Coleco ADAM Power Supply
458 replies to this topic
#1 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
  • Mods for ColecoVision & ADAM
Posted Tue May 27, 2014 12:20 PM
I've looked a lot for a schematic for the ADAM printer power supply but can not find a good clear one. Does anyone have a copy? I'm trying to see if I can figure out a power supply for this thing.
#2 Geoff Oltmans OFFLINE
Geoff Oltmans
    Chopper Commander
  • 100 posts
Posted Tue May 27, 2014 9:18 PM
I'm sure I've got a PDF copy if you need a copy, but there's really nothing mystical about the voltages it supplies. A PC supply can easily replace the printer.
#3 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Thu May 29, 2014 6:59 AM
I got some information thanks to Bob's site just because I like to have any and all information at hand if possible no matter how simple the task. I am going to order a psu that will give me the voltages I need and a enclosure for it. I believe a 180w PS should be enough. I'll let you guys know how it goes.
#4 Dr. D. OFFLINE
Dr. D.
    Space Invader
  • 44 posts
  • Healer of Appliances
Posted Thu May 29, 2014 7:49 AM
The best one I have is here:   http://drushel.biol....king_bitmap.pdf   It's fairly legible.
Bob Slopesma may have a better one at his site.  Mine was made from a full-sized (D-print) photocopy lent by Richard Clee; I think Bob's came from a Coleco original blueprint.
*Dr. D.*
#5 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Thu May 29, 2014 7:54 AM
Thank you
#6 adamcon OFFLINE
adamcon
    Moonsweeper
  • 326 posts
Posted Fri May 30, 2014 9:12 AM
Ok Rey....got one for you IF it comes thru here.  It is a .jpg and should be clear enough, the other alternative is a .png picture which is 3.5mg.
  • Rey likes this
#7 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Fri May 30, 2014 9:44 AM
Thanks Bob, that's perfectly clear for me my friend.
#8 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Sat May 31, 2014 2:40 PM
I received the power supply today but for some reason I'm not getting a -5volt reading out of any of the pins. The label on the supply clearly shows the -5v is one of the voltages it's capable of.  I grounded the green ps-on wire and it powers on fine but not getting the -5v anywhere. Any ideas?
#9 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Sat May 31, 2014 6:36 PM
For the price of these power supplies it's worth just attaching a L790. Hopefully I'll have this done soon,complete with a nice label in top :)
Edited by rey_1178, Sat May 31, 2014 6:37 PM.
#10 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Wed Jun 4, 2014 9:00 PM
An update on the power supply. I got it up and running and so far so good. I still have a little more work to do with it which includes a label but here's how it looks so far.
#11 adamcon OFFLINE
adamcon
    Moonsweeper
  • 326 posts
Posted Thu Jun 5, 2014 5:19 AM
Looking GOOD Rey!  :grin:  You will have to tell the masses how to do it and what you used.  I just took an old 180watt ibm supply and wired it to an ADAM power cord, works great, but not so pretty as yours.
  • Rey likes this
#12 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Thu Jun 5, 2014 5:35 AM
Thanks Bob. It takes some good amount of work to do it like this but if someone feels confident enough it's worth it. You can see it's smaller than the disk drive. I'm still trying to figure out an even smaller solution, way smaller and have an eye on some parts but for now this is very nice and beats having to rely on the large printer. I will do lots of testing during the next few days to make sure there's no over heating in the supply. It ran fine last night using everything, tapes,floppies,cartridges, all one after the other and the heat coming from the supply seemed normal. This will also be receiving a nice custom label.
#13 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Sun Jun 8, 2014 3:34 PM
I re did this again in a slightly larger enclosure and added ventilation which includes a tiny fan. Now it runs cool. Have had it running all day and it doesn't even get warm so success! I changed the location of the switch and added a DB9 port at the rear. There's a label at the bottom but still need the label at the top which will look like what's on the keyboard,memory console, etc.
The cable I'm using fits perfectly so no modification to your memory console is required. From all the searching I did before starting this little project, I saw the problem where some removal of plastic around around the male port on the memory console was necessary for the plug to fit. So I looked for one that would fit correctly and from the pictures below you will notice the female end completely fits into the male plug on the ADAM. The point is to just make it plug and play without any hassles.
I considered painting the supply in the ADAMs colors but for now it will be black. Label will be coming shortly.
20140608_115430.jpg 20140608_115525.jpg 20140608_165640.jpg 20140608_165608.jpg 20140608_163503.jpg 20140608_122030.jpg 20140607_220930.jpg
#14 adamcon OFFLINE
adamcon
    Moonsweeper
  • 326 posts
Posted Sun Jun 8, 2014 5:26 PM
attachicon.gif20140608_115430.jpgattachicon.gif20140608_115525.jpgattachicon.gif20140608_165640.jpgattachicon.gif20140608_165608.jpgattachicon.gif20140608_163503.jpgattachicon.gif20140608_122030.jpgattachicon.gif20140607_220930.jpg
Rey, you got to start making these commercially.  People want a separate ps for the ADAM, and yours is looking great !!!  ;-)
#15 NIAD OFFLINE
NIAD
  • 6,140 posts
Posted Sun Jun 8, 2014 5:49 PM
Great job on the power supply and I second ADAMcon's suggestion to open up shop! Although I'd want mine all tricked out with a matching paint job and replica ADAM label seeing as you brought those up in your post. ;)
Oh yeah, great find on that DB9 power cord.
#16 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Mon Jun 9, 2014 4:31 AM
Thanks guys. If people want one I'm willing to make them once this one is done. I'm still trying to really perfect this thing. Can't help it, it's in my nature :-)
#17 SiLic0ne t0aD ONLINE
SiLic0ne t0aD
  • 2,280 posts
  • Rock 'N Roller, Space Patroller
Posted Thu Jun 12, 2014 6:59 PM
Very nice work, i hope to get myself an ADAM computer here soon.. :thumbsup:
  • Rey likes this
#18 Bill Loguidice OFFLINE
Bill Loguidice
  • 7,112 posts
  • Armchair Arcade Managing Director
Posted Fri Jun 13, 2014 8:39 AM
There's definitely a market. I'm in for one when you're ready. Honestly, I already have a power supply pulled and crudely cased from the printer, but I'd like something a bit more professional and easier to move about.
#19 Pixelboy OFFLINE
Pixelboy
  • 8,097 posts
Posted Fri Jun 13, 2014 8:49 AM
I'm in the exact same situation. I bought a similar "homebrew" Adam power supply from Jibbajabba (I think that was his username here, or perhaps it's someone else with a similar username) some years ago, but when I used it with my Adam, the picture was all "wavy" on the TV screen and I felt that was really weird and I couldn't trust this power supply, so I returned it to the guy for a refund. I hope this one will work better...
#20 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Fri Jun 13, 2014 4:20 PM
I'll keep you guys updated. The plan is to make this available to those who need one.
Pixelboy, you have the F18a in your Adam or the original vdp? It shouldn't make a difference when it comes to the power supply but still, I would've loved to been able to save the chip for test purposes.  I believe I've found these chips on eBay.
So far for me it's been flawless.
Edited by rey_1178, Fri Jun 13, 2014 4:23 PM.
#21 Pixelboy OFFLINE
Pixelboy
  • 8,097 posts
Posted Fri Jun 13, 2014 8:45 PM
I got that homebrew Adam power supply several year ago, long before I ever heard of the F18A. I don't have the F18A in my Adam.
#22 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Wed Jun 25, 2014 1:24 PM
Update on the power supply. Here's the new label :-)
#23 Bill Loguidice OFFLINE
Bill Loguidice
  • 7,112 posts
Posted Wed Jun 25, 2014 1:32 PM
Fantastic, but I'd be happy even without a professional label. ;-)
  • Rey likes this
#24 Rey OFFLINE
Rey
    Dragonstomper
  • 727 posts
Posted Wed Jun 25, 2014 1:40 PM
Thanks Bill. I'll be putting the numbers together real soon to make these available for purchase.
Rey
#25 mightywiz OFFLINE
mightywiz
    Chopper Commander
  • 176 posts
Posted Wed Jun 25, 2014 3:11 PM
so is this a custom built power supply or is it a purchased switching powersupply you very nicely mounted in a case?
can we see a picture of the internals?
