Draconian (2600)
668 replies to this topic
#651 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Thu Nov 22, 2018 4:57 PM
wait wait on the pal setting, the colours look like the secam but it is NOT rolling, usu the screen rolls, hmm. well enough messing around, going to read your manual now
#652 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Thu Nov 22, 2018 5:03 PM
look im new here, but dog this is bar none the best aaa #1 spaceshooter better than the history of atari spaceshooters put together, that i know
#653 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Thu Nov 22, 2018 5:04 PM
so games like this, there is no way, they could of been done in the early 80s, right.  it is out of modern techniques and new ways of programming that are compatable w/ the hardware, that you can rock something that i want to play for more than 5 minutes?
#654 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Thu Nov 22, 2018 5:07 PM
i will tell you this, when cycling thru the logos, on my 1986 rca colortrak which is not as bright a tube as it once was, the logo looks best in secam.  on the other two the top 1/3'rd slice of top is too dark.  when secam is on the menu the logo is full and i can read it most clearly!
#655 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Thu Nov 22, 2018 5:17 PM
NEVER BEFORE THIS GAME HAVE I MORE WANTED LIKE A FIXED JOYSTICK INSTEAD OF ONE I HOLD IN MY HAND.  I AM ON A TAC-2 AND IF I KEEP IT STEADY I CAN ANGLE IT BETTER ON THIS GAME, JUST LIKE ON A REAL ARCADE.  THIS DEFINETLY HAS TO BE IN THE TOP 5 LIKE BEST ARCADE GAMES ON ATARI 2600 BRO
Edited by chewy, Thu Nov 22, 2018 5:21 PM.
#656 Cambouis de l'Atari OFFLINE
Cambouis de l'Atari
    Moonsweeper
  • 287 posts
  • Also known as "Urbinoo"
Posted Fri Nov 23, 2018 1:57 AM
You should have added this screen Spice ;)
Edited by Cambouis de l'Atari, Fri Nov 23, 2018 1:58 AM.
#657 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,933 posts
  • Always left from right here!
Posted Fri Nov 23, 2018 3:01 AM
That or an overenthusiastic, very happy customer. :)
#658 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,613 posts
  • Medieval Mayhem
Posted Fri Nov 23, 2018 10:51 AM
YOUR GAME HAS VOICE ON MY LIGHT 6'ER
It's been known now to get the 2600 to play digital samples for a long time, both Quadrun and Open Sesame utilized it back in 1983. Back then the gameplay would have to stop while the sample was played.
IT LOOKS VERY 3D, IT ALMOST LOOKS LIKE SEGA GENESIS OR SOMETHING
Being able to reuse the Atari's 5 moveable objects frequently made it possible to create the parallax effect. Those objects are 2 players (nowadays known as sprites), 2 missiles, and a ball. The missiles and ball are just a single pixel, though they can be sized at 1x, 2x, 4x or 8x.
you put a menu option that cycles between pal, ntsc, and secam?? whoa ive never experenced secam before the colours dont look bad on my american rca........
The option only sets the color values used, which are different on the NTSC, PAL and SECAM versions of TIA(the video chip). The frame rate is kept at 60 Hz for all of them, rather than 50 Hz as expected for PAL and SECAM. Displays in Europe normally can handle 60 Hz though, so "PAL60" is a common way to implement homebrews for over there. More info on my Atari NTSC vs PAL vs SECAM page.
Correct. Back in the day Activision came out with a coprocessor to put in the cartridge and used it to create Pitfall 2. We're doing the same thing, but using a modern ARM processor as the coprocessor. This is what allows me to reuse the objects so frequently, as well as play back digital samples without pausing the gameplay. The ARM has an internal clock and by using it we can detect if the 2600 in question is NTSC, PAL, or SECAM because each model uses a slightly different clock speed.
The top two colors in the logo use a luma value of 2, which can be dark depending upon how the brightness and contrast on your display is adjusted.
Thanks! I use a regular 2600 style joystick to play, though it's a newer one that was made for one of the earlier Flashback units. I don't like the newer flashback joystick though, they revised the internals and no longer feel right.
#659 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,382 posts
Posted Fri Nov 23, 2018 11:16 AM
DOG I JUST GOT MY H. CART AND I SWEAR TO GOD I DONT HAVE THE 60 DOLLAR ATARVOX ADD-ON, BUT YOUR GAME HAS VOICE ON MY LIGHT 6'ER AND IT LOOKS VERY 3D, IT ALMOST LOOKS LIKE SEGA GENESIS OR SOMETHING
If you bought the AtariVox for $60, you overpaid. It is $45 in the AA store. https://atariage.com...t_detail&p=1045
The speech synthesis is based on arcade samples but it uses a TIA audio register stuffing process for the speech synths similar to the music synth chip in Pitfall II. Also a bit overzealous on the posts mate...
Glad you are enjoying it. Yes, the new CDW bankswitching capable games are mind blowing. Yes, this game is so fantastic, I was playing on my AV modded 7800 and forgot that I was in actuality playing a 2600 game. It's that good! :grin:
I would also personally recommend Space Rocks, Scramble, and Super Cobra Arcade if you want more advanced 2600 games like this.
#660 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Fri Nov 23, 2018 1:44 PM
thanks you guys
Edited by chewy, Fri Nov 23, 2018 1:45 PM.
#661 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Fri Nov 23, 2018 1:46 PM
im really getting a comprehension for this thanks for the info---- so is this as far as we can go w/ VCS, or do you think in 10 years we could even go further?
The option only sets the color values used, which are different on the NTSC, PAL and SECAM colors. The frame rate is kept at 60 Hz for all of them, rather than 50 Hz as expected for PAL and SECAM. Displays in Europe normally can handle 60 Hz though, so "PAL60" is a common way to implement homebrews for over there. More info on my Atari NTSC vs PAL vs SECAM page.
#662 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Fri Nov 23, 2018 5:58 PM
are we ever gonna get like a 16 gb game for the vcs in 20 years, is it going to be constantly improved upon or is it going to reach like a point where it cant go further?
and if we did have a 16 gb game would it just mean the game is really really long, or i mean could we get a game 16gb that would improve the graphics even more?
Edited by chewy, Fri Nov 23, 2018 5:59 PM.
#663 Twin_power OFFLINE
Twin_power
    Chopper Commander
  • 132 posts
Posted Fri Nov 23, 2018 7:24 PM
I don't think the AtariVox is available right now..
#664 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,613 posts
  • Medieval Mayhem
Posted Sat Nov 24, 2018 10:40 AM
We can go further, though we ran into problems with Bus Stuffing on a few systems (namely Juniors and 7800s).  We were trying to get this working for Draconian, but ran out of time for my planned release of Draconian at PRGE in 2017. So we can up with CDF instead, as covered in this Draconian blog entry.
We could do a 16 GB game now by utilizing an SD card in a Harmony for game data. 2600 homebrews are individual or small group projects, who would likely be overwhelmed with trying to create that much data for a 2600 game.
#665 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Sat Nov 24, 2018 1:54 PM
i hope you sleep well at night because you should be proud you created the aaa #1 most advanced best and repeatily fun atari game, and most authentic arcade reproduction.  It should feel good to be the best at something.  You really should send a copy to Nolan Bushnell dawg, hed get a kick out of this
Edited by chewy, Sat Nov 24, 2018 1:56 PM.
#666 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Sat Nov 24, 2018 1:55 PM
#667 Kosmic Stardust OFFLINE
Kosmic Stardust
    Princess Rescuer
  • 18,382 posts
Posted Sat Nov 24, 2018 4:41 PM
We can go further, though we ran into problems with Bus Stuffing on a few systems (namely Juniors and 7800s).  We were trying to get this working for Draconian, but ran out of time for my planned release of Draconian at PRGE in 2017. So we can up with CDF instead, as covered in this Draconian blog entrypost-3056-0-85676400-1477191617.jpg  We could do a 16 GB game now by utilizing an SD card in a Harmony for game data. 2600 homebrews are individual or small group projects, who would likely be overwhelmed with trying to create that much data for a 2600 game.
I remembered the bus stuffing demos. They functioned fine on my 4-switch 2600 and my 7800. I did not test on the Gemini.
I would love to see more complex games made with the bus stuffing. They nearly rival the 7800 in capabilities.
Due to the way the tia operates, any static screen displayable on the Atari could potentially be a game screenshot in a 60hz game. Somewhat was working on the Cicada demo (galaga port using gb like monochrome). Whatever happened?
#668 chewy OFFLINE
chewy
    Chopper Commander
  • 130 posts
Posted Sun Nov 25, 2018 1:23 AM
actually dawg i think it might be a tossup between Draconian game and that car pic for thing thats blowin my mind the most.....
#669 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,613 posts
  • Medieval Mayhem
Posted Sun Nov 25, 2018 1:28 PM
The color picture of my old S2000 is super flickery, so much that I find it painful to look at.
The monochrome version flickers as well, but not as much so it is useful for things like pictures and displaying 32 column text. It could also be used for games, though the flicker causes moving objects to produce strange motion artifacts. Hopefully early next year SpiceC will have progressed far enough that people can start experimenting with that.
