose you can also wrap the cord up inside when it's not in use!
