MESS 0.153…The next generation of Atari 7800 emulation
Mess emulation emulator roms games download best
152 replies to this topic
#51 ColecoGemini OFFLINE
ColecoGemini
    Chopper Commander
  • 108 posts
Posted Thu Apr 17, 2014 9:00 AM
Since when did they take away the option of using a custom video size/resolution when running in windowed mode? I can now only choose full screen or tiny 320x240 postage stamp size? Weak Sauce.
#52 Trebor OFFLINE
Trebor
  • 4,731 posts
Posted Thu Apr 17, 2014 9:35 AM
I can confirm Window re-sizing works perfectly on both Windows 7 32-bit Professional and 64-bit Home Premium with and without hlsl turned on.
I just grab the corner of the window and make it as big, or as small, as desired while it also maintains proper aspect ratio.
Did you try a clean install/folder?
EDIT:  Also, you can specify what display and specific resolution you would like to start with (Can be re-sized bigger or smaller still 'on the fly') here inside the mess.ini file:
# PER-WINDOW VIDEO OPTIONS
screen                    \\.\DISPLAY2
aspect                    auto
resolution                960x720
In the above, it will send the image to the second display using the aspect ratio dictated by the driver/system (4:3) and a custom resolution of 960x720.
Works perfect on both of the aforementioned OS's, and as a side note, one graphics card is a 'Intel on a chip' (Win 7 Pro 32bit) the other is a Radeon 5670 HD (Win 7 Home Prem. 64bit).
#53 gambler172 ONLINE
gambler172
  • 3,367 posts
  • none
Posted Thu Apr 17, 2014 10:28 PM
Hi Guys
i was asked,if there is anybody,who owns a MAC and who could explain,how to get run the 7800?
Can you use A78 files?
And whatelse do you need to get the 7800 work on MESS?
Cause i do not own a Mac,i could not help.
Would be great,if someone could give a detailed description,also with the link,where to get the needed files
greetings Walter
#54 NIKON OFFLINE
NIKON
  • 1,903 posts
Posted Thu Apr 17, 2014 10:50 PM
I do not know if it will help but here is a site that could explain it for you
http://sdlmame.lngn.net/
#55 Trebor OFFLINE
Trebor
  • 4,731 posts
Posted Fri Apr 18, 2014 5:47 AM
:thumbsup:
The forum here too may help: http://forums.bannis...&Board=8&page=1
#56 gambler172 ONLINE
gambler172
  • 3,367 posts
  • none
Posted Fri Apr 18, 2014 1:12 PM
Hi Guys
or do other 7800 Emulators exist for the MAC?
greetings Walter
#57 gambler172 ONLINE
gambler172
  • 3,367 posts
  • none
Posted Fri Apr 18, 2014 1:14 PM
Hi Guys
a simple step by step guide,how to load 7800 games on the MAC would be great......
Then i could send it to some friends,who asked..................
greetings Walter
#58 ColecoGemini OFFLINE
ColecoGemini
    Chopper Commander
  • 108 posts
Posted Fri Apr 18, 2014 1:30 PM
Hi Guys
greetings Walter
Step 1: buy a PC. :grin:
#59 gambler172 ONLINE
gambler172
  • 3,367 posts
  • none
Posted Fri Apr 18, 2014 1:33 PM
Ha ha ha
i own a PC
some friends use a MAC :)
#60 ColecoGemini OFFLINE
ColecoGemini
    Chopper Commander
  • 108 posts
screen                    \\.\DISPLAY2
aspect                    auto
resolution                960x720
Ah, well duh...I was looking in the options for the device, and in versions way back you could choose present standard resolutions, or a custom setting where you set one you want. Didn't think of just stretching the window. I think that didn't work in some older versions.
#61 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Sat Apr 19, 2014 12:12 AM
Just tried MESS, it has now become my 7800 emulator of choice!
I am working on a project right now that requires the use of the Hi-pass filter function of POKEY.
In layman's terms:  You store $04 in the AUDCTL register, then use channel 0 (AUDC0 and AUDF0), zero AUDC2, and use AUDF2 to modulate the frequency in AUDF0.  This can make some nice Commodore 64 SID type sounds.
Unfortunately, ProSystem emulator will have none of this Hi-pass stuff.  It doesn't work.  It does, however, work in MESS.  Guess no one's ever tried to mess with hi-pass POKEY on the 7800 before ...
#62 edweird13 OFFLINE
edweird13
  • 1,023 posts
Posted Sat Apr 19, 2014 12:37 AM
Wow MESS has always been a mess with 7800 as far as I am concerned. Bob has a version of the ProSystem Emu that he uses that has not been released to the public. I wonder how it stacks up to the new MESS.
#63 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Sat Apr 19, 2014 12:44 AM
Don't know but I'd be willing to get my hands on it and try it.  It'd be okay for me as long as it correctly emulates the POKEY behaviours described above.
#64 Trebor OFFLINE
Trebor
  • 4,731 posts
Posted Sat Apr 19, 2014 4:22 AM
http://atariage.com/...n/#entry2964902
#65 Nerf Herder73 OFFLINE
Nerf Herder73
    Chopper Commander
  • 164 posts
Posted Sat Apr 19, 2014 6:22 AM
Hi Guys
There is OpenEmu. Download the experimental version of 1.0.2 from here.
https://github.com/O...penEmu/releases
#66 Shannon OFFLINE
Shannon
    Born To Be Insane
  • 7,847 posts
  • Pac-man Fever
Posted Sat Apr 19, 2014 9:34 AM
Just a few notes/observations from my testing..
Horizon in Choplifter is fixed.
Food Fight has a little graphic glitch at the top left. Not sure if it does this on a real 7800.
A glitch in the Ace Of Aces title screen was fixed at some point.
A glitch in the score line in Basketbrawl is now fixed.
So I guess that just leaves lightgun support next? ;) :P
#67 Bakasama OFFLINE
Bakasama
  • 1,719 posts
  • Blizzcon '18, what a PR disaster.
Posted Sat Apr 19, 2014 10:51 AM
Hi Guys
greetings Walter
I do know how to use Prosystem on a Mac but that involves getting a WINE wrapper first.
#68 RevEng OFFLINE
RevEng
    Bit Player
  • 5,193 posts
Posted Sat Apr 19, 2014 11:10 AM
Food Fight does indeed do that top-of-the-screen glitch in real life.
No lightgun plans for now. :)
Edited by RevEng, Sat Apr 19, 2014 11:10 AM.
#69 Jinks OFFLINE
Jinks
  • 4,680 posts
Posted Sat Apr 19, 2014 4:46 PM
What do you guys think of jsmess?
It maybe is a better idiot proof emulator?
I cant use it on my phone tho.. I need to turn on a "computer" someday..
Computers are so 2010
#70 Trebor OFFLINE
Trebor
  • 4,731 posts
Posted Sat Apr 19, 2014 8:00 PM
:thumbsup:
Another great feature with MESS, you can stretch or/and align the screen vertically (And horizontally) to give the appearance of how great or small you prefer overscan and overall screen positioning.
Just see the slider options under the tab menu:
I see the glitch under my C1702, but there were many CRTs evidently that cropped out the top enough so it wasn't noticeable 'back in the day'.
#71 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,881 posts
  • I am the one who knocks!
Posted Sat Apr 19, 2014 8:12 PM
I can confirm that.
#72 Allan ONLINE
Allan
  • 6,366 posts
Posted Sat Apr 19, 2014 8:39 PM
Hi Guys
greetings Walter
I use Mess on the Mac. It's really wierd how it works but it works.
Install.
Put 7800 bios in proper folder.
put your .A78 files in proper folder.
Run mess. Click on 7800 PAL or NTSC when list of machines come up.
Click on box to put a check mark next to "Insert/Eject disk or cartridge" on left.
Click on Start button.
After games window pops up, click on .A78 file you want.
Click on Insert.
Then click on Done button.
After 7800 Window pops up, hit Return on your keyboard and you should then see the Fuji.
Allan
#73 CPUWIZ OFFLINE
CPUWIZ
    Commander
  • 34,881 posts
Posted Sat Apr 19, 2014 8:41 PM
More steps than my devcart, I love it. :P :D
#74 Allan ONLINE
Allan
  • 6,366 posts
Posted Sat Apr 19, 2014 8:47 PM
Yes because your development cart is not here on my desk which means there are no steps. :_(  :D But hopefully not for long. ;-)
Allan
#75 Trebor OFFLINE
Trebor
  • 4,731 posts
Posted Sun Apr 20, 2014 9:32 PM
Speaking of steps...here's another go to simplify and get any still apprehensive or confused about configuring MESS for the Atari 7800 up and running, practically eliminating the entire setup process.
1.  Download MESS 0.153 (Direct link to Win32 most compatible version which works on XP/Vista/7/8, 32 or 64-bit - for other flavors see here).
          -Double click the downloaded file and install to desired location.
2.  Unzip the following file* to the same desired location:  Attached File  MESS0153_A7800_ADDFILES_20140421.zip   3.32MB   183 downloads
3.  Double click either "PLAY_NTSC_ATARI_7800" or "PLAY_PAL_ATARI_7800".
4.  Press 'Tab' --> Arrow down to 'File Manager' and press 'Enter' --> After 'Cartslot' appears, press 'Enter' again --> Highlight game ROM (Use arrow keys down/up), press 'Enter' and play game. 'Esc' exits emulator.
*Step 2 [MESS0153_A7800_ADDFILES_20140421.zip] content notes:
-NTSC and PAL BIOS files already stored to their correct location and structure.
-The entire NTSC and PAL original library of games in their correct location and structure.
-Already created *.ini and *.cfg files which have been initiated for NTSC and PAL regions respectively with the following conditions:
     A. Starts MESS Atari 7800 emulation in a maximized window
                -Press Alt-Enter to toggle between Window and Full Screen mode.
                     -In Window mode, grab corner of window to modify size.
     B. Default controls: Arrow Keys, Left Ctrl, Left Alt (Remap via "Tab" menu).
                -First installed game controller under Windows automatically becomes mapped to Player 1 (Remap via "Tab" menu).
EDIT 4/21 - Streamlined process further and made more versatile.
Also tagged with one or more of these keywords: Mess, emulation, emulator, roms, games, download, best
