Jaguar Custom Game Hard Cases
Custom Game Cases Hard Cases Storage
191 replies to this topic
#26 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Sun Feb 15, 2015 9:13 PM
Say, is it possible to fit the white cardboard cartridge holders from the cardboard boxes into the UGCs? Those are sold separately by B+C for cheap and maybe it would add to a cleaner look inside the case?
I like your thinking but I'm guessing no because it's a pretty tight squeeze in there (especially with the curvature on the jaguar carts.)  You would additionally have to dremel out the existing cart supports to fit the boxes in, which is very labor intensive (i do it for my Jag manual cases, as seen above.)
Anythings possible I suppose..
#27 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Tue Feb 17, 2015 11:35 AM
Here you go good sir, straight from the request forum at TCP
#28 sirlynxalot OFFLINE
sirlynxalot
    Dragonstomper
  • 551 posts
Posted Tue Feb 17, 2015 7:02 PM
Excellent! Thank you very much!
#29 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:06 AM
Hey peeps,
I am going to be uploading the rest of the universal game case inserts that ChrisWR and I collaborated on.  If I don't upload it you can assume it's on The Cover Project.  There should be a cover for just about every cart and CD release on the jaguar up here shortly.
Please, use these for PERSONAL use only.  If I see any of these for sale on fleabay for $10 bucks a pop, i'm going to turn into the creature from The Thing and infiltrate your Antarctic base camp, killing team members slowly and one at a time.
Any instructions needed on how to use these should be available in the thread above.
ENJOY!
#30 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:10 AM
More to follow in the coming days. I am on slow public WiFi at the moment.
#31 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:15 AM
A few more.
#32 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:19 AM
more...more...more (to quote Magenta)
#33 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:22 AM
Total Carnage, Zero 5, B&C Bypass Cart
#34 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:29 AM
Breakout 2000, Worms
#35 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:32 AM
JHL 15, Another World, Brett Hull Hockey
#36 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:35 AM
Soccer Kid, Protector SE
#37 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Fri Sep 4, 2015 11:39 AM
Skyhammer, FYI the Memory Track UGC insert is listed under Jaguar CD on The Cover Project, look under "M"
#38 JaguarBrett OFFLINE
JaguarBrett
    Chopper Commander
  • 232 posts
Posted Fri Sep 4, 2015 1:09 PM
Definitely going to use the Air Cars and Spacewar ones! Appreciate your efforts =)
#39 sirlynxalot OFFLINE
sirlynxalot
    Dragonstomper
  • 551 posts
Posted Fri Sep 4, 2015 2:53 PM
This is great, thanks for sharing!
By the way, I got around to doing the UGC cases and I have some advice for other people going this route:
-UGCs have shrunk in size compared to a few years ago (smaller width), and some people recommend resizing the images from cover project to be about 98% of the size of the image you download. Otherwise, I have found that you really need to cut into the game art to get them to fit in the current size UGCs, and you might cut into part of the back page description, or copyright info, and you will become ocd that things aren't perfect :) At least that's my experience.
-If you use normal weight paper, along the lines of the typical stuff you would print text out on on your pc, the paper wrinkles a little bit on the back. All of my UGCs are slightly convex on the front and concave on the back, and this means that the sleeve is not entirely flat with the back plastic. I notice the cover art for Elansar does not have this problem (it looks flat, despite the concavity of the back plastic) and I think it is because the art was printed on a heavier weight glossy paper that isn't as thin.
-Finally, you need to print out the insert artwork on legal size paper, or at least something larger than 8.5x11.
Edited by sirlynxalot, Fri Sep 4, 2015 2:54 PM.
#40 Pete5125 OFFLINE
Pete5125
    Moonsweeper
  • 434 posts
Posted Fri Sep 4, 2015 5:58 PM
If you want a cheaper route to game cases you can take Sega Genesis, EA Sports Game boxes and cut out some of the tab that holds the genesis cart inside and it makes a great Jaguar Game case with a spot for the manual.
Also if you don't have a copy of the box if you hit print screen under box scans on Atari Age it is the perfect size you just dont get the spine, you can print the back cover again it normaly will work for the spine.
Yours look great though.
#41 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
  • Location:Angers, France, Europe, planet Earth, Solar System, Universe
Posted Sat Nov 21, 2015 8:45 AM
Please find attached the box cover for Joust:
You can find the cartridge label here in the topic Cyrano created for this great port from the ST version: http://atariage.com/...e-dactyl/page-3
#42 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
Posted Sun Nov 22, 2015 1:46 AM
Forget that cover: it is wrong because it comes from the CD cover and shows a Jag CD while it should show the Jaguar on its back.
I have fixed that this morning when I noticed that:
Please find below the corrected cover:
Edited by Felyx, Sun Nov 22, 2015 1:48 AM.
#43 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
Posted Sun Nov 22, 2015 6:12 AM
Below is a box cover for Defender 2000.
Enjoy :)
Edited by Felyx, Sun Nov 22, 2015 6:12 AM.
#44 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
Posted Sun Nov 22, 2015 10:18 AM
Below is a cover for Alice Moms rescue cartridge:
#45 Sapicco OFFLINE
Sapicco
    Dragonstomper
  • 789 posts
Posted Sun Nov 22, 2015 1:58 PM
Is anyone printing boxes for sale? I could use one for space war 2000.
#46 travistouchdown OFFLINE
travistouchdown
  • 4,533 posts
  • Do the math!
Posted Sun Nov 22, 2015 3:59 PM
Felyx, you kick so many asses.  Thank you and I will be in touch.
#47 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
Posted Mon Nov 23, 2015 9:03 AM
I improved the previous covers:
Another World: better contrast and cleaner:
Alice Mom's rescue: better contrast and Jag logos improved
and Alice Mom's Rescue Limited Edition:
#48 Felyx OFFLINE
Felyx
    Dragonstomper
  • 626 posts
Posted Mon Nov 23, 2015 10:25 AM
Forget the previous Alice Mom's Limited Edition and prefer that one:
N.B: I start understanding that I got only one hour for editing a previous message to post improved covers (while on french forum it is 24h :/
Edited by Felyx, Mon Nov 23, 2015 10:50 AM.
#49 Rubio80 OFFLINE
Rubio80
    Star Raider
  • 60 posts
Posted Wed Nov 25, 2015 4:29 AM
Glad to see the Brett Hull Hockey cover I did some years ago is still around. :)
I love that Joust cover, very nice work!!
#50 Sapicco OFFLINE
Sapicco
    Dragonstomper
  • 789 posts
Posted Thu Nov 26, 2015 2:42 PM
Is there really a joust cart on the jag?
Also tagged with one or more of these keywords: Custom Game Cases, Hard Cases, Storage
