Myarc XBII ('Advanced BASIC') Tips and Tricks
geneve myarc XBII Advanaced BASIC ABASIC
28 replies to this topic
#1 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Tue Jul 8, 2014 1:17 PM
Since there doesn't appear to be a manual for 'Advanced BASIC' on whtech (at least not one that's not buried in some inconspicuous disk), I thought I'd start a support thread for advice and tips.
So far, I've found that many XB programs can be used exactly as they were designed with just a few adjustments to the program.   If you used WDS# for the drive on the TI, it needs to be changed to HDS# for ABASIC on the Geneve.  The other important thing is the GRAPHICS subprogram:
Set screen to 32-column mode:
CALL GRAPHICS(1)
Set screen to 80-column mode:
CALL GRAPHICS(4)
Note that in 80-column mode, CALL COLOR(S,F,B) doesn't work, you must use CALL SCREEN(F,B).  (This information was found on mainbyte).
Here's a text of collected commands.  This is pretty much all from the sparse documentation that currently exists, but saves having to dig through generically named RTF files.
Edited by RobertLM78, Fri Jul 11, 2014 11:44 AM.
#2 --- Ω --- OFFLINE
--- Ω ---
    Hexacorerunner
  • 13,623 posts
Posted Tue Jul 8, 2014 1:55 PM
This probably does not help, much if at all, but it's all I had.
#3 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Tue Jul 8, 2014 2:20 PM
Good start - thanks buddy!
#4 Ksarul OFFLINE
Ksarul
  • 5,136 posts
Posted Tue Jul 8, 2014 4:48 PM
I thought the whole ABASIC manual was on WHT somewhere--I thought it was part of the final version package. . .
#5 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Tue Jul 8, 2014 5:02 PM
It might be, buried somewhere, but I haven't been able to find it yet.  Actually, I have seen the errata doc that Omega posted, but it's still a good link to have up.
#6 mdorman OFFLINE
mdorman
    Space Invader
  • 32 posts
Posted Wed Jul 9, 2014 2:27 PM
Here's what I've found on whtech.  Under /geneve/mdos/advanced_basic_software/, there are two files mybeven.zip and mybodd.zip.   These seem to contain the individual page scans of the ABASIC manual.
Mike
#7 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Wed Jul 9, 2014 2:38 PM
Thanks Mike - I've actually seen those as well (I should have clarified that- my mistake ;)).  I'm pretty sure those are fixes to the manual only, not the complete manual :(.
#8 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Wed Jul 9, 2014 2:55 PM
I actually have the printed manual - but not scanned (yet). Although I do have a flatbed scanner, I'll first check whether I can get it scanned with a document feeder.
#9 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jul 9, 2014 4:48 PM
I have some of Jim's disk images (thanks to Ben) which contained manual updates.   But I don't recall ever seeing a completed, final document.
A.Freuh was working on an updated Geneve manual that corresponded to MDOS version 6.0.  I don't recall if he had updated Advanced BASIC.  I am not sure what I did with those files and will add that to my list of things to look for
Robert, if you have programs that use assembly language be sure to download the updated Advanced Basic files.  There was an obnoxious, long-standing bug that I found that was causing much trouble.   There are also some things in XB programs that ABASIC doesn't properly understand, so if you get some weird syntax errors, particularly in complicated IF/THEN/ELSE statements, you may have to break things apart.
Edit:
Here is more recent MDOS and GPL manual.  However, it needs work as it isn't current. I believe Andy was in the process of incorporating the latest changes into this at one point.  I may have the word .doc somewhere.
Attached File  MDOS_and_GPL_6.0_Manual.pdf   2.01MB   26 downloads
Edited by InsaneMultitasker, Wed Jul 9, 2014 5:12 PM.
#10 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Wed Jul 9, 2014 5:35 PM
Edit:
attachicon.gifMDOS_and_GPL_6.0_Manual.pdf
I have ABASIC 403/404 on the Hard disk from Tony, but I found a version 405 in an archive file on whtech- so I should replace 404 with that 405 archive (which appears to be complete, rather than a patch)?  I did notice that TEXTLOADer didn't work, which uses assembly, so I wonder if a the new version will fix that.  It would be a pain to have to start TI-Ext. BASIC just to use that - never mind all the other stuff that has assembly on it that I haven't tried yet :).
#11 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jul 9, 2014 5:40 PM
Yes,  405 is the version I modified to correct the parameter passing problems with CALL LINK.   I cannot guarantee TEXTLOADer will work, I can only tell you it is more likely to work in 405 :)
Edit:
Come to think of it, I am not sure that programs with embedded assembly (i.e., produced by SYSTEX) work with ABASIC.  When I fixed the parameter passing problem I was using object code and never went back to testing my systex assembly loader.  Hmmmm....  I'd be interested in your findings.
Edited by InsaneMultitasker, Wed Jul 9, 2014 5:57 PM.
#12 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Wed Jul 9, 2014 6:02 PM
Edit:
Cool, then you'll be happy to know I just tested TEXTLOADER, but disappointed, because it didn't work :(.  On another plus note though, the new version loaded and seems to be working fine (except for TEXTLOAD, of course ;)).
#13 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jul 9, 2014 6:15 PM
PM me with the program and if I have time in the next week or two I'll take a quick look at it.  No promises.
Fortunately, loading XB is also easy with the Geneve.
#14 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Wed Jul 9, 2014 7:11 PM
Send TEXTLOADER or the program I'm trying to load?  The program I'm trying to load is just a trivial test program in DIS/VAR 80 format for TEXTLOADER.  Here is TEXTLOADER on whtech though (in ark form).
Yeah, loading XB isn't much harder than typing 'GPL E:\GRAM\T1\TI-EXB110' at the prompt, but it would save time not having to go back and forth.  Although with 80-columns, ABASIC command line isn't so bad itself for coding.  I could probably TEXTLOAD the first draft and debug in ABASIC as a compromise ;).
#15 OLD CS1 OFFLINE
OLD CS1
    Technomancer
  • 5,921 posts
  • Technology Samurai
Posted Wed Jul 9, 2014 7:56 PM
In the Amiga world, there are a couple of people who have produced ready-to-run installations with the OS and various "must have" tools.  Is there such a thing for the Geneve?  (This was spurred by the talk of utilities and various versions of Myarc BASIC.)
#16 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Wed Jul 9, 2014 8:13 PM
From the documentation:
  This program taps directly into  certain  areas  of  the.  Extended  BASIC  module  and may therefore not work with your particular module.  It does  work  well  with  TI's  Extended BASIC  version 110 and MICROPAL's Extended BASIC version 110.
I don't think you're going to have much luck with this program given ABASIC's itself is built on all-assembly and is built for the Geneve.  :(
#17 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Wed Jul 9, 2014 8:33 PM
Ah well, I'll just use TIXB for that purpose.  Text-loading is a nice way to go since you can write on the PC, then import it to the TI.  Thanks for taking a look at it though, Insane :).
#18 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Sun Jul 27, 2014 12:04 AM
I dug through my paper files today and confirmed I no longer have an ABASIC manual, either given away or lost during my move.  I thought WHT had a copy of the manual, though like others I find it contains only a handful of updates.   It seems Jim's full manual, if there was such a beast, was lost when he passed away.
If you have time, could you check whether or not the manual contains a section (or appendix) covering the ABASIC memory usage in detail?  I fixed the LINK parameter passing last year but am finding some other oddities in the interpreter and legacy programs.  It also appears any XB assembly LINK routines related to file IO, particularly those using PAD RAM (83xx) pointers cannot run given the MDOS IO requirements.
#19 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Sun Jul 27, 2014 5:42 AM
Are we talking about this manual: (first 8 pages)
BTW, I tried tesseract for OCR, see the attached txt file.
#20 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Sun Jul 27, 2014 11:51 AM
That looks like the first 8 pages to an ABASIC manual to me :).
#21 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 2,360 posts
Posted Sun Jul 27, 2014 12:46 PM
Nice PDF scan!  This looks like the right manual to me.  ;)
The OCR would be nice if someone has the time to import Jim's corrections into the full document.   I know that Foxit and others allow you to annotate comments into a PDF but that isn't quite the same as editing the document directly.
#22 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Sun Jul 27, 2014 3:24 PM
OK, if that is the correct document I can carry on with scanning. Will take some hours, but only once.
We should consider converting scanned documents to text in order to make them more useful, searchable etc. I did not know much about tesseract, but it seems to deliver some good results. I also tried that with the scanned Editor/Assembler manual with good results as well. It will take some time to post-process it (checking unrecognized characters, formatting), but this should be worth it.
The question I'm still not quite sure about is the document format. Due to the simple graphics, a plain text may be sufficient. Beyond that I'm favoring LaTeX or OpenDocument, from both we can produce a PDF later, and ODF can also be saved as DOC to be read by MS Word. Or a self-tailored XML language; using an XSLT one could produce multiple formats, also HTML for web pages.
#23 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Sun Jul 27, 2014 5:33 PM
Thank you Michael! :thumbsup:
Edit: I like the idea of using OpenDocument format, since it's so easy to make a pdf from there.
Edited by RobertLM78, Sun Jul 27, 2014 5:43 PM.
#24 mizapf OFFLINE
mizapf
  • 3,506 posts
Posted Tue Jul 29, 2014 5:42 PM
I just uploaded the Advanced Basic manual on WHTech. Use our Geneve home page to get it: http://ftp.whtech.com/info/geneve.html
I scanned the pages with 300dpi, but this would have created a 150 MiB PDF file, so I resized all pages to 150 dpi before creating the PDF. Praised be ImageMagick.
I still retain the 300dpi files; maybe I can do a OCR on them later.
#25 RobertLM78 OFFLINE
RobertLM78
  • 1,055 posts
Posted Tue Jul 29, 2014 7:34 PM
Thank you muchly Michael!
Also tagged with one or more of these keywords: geneve, myarc, XBII, Advanaced BASIC, ABASIC
