Full Color ANSI VBXE terminal in the works
Terminal Emulator ANSI VBXE 80 columns 16 color
52 replies to this topic
#26 JAC! OFFLINE
JAC!
  • 1,683 posts
  • Always looking for GFX and MSX for my demos
Posted Sat Apr 4, 2015 1:40 AM
Very nice. And even nicer to see with how litte code this can be done on the Atari.
#27 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Mon Apr 6, 2015 6:29 PM
FJC tried to run the terminal, and was having issues. Unfortunately, given the time zone difference, he had to log off before we could pinpoint the cause of the issue. However, I think I was able to find it some time afterward. I realized that it wasn't working with the 1200XL OS. Turns out, I had a few places where I had lda 1 instead of lda #1 (I'm really getting sick of these errors :()
Anyway, here's the latest version again.
EDIT: turns out this doesn't work in SDX because the VBXE memory window overlays the banking RAM window. Should be a relatively simple fix, I just need to turn that off after the init routine, then turn it back on in the main program segment.
Edited by Joey Z, Mon Apr 6, 2015 7:25 PM.
#28 Ripdubski OFFLINE
Ripdubski
  • 1,271 posts
Posted Mon Apr 6, 2015 7:29 PM
wow, now i need a vbxe
#29 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Wed Apr 8, 2015 7:44 AM
v0.01.2015.04.07
new features:
- added version number into main source file as data coded for human readablity
in compiled form.
bugfixes:
- VBXE memory window no longer conflicts with extended memory. It hase been
moved to $A000-AFFF. This overlaps the cartridge area, but cartridges have
priority over the VBXE memory area, so it works as long as you run with X.
known bugs:
- none yet ;)
todo:
- add more ANSI control sequence support
also added a license.txt, which isn't done yet. I haven't had time. So, for this version, the license.txt can be ignored. Instead, follow my definition of "don't be a dick" and you should be fine. If you have to ask, safest bet is to not do it. When I do complete the license, it will apply to the first version it appears in as well as all previous versions, so keep that in mind.
Edited by Joey Z, Wed Apr 8, 2015 7:46 AM.
#30 flashjazzcat ONLINE
flashjazzcat
  • 13,555 posts
Posted Wed Apr 8, 2015 7:50 AM
Thanks Joey. Finally got this version running under SDX in Altirra. Haven't tested on real hardware yet. Looks great, though. :)
#31 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Wed Apr 8, 2015 9:46 AM
just so everyone knows, if you get a screen full of scrolling garbage when you start the term, that means you don't have an R: handler loaded.
#32 Mathy OFFLINE
Mathy
  • 2,622 posts
Posted Wed Apr 8, 2015 2:40 PM
Hello Joey
Why doesn't the terminal test for the presents of an R: handler?
Sincerely
Mathy
#33 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Wed Apr 8, 2015 5:28 PM
Hello Joey
Sincerely
Mathy
simple: it's not done yet and I haven't added that feature.
#34 gozar OFFLINE
gozar
    Dragonstomper
  • 873 posts
Posted Sat Jan 9, 2016 5:28 PM
Tried it out tonight in real hardware, and it worked really well for BBSing. Unfortunately, not so well as a Linux terminal. :-)
Pretty awesome!
Sent from my iPhone using Tapatalk
#35 fujidude OFFLINE
fujidude
  • 4,972 posts
Posted Sat Jan 9, 2016 6:14 PM
Looks good!
#36 doctorclu OFFLINE
doctorclu
    ***Moon Patrol 5200*** ***Moon Master*** *Blue Max:Class 4*
  • 7,363 posts
  • *Star Raiders 2* **Captain -CL 2**
Posted Sat Jan 9, 2016 11:17 PM
Wow, now THAT terminal I would use.
#37 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Sat Jan 9, 2016 11:31 PM
Interesting question:  Could one potentially do PETASCII on the VBXE?  That is, all 16 commodore colors, with a 40-column 256 character set?  One of the things I always wanted when I was in my teenage years BBSing on my Atari, was to be able to call the local Commodore BBS in full color. :)
#38 Stephen OFFLINE
Stephen
  • 7,050 posts
  • A8 Gear Head
Posted Sun Jan 10, 2016 8:37 AM
Yes, VBXE will allow that.
#39 doctorclu OFFLINE
doctorclu
  • 7,363 posts
Posted Sun Jan 10, 2016 8:50 AM
Someday I might have to look up one these VBXE's.  See if they can be adapted to the Incogneto in the 800.
#40 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Tue Jan 12, 2016 2:36 PM
VBXE does not have a 40 column mode unfortunately, so it may be harder than it seems.
#41 Synthpopalooza OFFLINE
Synthpopalooza
  • 1,472 posts
Posted Tue Jan 12, 2016 11:52 PM
Could it not be done in a bitmap mode though?  Have the characters written directly to a bitmap instead of using character mode?
#42 Shawn Jefferson OFFLINE
Shawn Jefferson
  • 1,987 posts
Posted Wed Jan 13, 2016 12:17 AM
Or just show 40 chars on the 80 char screen,indent 20 chars on each side.
#43 phaeron OFFLINE
phaeron
  • 2,506 posts
Posted Wed Jan 13, 2016 12:36 AM
You can emulate a 40 column display with the blitter -- it copies at 7MB/sec. Use a series of strided blits to copy from character/attribute arrays into another set of blits with one blit per character. Should take only one short routine to restart the entire blit list each frame.
#44 Shift838 OFFLINE
Shift838
  • 2,298 posts
  • SHIFT838
Posted Fri Mar 18, 2016 7:39 PM
v0.01.2015.04.07
new features:
in compiled form.
bugfixes:
known bugs:
- none yet ;)
todo:
is this just a text terminal right now?  No menu to access to configure yet? no file xfers ?
It looks pretty good so far.
#45 Joey Z OFFLINE
Joey Z
    Dragonstomper
  • 876 posts
Posted Fri Mar 18, 2016 7:58 PM
Yes, it's nowhere near complete. No configuration at all, more or less full ASCII support, miniscule set of ANSI support. UI is limited to you pressing a key, it sends it, it receives something, it displays it.
#46 Shift838 OFFLINE
Shift838
  • 2,298 posts
  • SHIFT838
Posted Fri Mar 18, 2016 8:05 PM
thanks for the info.  I just started learning Atari and was looking for something like this.  I am currently running it via a emulated 130XE via Altirra.
It works pretty good so far.  I have found it does not display my ANSI screens completely correct, but it's a very good start.  I will be following this topic.
Thanks for the info.  and keep up the good work!
#47 Rybags OFFLINE
Rybags
  • 15,663 posts
Posted Fri Mar 18, 2016 8:15 PM
40 cols could be done multiple ways.  Another is to use 2 characters side by side, 0-127 represent left half, 128-255 for the right.
Another way could be to overlay VBXE Ram to where the OS text screen is mapped.  That allows leaving standard E: and S: devices as they are.  Blits could be used to translate the stock screen into something VBXE can display.
It could be done every frame though for translating to a VBXE bitmap would probably have to be spread over multiple frames.
Character set mapping for doing bitmap would probably have to be done like the 7800 does it.  Have each scanline of a character 256 bytes further in memory than the previous.
#48 flashjazzcat ONLINE
flashjazzcat
  • 13,555 posts
Posted Sat Mar 19, 2016 4:40 AM
Phaeron noted a while ago that the blitter can emulate a 40 column display, I would imagine very efficiently.
#49 Rybags OFFLINE
Rybags
  • 15,663 posts
Posted Sat Mar 19, 2016 5:04 AM
Depends how you want to do it.  With Quadrillion which I had source and ported over from Plus/4 the original plan was to rewrite the rendering such that it correlated directly to the Atari way.
That was going all well and good until some nasty bug crept in and I was left with a steaming mess, turned out quicker to just start again.  Which was a pity as doing it the Atari way would have meant I could have done an easy legacy hw only port as well.
The end result was that I left the rendering mostly alone and just used blits to remap the C= bitmap to Atari type.  It's only moving 8,000 bytes or so per frame which in VBXE terms is barely above idling.
But yeah, doing a 40x24 remap to 80x24 would allow improved resolution and cheaply in terms of both blit time and VRam usage.  In fact could even use real interlace to give 16x16 characters in the same physical space as 8x8 ones.
Edited by Rybags, Sat Mar 19, 2016 5:04 AM.
#50 Shift838 OFFLINE
Shift838
  • 2,298 posts
  • SHIFT838
Posted Sat Mar 19, 2016 10:56 PM
How do you exit out of this program?  Any key to bring up a menu or anything?
Also tagged with one or more of these keywords: Terminal Emulator, ANSI, VBXE, 80 columns, 16 color
