130 XE RAM bank handling advanced question ;=)
when I am reading the docs correctly it is possible to have
code running in RAM bank #0 at $4000 while ANTIC displays gfx at BASE RAM at $4000? and can I even put display lists there? (as ANTIC runs here as co-processor)?
GTIA sprites would be not as GTIA has not such kind of logic and control register $d301? right?
Do any of them support it?
I think so. At least the Compy-Shop expansion I have AFAIK. haven't tested it.
It's a pitty that no all support it. When you think about it, it's a bit like the C64's VIC-II can access a 16Kb area anywhere in its 64K.
Guess that could solve some memory problems we face on the 8-Bit. for example PMG (>1k) char-screen (1k) each charset (1k).
When using hi-res screen (8k) and double buffering for free. You do not even have to change the rendering routine because it always writes in teh $4000-$7fff area :)
However, I think when using SW sprites its not that cool. But haven't thought about that.
i hope Heaven has more (cooler) ideas :)
The A8 would benefit from a better banking scheme. Too late I guess.
True on both counts. It would be nice to keep frame buffers in extended RAM, but the completely inflexible Antic/CPU banking system makes it impossible in most situations. And once you get past half a meg that functionality's gone anyway. Even the fact the banking window is fixed at $4000-$7FFF is limiting.
Edited by flashjazzcat
Would linear memory in a 65816 be more useful? You can even access upper memory banks when you are in 6502 mode. How modular is most code? Would it be a major task to convert some of the routines to linear memory access?
Is this meant for me? Yeah - linear memory access would be very convenient, as would be four times the stock CPU speed. But what I'm writing needs to work with non-specialised hardware (i.e. stock machines with at least 128K, or most people's base configuration). :)
