Posted Sun Oct 12, 2014 11:02 PM
Posted Tue Oct 14, 2014 6:36 PM
Posted Tue Oct 14, 2014 6:52 PM
Posted Tue Oct 14, 2014 7:02 PM
Not dumb--that was a learning experience. . .many of us would have made a similar mistake. . .
Posted Tue Oct 14, 2014 8:26 PM
3) Remember to push the center button! When you see the numbers on the second row, you'll know
that the disk image is "loaded" and ready to go.
I so dumb
forgot to press enter to select disk
Hey, I overlooked that one too!
Glad you got up up and running!!!!
Posted Sun Nov 2, 2014 7:01 PM
the 80 track mod on the TI FDC is very simple to do, the hardest part is getting the old chips out.
Posted Tue Feb 10, 2015 9:36 AM
Oh yeah, one more question.... CAN YOU TURN OFF THE SOUND?
From the demo's I've seen on YouTube, the sounds it makes during file access would drive me nuts.
Hi,
YES, you can switch sound off (got mine emu running today)
In the HxC-Tool goto Settings, switch sound off (2x),
save new config-file (HXCSDFE.CFG)
and copy it to the root of the SD-Card
(was my first act after install >>8O)
Edited by schmitzi, Tue Feb 10, 2015 9:41 AM.
Posted Tue Feb 10, 2015 10:19 AM
Interestingly enough, in the months since I posted that and received my HxC, I now leave the sound on, just on a low setting.
YOu know, I'm seriously dying to pair the HxC up with the new Myarc Clone in a few months. Rasmus will have to work overtime to write enough game programs to exceed the capacity of one of those images!
Posted Tue Feb 10, 2015 1:28 PM
extremely confirmed!!
Posted Tue Feb 10, 2015 1:55 PM
Hi,
some strategy-questions before mounting my drives
I have some Shugart 455, this external 3.5 BackPack from TexinTreasures,
and many drives more.
I also have MyArc Standard-FloppyCTRL and one MyArc with 80track-mod,
have 6 PEBs, nanoPEB, F18A, about 20 TI-Consoles, some standard TI-Floppy-CTRLs
any many many parts more). Now I am struggling with what to mount where
My very first need is one "Copy-Machine" for converting many real-floppies to HFE.
I think the 80tracker goes to another PEB later, maybe twith HFDC and Geneve a.s.o. ?
(also have Thiery´s IDE-CTRL, but didn´t use all of them yet,
that is coming up next months, step-by-step, because have to learn all of it)
So, I think I pair the HxC on the unmodded MyArc-CTRL with the 5.25 Shugart and the 2.5" in a first step.
And there is no need to do that with the 80tracker, also this format is hard to give away
because only less of the 99ers who have HxC (=.HFE) also will have 80track-mod,
so they can´t use big HFE-image-files. Also my FloppyDisk are also only 90 or 180 KB.
The STD-MyArc herein would be great (?) as sometimes it would be nice just to
boot in XB and to use the CALL DIR(x) and test some proggies....
what is the best thought for the HxC ? DSK1 ?
If I config the HxC to DSK1, is there a way to bypass the LOAD by Extended Basic ?
Something like "Shift-Enter" at startscreen ? Or do I have to "eject" the virtual disk
everytime if want to boot into XB ?
Or is there a big advantage to make the HxC to DSK1, because of all the
tools like DM2K (also have GRAM-Card and some Horizons too).
So I could make the Shugart-5.25 as DSK3, that may be enough for copying
my Disks to HxC/HFE ?
But if I understand right, then I first have to mount the Image with my
Copy-CAT-Tool to startup, and then I have to remount my HxC to an empty
diskimage, then initiate the copy from DSK3/5.25 to DSK1/HFE ?
Do I think to complicate ?
I think, it is recommended the 2.5" external must be DSK2, but I am not sure.
Thanks for any suggestions, system is still dismounted
Ralf
Edited by schmitzi, Tue Feb 10, 2015 1:57 PM.
Posted Tue Feb 10, 2015 2:47 PM
1) If you have the HDX modification, the easiest method by far is to use DSK2PC and just copy all the disks to a DOAD directory on the PC. Once on the PC, use the HxC's BATCH CONVERTER on the directory and all of the DSK files will be instantly converted to HFE format. Then all you have to do is copy them to the SD card. (This is my preferred method.)
2) If you don't have an HDX, make multiple copies of a blank HFE disk (in the format of your choice). Be sure to rename the PC format (HFE) on each one so you can distinguish what is what. You can make an original DSK image with Ti99Dir. Now you can put a diskette in one drive and either copy or backup the original diskette to the selected blank HFE disk.
If you already have a ton of DSK files on your PC or just want to download stuff off the Internet, you can manipulate all of the TI programs with an awesome program called Ti99Dir (I HIGHLY RECOMMEND THAT PROGRAM). Once you get everything setup perfect, the HxC program can convert the DSK image.
If you need an DSDD/80 disk image, you are in luck! Atari age member Sparkdrummer recently posted a couple you can use and manipulate in << THIS MESSAGE >>
Fred Kaal's awesome website << HERE >> has a copy of Ti99Dir that you will need.
Hope this get's you started in the right direction.
Posted Tue Feb 10, 2015 3:48 PM
yes, thanks. I have struggled through ALL this great tools the last 4 months, incl. OmniFlop.
The HDX(S1 with Freds great mod) took me night for night over weeks because of serial cable-issue.
Not running until today (but all other communications over RS232 are running fine,
think depends on the nano but not for sure). So after months of time I gave up.
(see here: https://www.facebook...27536797&type=3 )
So my nano is in cupboard now, OmniFlop works for importing original TI-Floppies
but is not my favorite because I want to do it on the TI
ah yes, naming the blank files I learned while fighting with Omniflop,
but I think there you can see it on the filesize.
I´ve also spent much time on TIDIR, this is best tool I´ve seen around.
Also managed several disks with it on bigger disk/DSK (with bigger format),
and then wrote that with OmniFlop on my PC to TI-format-disk.
This was just for fun, because have to learn and understand it,
and was nice to see ie the TI-Artist and fonts a.s.o running on 1 Disk on the TI
yes, great effort, small gain, but big leraning 4 me
It was about 1984 when I "left" TI, went via PDP11/34 to PC-Systems,
so I have to learn all that stuff that came later.
But this all makes so much fun like in the 80ies
thanks for support
Ralf
Posted Thu Feb 12, 2015 8:18 PM
Hey all,
Here's a set of all blank disk images in both .dsk and .hfe formats, 50 each.
40trk - 90k, 180k, 360k
80trk - 360k, 720k
Hope this helps some just getting the HxC....a great product.
For the new ppl, remember to match the disks with your controller type
Posted Fri Feb 13, 2015 9:37 AM
Hey all,
80trk - 360k, 720k
CF7 - 400k
EDIT: Added CF7 blank disks
Posted Fri Feb 13, 2015 9:49 AM
Fritz,
This is such a great file, I linked to if from my blog entry about the HxC. I wish this file had been around when I first got into it, it would have saved a lot of time!
Posted Fri Feb 13, 2015 9:52 AM
Are you saying a Nano-PEB/CF7 400K format image will work on an HxC that has a DSDD 80 track controller?
Posted Fri Feb 13, 2015 10:13 AM
great work, thanks a lot to Fritz442
Ralf
Posted Fri Feb 13, 2015 11:34 AM
NO I don't think so, they only work on the CF7/Nano's I've seen, I have not seen a CF7 with a DSDD 80t controller
maybe there out there but I haven't seen that.
I only added them to help others that have the CF7 also, to keep them all in one file.
Ralf
NP Ralf, this is the least I can do for all the great help I've received
from our AA friends
Edited by Fritz442, Fri Feb 13, 2015 12:18 PM.
Posted Thu Mar 12, 2015 2:09 PM
The time to buy a Lotharek HxC is almost perfect, according to << THIS NEWS STORY >>.
So in preparation for the new Myarc clone, we might be able to save a few bucks on the device & shipping.
Posted Thu Mar 12, 2015 2:29 PM
I have ordered my 2nd HxC today, for my Geneve-workout
Posted Wed Mar 18, 2015 4:28 PM
Works fine
/EDIT/ some more here: https://www.facebook...27536797&type=3
Edited by schmitzi, Wed Mar 18, 2015 4:30 PM.
Posted Wed Mar 18, 2015 8:30 PM
Works fine
Posted Tue Apr 17, 2018 6:19 PM
Hey all,
80trk - 360k, 720k
CF7 - 400k
Bumping this.
Has anyone made some 320K blank HFE images for use with Myarc controllers? After all, Myarc's DSDD method is different.
I also wonder what happens if you try to format a 360K "standard" disk with a Myarc Controller with DM2K - I'm gathering you'll get errors? DM2K doesn't seem to know about Myarc DSDD format.
Posted Tue Apr 17, 2018 11:59 PM
Posted Wed Apr 18, 2018 2:17 AM
I think he means the 16-sectors format
MyArc-Formats320KB.JPG 356.46KB
4 downloads
(important: no warranty for this orphaned list !! Have to spend more time on it)
Gaming General →
Classic Computing →
TI-99/4A Computers →
![]() New game - StrategoStarted by Vorticon, 7 Feb 2019 ![]() |
Gaming General →
Classic Computing →
TI-99/4A Development →
![]() New Game - StrategoStarted by Vorticon, 7 Feb 2019 ![]() |
Gaming General →
Classic Computing →
![]() IRATA.ONLINE: PLATOTerm99 for TI-99/4A now accessible via TIPIStarted by tschak909, 18 Jan 2019 ![]() |
Atari Systems →
Atari 8-Bit Computers →
Expansions for Atari 800? RAM, ROM, sound, etc.?Started by LambdaCalculus379, 14 Dec 2018 ![]() |
Marketplace →
Buy, Sell, and Trade →
![]() FS: Massive selection of software & paperworkStarted by Pheonix, 1 Dec 2018 ![]() |
