XB Game Developers Package
538 replies to this topic
#51 Ksarul OFFLINE
Ksarul
  • 5,205 posts
Posted Sun Nov 16, 2014 4:24 PM
Thank you for a very nice development tool!
#52 firepod OFFLINE
firepod
    Star Raider
  • 75 posts
Posted Mon Nov 17, 2014 7:50 AM
Thank you Harry, this looks like something that would be very useful once I start developing in Extended.
#53 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Tue Nov 25, 2014 8:01 PM
I would like to include a library of sounds that is automatically loaded with XB256 such as CHIME, CRASH, BEEP, HONK, etc.  This can be up to 680 bytes long and will not reduce the available space for programming.  If you have favorite sound effects that you think would be appropriate, send them to me either as an assembly language source file for the sound list, or as an XB program using CALL SOUNDs which I can then convert. Thanks!
#54 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Sun Nov 30, 2014 8:35 PM
Attached is an updated version of the XB Game Developers Package.  This is also in post #1 of this thread.  Automatic sprite motion can be turned off and on with FREEZE and THAW.  One call to IRND can now return up to 8 random numbers. There was some general polishing and a minor bug was fixed that caused problems with an input prompt of 28 bytes long.  Also some general polishing was done.
The animated GIF below shows a couple parts of 256DEMO2. This is running in XB with support from XB256.  First, the hilighted menu selection is easy to do in XB256; almost impossible in regular XB because there aren't enough characters to redefine.  The pixel scrolling is just plain cool.  The choppiness is caused by the animated GIF.  In the final selection, the entire screen is drawn, and all 256 characters and their colors are redefined, all in under 2 seconds and from Extended BASIC.  This is done using compressed DATA statements and writing to VDP memory with the CWRITE subprogram.
This is a great way to make your XB program both smaller and faster.
#55 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Sun Nov 30, 2014 8:49 PM
One of the challenges in working with the compiler is adjusting delays until they are what you want.  You write the XB program, save in merge format, compile it, assemble it, load it, and test it only to find out that the delay is wrong.  So you modify the program and repeat the process over and over until it is just right, or until you are sick of the whole thing.
There is a much better way using XB256.  You can set the program up to go to a debugging page in the other screen where you can adjust values, then return to the main program to test them out.  You would probably be working in screen2, so the debugging should happen in screen1 to avoid disrupting the game screen. The simple XB program below gives a quick example of how to do this.  It defines A as a ball and used the ESDX keys to move it around on the screen.  Press <Fctn 1> goes to the editing page in line 210 where you can modify DLY.  Note that when you return to Screen2 everything is just the same as when you left.
100 CALL LINK("CHAR2",65,"3C7EFFFFFFFF7E3C"):: R=12 :: C=16 :: DLY=1
110 CALL LINK("SCRN2")
120 CALL HCHAR(R,C,65)
130 FOR I=1 TO DLY
140 CALL KEY(0,K,S):: IF S=1 THEN 160
150 NEXT I
160 IF K=3 THEN 210
170 RN=R-(K=69)*(R>1)+(K=88)*(R<24):: CN=C-(K=83)*(C>1)+(K=68)*(C<32)
190 IF RN=R AND CN=C THEN 130
200 CALL HCHAR(R,C,32):: R=RN :: C=CN :: GOTO 120
210 CALL LINK("SCRN1"):: CALL CLEAR :: INPUT "DELAY VALUE? ":DLY :: GOTO 110
The animated GIF below shows the compiled version of this program (with a few comments thrown in):
Edited by senior_falcon, Sun Nov 30, 2014 8:58 PM.
#56 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,004 posts
  • Technology Samurai
Posted Sun Nov 30, 2014 10:15 PM
How about these two goodies:
BYTE >07,>9F,>BF,>DF,>FF,>80,>05,>99,>0A          * F41
BYTE >02,>80,>06,>0A
BYTE >02,>80,>05,>06                              * F41
BYTE >02,>80,>06,>06
BYTE >02,>80,>05,>05                              * F41
BYTE >02,>80,>06,>05
BYTE >02,>80,>05,>04                              * F41
BYTE >02,>80,>06,>04
BYTE >02,>80,>05,>03                              * F41
BYTE >02,>80,>06,>03
BYTE >02,>80,>05,>02                              * F41
BYTE >02,>80,>06,>02
BYTE >02,>80,>05,>01                              * F41
BYTE >02,>80,>06,>01
BYTE >01,>9F,>00
BYTE >04,>9F,>BF,>DF,>FF,>01
BYTE >06,>81,>2C,>96,>A0,>2C,>B6,>02
BYTE >04,>81,>2E,>A0,>2E,>02
BYTE >04,>81,>30,>A0,>30,>02
BYTE >04,>81,>32,>A0,>32,>03
BYTE >04,>81,>34,>A0,>34,>03
BYTE >04,>81,>35,>A0,>35,>03
BYTE >04,>81,>36,>A0,>36,>04
BYTE >04,>81,>37,>A0,>37,>04
BYTE >04,>81,>38,>A0,>38,>05
BYTE >04,>81,>39,>A0,>39,>05
BYTE >04,>81,>3A,>A0,>3A,>06
BYTE >04,>81,>3B,>A0,>3B,>07
BYTE >04,>81,>3C,>A0,>3C,>08                      * A#02
BYTE >04,>81,>3D,>A0,>3D,>09
BYTE >04,>81,>3E,>A0,>3E,>0A
BYTE >04,>81,>3F,>A0,>3F,>14
BYTE >07,>9F,>BF,>DF,>CC,>01,>F2,>E3,>05          * B53, P3
BYTE >01,>F3,>04
BYTE >01,>F4,>04
BYTE >01,>F5,>03
BYTE >01,>F6,>03
BYTE >01,>F7,>02
BYTE >01,>F8,>02
BYTE >01,>F9,>01
BYTE >01,>FA,>01
BYTE >04,>9F,>BF,>DF,>FF,>00
#57 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Mon Dec 1, 2014 6:01 AM
Thanks!  The second sound is one I've heard many times; the death of a munchman.  What is the first? Level complete in muchman?
#58 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,004 posts
Posted Mon Dec 1, 2014 7:40 AM
You got it!  I am digging around to find some others ones which might be fun or useful.
#59 Ksarul OFFLINE
Ksarul
  • 5,205 posts
Posted Mon Dec 1, 2014 10:41 AM
All of the sounds used in Parsec are in the source code files I uploaded last year--and each is identified in the code.
#60 OLD CS1 OFFLINE
OLD CS1
    >OLD CS1█
  • 6,004 posts
Posted Mon Dec 1, 2014 12:38 PM
Really, anybody can do what I am doing.  I am using Rasmus' SoundListRipper and loading modules.  I am just willing to do the work for it :)
#61 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Fri Dec 26, 2014 10:37 AM
This should be the final update of the XB256/COMPILER256 combination.   There is a built in utility that forces a program to be saved in IV254 format.  If the XB program segments are in IV254 fomat then large programs running under XB256 can be chained together without overwriting the screen, character definitions and colors used when in screen2.  A subroutine has been added that will load a font with true lower case characters with descenders.  There is a subprogram CALL LINK("SCREEN",color) that works exactly like CALL SCREEN except the screen color is saved.  That way when you change screens the screen background colors are saved/restored.  And of course, the usual tweaks to the documents.
#62 Ksarul OFFLINE
Ksarul
  • 5,205 posts
Posted Fri Dec 26, 2014 10:46 AM
Thank you for the update! Looks like I need to take some time off from hardware and try my hand at some XB programming again!  :)
#63 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Sun Jun 14, 2015 6:46 PM
Disk access has been added to the XB compiler.  Post #1 has the updated version of XB Game Developer's Package.  DISPLAY, VARIABLE only, but any length from 1 to 254 is OK.  Up to 3 files open at a time.  You must use file #1, #2, or #3 only.  Error checking implemented for disk access - read the docs for details.  Other peripherals may work provided they can use DV files.
Enjoy!
#64 Bones-69 OFFLINE
Bones-69
    Chopper Commander
  • 215 posts
Posted Sat Jun 20, 2015 12:53 AM
Wow. Disc access.
Downloading.
#65 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,792 posts
Posted Sun Jun 21, 2015 12:14 AM
Disk access has been added to the XB compiler...
Dang, I almost missed this...
#66 Opry99er OFFLINE
Opry99er
  • 10,676 posts
Posted Sun Aug 16, 2015 9:41 PM
RIGHT NOW doing some very neat stuff with CRAWL and WINDOW on my new game project.  :)
The docs for this package are very thorough and well-written.
Once again, thank you a million times for this package, falcon!
#67 Davvel OFFLINE
Davvel
    Moonsweeper
  • 259 posts
  • Married
Posted Sat Jan 16, 2016 9:21 AM
Yea,  well the more I promoted GPL the more flak I got for it.
Some fans  but as most are Assembly and C people on this site.
I feel I was flogging a dead horse.
Which is why I do not show up much anymore.
(Not that I am picking a fight, just pointing out the truth of my feelings on this matter.)
http://atariage.com/...ment-resources/
Look at GPL Section.
I will try my best to dedicate time to GPL. I am trying to get to grips with the new paradigm without asking too many questions in this forum. I know that if I get stuck the atariage members are always willing to assist, but on the other hand I do not want to abuse of your time.
#68 Davvel OFFLINE
Davvel
    Moonsweeper
  • 259 posts
  • Married
Posted Sat Jan 16, 2016 9:22 AM
Well done for your work, I probably will not use it much for now so that I will force myself into GPL but I appreciate your great work here.
#69 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 984 posts
Posted Sun Jul 24, 2016 1:49 PM
CALL LINK("DELAY",250)
Can someone tell me what I am doing wrong with the delay command  using XB256D
I tried other commands like CALL LINK("SCREEN",15)  and that works fine?
Thank you.
#70 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 984 posts
Posted Sun Jul 24, 2016 2:23 PM
another question
I use x=int(rnd*3)+1   this gives me a value from 1 to 3
how do I do this with CALL LINK("IRND",3,X)
ALSO..... When pasting into XB, all of the quotes are removed from the CALL LINK("xxx") lines.
Thanks again!
Edited by 1980gamer, Sun Jul 24, 2016 2:23 PM.
#71 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Sun Jul 24, 2016 8:14 PM
Taking your questions in order:
1-There is indeed a bug with CALL LINK("DELAY")  Assembly subroutines in XB use a lookup table to find the address of the subroutine.  Somehow DELAY was removed from that table.  All the code is there, and I checked that it is also in the compiler, so if you use DELAY and want to compile the program it will be recognized.  The fix is to add DELAY to the lookup table.  Here's how:
Type OLD DSK1.XB256 which will load XB256.
Be sure the loader is dated December 23,2014.  Edit the loader so that it becomes:
5 ! XB256 by Harry Wilhelm      December 23, 2014           Copyright 2013,2014         Free distribution only
9 CALL INIT :: CALL LOAD(8192,255,154)
10 CALL LINK("X"):: CALL LOAD(8197,224,"",16096,68,69,76,65,89,32,50,90):: CALL LINK("XB256")!:: RUN "DSKn.PROGNAME"
Type SAVE DSK1.XB256 to save the modified program.
With DELAY added to the table, it should work as described. Someday I will get around to doing a proper fix for this, but I am waiting for folks to find all the other bugs!!
2 - CALL LINK("IRND",3,X) returns an integer value of 0,1 or 2 in X.  This is the same as X=INT(RND*3).  If X must be 1,2 or 3 then you have to add one to it.  Remember that you can generate up to 8 random numbers with one call to IRND.
3 - "When pasting into XB, all of the quotes are removed from the CALL LINK("xxx") lines"  - I don't know why this would happen.  Using Classic99 (QI 381) running on Windows XP and using Notepad as the text editor, paste XB works as expected.  It could be a problem with a newer version of windows, a newer version of Classic99, or with the text editor you are using.
Edited by senior_falcon, Mon Jul 25, 2016 10:27 AM.
#72 1980gamer OFFLINE
1980gamer
    Dragonstomper
  • 984 posts
Posted Sun Jul 24, 2016 8:48 PM
Thank you Senior_Falcon.
I will try the fix.
So X=INT(RND*3)+1 :: Y=INT(RND*36)+1  would be CALL LINK("IRND",3,X,36,Y) :: X=X+1 :: Y=Y+1
I am using QI 365, I'll look for a newer version.   Hmmmm, wonder if I had a reason to have not updated?
As always...Thank you!
#73 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Mon Jul 25, 2016 10:28 AM
Yep, that will do it.  It would be slightly faster if you can adjust your program to avoid having to add one to X and Y, but that's not always possible.
And I thought my version QI 381was out of date!
#74 senior_falcon OFFLINE
senior_falcon
  • 1,413 posts
Posted Thu Apr 27, 2017 9:48 PM
Attached is a folder containing BXLOADER.  This is a TI BASIC program that lets you load a compiled XB program about 20x faster.  Instructions are in a PDF in the folder.  Editor/Assembler cartridge is required.
(Edit April 28, 2017) BXLOADER is updated to support both compressed and uncompressed object code files.  See post 1 or post 78 for the updated version.
Edited by senior_falcon, Fri Apr 28, 2017 7:53 PM.
#75 Opry99er OFFLINE
Opry99er
  • 10,676 posts
Posted Fri Apr 28, 2017 2:14 AM
Whoa... can't wait to check this out!!
