Full Color ANSI VBXE terminal in the works
Terminal Emulator ANSI VBXE 80 columns 16 color
55 replies to this topic
#1 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sun May 4, 2014 9:55 AM
Sometime last year, I realized what great potential the VBXE has for BBS'ers. Having a full 256 character font, 80 columns, and the potential to support 8 background and 16 foreground colors means it could be used for a full ANSI/ECMA-48 terminal emulator.
Right now, I have a demo program which does 80 column 16 color text on VBXE, with an IBMPC font (lots of ANSI BBS'es assumed this font for the extended graphics characters), interprets ASCII control codes (otherwise known as the C0 control character set as defined by the ECMA) and I just got scrolling done yesterday. It reads from a file right now, rather than an R: device.
So I have zipped up the files with the source (don't copy without crediting me please) and put them here for people to see.
#2 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** *Moon Master2015* *Blue Max:Class 4*
  • 7,729 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Sun May 4, 2014 10:34 AM
NOW I Suddenly want the XBXE and somehow make it work with my incogneto.  :)
Can you supply pictures of this in action?   Show some screen shots of the Prison Board if you don't mind at telnet://rdfig.net
Truly great news!
#3 venom4728a OFFLINE
venom4728a
    Dragonstomper
  • 617 posts
Posted Sun May 4, 2014 6:20 PM
This is going to be awesome.
#4 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sat Sep 13, 2014 6:48 PM
I've done some more work. The terminal now reads from R1: at 9600 baud. It also accepts keyboard input. The extent of the testing I've done with it is to run it in altirra and log in to irc.atarinet.com (port 400) which is a pure ASCII text gateway to the ##Atari IRC channel on the Freenode IRC network. Attached is an ATR, the program to run is ANSIVBXE.XEX
#5 doctorclu OFFLINE
doctorclu
  • 7,729 posts
Posted Sat Sep 13, 2014 8:54 PM
So, anyone get a VBXE to work in a beige 800 yet?  :)
#6 Stephen OFFLINE
Stephen
  • 7,535 posts
  • A8 Gear Head
Posted Sat Sep 13, 2014 8:58 PM
Clu - I just got a plasma cutter.  I bet I get to be first :)
#7 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Sun Sep 14, 2014 12:02 PM
Since I don't yet have ANSI support, there aren't too many pages that look right, but here are a couple screenshots from the prison board BBS for doctorclu.
EDIT: forgot VBXE screen shot scaling was weird, but you get the idea (640x192 is a pretty odd ratio)
Edited by Joey Z, Sun Sep 14, 2014 12:03 PM.
#8 flashjazzcat OFFLINE
flashjazzcat
  • 14,431 posts
Posted Sun Sep 14, 2014 12:06 PM
Joey: enable interlace in Altirra and the screengrabs will come out right.
EDIT: took the liberty.
Looks great. :)
Edited by flashjazzcat, Sun Sep 14, 2014 12:13 PM.
#9 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Mon Mar 23, 2015 5:13 PM
Changes:
improved keyboard input (no more dropped keypresses as far as I can tell)
improved reception of characters: Before, I was calling CIO twice for each character, first to check if there were any characters ready to be read, and the next to get just one character. This was only ever intended to be temporary. Now, I check if there are characters, and read a whole buffer (up to 255) and thus reduce the time used in CIO calls. It's MUCH faster now. Running in altirra, I get over 70kbaud (took 4.88 seconds for 35K to scroll by). That was just purely normal characters though, I can't say what would happen if some of those were control characters, and what it'll be like when I finally add support for ANSI escape sequences.
#10 Kyle22 OFFLINE
Kyle22
  • 3,883 posts
  • Call my BBS! telnet://broadway1.lorexddns.net
Posted Mon Mar 23, 2015 8:17 PM
That's what I want, as a companion for my Incognito.  A VBXE/Rapidus combo CPU card would be AWESOME:) But, I don't expect miracles.  Just an easy way, probably using a ribbon cable, and put the VBXE somewhere in the empty space inside the 800's case.  Run the cable out the back where the RF cable was, to avoid cutting holes.
#11 doctorclu OFFLINE
doctorclu
  • 7,729 posts
Posted Mon Mar 23, 2015 8:47 PM
I'm just glad this is still being played with.   Looks good overall!
#12 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Tue Mar 24, 2015 12:12 AM
New features:
FULL COLOR SUPPORT!!
yep, finally got that implemented... It's not only the first ANSI/ECMA 48 control sequence I've implemented, it's also the only one.
Edited by Joey Z, Tue Mar 24, 2015 12:28 AM.
#13 DarkLord OFFLINE
DarkLord
  • 3,312 posts
Posted Tue Mar 24, 2015 12:56 AM
This looks awesome and the 8bit BBS crowd has deserved it for a very long time.
Huzzah! :)
#14 doctorclu OFFLINE
doctorclu
  • 7,729 posts
Posted Tue Mar 24, 2015 10:52 AM
That video shows almost flawless ANSI terminal emulation.  Now I have two dilemas:
1) Get the Incogneto where I can use serial connections for an extended period of time without flaking out. (Part of the reason I don't use the Incogneto for BBSing)
2) Get the VBXE to work with the Incogneto.
But it is nice to see that the 8 bit Atari has good color ANSI option now.
#15 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Tue Mar 24, 2015 8:16 PM
so I just found a major bug thanks to gozar. There was a line in the source: lda 0. It was supposed to be lda #0. This prevented the program from working on most OS'es, this has probably been a problem for quite some time. Anyway, it's fixed now, so here's the latest ATR.
#16 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Wed Mar 25, 2015 8:50 PM
Another interesting idea ...
PETASCII emulation, for calling those old Commodore 64 BBSes ... always wanted my Atari to be able to do that. :)
#17 doctorclu OFFLINE
doctorclu
  • 7,729 posts
Posted Wed Mar 25, 2015 11:54 PM
PETASCII!!!   That would rock!
#18 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Thu Mar 26, 2015 10:37 PM
update: rearranged the memory map a bit and got everything to run in 16K only. Probably better this way anyway.
#19 JoSch OFFLINE
JoSch
    Moonsweeper
  • 473 posts
Posted Fri Mar 27, 2015 3:07 AM
Would it be possible to separate the ANSI character stuff as a library?
#20 a8isa1 OFFLINE
a8isa1
  • 1,559 posts
Posted Fri Mar 27, 2015 7:17 AM
I got a chuckle from this.  I wondered who might take the time to install a VBXE yet leave the machine at 16K.
However, congrats and thanks for all your successes with VBXETERM.
#21 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Fri Mar 27, 2015 9:17 AM
Thanks to a8isa1 for continually complaining and finding a bug :twisted:
But seriously though, thanks for pushing me about the differences you saw between linux telnet and my terminal on DarkForce BBS. I did uncover a bug in the code for the color interpretation routines. I had a slightly misplaced label one line down from where it should have been, causing 1 digit parameters in a Set Graphics Rendition control sequence to partially combine with any previous parameters and fail miserably. For example, a control sequence like (esc)[33;1;44m (set foreground color to yellow, bold/high intensity foreground, background to blue) was being interpreted as if it were 33;31;44, set foreground to yellow, set foreground to red, set background to blue.
So here's the latest revision.
And if anyone else finds anything amiss in any way, let me know, it's probably a bug or a feature that hasn't been added yet (or even a feature I didn't think to add, but might consider). I'll take constructive criticism (I'll probably need it for the software to be successful).
Edited by Joey Z, Fri Mar 27, 2015 9:25 AM.
#22 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Fri Mar 27, 2015 9:27 AM
In what way? You mean to use in a different program? Possibly, but don't count on my doing it for you. Eventually I'll put up all the source, once I figure out how I want to do licensing. Keep in mind, it's all assembly code, so it could turn out to be more implementation specific than you thought and not be very useful as a separate module.
#23 917k OFFLINE
917k
    Chopper Commander
  • 157 posts
Posted Tue Mar 31, 2015 12:49 AM
Does this support smooth scrolling?
#24 JoSch OFFLINE
JoSch
    Moonsweeper
  • 473 posts
Posted Tue Mar 31, 2015 5:40 AM
Yes, that's what I meant. And your answer is what I feared ;-)
So, I have to look at it, when you release the code.
#25 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Wed Apr 1, 2015 9:32 AM
not yet, I'm more concerned with getting it to work properly than making it look nice right now. I've taken another break from work on it (except fixing any bugs that are found) since I'm back at University now and I have other work to do. But I'll consider adding it later for sure, if it doesn't prove to be a speed detriment (and if it does, then I'll probably just have a way to turn it off).
Also tagged with one or more of these keywords: Terminal Emulator, ANSI, VBXE, 80 columns, 16 color
