Jaguar Cheats
Saturn
These were originally posted at
http://members.aol.com/TheMage1/jaguar
but the link(s) are long dead. All credit goes to the original team. All I did was preserve it, as it is an invaluable tool :)
*** SPOILERS: Jaguar Cheats & Codes *** 30-Jun-99
(For best results, view this file with a mono-spaced font)
__________________________________________________________________________
| _______ _ ____ _ _ _ ____ |
| |__ ___/ |/ ___\| | | | / | _ \ |
| ||| Atari | | / | | __| | | | / | |_| | |
| ||| /| | |/ / | | |_ | | | |/ / | _ < |
| / | \ | |_| / _ | |__| | |_| / _ | | \\\ |
| \___/_/ |_|\____/ \___/_/ |_|_| \\\ |
| (6) (4) (-) (B) (I) (T) \\\ |
|__________________________________________________________________________|
CONCISE COMPENDIUM OF FREQUENTLY ASKED CODES, MOVES, AND CHEATS (FACMAC)
Rev.: 30-Jun-99
Courtesy of The Mage (Lonnie M. Smith)
E-mail: TheMage1@aol.com
Latest version of this file available via FTP at:
members.aol.com:/TheMage1/jaguar
You can also access it on the web at:
____________________________________________________________________________
NEW THIS ISSUE:
* Super BurnOut Display Version (thanks to Elysee Ade)
CONTENTS:
1. CONVENTIONS USED 20. EVOLUTION: DINO 40. SPACE ACE
2. JAGUAR GENERAL DUDES 41. SUPER BURNOUT
3. ALIEN VS PREDATOR 21. FIGHT FOR LIFE 42. SYNDICATE
4. ATARI KARTS 22. FLASHBACK 43. TEMPEST 2000
5. BALDIES 23. FLIP OUT 44. THEME PARK
6. BATTLEMORPH 24. HIGHLANDER 45. TOWERS II
7. BLUE LIGHTNING 25. HOVER STRIKE 46. TREVOR MCFUR IN THE
8. BRAINDEAD 13 26. IRON SOLDIER CRESCENT GALAXY
9. BREAKOUT 2000 27. IRON SOLDIER 2 47. TROY AIKMAN FOOTBALL
10. BRUTAL SPORTS 28. I-WAR 48. ULTRA VORTEK
FOOTBALL 29. KASUMI NINJA 49. VAL D'ISERE SKIING &
11. BUBSY IN FRACTURED 30. MEMORY TRACK SNOWBOARDING
FURRY TAILS 31. MISSLE COMMAND 3D 50. VID GRID
12. CANNON FODDER 32. MYST 51. VIRTUAL LIGHT
13. CHECKERED FLAG 33. NBA JAM TE MACHINE (VLM)
14. CLUB DRIVE 34. PITFALL: THE MAYAN 52. WHITE MEN CAN'T JUMP
15. CYBERMORPH ADVENTURE 53. WOLFENSTEIN 3D
16. DEFENDER 2000 35. POWER DRIVE RALLY 54. WORLD TOUR RACING
17. DOOM 36. PRIMAL RAGE 55. WORMS
18. DOUBLE DRAGON V 37. RAIDEN 56. ZERO 5
19. DRAGON'S LAIR 38. RAYMAN 57. ZOOL 2
39. RUINER PINBALL
1. CONVENTIONS USED
* A, B, C, X, Y, Z = Firebuttons as marked.
* Li = Left index-finger firebutton.
* Ri = Right index-finger firebutton.
* U/D = Up/Down on joypad (the "D" button).
* L/R = Left/Right on joypad.
* Comma(,) = press the keys in that order like dialing a phone.
* Plus(+) = press and hold the keys at the same time in that order.
* Dash(-) = Slide across and into the keys in that order.
* Slash(/) = press either key.
* Parenthesis = Grouped keys are pressed while pressing other key(s).
* Walkthroughs:
@ = Wait until previous action completed (assumed between scenes).
^ = Continue point within a scene if killed.
* Moves:
* DT = Diagonal direction down & * <Far> moves performed a good
towards opponent. distance from opponent.
* DA = Diagonal direction down & * An at-symbol(@) after the
away from opponent. button means it can be pressed
* UT = Diagonal direction up & repeatedly.
towards opponent. * A carrot(^) after the move name
* UA = Diagonal direction up & means it's a death move.
away from opponent. * P = Punch
* <Charge> means to hold the * K = Kick
direction for at least two * J = Jab
seconds. * L = Light/Low
* <Close> moves performed * M = Medium
standing next to opponent. * H = Hard/High
* <Not close> moves performed * F = Fierce
from 3-4 steps from opponent. * Q = Quick
* <In air> moves are done while * T = Towards opponent.
jumping. * Aw = Away from opponent.
* Pro-Controller buttons map to the standard controller as follows:
* X = 9 * Li = 4
* Y = 8 * Ri = 6
* Z = 7
2. JAGUAR GENERAL
* Remove "PAUSED" Message (doesn't work with all games): 1+3
* Toggle Music on/off (doesn't work with all games): 0
* Customize Spinning Cube (not available with the JagCD):
1) Activation:
* Pause + Option (during Jaguar Logo)
- OR -
* Hold Pause (when the spinning cube appears)
2) Commands:
* Size = U/D
* Spin speed = L/R
* Spin direction = 0
3) Continue startup sequence:
* If holding Pause, release Pause.
* Option, or Pause, or any firebutton, or Reset (# + *)
* Cheats:
* Activate "Hold that Fuji!" (during game play):
(Pause + Option) + (1+3, 2+5+7+9) Predator laugh confirms
* Commands:
* Security Clearance = Raise:Option+6; Lower:Option+9
* Motion Tracker Toggle = Option+8
* Recharge all weapons = Option+1+2+3+4
* Shotgun toggle = Option+1
* Pulse Rifle toggle = Option+2
* Flame Thrower toggle = Option+3
* Smart Gun toggle = Option+4
* Activate "Banana Stops" (*=STar, #=POund) (during game play):
Step 1) Pause,Option,6,1+3
Step 2) B,A,9,A,9,A "BANANA"
Step 3) *,Option,6 "STOPS"
Step 4) #,* "POST"
Step 5) *,Option "STOP"
Step 6) 2,Option "TOP" (Predator laugh confirms)
* Commands (the same as "Hold that Fuji!"; see above). Also:
* Level Select = Option+A (Up), Option+B (Down)
(Up = 5,4,3,2,1, Pred. Ship, Alien Ship, Airducts)
* God mode = Option+5
(Invincible & auto weapons power-up. Must have ammo first)
* Freeze Alien Queen (just outside the Queen's Lair):
Save game, then reload. Queen will be frozen & can be damaged.
She'll die when you unfreeze her by walking through entrance.
* Shoot Predators first (in the Predator ship):
Before collecting the smart gun, use the pulse rifle or shotgun
to shoot around (or at where you know Predator(s) will appear
when you get the smart gun). You'll see the blood, and if you've
used enough ammo, the Predator(s) will die as soon as you
collect the smart gun.
* Shortcut to Alien Ending:
Enter the "Banana Stops" cheat. Make a cocoon and when it is
mature, get your alien killed (don't enable God mode,
obviously). As the screen fades dark & the cocoon is hatching,
press Option+A/B (for level up/down) and the screen will fade to
the Alien Ending.
* Eggs:
* Global Positioning (during game play):
(Pause) + (Option, 1+3, Option) Shotgun sounds confirm
* Details:
* dec(xx,yy) = your X/Y Coordinates "course" position
* hex(aaaa,bbbb) = your X/Y Coordinates "fine" position
* l(01) through l(05) = Sublevels 1 through 5
* l(06) through l(13) = Airducts 1B,2B,3B,3C,4B,4C,5B,5C
* l(14) = Alien Ship
* l(15) = Predator Ship
4. ATARI KARTS
* Cheats:
* Access any Challenge's Miracle Race:
1. Select the Beginner Challenge Miracle Race.
(You must win this race at least once)
2. While camera zooms-in on your kart, press Reset (* + #).
3. Select the Challenge who's Miracle Race you want to play.
4. The Miracle Race for that Challenge will now be highlighted
(don't move it!) and can be played to win the boss kart.
* Miracle Race Track Short-cuts
(directions are from the starting line)
* Beginner : 3 left bends then on the right side.
* Warrior : Immediately to your left.
* Miracle : ??
* Jaguar Aces: 3 left bends then on the right side.
* Eggs:
* Sit and Spin: On the desert race, slowly run over a purple spot
that causes your kart to lose control. When on top of the patch,
turn left or right and press pause twice. The whole world will be
spinning around!
5. BALDIES
* Level Codes:
Green Ice Circus Desert Hell
01:(none) 21:26481912 41:99799799 61:69556532 81:99589435
02:69317691 22:37736169 42:71394421 62:92826938 82:26997667
03:32585431 23:29329995 43:37118763 63:38293232 83:72143164
04:53199313 24:25849779 44:51776684 64:92729513 84:25454616
05:95568176 25:44694221 45:99584621 65:23835728 85:99162722
06:14799741 26:25259781 46:96193782 66:46365977 86:15969299
07:99112932 27:26827251 47:55992751 67:42127597 87:22789619
08:25579427 28:37495714 48:75326691 68:59744212 88:19783692
09:94554648 29:25899273 49:36296862 69:66652545 89:32927721
10:95555366 30:25141462 50:17228223 70:92969395 90:19892933
11:95532656 31:98435959 51:75478824 71:22169481 91:99997799
12:22938689 32:69667792 52:67788234 72:93671736 92:17214394
13:89232323 33:24164317 53:13324585 73:52999329 93:33677118
14:22513979 34:55616442 54:35133199 74:92757849 94:45816776
15:33728582 35:96722219 55:69751568 75:14242694 95:19296584
16:66977534 36:56299991 56:11447799 76:12857259 96:29867193
17:22597714 37:28619972 57:29399112 77:12562827 97:15557992
18:94212475 38:98692371 58:72254579 78:43177495 98:17956326
19:65545266 39:22721793 59:89446554 79:32752899 99:23668296
20:26395999 40:99933281 60:69653555 80:22654141 100:31272228
6. BATTLEMORPH
* Level Codes (enter as "new player"):
2. Carmine: ATDC2 5. Straussen: ATDC5
3. Ferial: ATDC3 6. Pyroxine: ATDC6
4. Pan Alma: ATDC4 7. Cygnus: ATDC7
8. Pernish: ATDC8
* Hidden Bonus Planets:
CLUSTER CLOAKER ON BONUS PLANET BONUS ITEM(S)
1. Zephyr Peramer Dyphor Clip, Ships(2)
2. Carmine Aphelion Adeptus Clip, Ships(2)
" Sanctine Camillari Trees?
3. Ferial Tyran Tehr Brockshear Clip, Ship
" Charnel Kant Liur Ships(3)
4. Pan Alma Shau Yen Tantaul Clip, Ship
5. Straussen (none) (none)
6. Pyroxine Alkelam Isolmin Flash(75%), Ship
" Cyclozone Borazine Flash(75%), Clip, Ship
7. Cygnus Chalnook Brichardii Clip, Ship
8. Pernish Laxer Reiss Ships(7)
* Eggs:
* Comedy Mode:
Enter "A NAME" for a new player. Sound confirms. Play a game.
* Quake Weapon:
Destroy most of the trees on all worlds of the first cluster.
* 2 Extra Ships: Debrief with a score ending with "99"
* 99,958 Bonus Points: Debrief with a score ending with "42"
7. BLUE LIGHTNING
* Cheats:
* Repair (during game play): *
Note, only works in Comedy Mode. See below.
* Eggs:
* Comedy Mode (at the options screen):
0+1+2+4+5+6+7+9. Sound confirms. Play a game.
8. BRAINDEAD 13
* Cheat:
* Replay scene: Pause, Pause
* Walkthrough:
* Hallway: L^, U^, L
* Conservatory: L, R, B, U, L
* Hallway: L^, L
* Red Witch: U, R^, @B, R, R^, R, @D^, R, @U^, B, U, R, R, @B
* Hallway: R
* Vivi: U^, @B, L^
(shave): B, R^, @R
(manicure): U, L, U, R, L, U, L, R^
(facial): B^, @B, L
* Hallway: U^, R
* Blue Witch: U, L^, @B, L, L, L, @D^, L, @U^, B, U, L, L, @B
* Hallway: R
* Conservatory: R, L
* Hallway: R
* Bedroom: D, B, B, B, R
* Library: D, U, R
* Hallway: U
* Garden: R, R^, @U^, L^, L^, L^, L^, @D^, D^, @R^, @U, U
* Statue:
(tiles) L, L, L, L^
(rim) @B, R, B, D^, B, B, R^, R, L, R, @B
(on statue) B, B, @R, @B, B
* Hallway: L
* Library: D, L, B, B, U, U
* Bedroom: D, L, U
* Hallway: L
* Hallway: U
* Moose: R^, B, U, R, R^, L, R, U, B, R^
(obstacle course) D, U, U, D, D, L, R, U^
(tower) @L, R^, @U, L, @R, R
* Hallway: L, U
* Fritz Showdown: B
(1st flight) L, B, B, L^
(2nd flight) B, R, L, R^
(3rd flight) L, B^
(4th flight) @R, B, L, B, R^
(5th flight) @B, L, R, L^, @R, B
* Brain Chamber: L^, R^, R, @D, L, R, D, @B, @R, U, D, B, @D, B, B,
B^, @U
9. BREAKOUT 2000
* Cheats (enter after brick formation before your ball is released):
* Breakthrough ball : 7+8+9+1
* Lightning ball : 7+8+9+2
* Attract ball : 7+8+9+3
* Catch mode on : 7+8+9+4
* 99 balls : 1+3+5
* Skip current level: 1+6+7
* Skip levels set : 1+5+7
* Banish robots when they appear: *+#
10. BRUTAL SPORTS FOOTBALL
* Correct the League Mode Bug (at password screen):
RMVVKL343 333VZ6387
* Start at the 2nd league w/ Mad Dogs (at password screen):
05CWLXSSR W1W08YVWX then enter a different teams name for the last
9 spaces for that name.
11. BUBSY IN FRACTURED FURRY TAILS
* Level Codes:
2 = 392652 5 = 739294 8 = 781367 11 = 673167 14 = 782389
3 = 458227 6 = 184792 9 = 126712 12 = 792323 15 = 672345
4 = 958936 7 = 812615 10 = 236721 13 = 672328
12. CANNON FODDER
* Cheats:
* Regain Weapons (must have at least two men left):
Split off another troop with no grenades or bazookas.
(new troop will have dead troop's weapons)
* Display Map (during game play): # or 0 or *
* Switch groups (during game play): 1, 2, or 3
* More Options (during "Boot Hill"): Press Option to change volume,
button config, screen resolution.
13. CHECKERED FLAG
* Eggs:
* Night-time Racing (at "Weather option") = 8,4,7,3
14. CLUB DRIVE
* Eggs:
* Planet Todd (during World Selection): 4+2, firebutton.
* Drop & Fixed Camera views / Debug (during game play): 8+6
* Atari Building: Enter the pulsating wall inside the mine shaft of
Wild-West World during a single player race.
* The Castle: Enter the first floor fireplace of Jerome's World
during a single player race. Must have fast car option turned on.
15. CYBERMORPH
* Cheats:
* Unlimited Ammo (at Control Options): 1+3+5+7+8+9, firebutton.
* Eggs:
* Play the Demo: press 1, 2, or 3 to use its Super Weapon
* Boss Rampage: Enter 1328 in a new game and play sectors 2 through
4. Then enter 1008 and play & finish Sector 1. You'll now fight the
sector 1,2,3,& 4 bosses consecutively.
* Level Codes:
Sector 1 = 1008 Sector 4 = 9226
Sector 2 = 1328 Sector 5 = 3444
Sector 3 = 9325 Unknown = 6009 (found on planet Codex)
(Bonus power-up planet = lower right)
16. DEFENDER 2000
* Eggs:
* Plazma Pong:
Enter "Nolan" in any high score table to get an extra game
* Flossie's Revenge (at Defender Plus high score table):
Enter "Ovine". Start Defender Plus by pressing A (instead of B).
* Warp Enable (at Defender 2000 high score table):
Enter "Beest". During Defender 2000, press 3 to warp to the next
level, and press 6 to warp to the bonus round.
* Super Bonus (during Defender 2000):
Catch a falling human as the wave is ending.
17. DOOM
* Cheats (during game play):
* God Mode = Pause, * + Pause
* Very Happy Ammo Mode = Pause, # + Pause
(all keys, weapons, ammo, armor, and health)
* Level Select (during game play):
* Pause, [level #] + Pause (A button adds 10, B adds 20)
18. DOUBLE DRAGON V
* Hidden Moves: Some of these were already listed in the manual.
LP, MP, HP, LK, MK, & HK refer to your button settings/config.
Overkills must be performed when both characters are on the ground,
and the attack listed by the opponents name must be used. The attack
must do enough damage to win the match in order for you to see the
overkill. Overkill does not work in easy mode.
* Billy Lee
* Throw : MP
* Dragon Snake: D, DA, A&P
* Dragon Slice: T, DT, D&P
* Dragon Shock: hold A, T&P
* Dragon Slide: T, T&P
* Overkill : Standing HP
* Jimmy Lee
* Throw : MP
* Dragon Fire : Hold A, T&P
* Overkill : Standing HK
* Jawbreaker
* Swallow : T, T&MK
* Bite and Toss : T, T&HK
* Flying Headbutt: T, T&P
* Loogie Hock : hold A, T&P
* Breath Wave : D, DA, A&P
* Ground Spark : T, DT, D&K
* Bones
* Throw : MP
* Eyebeam : D, DA, A&P
* Skull Toss : Hold A, T&P
* Gun Shot : T, DT, D&K
* Long Arm Lash : T, T&MP
* Super Headbutt: T, T&MK
* Overkill : Standing MP
* Sickle
* Throw : MP
* Energy Blade : D, DT, T&P
* Whirlwind Slice : Hold A, T&P
* Rolling Sawblade: D, DA, A&P
* Flying Sawblade : T, DT, D&K
* Overkill : Standing MK
* Countdown
* Throw : MK
* Laser Bolt : Hold A, T&P
* Knucklespin Twistkick: Hold A, T&K
* Jet Flare : D, DA, A&P
* Missile Shot : T, DT, D&K
* Rocket Dive : T, T&K
* Overkill : Standing LP
* Sekka
* Throw : MP
* Flying Claw Slam : Hold A, T&K
* Claw Roll Attack : D, DA, A&P
* Inverted Spinkick : D, DA, A&K
* Blender from Above : D, D&LK
* Clawvault Boomerang Kick: T, T&HK
* Head Bounce Kick : In Mid-Air, D&HK
* Dominique
* Point-Blank Throw : MP
* Short Distance Throw: HP
* Hold and Bite : MK
* Ponytail Beam : T, DT, D&K
* Swoop Hurricane : D, DA, A&K
* Highheel Knife Slide: D, D&LK
* Overkill : Standing Long-Range MP
* Shadow Master
* Overkill: Standing HK
19. DRAGON'S LAIR
* Cheat:
20. EVOLUTION: DINO DUDES
* Cheats:
* Infinite Time (at password screen):
<AC> "TIME STANDS" <OK> <AC> "STILL FOREVER" <OK>
* Infinite Dudes (at password screen):
<AC> "ONCE DEAD" <OK> <AC> "TWICE BORN" <OK>
* Level Codes:
1:ROUND ONE 21:CANVAS SAIL 41:LARGE MUG 61:PINK MARBLE
2:LIBERTY ISLAND22:GOLDEN ERA 42:HALF A BET 62:ROLLING PLAINS
3:STONE WALL 23:WIDE SEAT 43:SING SING 63:ICON DRIVE
4:G MEN 24:BAD KARMA 44:BROWN COW 64:CARROT TOP
5:WILD WEST 25:CRASH BARRIER 45:IRON HORSE 65:QUILL PEN
6:LEMON ENTRY 26:LIME GLASS 46:WHITE MALE 66:TUTTI FRUTTI
7:WAGON WHEEL 27:SURFS UP 47:BOX OFFICE 67:PUBLIC ENEMY
8:OIL DRUM 28:PENAL COLONY 48:CORNY FUR 68:BIG END
9:MOON ORBIT 29:RELIEF ART 49:ATOM CAT 69:TAN PARLOR
10:HARD ROCK 30:TRIBAL DANCE 50:FREE WHEELING 70:NEVER READY
11:TRIP AND FALL 31:SODA FOUNTAIN 51:BUSH FIRE 71:SHARK FANGS
12:ALARM CLOCK 32:PARKING SPACE 52:CAR BRA 72:STOOL PIGEON
13:BIG COUNTRY 33:PIZZA DUDE 53:PORK PIES 73:PROM QUEEN
14:HOG TIED 34:CROW FLIES 54:STORMY WEATHER 74:RED LETTER
15:CAN CAN 35:TILED ROOF 55:STAGE COACH 75:CORN PONE
16:CUTE MOUSE 36:SLATE MISSING 56:QUAY BORED 76:BILGE PUMP
17:SPARK PLUG 37:OPENING TIME 57:SPLASH DOWN 77:SIXTY FOUR BIT
18:PONY EXPRESS 38:INNER PEACE 58:BUG POLITICS 78:HALF MAST
19:PADDED CELL 39:BAD DOG 59:SHAKE SPEAR 79:WALKING BOSS
20:LOG PLUME 40:SOUR BELLY 60:SCHOOL ZONE 80:SPACE TO LET
21. FIGHT FOR LIFE
* Cheats (press Option at character select screen to enter passwords):
* JAGUARTIME (Demo mode)
* IWANTPOWER (All special & signature moves)
* GIVEMETIME (Kara)
* GIVEMEMOVE (Kara)
* GIVEMEPOWR (Mr. G)
* GIVEMEXXXX (Pog)
* IWANTDRUGS (Lun)
* IWANTPINKY (Pog)
* GIVEMEPOWn (To choose Junior as a character. Note small "n")
* cWANTREFER (Jenny) all moves except signature moves
* VWANTSPEED (Mr. G) all moves except signature move.
* LOVEJUNIOR Play Junior vs. Junior
* Morph as Junior: C + (U, L, D)
* Short Junior Battle: Defeat Junior the second time with a ring-out.
When the next fight begins, pause & rewind to before the
electrocution.
22. FLASHBACK
* Level Codes: Easy Medium Expert
1. "Planet Titan" = LETY RISING RODEO
2. "New Washington = BOXER ORDO BINGO
3. "Death Tower" = EAGLE PROFIT LSTED
4. "Earth" = STKTON PRIZE DARTS
5. "Secret Base" = TICKET SKAEPS BUDDY
6. "Morph Planet I" = SUITE HITTER MUSIC
7. "Morph Planet II" = PHASER TWIN SHOGI
23. FLIP OUT
(Note: these may take several attempts till you get a confirmation)
* Cheats:
* Win Current Match (enter before play starts) : 779889#
* All Levels Activated (enter at Map screen) : 7798899
* Eggs:
* Programmers' Heads (enter before play starts): 14283722
(at any level with the three "cheerleader" aliens)
24. HIGHLANDER
* Invulnerable : 4,1,3,3,5,6,4
* Rogues Gallery : 2,1,8,8,3,5,3,8,9
* All Items : 9,4,4,6,9,2,1,3
* Get the Chicken God and activate the Teleport:
Place flower in the vase in the Temple of the Chicken God hidden
in the canyon behind the large tall rock with sniper on top.
25. HOVER STRIKE
(Cartridge & CD):
* Cheats (at Mission Select Screen, unless otherwise noted):
* Unlimited Weapons/Energy/Shields : D+3+4+6+7 (tone confirms)
* Extra Lives (limit = 9) : 3+6+9+# " "
* Level Skip : 2+4+6+7+8+9 " "
* Toggle Day/Night (during game play): U+A+B+C+7
* Eggs (at Mission Select Screen, unless otherwise noted):
* Change Globe Speed/Direction : 4+6
* Change Globe Size (CD only) : U/D
* Alternate External Monitor Frame : R+C+1+4+5
* Alternate Ground Texture (during game play) : U+A+B+C+3
* Debug Mode (during game play) : U+A+B+C+6
* Change Music Tracks (during game play) : U+A+B+C+0 (Cart.only)
* Comedy "Ammo Depleted" Cue : C+4+8 (Cart. only)
* Enable Secret Bonus Missions (at Mission Select Screen):
Level 1 = U+2+3+6 Level 3 = R+3+5+6
Level 2 = D+2+6+7+8 Level 4 = U+2+5+8 Level 5 = R+2+4+5+6
26. IRON SOLDIER
* Cheats (at Options Screen, unless otherwise noted):
* All Weapons & Levels: 3,7,6,6,8,2,4,2 (border flash confirms)
* Unlimited Ammo : 2,7,2,8,3,7 ("CRATES" on phone pad)
* Extra fast rotation : A+C while turning (during game play)
* Repair : Hit yourself with a Cruise Missile
(only during the low energy warning!)
* Mission Pass/Fail : 2,8,8,8,6,6,7,7,3,7,7
(then during game play press: * = Fail, # = Pass)
* Eggs (at Options Screen, unless otherwise noted):
* Insane Difficulty : 6,8,2,4 ("OUCH" on phone pad)
* Display Mission Stats: 8 (during game play)
* Single-Frame Advance : Pause, 1 or 3 (during game play)
* Swivel Mech View : At mech configuration screen, select add or
remove weapon then press 1 or 2 to swivel mech.
* Scroll Title Screen : At "Iron Soldier" logo, use joypad to
manually scroll screen up or down.
27. IRON SOLDIER 2
* All Weapons & Levels : 5,2,6,2,0,4,8,1
* Unlimited Ammo : 1,4,8,8,2,5,0,2
* Invulnerable : 8,3,0,5,5,7,2,6
* Mission Pass/Fail : 3,4,4,9,5,2,2,0,7,1,6
(then during game play press: * = "Game Over", 0 = "Failed",
# = "Completed")
* All of the above : 9,7,0,0,2,3,8,6,6,5,4,1
* Satyr War Walker : 7,2,8,9,7,6,6 ("SATYR ON" on phone pad)
* Instant Demo : Press Option on any menu screen.
* Endgame Sequence : 7,2,4,4,9,8,0,1, (then select "Start Game)
* Quick Exit from mech configuration screen: A
28. I-WAR
* Easter Eggs:
* Expanded Options Menu: 2+4+6+8 from the Main Menu. Then select
Options. This gives two more options:
* Level-codes. Use this to enter the codes listed below.
* Texture-mapping Toggle. Unfortunately, this doesn't work in the
final release of the game.
* Level Codes:
1: 3495823456 7: 6315678561 13: 8563457634 19: 2359834235
2: 7983456383 8: 1238261234 14: 8278634589 20: 7892597223
3: 5282259782 9: 3982612389 15: 5785623456 21: 7891237892
4: 9452382725 10: 4826178962 16: 5234545214
5: 7357286586 11: 2397856123 17: 9238471472
6: 3985615345 12: 3482623457 18: 8957235957
29. KASUMI NINJA
* Eggs:
(To enable modes, a gore code must've already been entered.) At
options screen, select "change code". On controller #2 press and hold
A+C then on controller #1 enter:
* Character vs. Same Character mode: 6,2,1,5,4,4 ("Ha!")
* "Sensible Fighter" #1: 7,4,3,8,7,1 ("Swish")
* "Sensible Fighter" #2: 8,9,9,2,4,4
* Play as Gyaku: 3,7,4,9,6,1 (Vs. mode only; Gyaku replace Senzo &
Habaki)
* Reset Gore/Parental Lockout: 5,2,4,6,4,8
* Start with Key to Temple: 6,3,7,4,0,4
* Self-Test Mode: 9,3,1,4,2,7, *+#, B (press firebutton to skip to
next player/background combination)
* Fight the Gyaku Demon for a different ending:
In Hard or Ninja-God mode, beat but don't finish Gyaku
* Alaric, King Of The Goths
* Dynamite : C + (D-DA-Aw-UA-U)
* Hammer Smash : C + (T, U) <close>
* Knee to crotch: K + T <close>
* Lunging Punch : P + T
* Power Slide : C + (Aw-DA-D-DT-T)
* Throw : K + Aw <close>
* Death Move^ : C + (T, Aw, T, K) <close>
* Angus Mcgreggor: The Scottish Brawler
* Caber Toss : C + (D, U) <close>
* Fireball : C + (Aw-UA-U-UT, T)
* Headbutt : C + (D, T) <close>
* Throw : P + Aw <close>
* Death Move^ : C + (T, Aw, D) <close>
* Chagi: The Kickboxer
* Elbow to head : P + T <close>
* Fireball : C + (Aw, T, T)
* Knee to crotch: C + (T, K + T) <close>
* Super Kick : C + (Aw, U)
* Death Move^ : C + (T, Aw, T, P) <close>
* Danja, The Urban Vigilante
* Bolas : C + (Aw, Aw, Aw, T)
* Teleport : C + (D, U, U)
* Death Move^ : C + (Aw, U, Aw) <far>
or C + (U, U, Aw)
* Gyaku, The Demon:
* Earthquake : B
* Shake & Toss : B <close>
* Uppercut : A
* Fire Breath : T + A
* Slam & Taunt : B + Aw
* Jump Kick : Jump, B
* Head Rip : C+(circle D-pad clockwise twice)
* Habaki, Ninja Twin
* Fireball : C + (Aw-DA-D-DT-T)
* Teleport : C + (U, U)
* Whirlwind Kick: C + (Aw, Aw, T, T)
* Death Move^ : C + (Aw, U) <close>
* Pakawa, The Comanche Chief
* Ground Stomp : C + (Aw, U, U)
* Headbutt : C + (T, T, T) <close>
* Hunting Knife : C + (Aw-DA-D-DT-T)
* Lunge High : P + Aw
* Lunge Low : P + T
* Death Move^ : C + (T-DT-D-DA-Aw) <close>
or C + (T, D, T, Aw)
* Senzo, Ninja Twin
* Death Move^ : C + (U, D) <close>
* Thundra, The Amazon Queen
* Jungle Lunge : C + (Aw, T, T) <far>
* Jungle Strike : C + (T, T, T) <close>
* Teleport : C + (D, U)
* Death Move^ : C + (U, T, U, T) <far>
or C + (U, U, T)
30. MEMORY TRACK
* Access Memory Track Manager (for those that didn't get or lost the
instruction card): Hold Option while turning on Jaguar.
* Commands: (a couple of these were already listed in the 'manual')
* Select files : U/D
* Delete selected file : A,B,C
* Type of Sort (Name or Size) : Option
* Type of Sort and save settings : Option+1 / Option+3
* Change selected file (name & size): Option+7+9
* Erase all files : Option+*+#
* Self-test : Option+*+0+#
* Exit : *+#
* Virtual Mode Stage Select (during game play):
* Stage 1: Pause, 1+9+C+Pause
* Stage 2: Pause, 2+9+C+Pause
* Stage 3: Pause, 3+9+C+Pause
* Ending : Pause, 4+9+C+Pause
32. MYST
* Passwords (press Option during game play):
* All Places of Protection Open:
hold: B B B B C C B B A B B A B C B A A A B C
+ : 5 5 8 7 2 7 0 0 1 7 # 6 5 6 3 0 3 7 5 7
* All Red/Blue Pages and White Page Collected:
hold: A C A A B C C B C B A A B B B C C B B A
+ : 5 1 5 4 # # 7 0 7 5 3 4 2 2 3 # 2 6 7 *
* Eggs:
* "Atari" Library: Enter May 22, 1970 6:30am in the planetarium. The
immediate front of the (still functioning) library will now be the
Atari building. Click up to see the Myst crew on the balcony.
33. NBA JAM TE
* Cheats & Eggs (enter at "Tonight's Matchup" screen):
3 Point Pup : UDDLLRU Push Other Pup: DLRULLLLAB
32X Doom Mode : ABCCBAABCCBA Push Pup : BRADARB
Baby Mode : BABUDLR Quick Hands : LRABRL
Big Heads : UCA Shot % On : DUDBU
CD Mode : CDCDCDCDCD Shrunken Heads: UUUBCAAAAAA
Dunks Pup : RLBABA Slippery Court: BADABRRRRR
Fire Powerup : DRAABL Small Ball : RRRRRRBBB
Flame Game : ALLDRAABBL Smurf Game : ABCDDDDDDD
Goaltender : RUDDRU Speed Pup : UUDDLRLLBA
High Shots : ULLDRUABAAAD Strong Men : RULRBDA
Offense Pup : AUBDBLR Teleport Pass : DRRAADLLRB
Push Both Pup : DUDULLLLAA Turbo Powerup : BBDDAAUL
* Team Substitutions (at Player Substitution Screen): D+C+A
* Get Extended Roster (as Select Screen appears) : 1+5+9
* Defeated 26 teams (as Select Screen appears) : 2+4+6
* Defeated 27 teams (as Select Screen appears) : 4+7+8
* Story (at attract mode roster) : L,1,4,6,9 from Pad 0
* Adisak Attack : Extended Roster + Baby Mode. Wait for the Coaching
Tips.
* Hidden Characters: Tournament mode should be off. Enter at the
initials screen. Each initial must be entered with a "code", which is
Option + the listed button. The N-button is any button with or without
Option; i.e., to play as Hugo, enter "H" with Option+A, "G" with
Option+C, then "O" with A, B, or C. '[' = space.
CHARACTER INI CODE CHARACTER INI CODE
Acclaim's Air Dog AIR BNC HVS Damion DJD ABC
Acclaim's Alex XYZ ABB HVS Harold HAM ANA
Acclaim's Kabuki DAN ABN HVS Kerry KJG BBN
Acclaim's Weasel RAY NAB HVS Morty K[M CCC
Beastie Boys (AdRock) ADR BCN Jazzy Jeff JAZ AAC
Beastie Boys (MCA) MCA NBB L Pacey PAY NNC
Beastie Boys (Mike D) MKD CNC NBA Carol Blazekowski BLZ CNC
Bull's Mascot Benny BNY CNB NBA Larry Bird BRD ACA
Chambers (Kristine) KC[ NAN Prince Charles ROY NAB
Clinton (Bill) CIC BNA Rivett (Jamie) RJR CAN
Clinton (Hillary) HC[ NBN Rosen (Shawn) SR[ NNA
Correll CRL CAN Rosenfield (Seth) SET NAB
Di Vita (Sal) SAL NCA Sun's Mascot Gorilla GOR BBN
Fresh Prince (Will) WIL NBC Theinvanich THE CAB
Gelber (Phil) FIL BAB Thomas (Frank) SOX ANB
Gunter GUN CCA Thomason (Faran) FAR ANN
Heavy D HVY BNA Tramiel (Leonard) LAT NCB
Hornets' Mascot Hugo HGO ACN Turmell (Mark) MJT ANA
HVS Adisak ALP CBA Wanat WAN BNB
HVS Bob Ganofsky RBG AAA Wolf's Mascot Crunch CRN NBA
34. PITFALL: THE MAYAN ADVENTURE
* Eggs:
* Classic 2600 Pitfall:
1. At the main menu, select "Info", press the C button 26 times,
then press Down.
2. Or at the start of the "Copan" level, get to the very top
platform, then do a running jump to the left to land on the
ledge with the 2600 version scorpion. Enter the door to a
ledge with another scorpion, a lock, and silver bar. Go left
to hit the wall, jump up & down till catapulted in the air.
Go right while in the air and land in a small room with a
colorful vortex. Enter the vortex.
* Cheats:
* Freeze/Pause your opponent : 6
* Un-freeze/un-pause opponent : 9
* Eggs:
* Change car color (at the car purchase screen): U/D
36. PRIMAL RAGE
* Cheats:
* Activate Cheat Menu (during opening "Jungle Scene"):
L,L,R,R,L,L,R,R,L,L,R,R
(Note: these have to be done very quickly and it may take several
attempts till you get the new "Cheat" item on the main menu.)
* Eggs:
* Alternate character colors (at character select screen):
* Original Recipe = (HQ)
* Old Alternate = (HP) or (HQ + HF)
* Weird #1 = (HQ + LQ)
* Weird #2 = (HQ + LF)
HQ, HF, HP, LQ, LF, & LP refer to your button settings/config.
* Armadon
* Bed-0-nails : (HF+LQ)+(D,U)
* Iron Maiden : (HF+LQ)+(Aw-U-T)<close>
* Mega Charge : (HQ+LQ)+(Aw-D-T)
* The Gut Gouger : (HP+LQ)+(T,Aw)
* Hornication Uppercut: (HP+LQ)+(DT-T-UT)<close>
* Spinning Death : (HQ+LF)+(Aw,T-D)
or (HQ+LF)+(T-D-Aw)
* Flying Spikes : (HF+LF)+(Aw-U)
* Gut Fling^ : (HP+LQ)+(D,D,D,D,U)
* Meditation^ : (HP+LP)+(T,D,Aw,T,T)
* The Impaler^ : (HP+LP)+(D,Aw,U,D)
* Chomp a Human : (HP+LP)+(U-T)
* Blizzard
* Short Mega Punch : (HQ+LQ)+(Aw,T)
* Quick Mega Punch : (HP+LP)+(Aw,T)
* Long Mega Punch : (HF+LF)+(Aw,T)
* Fake Mega Punch : (HQ+LQ)+(D,U)
* Freeze Breath : (HP+LF)+(Aw,T)
* Ice Geyser : (HP+LF)+(D,U)<close>
* Punching Bag : (HQ+LF)+(T-D-Aw-U), HQ@
then for wind-up: HF/LQ/LF
* Air Throw : <in air> (HF+LQ)
* Throw : (HF+LQ)+(T-D-Aw-U)
* Brain Bash^ : (HP+LF)+(D,D-Aw-U-T)
* To-Da-Moon^ : (HP+LP)+(D,D,D,D,U)
* Redemption^ : (HP+LP)+(D,T,U,D,U)
* Chomp a Human : (HP+LP)+(Aw-U-T-D)
* Chaos
* Grab-'n'-Throw : (HF+LF)+(T,Aw) <close>
* Slow Power Puke : (HF+LQ)+(U-T)
* Fast Power Puke : (HQ+LF)+(U-T)
* Fart of Fury : (HF+LQ)+(D-T-U-A)
* Ground Shaker : (HF+LQ)+(Aw,AU,AD)
* Flying Butt Slam : (HF+LF)+(D-T-U-UT-DT) <close>
* Battering Ram : (HQ+LQ)+(T,T)
* Golden Shower^ : (HQ+LQ)+(D,D)-(HP+LP)+(Aw,T,Aw,T)
* Cannonball^ : (HP+LP)+(DA,UT-DT-DA)
* The Churl^ : (HP+LP)+(T,T,T,Aw,Aw,Aw)
* Chop a Human : (HP+LP)+(T-D-Aw)
* Diablo
* Slow Fireball : (HF+LF)+(D-T)
* Fast Fireball : (HQ+LQ)+(D-T)
* Torch : (HQ+LQ)+(U-T)
* Hot Foot : (HF+LF)+(UA,DT) <close>
* Mega Lunge : (HQ+LF)+(Aw-D-T)
* The Pulverizer : (HQ+LF)+(U-T-D)
* Infernal Flash : (HF+LP)+(U)
* Incinerator^ : (HP+LP)+(UA-D-DT)
* Fireball^ : (HF+LP)+(T,T,T,T,T)
* Infernal^ : (HQ+LP)+(U,D,U,D,D)
* Chomp a Human : (HP+LP)+(D,U,D)
* Sauron
* Primal Scream : (HQ+LQ)+(D,U) <close>
* Earthquake Stomp : (HP+LF)+(U,D)
* The Cranium Crusher : (HQ+LF)+(D,U) <close>
* Leaping Bone Bash : (HF+LQ)+(D,U,D)
* Stun Roar : (HQ+LQ)+(Aw,T)
* Air Throw : <in air> (HF+LF)
* Neck Throw : (HF+LF)+(T+Aw) <close>
* Carnage^ : (HP+LP)+(Aw,T,Aw,T,Aw)
* Flesh Eating^ : (HQ+LQ)+(D,D)-(HP+LP)+(U,U)
* Grape Crusher^ : (HP+LP)+(U,D,U,D,D)
* Chomp a Human : (HP+LP)+(D,D,U)
* Talon
* Brain Basher : (HF+LQ)+(Aw-U-T)
* Pounce & Flip : (HF+LQ)+(T-D-T)
* Frantic Fury : (HQ+LF)+(D-T)
* The Slasher : (HQ+LP)+(D-T) <close>
* The Face Ripper : (HF+LF)+(D-T)
* Jugular Bite : (HF+LF)+(Aw,T) <in combo?>
* Run Forward/Back : (HQ+LQ)+(T/Aw)
* Heart Wrenching^ : (HQ+LP)+(T-D-Aw-U)
* Shredder^ : (HQ+LF)+(T-D-Aw-U)
* Stampede^ : (HP+LP)+(T,Aw,U,D)
* Chomp a Human : (HP+LP)+(T-D-Aw)
* Vertigo
* Slow Venom Spit : (HF+LF)+(T,T)
* Fast Venom Spit : (HQ+LQ)+(T,T)
* Voodoo Spell : (HF+LQ)+(Aw,Aw) <close>
* Ground Teleport : (HF+LF)+(D,D)
* Air Teleport : (HF+LF)+(D,U)
* Come Slither : (HQ+LQ)+(Aw,Aw) <not close>
* Scorpion Sting : (HF+LQ)+(T,T) <close>
* Petrify^ : (HF+LF)+(Aw,Aw,Aw)-(HP+LP)+(T,T)
* Shrink & Eat^ : (HF+LF)+(Aw,Aw,Aw)-(HP+LP)+(D,U)
* La Vache Qui Rit^ : (HP+LP)+(Aw,Aw,Aw,D,T)
* Chomp a Human : (HP+LP)+(D-T-U)
37. RAIDEN
* Cheats:
* Infinite Lives and Bombs (at first boss):
1+4+7+3+6+9+Option ("Extra ship" sound confirms)
38. RAYMAN
* Cheats (entered only at "hands assembly" intro sequence):
* All powers & all maps = 1,3,5,7,9
* 50 lives = 5,1,5,2,5,3
* For both cheats, enter one code, wait until the demo game, press
any number, then enter the other code at "assembly" intro.
* Eggs (entered only at "hands assembly" intro sequence):
* Credits screen = 2,5,5,2
* Rayman "Breakout" game = 1,3,6,4
(gives unlimited continues, upon winning)
* Sound effects toggle = 8 (during game play)
* Ting Loop: keep going back through quick & easy levels (such as
Anguish Lagoon) for more tings & extra lives.
* Rayman "Razzberry" = press & hold Option (during game play)
("can be used to scare away the Scavengers in the Dream Forest
world - although it's probably quicker to just punch them.")
* Various dedications:
0,0,7,* 1,5,9,# 2,2,0,4,7,3 3,4,4,7,0
0,1,0,2,7,1 1,5,9,* 2,2,7,1 4,5,6,8
1,2,3,0 1,5,9,0 2,7,2,6,9 9,3,1,0,0
1,2,4,5,7,8 2,1,1,1,6 3,4,0,8,0 9,6,2,7,2
39. RUINER PINBALL
* Cheats:
* To continue game with the same Defcon (in Ruiner) or same spells
cast (in Tower) press at the "Game Over" sequence: 7 or 9
40. SPACE ACE
* Cheat:
41. SUPER BURNOUT
* Cheats:
* Turbo Speed (at title screen): 1,9,6,7,2 (musical beep)
(Note: Automatic transmission option must be active. When bike's
speed reaches 175mph, turbo accelerate by pressing C or the
firebutton configured for "nothing". Top speed is 343mph and speed
records are not acknowledged or saved.)
* "The Punisher" bike (at title screen): 2,1,7,9,4 (musical beep)
(Note: "It's a high acceleration, high grip, fast bike. You can
toast all previous lap records especially with the turbo. It's
basically just the best bike!!")
* Eggs:
* Display Version Number: A+B+C while turning on Jaguar
42. SYNDICATE
* Cheats (enter as a company name):
* All missions, weapons, money: "TO THE TOP"
* For $100 million: "ROB A BANK", then use your own company name
* Play any Mission: "NUK THEM"
* Reload all weapons for free: save game then reload game.
* Eggs:
* Speed up game clock (20X): "WATCH THE CLOCK"
43. TEMPEST 2000
* Cheats:
* Activation (at main menu) = 1+4+7+A ("Excellent")
* Commands (during game play):
* Skip to Next Level = Option ("Outta Here")
* Enable Warp Bonus Round = 6 ("Warp Enabled")
* Eggs:
* Enable Rotary Controller (at Game Option menu):
Press Pause on both controllers ("Excellent")
* Web Rotation (during Web Select screen):
* U/D = Web level
* L/R = Rotate toggle
* Invisible Web:
Start any Tempest Plus game. Hold down Option (cheats must be
active) until you get to the rainbow levels. The web will be
invisible during the rainbow levels only.
* Pause Bug:
At the end of the Bacon/Jupiter River bonus round, press Pause
just as it switches back to the main game (after approximately
two & a half pulses of the "Excellent!" graphic).
* Secret Sheep:
At the first "Jupiter" warp level, press pause, select music
volume, and wait. Late in the track, you'll hear Flossie and the
other sheep engaged in conversation.
44. THEME PARK
* Cheats:
* All shops & rides:
Sink all your money into shops research, then wait until April,
two years later.
* Low Cost Super-ride:
When laying a track ride, first do the world's smallest track
(something like this:)
OOOOO
O O
OOOOO
&& <--Gate
Then open it and immediately close it again. You can edit it now
and make it huge and you'll only be charged for the first, small
ride. One disadvantage: You will not win the "Biggest, tallest
etc." ride of the year come awards time. Depending on how long you
want to run your park, it may be better NOT to do this.
* Eggs:
* Adjust Screen Position (at any time): Option + L/R
45. TOWERS II
* Eggs:
* Change screen-size: Pause, C + (L/R)
* Center screen : Pause, C + (U/D)
* Secret room: Enter the Test of Magic area (reached from the library
on level 3). At the red square of carpet with two candles use the
levitation spell to see the secret room.
* Cheats:
* God Mode: Pause, 3+7, 1+9
46. TREVOR MCFUR IN THE CRESCENT GALAXY
* Eggs:
* High Score Bug: Get a score of several million and finish the game.
An easy way of doing that is to activate the cheats, halt the
background at a bunker and 'park' your ship on the bunker to
receive tons of power-ups and points. When you get a score of
several million, and finish the game the number 029 will appear
(inexplicably?) in the top left corner of the title screen.
* Cheats:
* Activation (at title screen):
1,1,9,3 (No confirmation) (11/93 = "Trevor's Birthday")
* Commands (use controller #2 during game play):
A = Speed up foreground scrolling
B = Slow down foreground scrolling
C = Fire special weapon without depleting inventory
1 = Power up gun
2 = Cycle through bomb power-ups
3 = Mark other moons as completed
4 = Toggle ship invincibility
0 = Cycle through sound effects
* = Play selected sound effect
L/R = Background scrolling speed
Option = Skip to next stage
* Cheats:
* Score 2 extra touchdowns:
After you score a touchdown, press Option and call a time-out.
You get 6 points and the ball at the 1 yard line. Then repeat.
You can score up to 3 touchdowns per down (18 points).
48. ULTRA VORTEK
* Cheats (at options screen):
* Uppercut Annihilations (during "Annihilation Time"):
Uppercut opponent (D+Punch). Works with any character only on
the "Stoned Poseidon", "Hell's Kitchen", or "Temple of the
Vortek" stages.
* Anvil Annihilations (during "Inner City Chaos Stage" only):
Do this far from opponent so you don't get crushed by the anvil
that drops from the sky. D, D, D, then:
* A (for Lucius, Dreadloc, and Skullcrusher)
* B (for Volcana and Grok)
* C (for Buzzsaw and Mercury).
* Eggs:
* Enable speed selector option (at title screen):
1+5+9 ("fight" confirms)
(can select "normal" or "turbo" speed)
* Hidden Backgrounds (during background select screen):
* Subway Passage: *
* Hidden Palace : #
* Carbon: Must be on Hard or Killer level, one-player mode,
"Earthquake Zone" stage, win a double perfect. Carbon will be on
"Subway Passage" stage. Easy way to get a double perfect in
"Earthquake Zone": at beginning of game, beat the first opponent
then lose & continue for the others until "Earthquake Zone",
then get in one hit and block until the timer runs out.
* Enable voice modem (at title screen):
9,1,1 (emergency on phone pad)
* Test Mode (enter at the "EYE"):
1+2+3+7+9+Option
* Change Music/Sound FX/Volume (in the middle of a round):
Pause, A/B/C
P, K, & J refer to your button settings/config.
* Buzzsaw
* Airgrab & Slam : U, D + P <close>
* Bolo : T, T, J <far>
* Gut Grinder : Aw + P@ <close>
* Gut Spear : <Charge> Aw, T, P <far>
* Hi, Buzzsaw : T, T, P <far>
* Pain Machine : <Charge> Aw, T, K <far>
* Ricochet Blades : UA, D + J
* Bolo Beheading^ : T, T, T, J <far>
* Screwed^ : D, T, P <not close>
* Poopality^ : D, D, Aw, T, Aw, J, P, Hold K
* Dreadloc
* Spear Dive : U, D, D, P <in air>
* Back Off, Man! : T, P
* Come to Daddy : T, T, P <far>
* Fire Breath : T, Aw, P <far>
* Jab (low) : D, P
* Speed Slice : <Charge> Aw, T, P <far>
* Spin Staff : D, T, J
* Volleyball^ : Aw, T, J <not close>
* Shish Kebab^ : T, T, T, J <not close>
* Grok
* Boulder Bounce : UT, D + J
* Boulder Morph : <Charge> Aw, D + J <far>
* Ground Pounder : <Charge> Aw, J <far>
* The Tenderizer : Aw + P@ <close>
* Avalanche^ : Jump over opponent, D + K
* Moon Shot^ : <charge> D + J <close>
* Lucius
* Electrotherapy : T, Aw, P@ <close>
* Spark Wave : T, T, K
* Hawk Attack Low : U, D, J
* Hawk Attack High : U, D + P <in air>
* Hawk Teleport : U, J
* Ground Lightning : D, T, P <far>
* Air Lightning : U, T + P
* Spinning Back Kick : Aw, K
* Electric Death^ : T, T, Aw, P <close>
* Hawk Decapitation^ : U, Aw, Aw, P <far>
* Mercury
* Big Gooey : Aw, T, P@ <close>
* Porcupine Spikes : D, D, P + K
* Sawblade : <Charge> Aw, T, K
* Spinning Blade Sweep : D, D, K + J
* Ground Beef^ : D, T, J
* Rock'em Sock'em^ : T, T, P <not close>
* Poopality^ : D, D, Aw, T, Aw, P, J, Hold K
* Skullcrusher
* Brain Fryin' Microwave : T, T, P <far>
* Charged Particle Blast : Aw, T, J <far>
* Choke & Thump : <Charge> Aw, T + P <far>
* Creeping Ground Blast : T, T, J <far>
* Grim Dive of Death : <Charge> D, U <far>
* Knife Head Butt : Aw, T, P@ <close>
* Stride & Slide : T, K <far>
* Fatal Grip^ : T, T, Aw, J <not close>
* Head, Well Done^ : <Charge> Aw, T, J <far>
* Volcana
* Fire-bomb : UA, D + P <in air>
* Fire-breath : Aw, P@ <close>
* Fireport Behind : D, Aw
* Fireport Uppercut : <Charge> D, U
* Fire-roll : U, T, J <in air>
* Fire-wall : <Charge> Aw, K
* Flame Blast : D, T, P <far>
* Flying Fire-dive : <Charge> Aw, T, J <far>
* Blowtorch^ : T, T, Aw, P <close>
* Shake 'n Bake^ : D, T, J <not close>
49. VAL D'ISERE SKIING & SNOWBOARDING
* Cheats:
* Infinite chances (during time results at end of race):
Press Reset (* + #), then choose play from main menu.
* Eggs:
* Secret menu (at the mode select screen):
4,0,8,5,7,4,1,4
50. VID GRID
* Cheats:
* Instant solve (during game play): (4+7+8) + B
51. VIRTUAL LIGHT MACHINE (VLM)
* Eggs:
* External Input Mode:
Close the drive lid without a CD and press A+*+#
* Freeze Swirls:
Go to effect 9-1 (or any other hold-down-B-button effect). Hold
down B to make the swirls appear. Release B & quickly press 1-1
(or any other non-B-button effect) before the swirls disappear.
Return to effect 9-1 (or any other B-button effect). Now the
swirls are in the state/size they were in when you left effect
9-1. Move the joypad around & notice the swirls will stay
without pressing B. They will stay frozen in the other B-button
effects. To cancel the freeze, press B.
* Spectrum Trigger Configuration Menu:
In VLM mode: * + 0 + 1 + 3
* Effects Configuration Menu:
From the Spectrum Menu (see above): U,D (8 times).
* Dunks list:
* Preppies (wearing sweatervests with logos):
Jules, Mace, Dr. Ed, O. G., Titan, Gruff
DD, U, R, UD, RL
* Women (women :) :
Stress, Wisp, Rio, Sully, Hail, Twitch
LR, LL, R, DU, DRU
* Arm Outs (dribble with the other arm out at a 45 degree angle):
Freaky, Eggman, G. Love, Stomp, Smack, Grip
LU, RR, L, DU, ULD
* Belly Rubbers (when dribbling towards you they rub their bellies):
Saber, Hack, Burger, Rabies, Van, Fence
LD, RD, L, DD, RUL
* Handshakers ("These guys are hilarious! They sort of "groove" while
they dribble. In profile when they're dribbling they look like
they're offering to shake hands."):
Rush, Scrape, Tower, Slag, Goose, Skin
D, DU, UU, L, RDL
53. WOLFENSTEIN 3D
* Cheats (during game play, unless otherwise noted):
* God Mode = 4,6,6,8
* Full Inventory = 4,9,9,6
* Next Level = 4,7,8,6
* Previous Level = 4,6,9,6
* Floor/mission menu = 1+3+7+9 (at main menu)
* Eggs (during game play, unless otherwise noted):
* Music Menu = # (at "Ball" title screen)
* Refresh Info = 4,8,8,7
* Eggs:
* Race as a Bus: 4 + 'start race' then change camera viewpoint to
view the race bus. Try 3 "Chase 2"
* Track-edit Mode: 0 + 'start race' then restart race to see changes
* Texture-map Track Toggle: 8 (during game-play or demo)
* First-place Race Codes (Championship Simulation):
U.S.A. Hungary Germany Brazil San Marino
00000000 00000000 00000001 00000001 00000001
39721063 79441102 19216456 58991638 98766992
37889812 40151109 30780394 42882646 34187162
64384072 63200081 70080120 83520168 41920200
Monaco Mexico Canada France England
00000002 00000002 00000003 00000003 00000003
29801569 69577264 09297645 48963393 88739088
19696667 55991186 03905186 53418674 89709025
44320244 22720312 61120325 99520396 68960400
Portugal Italy Egypt Australia Japan
00000004 00000004 00000005 00000005 00000005
28514442 68180184 08065487 47841182 78875418
80338310 88966342 81124970 08711517 54587794
75840467 24640487 08640556 96224567 39207006
55. WORMS
* Level Codes (after landscape is generated, press B & enter code):
* Last played : 1471 * Only Desert : DESERT
* All : ALL * Only Forest : FOREST
* Only Alien : ALIEN * Only Hell : 666
* Only Arctic : ARCTIC * Only Junkyard: JUNK
* Only Candy : CANDY * Only Martian : MARS
* Landscape Eggs (after landscape is generated, press B & enter code):
* Alien: * Forest:
* Flat: TISSOGDRIT * King of the Hill: OUCH
* Big bowl: 02185719 * Flat w/trees: MYSTEE
* Pedestal at sea: 980351 * Long bridge: 99289
* Arctic * Long bridge: HOPELESS
* Flat: WILTON * Big dome: 02183719
* Long bridge: 731931229 * Viet Nam Caverns: 416241
* Big columns: 02180719 * Pedestal at sea: HIDEYHOLE
* Slope/dome: 02187719 * Pedestal at sea: 75912494
* Big slope: 7007230 * Land bridge: 3333333333
* Candy: * Hell:
* Long bridge: SEAGULL * Two sides of the ocean: BEN
* Shallow slope: 70345 * Flat: 24833916
* Desert: * Big columns: 7373888390
* Injun Joe's Hideout: 62997503 * Underground maze: TRIFECTA
* Long bridge: BADRAN * Underground maze II: CLITO
* Big columns: 02184719 * Big columns: 02182719
* Short columns: 8131166523 * Junkyard:
* Slope/dome: 02189719 * Big columns: 02186719
* Tiny outcrop at sea: 66888
* Trash heap at sea: 8878942
* Martian:
* Outcrop at sea: LOSE
* Caverns of Mars: 98620
56. ZERO 5
* Unlock Missions (at options screen, change mission):
* 1 = Pause + (0,5,0,5,0,5) * 1-9 = Pause + (?)
* 1-2 = Pause + (6,8,9,2,1,4) * 1-10 = Pause + (2,7,6,5,4,9)
* 1-3 = Pause + (1,2,2,1,6,9) * 1-11 = Pause + (1,0,7,8,4,0)
* 1-4 = Pause + (6,7,6,3,9,6) * 1-12 = Pause + (2,9,7,4,3,0)
* 1-5 = Pause + (4,9,3,1,7,5) * 1-13 = Pause + (9,2,1,7,5,3)
* 1-6 = Pause + (3,2,9,7,8,1) * 1-14 = Pause + (3,8,5,1,7,9)
* 1-7 = Pause + (7,4,8,6,2,7) * 1-15 = Pause + (9,0,1,9,3,4)
* 1-8 = Pause + (2,4,9,3,4,7)
57. ZOOL 2
* Infinite health = 1,1,2,7,5 (Rooster sound)
* 99 Lives = 3,1,9,6,5 " "
* Bonus Rounds enabled = 3,1,8,6,7 " "
* Level Codes (at options screen):
* Bulberry Hill first stage = 7,7,7,4,9 (Rooster sound)
* Tooting Common first stage = 8,8,5,6,3 " "
* Snaking Pass first stage = 3,3,6,6,6 " "
* Mount Ices first stage = 1,1,9,6,8 " "
* Mental Blockage start = 9,1,2,6,6 " "
Here is another cheat list that is still available at http://www.atarihq.c...ag/jagcheat.txt
Myself and Shaggy the Atarian had this updated to a much newer version at JSII w/ tons of cheats from new games but I don't have a backup of the list so it's back to the original:
Atari Jaguar Game Cheats and Codes
Compiled by Clay Halliwell (aka Earl C. Halliwell)
Last updated December 18, 1998
As seen in the "Atari Jaguar Official Gamer's Guide", by Zach Meston and J.
Douglas Arnold.
Additions/corrections to:
earl.halliwell@dyess.af.mil
The latest version of this file can be snagged from:
Atari Gaming Headquarters
http://www.atarihq.com/jaglynx/jag/jagcheat.txt
New info in this update:
I-War Level Codes (thanks to Andrew Seed, via Carl Forhan)
Skyhammer Cheat (thanks to Chris Blackmore, via Dave Homenuck)
Super BurnOut Display Version (thanks to Elysee Ade, via Fred Moreau)
Table of Contents
JGT Jaguar General Tricks
AVP Alien vs Predator
AKA Atari Karts
BLD Baldies
BTM Battlemorph
BLI Blue Lightning
B13 BrainDead 13
B2K Breakout 2000
BSF Brutal Sports Football
BIF Bubsy in: Fractured Furry Tails
CAF Cannon Fodder
CHF Checkered Flag
CLD Club Drive
CBM Cybermorph
D2K Defender 2000
DOM Doom
DRL Dragon's Lair
EDD Evolution: Dino Dudes
FFL Fight For Life
FLB Flashback
FLP Flip Out!
HIL Highlander: Last of the MacLeods
HST Hover Strike/Hover Strike: Unconquered Lands
IS1 Iron Soldier
IS2 Iron Soldier 2
IWR I-War
KAN Kasumi Ninja
MTR Memory Track
M3D Missile Command 3D
MST Myst
NBJ NBA Jam: Tournament Edition
PTM Pitfall: The Mayan Adventure
PDR Power Drive Rally
PRG Primal Rage
RDN Raiden
RMN Rayman
RNR Ruiner
SKH Skyhammer
SPC Space Ace
SBO Super Burnout
S3D Supercross 3D
SDC Syndicate
T2K Tempest 2000
THP Theme Park
TII Towers II
TMF Trevor McFur in the Crescent Galaxy
TAF Troy Aikman NFL Football
ULV Ultra Vortek
VDS Val d'Isere Skiing and Snowboarding
VGR Vid Grid
VLM Virtual Light Machine
W3D Wolfenstein 3D
WTR World Tour Racing
WRM Worms
ZE5 Zero 5
ZL2 Zool 2
Conventions
"Type" or "Press", with lists of keys separated by commas, means to
press the keys in order, without holding them down after they've been
pressed.
"Hold", with lists of keys separated by plusses, means to press and
hold the keys in order. Unless instructed otherwise, don't release the
key(s) until the end of the code.
"Type" or "Press", in combination with plusses means to press and hold
the keys in order, and then release.
"1...4" means to press any single number in the range specified.
"A[n]" means to press the specified button or key "n" times.
The three-character codes preceding each game title are provided so you
can use your editor's search function to go directly to an entry.
Purpose
This document contains level codes and passwords, cheats, cool bugs,
and simple gameplay tricks. It does not contain fighting game moves, walk-
throughs, maps, nor anything else which properly belongs in a strategy FAQ.
Codes Wanted
The following codes are known to exist and WANTED: Air Cars cheats,
Double Dragon V "Play as Shadow Master" code, Super Burnout "Move to the
Head of the Pack" cheat, and Ultra Vortek "Play as Guardian" and "Play as
Carbon" codes.
No cheats/tricks/codes are known to exist for the following games:
Attack of the Mutant Penguins, Dragon: The Bruce Lee Story, Fever Pitch
Soccer, Pinball Fantasies, Sensible Soccer, White Men Can't Jump, and Zoop.
But if you discover something, by all means please let me know!
Vanity Zone
The following are codes I discovered/documented myself: AvP "Freeze
Alien Queen", Baldies level codes, Battlemorph cluster codes (with a nudge
from Don Thomas) and "Bonus Points" code, Cybermorph level codes and Boss
Rampage, Doom "Fire Weapons in Automap" and "Music During Gameplay",
Flashback level passwords, Highlander "Rogues Gallery" and "Chicken
God/Teleportal", Hover Strike "Weird Ground Texture Colors" and "Vector
Graphics Mode", Iron Soldier "Scroll Title Screen", "Swivel Mech View", and
"Rapid Left/Right Rotation", Iron Soldier 2 "Instant Demo", Myst saved game
codes, Power Drive Rally "Change Car Color", Primal Rage "Alternate
Character Colors", Rayman "Toggle Sound Effects", Tempest 2000 "Pause Bug"
and "Invisible Web", VLM "Effects Edit Mode" and "External Input Mode", and
Wolfenstein 3D "Previous Level".
JAGUAR GENERAL TRICKS (JGT)
Stupid JagCube Tricks:
As soon as the spinning cube appears, press and hold Pause (or, press
and release Pause+Option before the letters start to fall), then:
Zoom In Up
Zoom Out Down
Spin Left Left
Spin Right Right
Reverse 0
Release Pause to continue the boot sequence. Press Reset (* + #) or any
action button to skip the remainder of the boot sequence.
Remove "PAUSED" Message:
Press 1+3 when paused. Doesn't work with all games.
ALIEN VS PREDATOR (AVP)
Cheat Codes:
All cheats entered anytime during play. Cheat II is a superset of Cheat I.
Cheat I ("Hold that Fuji!") Enable:
Hold Pause+Option.
Press 1+3, then release (1+3 only).
Press 2+5+7+9.
Predator laugh confirms.
Cheat I Commands:
Toggle Weapon Access Option+1...4
Reload All Ammo Option+1+2+3+4 (simultaneous)
Raise Security Level Option+6
Lower Security Level Option+9
Toggle Motion Tracker Option+8
Cheat II ("Banana Stops") Enable:
Press Pause+Option+6+1+3, then release.
Press B,A,9,A,9,A ("BANANA")
Press *,Option,6 ("STOPS")
Press #,* ("POST")
Press *,Option ("STOP")
Press 2,Option ("TOP")
Cheat II Commands:
Toggle Cheat Option+5
Up Level Option+A
Down Level Option+B
After entering the Cheat II code, using the Toggle Cheat command will give
you unlimited life and ammo (the ammo bars will run down, then refresh
themselves; the energy bar will run down to zero and stop). To get
unlimited ammo, you must already have some ammo in the weapon. The Up/Down
Level commands cycle through each sublevel, both alien ships, and all the
air vents. This cheat works with all characters.
Debug Info:
Hold Pause.
Press Option.
Press 1+3.
Release Pause.
Press Option.
Shotgun blast confirms.
"dec(nn,nn)" is your map grid coordinates. "hex(nnnn,nnnn)" is your precise
coordinates (in hexadecimal). "1(nn)" is the current level.
Freeze Alien Queen:
Anywhere inside the Queen's lair, save your game, then reload. Awaken
Queen by walking through the lair entrance. The Queen can be damaged while
frozen, but won't actually die until you "unfreeze" her.
View Alien Ending:
Enable the "Banana Stops" cheat. Must have at least one fully-grown
cocoon. Get killed. When "Cocoon Hatching" appears, press Option+A or
Option+B.
ATARI KARTS (AKA)
Skip to Miracle Race:
The Beginner Challenge Miracle Race must be playable. Start this race,
then reset (* + #) at any time. Start a new game and select any of the
higher Challenges. The Miracle Race will still be highlighted and can be
played.
Spinout Bug:
On any California Highway track, pause the game while driving through a
puddle of water, then unpause. You will be spinning at a speed proportional
to how fast you were going when you paused. You can speed up the spin by
pressing the accelerator while spinning.
BALDIES (BLD)
Level Codes:
#1 (none) #21 26481912 #41 99799799 #61 69556532 #81 99589435
#2 69317691 #22 37736169 #42 71394421 #62 92826938 #82 26997667
#3 32585431 #23 29329995 #43 37118763 #63 38293232 #83 72143164
#4 53199313 #24 25849779 #44 51776684 #64 92729513 #84 25454616
#5 95568176 #25 44694221 #45 99584621 #65 23835728 #85 99162722
#6 14799741 #26 25259781 #46 96193782 #66 46365977 #86 15969299
#7 99112932 #27 26827251 #47 55992751 #67 42127597 #87 22789619
#8 25579427 #28 37495714 #48 75326691 #68 59744212 #88 19783692
#9 94554648 #29 25899273 #49 36296862 #69 66652545 #89 32927721
#10 95555366 #30 25141462 #50 17228223 #70 92969395 #90 19892933
#11 95532656 #31 98435959 #51 75478824 #71 22169481 #91 99997799
#12 22938689 #32 69667792 #52 67788234 #72 93671736 #92 17214394
#13 89232323 #33 24164317 #53 13324585 #73 52999329 #93 33677118
#14 22513979 #34 55616442 #54 35133199 #74 92757849 #94 45816776
#15 33728582 #35 96722219 #55 69751568 #75 14242694 #95 19296584
#16 66977534 #36 56299991 #56 11447799 #76 12857259 #96 29867193
#17 22597714 #37 28619972 #57 29399112 #77 12562827 #97 15557992
#18 94212475 #38 98692371 #58 72254579 #78 43177495 #98 17956326
#19 65545266 #39 22721793 #59 89446554 #79 32752899 #99 23668296
#20 26395999 #40 99933281 #60 69653555 #80 22654141 #100 31272228
BATTLEMORPH (BTM)
Cluster Codes:
All codes entered as new player name. You will be given all weapons and
magazines you would have earned up to that point (including secret weapons).
Note that on the load-game screen it will say "Zephyr Cluster" even after
successfully entering a code.
Zephyr (none)
Carmine ATDC2
Ferial ATDC3
Pan Alma ATDC4
Straussen ATDC5
Pyroxine ATDC6
Cygnus ATDC7
Pernish ATDC8
Quake:
Destroy most of the trees (at least 400, of 476 trees total) on all the
Comedy Mode:
Enter "A NAME" as new player name. Sound confirms. Changes Skylar's
voice, cockpit graphics, and between-level FMV voiceover.
Extra Ships:
If the last two digits of your score are "99" on completion of a world,
you are awarded two extra ships.
Bonus Points:
If the last two digits of your score are "42" on completion of a world,
you are awarded 99,958 bonus points ("Hitchhiker's Guide" bonus).
BLUE LIGHTNING (BLI)
Comedy Mode:
At the option screen, hold 0+1+2+4+5+6+7+9. Thud sound confirms.
Changes voices and adds an extra FMV segment to the end game.
Instant Repair:
Comedy mode must be enabled. Anytime during play, press *.
BRAINDEAD 13 (B13)
Instant Replay:
Press Pause, Pause to replay the current section from the start.
BREAKOUT 2000 (B2K)
Cheat Codes:
Enter all cheats after bricks are formed, but before any balls are launched.
99 Balls 1+3+5
Skip Level 1+6+7
Skip Phase 1+5+7
Super Ball 7+8+9+1
Plasma Cannon 7+8+9+2
Attract Ball 7+8+9+3
Catch On 7+8+9+4
Banish Robots:
When robots appear during gameplay, press * + #.
BRUTAL SPORTS FOOTBALL (BSF)
Bypass League Mode Bug:
Enter at the password screen.
RMVVKL343
333VZ6387
BUBSY IN: FRACTURED FURRY TAILS (BIF)
Level Codes:
#1 (none) #6 184792 #11 673167
#2 392652 #7 812615 #12 792323
#3 458227 #8 781367 #13 672328
#4 958936 #9 126712 #14 782389
#5 739294 #10 236721 #15 672345
CANNON FODDER (CAF)
Regain Lost Weapons:
After a troop has been wiped out, if you have at least two men left and
some weapons, split off another troop but don't give it any grenades or
bazookas. The new troop will then have the dead troop's weapons.
Quick Map Display:
Anytime during play, press *, or 0, or #.
CHECKERED FLAG (CHF)
Night Racing:
At the Options menu, highlight "Weather", then type 8,4,7,3.
CLUB DRIVE (CLD)
Planet Todd:
At the main menu, highlight and select "World", then press 4+2
("Hitchhiker's Guide" cheat).
Debug Info/Camera Enable:
Anytime during play, press 8+6 (either controller). This displays
three rows of hexadecimal numbers, and gives you access to the Drop Camera
and Fixed Camera views in all play modes.
CYBERMORPH (CBM)
Sector Codes:
#1 1008
#2 1328
#3 9325
#4 9226
#5 3444
#? 6009 ("Unknown" sector)
Unlimited Ammo:
At the Control Options screen, hold 1+3+5+7+8+9. Sound confirms.
Boss Rampage:
Start a new game, then enter "1328" to skip to Sector 2. Finish
Sectors 2 through 4. Enter "1008" to skip to Sector 1. Finish Sector 1.
You will be forced to fight the Sector 1, 2, 3, and 4 bosses consecutively.
DEFENDER 2000 (D2K)
Cheat Codes:
All codes entered on high score entry screen (any play mode). Codes remain
enabled until the cartridge EEPROM is cleared.
Plazma Pong NOLAN ("Perfect" confirms)
Plazma Pong is added to the list of available games.
Flossie Defender OVINE ("Baaa" confirms)
Play Flossie Defender by pressing any button to choose a
Defender Plus game, then pressing "A" to start.
Level Skip BEEST ("Baaa" confirms)
Defender 2000 only. Anytime during play, press "3" to skip
a level, "6" to go to the warp screen.
Huge Bonus:
In Defender 2000, catch a falling humanoid as the wave is ending.
DOOM (DOM)
All codes entered during gameplay. Cheats are disabled in Co-Op and
Deathmatch modes.
Level Select:
1-9 1...9+Pause
10 A+Pause
11-19 A+1...9+Pause
20 B+Pause
21-24 B+1...4+Pause
God Mode:
Pause, then * + Pause
Very Happy Ammo Mode (full keys, weapons, armor and ammo):
Pause, then # + Pause
Fire Weapons in Automap:
Hold C+B (or whichever buttons are configured as Use & Fire).
Music During Gameplay:
Start a Deathmatch or Co-Op game on Area 23. Exit the level, press any
button to start the congratulation text, then have either (but only one!)
player reset and start a new Deathmatch or Co-Op game. Now one player's Jag
will be playing music instead of sound effects.
DRAGON'S LAIR (DRL)
Instant Replay:
EVOLUTION: DINO DUDES (EDD)
Infinite Time:
<AC>
"TIME STANDS"
<OK> (thunderclap confirms)
<AC>
"STILL FOREVER"
<OK> ("Okay" and witchdoctor chant confirms)
Infinite Dudes:
<AC>
"ONCE DEAD"
<AC>
"TWICE BORN"
<OK> (Belch and witchdoctor chant confirms)
Level Passwords:
#1 ROUND ONE #28 PENAL COLONY #55 STAGE COACH
#2 LIBERTY ISLAND #29 RELIEF ART #56 QUAY BORED
#3 STONE WALL #30 TRIBAL DANCE #57 SPLASH DOWN
#4 G MEN #31 SODA FOUNTAIN #58 BUG POLITICS
#5 WILD WEST #32 PARKING SPACE #59 SHAKE SPEAR
#6 LEMON ENTRY #33 PIZZA DUDE #60 SCHOOL ZONE
#7 WAGON WHEEL #34 CROW FLIES #61 PINK MARBLE
#8 OIL DRUM #35 TILED ROOF #62 ROLLING PLAINS
#9 MOON ORBIT #36 SLATE MISSING #63 ICON DRIVE
#10 HARD ROCK #37 OPENING TIME #64 CARROT TOP
#11 TRIP AND FALL #38 INNER PEACE #65 QUILL PEN
#12 ALARM CLOCK #39 BAD DOG #66 TUTTI FRUTTI
#13 BIG COUNTRY #40 SOUR BELLY #67 PUBLIC ENEMY
#14 HOG TIED #41 LARGE MUG #68 BIG END
#15 CAN CAN #42 HALF A BET #69 TAN PARLOR
#16 CUTE MOUSE #43 SING SING #70 NEVER READY
#17 SPARK PLUG #44 BROWN COW #71 SHARK FANGS
#18 PONY EXPRESS #45 IRON HORSE #72 STOOL PIGEON
#19 PADDED CELL #46 WHITE MALE #73 PROM QUEEN
#20 LOG PLUME #47 BOX OFFICE #74 RED LETTER
#21 CANVAS SAIL #48 CORNY FUR #75 CORN PONE
#22 GOLDEN ERA #49 ATOM CAT #76 BILGE PUMP
#23 WIDE SEAT #50 FREE WHEELING #77 SIXTY FOUR BIT
#24 BAD KARMA #51 BRUSH FIRE #78 HALF MAST
#25 CRASH BARRIER #52 CAR BRA #79 WALKING BOSS
#26 LIME GLASS #53 PORK PIES #80 SPACE TO LET
#27 SURF UP #54 STORMY WEATHER
FIGHT FOR LIFE (FFL)
Passwords:
Enter on character select screen after pressing Option.
Demo Mode (default) JAGUARTIME (or 1+5+9)
All Special Moves IWANTPOWER (or 1+3+5+9)
Play Junior vs Junior LOVEJUNIOR (or 1+3+5+7+9)
(Morph as Junior: C+U,L,D)
Shorter Junior Battle:
Defeat Junior the second time with a ring-out. When the next fight
begins, pause and rewind to before the electrocution.
FLASHBACK (FLB)
Level Passwords:
Easy Medium Hard
Stage 1 - Planet Titan LETY RISING RODEO
Stage 2 - New Washington BOXER ORDO BINGO
Stage 3 - Death Tower EAGLE PROFIT LSTED
Stage 4 - Earth STKTON PRIZE DARTS
Stage 5 - Secret Base TICKET SKAEPS BUDDY
Stage 6 - Morph Planet I SUITE HITTER MUSIC
Stage 7 - Morph Planet II PHASER TWIN SHOGI
FLIP OUT! (FLP)
Cheat Codes:
Enter during game, before play starts. Sound confirms.
Finish Match 7,7,9,8,8,9,#
Programmer's Heads 1,4,2,8,3,7,2,2
(must be a level with three "cheerleader" aliens)
Enter on map screen. Sound confirms.
Access All Levels 7,7,9,8,8,9,9
HIGHLANDER: LAST OF THE MACLEODS (HIL)
Cheat Codes:
Enter anytime during play. No confirmation.
Invulnerability 4,1,3,3,5,6,4
Teleport to Rogues Gallery 2,1,8,8,3,5,3,8,9
Gain All Vital Objects 9,4,4,6,9,2,1,3
(must enter before any items collected; messes up Option
button)
Rogues Gallery:
The Gallery is hidden in the canyon, behind the large tall rock with
the sniper on top.
Chicken God/Teleportal:
To gain the Chicken God and activate the Teleportal, place a flower in
the vase in the Rogues Gallery.
HOVER STRIKE/HOVER STRIKE: UNCONQUERED LANDS (HST)
Cheat Codes:
Enter on the Mission Select screen. All combinations MUST be pressed
simultaneously... this may take a couple of tries. Sound confirms.
Change Globe Speed/Direction 4/6
Change Globe Size (CD) Up/Down
Alternate External Monitor (cart) Right+C+1+4+5
Alternate "Ammo Depleted" Cue (cart) C+4+8
Unlimited Weapons/Energy/Shields Down+3+4+6+7
Extra Lives 3+6+9+#
Level Skip 2+4+6+7+8+9
Enable Secret Bonus Missions:
Level 1 Up+2+3+6
Level 2 Down+2+6+7+8
Level 3 Right+3+5+6
Level 4 Up+2+5+8
Level 5 Right+2+4+5+6
Enter anytime during gameplay.
Toggle Day/Night Up+A+B+C+7
Toggle Debug Mode Up+A+B+C+6
(upper-right number is the current frame rate)
Weird Ground Texture Colors (cart) Up+A+B+C+3
Vector Graphics Mode (CD) Up+A+B+C+3
Cycle Background Music (cart) Up+A+B+C+0
(Brief delay before music restarts. If music doesn't
restart, press 0 to make sure you didn't turn music off.)
IRON SOLDIER (IS1)
Cheat Codes:
Type on the Options screen. Border flash confirms.
Enable "Insane" Difficulty Level 6,8,2,4 ("OUCH" on phone keypad)
Access All Levels and Weapons 3,7,6,6,8,2,4,2
Infinite Ammo 2,7,2,8,3,7 ("CRATES")
Instant Mission Pass/Fail 2,8,8,8,6,6,7,7,3,7,7
(during gameplay, press * to fail, # to pass)
Single-Frame Advance Pause, then 1 or 3 to advance
Rapid Rotation A+C while turning
Display Mission Stats 8
Scroll Title Screen:
On the scrolling title screen, once the "Iron Soldier" logo appears,
use the joypad to scroll the screen up and down.
Swivel Mech View:
At the mech configuration screen, select add or remove weapon, then 1
or 2 to swivel your mech (doesn't go all the way around).
Almost Full Repair:
When damaged to the point that you get a Low Energy warning, launch a
Cruise Missile and hit yourself with it.
IRON SOLDIER 2 (IS2)
Cheat Codes:
Type on the Options screen. Option screen exit confirms.
Access All Levels and Weapons 5,2,6,2,0,4,8,1
Infinite Ammo 1,4,8,8,2,5,0,2
Invulnerability 8,3,0,5,5,7,2,6
Instant Mission Pass/Fail 3,4,4,9,5,2,2,0,7,1,6
(during gameplay, press 0 to fail, # to pass, * to die)
Combo Cheat (all of the above) 9,7,0,0,2,3,8,6,6,5,4,1
Play as Satyr War Strider 7,2,8,9,7,6,6 ("SATYR ON")
(use Option to cycle weapons; don't run out of ammo in any one
weapon, or you'll be stuck with the weapon just before it)
View Endgame Sequence 7,2,4,4,9,8,0,1
(then select "Start Game" from main menu)
Instant Demo:
Jump to Exit:
At the mech configuration screen, press A to jump the cursor to the
Exit box.
Almost Full Repair:
I-WAR (IWR)
Secret Options:
At the main menu, press 2+4+6+8. No confirmation; does not survive resets.
The option menu will now have a texture toggle option (does nothing), and a
node select option.
Level Codes:
Entered on option screen (Secret Options must be enabled). Select Enter
Code, then use number keys to enter code. Left/right moves cursor, A/B/C
confirms code. Select Start to begin.
#1 Alpha Matrix 3495823456
#2 Data Core 7983456383
#3 Central Web 5282259782
#4 Outer Ring 9452382725
#5 Home Node 7357286586
#6 Core Dump 3985615345
#7 Internal Store 6315678561
#8 Vector Five 1238261234
#9 AI Reserve 3982612389
#10 Safe Segment 4826178962
#11 Code Segment 2397856123
#12 Parallel Area 3482623457
#13 Logic Switch 8563457634
#14 Gate Two 8278634589
#15 Binary Path 5785623456
#16 Damage Vector 5234545214
#17 Restore Buffer 9238471472
#18 Energy Grid 8957235957
#19 Defense Segment 2359834235
#20 Decision Vector 7892597223
#21 Override Central 7891237892
Block
KASUMI NINJA (KAN)
Cheat Codes:
At the Options screen, select Change Code (a lockout code must already be
entered). Hold A+C on controller #2, then type code on controller #1.
Various sounds confirm.
Play as Gyaku/Demon Gyaku 3,7,4,9,6,1
(VS mode only; Gyaku/Demon Gyaku replace Senzo and Habaki)
Allow Same-Character Fights 6,2,1,5,4,4
Sensible Fighter #1 7,4,3,8,7,1
Sensible Fighter #2 8,9,9,2,4,4
(named after the tiny characters in all Sensible Software games)
Reset Parental Lockout 5,2,4,6,4,8
Start w/Key to Temple 6,3,7,4,0,4
Self-Test Mode 9,3,1,4,2,7
(reset and press fire after entering code; cycles through all
player and background combinations one fight at a time;
press A/B/C/Option on controller #1, or Option on controller
#2, to skip to next fight)
Demon Gyaku Moves:
Uppercut A
Fire Breath Toward+A
Earthquake Stomp B
Shake & Toss B (close)
Slam & Taunt Away+B (close)
Jump Kick Jump, B
Head Rip Fatality (unknown)
MEMORY TRACK (MTR)
Memory Track Manager:
Hold Option and turn on Jaguar (not a cheat, but easy to forget).
Commands:
Delete File A/B/C
Set Sort Type Option
Set Sort & Save 1+Option/3+Option
Edit Name/Size 7+9+Option
Delete All Files *+#+Option
Self Test *+0+#+Option
Exit *+#
MISSILE COMMAND 3D (M3D)
Stage Select:
Virtual mode only. Enter anytime during play.
Stage 1 Pause, 1+9+C+Pause
Stage 2 Pause, 2+9+C+Pause
Stage 3 Pause, 3+9+C+Pause
Ending Pause, 4+9+C+Pause
MYST (MST)
Atari Headquarters:
Set the machine in the planetarium to May 22, 1970 6:30am (birthday of
programmer who did the Jag Myst conversion). The front view of the library
will be replaced by a picture of Atari's former HQ. Look up to see the Myst
B B B B C C B B A B
5 5 8 7 2 7 0 0 1 7
B A B C B A A A B C
# 6 5 6 3 0 3 7 5 7
A C A A B C C B C B
5 1 5 4 # # 7 0 7 5
A A B B B C C B B A
3 4 2 2 3 # 2 6 7 *
NBA JAM: TOURNAMENT EDITION (NBJ)
Cheat Codes:
Enter at "Tonight's Matchup" screen. Tournament mode must be disabled.
Unless otherwise noted, all powerups apply to the first player only (the
player who's name appears at the far left of the screen).
Strength Right, Up, Left, Right, B, Down, A
Strength powerup. "MAX POWER" confirms.
Quick Hands Left, Right, A, B, Right, Left
Stealing(?) powerup. "QUICK HANDS" confirms.
Offense A, Up, B, Down, B, Left, Right
Offense powerup. "OFFENSE" confirms.
3-Pointers Up, Down, Down, Left, Left, Right, Up
3-pointer powerup. "THREE POINT" confirms.
Pushing B, Right, A, Down, A, Right, B
Push powerup. "PUSH POWERUP" confirms.
Speed Up, Up, Down, Down, Left, Right, Left, Left, B, A
Speed powerup. No confirmation.
Fire Down, Right, A, A, B, Left
Always on fire. "ON FIRE" confirms.
Turbo B, B, Down, Down, A, A, Up, Left
Unlimited turbo. "TURBO" confirms.
Dunks Right, Left, B, A, B, A
Dunk from anywhere. "DUNK POWERUP" confirms.
Shot Percent Down, Up, Down, B, Up
Shows chance of a shot going in. "SHOT PERCENT DISPLAY" confirms.
Slippery Court B, A, Down, A, B, Right[5]
All players slide around on the court. No confirmation.
Flame Game A, Left, Left, Down, Right, A, A, B, B, Left
All players always on fire. "ON FIRE" confirms.
Teleport Passing Down, Right, Right, A, A, Down, Left, Left, Right, B
Passed balls "teleport" directly to other player. No confirmation.
Push Other Down, Left, Right, Up, Left[4], A, B
Pushing a player causes other player to fall down. No confirmation.
Push Both Down, Up, Down, Up, Left[4], A, A
Pushing a player causes both players to fall down. No confirmation.
High Shots Up, Left, Left, Down, Right, Up, A, B, A[3], Down
Shots arc much higher than normal. No confirmation.
Goal Tending Right, Up, Down, Down, Right, Up
No fouls called for goal tending. "GOAL TEND" confirms.
Baby Mode B, A, B, Up, Down, Left, Right
All players have small bodies, normal heads. "BABY MODE" confirms.
Big Heads Up, C, A
All players have normal bodies, big heads. "BIG HEADS" confirms.
Shrunken Heads Up[3], B, C, A[6]
All players have normal bodies, small heads. No confirmation.
Smurf Mode A, B, C, Down[7]
All players have small bodies and heads. No confirmation.
Small Ball Right[6], B[3]
Ball reduced to baseball size. No confirmation.
32X Doom Mode A, B, C, C, B, A, A, B, C, C, B, A
What if Jag NBA Jam had been written by the team responsible for 32X
Doom? No confirmation.
CD-ROM Mode C, Down, C, Down, C, Down, C, Down, C, Down
Brings you the joy of playing NBA Jam off a CD. No confirmation.
More NBA Players:
Hold before player select screen appears.
Defeated 26 Teams 2+4+6
Defeated 27 Teams 4+7+8
Extended Roster 1+5+9
Weird Story:
At the player roster display in the attract mode, hold Left+1+4+6+9 as
the roster ends.
Adisak Attack:
Enter Extended Roster cheat, then the Baby Mode cheat. The phrase
"ADISAK ATTACK" will appear on one of the coaching tips screens. Is that
all this does?
Secret Characters:
All secret character codes entered at the initials screen. Enter each
initial by holding Option + the indicated button. "n" means do nothing
special-- use any button, and don't hold Option. "SECRET PLAYER" text
confirms.
Example:
CLINTON "C"+B "I"+n "C"+A Bill Clinton
Move cursor to "C". Press Option+B. Move cursor to "I". Press A, B, or C.
Move cursor to "C". Press Option+A.
ADISAK "A"+C "L"+B "P"+A Adisak L. Pochanayon (High Voltage)
ADROCK "A"+B "D"+C "R"+n Adrock (Beastie Boys)
AIR DOG "A"+B "I"+n "R"+C Eric "Air Dog" Samulski (Acclaim)
BENNY "B"+C "N"+n "Y"+B Benny (Bulls mascot)
BIRD "B"+A "R"+C "D"+A Larry Bird
BLAZE "B"+C "L"+n "Z"+C Carol Blazekowski (NBA)
CHAMBERS "K"+n "C"+A " "+n Kristine Chambers (Atari)
CHARLES "R"+n "O"+A "Y"+B Prince Charles
CLINTON "C"+B "I"+n "C"+A Bill Clinton (President of the USA)
CLINTON "H"+n "C"+B " "+n Hillary Clinton (First Lady)
CORRELL "C"+C "R"+A "L"+n Correll (Atari)
CRUNCH "C"+n "R"+B "N"+A Crunch (Wolves mascot)
DAMION "D"+A "J"+B "D"+C Damion J. Davis (High Voltage)
DI-VITA "S"+n "A"+C "L"+A Sal DiVita (Bally)
FACIME "X"+A "Y"+B "Z"+B Alex Facime (Acclaim)
FRESH "W"+n "I"+B "L"+C Will "Fresh Prince" Smith
GANOFSKY "R"+A "B"+A "G"+A Robert B. Ganofsky (High Voltage)
GELBER "F"+B "I"+A "L"+B Phil Gelber (Atari)
GORILLA "G"+B "O"+B "R"+n Gorilla (Suns mascot)
GUNTER "G"+C "U"+C "N"+A Gunter
HAROLD "H"+A "A"+n "M"+A Harold (High Voltage)
HEAVY D "H"+B "V"+n "Y"+A Heavy D
HI VOLTAGE "K"+B "J"+B "G"+n Kerry (High Voltage)
HUGO "H"+A "G"+C "O"+n Hugo (Hornets mascot)
JAZZY JEFF "J"+A "A"+A "Z"+C D.J. Jazzy Jeff
KABUKI "D"+A "A"+B "N"+n Eric "Kabuki" Kuby (Acclaim)
MCA "M"+n "C"+B "A"+B MCA (Beastie Boys)
MIKE D "M"+C "K"+n "D"+C Mike D. (Beastie Boys)
MORTY "K"+C " "+C "M"+C Morty (High Voltage)
PACEY "P"+n "A"+n "Y"+C Larry Pacey (Atari)
RIVETT "R"+C "J"+A "R"+n Jamie Rivett (Bally)
ROSEN "S"+n "R"+n " "+A Shawn Rosen
ROSENFIELD "S"+n "E"+A "T"+B Seth Rosenfield
THEINVANICH "T"+C "H"+A "E"+B Theinvanich
THOMAS "S"+A "O"+n "X"+B Frank Thomas
THOMASON "F"+A "A"+n "R"+n Faran Thomason (Atari)
TRAMIEL "L"+n "A"+C "T"+B Leonard Tramiel (Atari)
TURMELL "M"+A "J"+n "T"+A Mark Turmell (Bally)
WANAT "W"+B "A"+n "N"+B Wanat
WEASEL "R"+n "A"+A "Y"+B Dan "Weasel" Feinstein (Acclaim)
PITFALL: THE MAYAN ADVENTURE (PTM)
Play 2600 Pitfall:
At the main menu, move the cursor to "Info". Press C[26], Down.
POWER DRIVE RALLY (PDR)
Freeze CPU Car:
Stop CPU Car 6
Start CPU Car 9
Change Car Color:
At the car purchase screen, press Up/Down to change car color.
PRIMAL RAGE (PRG)
Secret Option Menu:
At the "jungle" title screen, before the logo appears, press Left,
Left, Right, Right, Left, Left, Right, Right.
Alternate Character Colors:
Type at the character select screen.
Original Recipe B
Alternate A+B
Weird #1 C+B
Weird #2 Option+B
RAIDEN (RDN)
Infinite Lives and Bombs:
At the first boss, hold 1+4+7+3+6+9+Option. Extra ship sound confirms.
Affects both players.
RAYMAN (RMN)
Cheat Codes:
Type at the title screen, during the walking hands. Text confirms.
Ray Breakout 1,3,6,4
(completing all 11(?) levels gives you infinite continues)
50 Lives Per Continue 5,1,5,2,5,3
All Powers 1,3,5,7,9
Credits 2,5,5,2
Dedications (in French!)
0,0,7,* 0,1,0,2,7,1 1,2,3,0 1,2,4,5,7,8
1,5,9,0 1,5,9,# 1,5,9,* 2,1,1,1,6
2,2,0,4,7,3 2,2,7,1 2,7,2,6,9 3,4,0,8,0
3,4,4,7,0 4,5,6,8 9,3,1,0,0 9,6,2,7,2
Toggle Sound Effects:
During gameplay, press 8 to turn sound effects on and off.
RUINER (RNR)
Continue:
To continue play at the same DefCon (Ruiner) or spells cast (Tower),
press 7 or 9 at the game over screen.
SKYHAMMER (SKH)
Full Weapons, 50K Credits, and Promotion to Next City:
While in dock, type *,0,9,1,0,1,9,9,3,#.
SPACE ACE (SPC)
Instant Replay:
SUPER BURNOUT (SBO)
Turbo Speed:
At the title screen, type 1,9,6,7,2. Sound confirms. Automatic
transmission must be selected for this code to work. Once your bike's speed
reaches 175 MPH, holding C (or whichever button you have configured to
"Nothing") will accelerate you up to 343 MPH.
Punisher:
At the title screen, type 2,1,7,9,4. Sound confirms. You may now
choose the Punisher on the bike select screen. This code may be used in
conjunction with the Turbo Speed code.
While turning on the Jaguar, hold A+B+C.
SUPERCROSS 3D (S3D)
Crash Replay:
Anytime during play, press Pause, then 1-5 to replay the first, second,
third, fourth, or fifth crash. After the fifth crash, 5 becomes the most
recent crash, 4 the second most recent, etc...
SYNDICATE (SDC)
Cheat Codes:
All codes entered as Company Name.
Play any Mission NUK THEM
Get $100,000,000 ROB A BANK
Speed up Game Clock 20X WATCH THE CLOCK
Start with $100,000,000 and TO THE TOP
all Weapons/Mods/Missions
Reload All Weapons For Free:
Save your game. Reload your game. Resets any research in progress.
TEMPEST 2000 (T2K)
Enable Cheats:
At the main menu, hold 1+4+7+A. "Excellent" confirms. The following
cheats are enabled during gameplay.
Skip to Next Level Option
Enable Warp Bonus Round 6
Enable Rotary Controller:
At the Game Option menu, hold Pause on both controllers. "Excellent"
confirms.
Rotate Web:
At the web select screen, press Left/Right to rotate the web.
Pause Bug:
At end of the Bacon/Jupiter River bonus round, press Pause just as it
switches back to the main game (after approximately two and a half pulses of
The graphics in the game will now be slightly glitched. The starfield
won't scroll, messages won't disappear, the SuperZapper might not work, and
the web won't be solid-filled. Entering the "Green Path" bonus round
effectively ends your game. Exiting the Jupiter River or LSD bonus rounds
will occasionally mess up the double-buffering of the main game (though it
corrects itself after you die or finish the level).
Invisible Web:
Start any Tempest Plus game. Hold down Option (cheats must be active)
until you get to the rainbow levels. The web will be invisible during the
THEME PARK (THP)
All Shops and Rides:
Invest all your money into shops research, then wait until April, two
years later.
Adjust Screen Position:
At any time, hold Option and press Left/Right to adjust the screen.
TOWERS II (TII)
Cheat Codes:
Enter any time while paused.
God Mode & Full Maps 3+7, 1+9
Screen Position C+Up/Down
Screen Height C+Left/Right
NOTE: Towers II ships with the screen height set slightly larger than the
"neutral" setting. To correct this, start a game, bring up the character
stats, then gradually decrease the height until there are no doubled lines
in the text.
Secret Room:
In the Test of Magic area, stand on the purple carpet flanked by two
candles, and use the Levitation spell.
TREVOR MCFUR IN THE CRESCENT GALAXY (TMF)
Enable Cheats:
At the title screen, type 1,1,9,3 ("Trevor's Birthday"). No
confirmation. The following cheats are enabled during gameplay and on the
level select screen. Enter on controller #2.
Option Skip to next stage
Right Speed up enemies/background graphics
Left Slow down " "
A Speed up foreground graphics
B Slow down " "
C Fire special weapon without depleting inventory
1 Power up gun
2 Cycle through bomb powerups
3 Mark other moons as completed
4 Toggle invincibility
0 Cycle through sound effects
* Play sound effect
TROY AIKMAN NFL FOOTBALL (TAF)
Extra Touchdowns:
After scoring a touchdown, press Option and call a time-out. You get 6
points and the ball at the 1-yard line. Press Option and call a time-out
again for another 6 points.
ULTRA VORTEK (ULV)
Turbo Option:
At the title screen, hold 1+5+9. "Fight!" confirms. At the main menu,
you will now have the choice between normal and turbo play speed.
Secret Option Menu:
At the title screen, hold 1+2+3+7+9+Option.
Access Voice Modem:
At the title screen, type 9,1,1. "Awesome!" confirms.
Fight Carbon:
Start a game at the Hard or Killer difficulty level. Defeat your
opponent with a double flawless on the Earthquake Zone stage.
Secret Levels:
Type on the background select screen.
Hidden Palace #
Subway Passage *
VAL D'ISERE SKIING AND SNOWBOARDING (VDS)
Secret Option Menu:
At the main option screen, type 4,0,8,5,7,4,1,4.
Infinite Chances:
At the time results screen, reset (* + #) after losing a race, then
select Play.
VID GRID (VGR)
Instant Unscramble:
Anytime during play, press 4+7+8+B.
Spectrum and Triggers Edit Mode:
On a blank VLM screen (no menus or status bars displayed), hold * + 0 +
1 + 3.
Effects Edit Mode:
Enable Spectrum and Triggers Edit mode. With the cursor on the first
entry, press Up then Down, eight times. Press C to exit menus with no
designated exit button.
Close lid without a CD in the drive. Hold A + * + #.
NOTE: This "code" may be a bug, because the read head will continually
attempt to seek the surface of the CD once you've entered it. This could
possibly shorten the lifespan of your Jag CD.
WOLFENSTEIN 3D (W3D)
Cheat Codes:
Enter anytime during play or in automap.
God Mode 4,6,6,8
Full Inventory 4,9,9,6
Next Level 4,7,8,6
Previous Level 4,6,9,6
Refresh Info 4,8,8,7
Music Test:
At the "ball" title screen, press #.
Level Select:
At the main menu, hold 1+3+7+9. 3-5 and 6-7 are secret levels.
WORLD TOUR RACING (WTR)
Cheat Codes:
Hold down while selecting the option that starts the race (Race, Qualify,
etc...).
Race as a Bus 4
Track Edit Mode 0
(abort race and restart to view changes)
Texture-Map Track:
Anytime during play, press 8 to toggle texture mapping of the track.
First-Place Race Codes:
#1 U.S.A. #2 Hungary #3 Germany #4 Brazil
#5 San Marino #6 Monaco #7 Mexico #8 Canada
00000001 00000002 00000002 00000003
98766992 29801569 69577264 09297645
34187162 19696667 55991186 03905186
41920200 44320244 22720312 61120325
#9 France #10 England #11 Portugal #12 Italy
00000003 00000003 00000004 00000004
48963393 88739088 28514442 68180184
53418674 89709025 80338310 88966342
99520396 68960400 75840467 24640487
#13 Egypt #14 Australia #15 Japan
WORMS (WRM)
Cheat Codes:
After the landscape is generated, press B and enter code.
Recall Last Played Level 1471
Allow All Levels ALL
Only Alien Levels ALIEN
Only Arctic Levels ARCTIC
Only Candy Levels CANDY
Only Desert Levels DESERT
Only Forest Levels FOREST
Only Hell Levels 666
Only Junkyard Levels JUNK
Only Martian Levels MARS
Cool Landscapes:
62997503 Injun Joe's Hideout - Desert
OUCH King of the Hill - Forest
BEN Two sides of the ocean - Hell
24833916 Flat and featureless - Hell
TISSOGDRIT Flat w/evenly spaced statues - Alien
WILTON Flat w/evenly spaced snowmen - Arctic
MYSTEE Flat w/trees - Forest
731931229 Long bridge - Ice
99289 Long bridge - Forest
HOPELESS Long bridge - Forest
BADRAN Long bridge - Desert
SEAGULL Long bridge - Candy
02180719 Big columns, bottomless - Arctic
02182719 Big columns, bottomless - Hell
02184719 Big columns, bottomless - Beach
02186719 Big columns, bottomless - Junkyard
02188719 Big columns, bottomless - Arctic
7373888390 Big columns - Hell
8131166523 Short columns - Beach
02183719 Big dome - Forest
02185719 Big bowl - Alien
02187719 Slope/dome - Arctic
02189719 Slope/dome - Beach
70345 Shallow slope w/bars - Candy
7007230 Big slope - Arctic
416241 Caverns of Viet Nam - Forest
LOSE Outcrop at sea - Martian
66888 Tiny outcrop at sea - Junkyard
980351 Pedestal at sea - Alien
HIDEYHOLE Bigger pedestal at sea - Forest
75912494 Yet another pedestal at sea - Forest
98620 Caverns of Mars - Martian
TRIFECTA Underground maze - Hell
CLITO Underground maze II - Hell
8878942 Trash heap at sea - Junkyard
3333333333 Bridge and land bridge - Forest
ZERO 5 (ZE5)
Cheat Codes:
At the Options screen, select Change Mission and highlight the high mission
to be unlocked. Hold Pause while entering code. Sound confirms.
Unlock Mission 1 0,5,0,5,0,5
Unlock Missions 1-2 6,8,9,2,1,4
Unlock Missions 1-3 1,2,2,1,6,9
Unlock Missions 1-4 6,7,6,3,9,6
Unlock Missions 1-5 4,9,3,1,7,5
Unlock Missions 1-6 3,2,9,7,8,1
Unlock Missions 1-7 7,4,8,6,2,7
Unlock Missions 1-8 2,4,9,3,4,7
Unlock Missions 1-9 (unknown)
Unlock Missions 1-10 2,7,6,5,4,9
Unlock Missions 1-11 1,0,7,8,4,0
Unlock Missions 1-12 2,9,7,4,3,0
Unlock Missions 1-13 9,2,1,7,5,3
Unlock Missions 1-14 3,8,5,1,7,9
Unlock Missions 1-15 9,0,1,9,3,4
NOTE: Entering a mission-unlock code will lock all missions above and beyond
that one, even if you've previously unlocked them.
ZOOL 2 (ZL2)
Cheat Codes:
Enter on the Options screen. Rooster sound confirms.
Bulberry Hill 7,7,7,4,9
Tooting Common 8,8,5,6,3
Snaking Pass 3,3,6,6,6
Mount Ices 1,1,9,6,8
Mental Blockage 9,1,2,6,6
Always Get Bonus Round 3,1,8,6,7
Infinite health 1,1,2,7,5
99 Lives 3,1,9,6,5
***This should be a sticky!****
Very informative, thanks for the preservation :)
Will use this often! Thanks again Saturn.
Had no idea you can race as a bus in WTR lol, heading up to try this now haha
You're welcome :)
Man, these posts are long :cool:
EDIT: Total Carnage cheats originally posted in this thread;
http://atariage.com/forums/topic/221632-does-anyone-have-cheatspasswordscodes-for-total-carnage/
DNAH- Landing In Desert
GOOB- Weasel Warp Bonus
ZULU- Incoming Transmission
ORCS- Orcus Warp Bonus
ROAD- All Smash TV Players Should Quit Now And Flee From This Machine
LIPS- Wipe Out General Akhboob's Air Power
LICK- Warping
FIRE- Warping
SHOK- You Have Been Captured! There Is No Escape! Submit To The Pain! Tap Fire To Escape
FOOD- You Have Survived This Far. I Am Impressed. Can You Last To See The Shocking Conclusion?
EATS- Message From Headquarters
HUSH- Destroy General Akhboob's Secret Nuclear Capability
BURN- Taking Elevator Down To Basement
NAZI- Destroy General Akhboob's War Machines. Do Not Let Him Escape!
DOME- Mission Complete: The Pleasure Domes Await.
WORM- Mission Complete: The Pleasure Domes Await.
AZAZ- Mission Complete: The Pleasure Domes Await.
Edited by Saturn
  • 2 months later...
Protector SE (cartridge) and Protector: Resurgence (CD add-on) Cheats
Invincibility:
Press and hold [pause]+2+4+6 at the title screen. there will be an explosion sound to confirm. do it again to disable.
Rapid Fire:
Pause during gameplay and hold 4+6+8. Release and sound confirms
75 Credits:
Pause during gameplay and hold 0+7+5. Release and sound confirms
Enable All Wave Selects:
Go to the Options screen. Highlight the "Save/Exit" option, hold Pause+Option, and press B to exit the screen.
Expert Mode:
Beat all Waves. A special Victory screen, ship and Expert Mode is unlocked. Another Victory screen awaits at the end of Expert.
Protector (Original cartridge) Cheats:
Press and hold [pause]+4+5+6 at the title screen. there will be an explosion sound to confirm. do it again to disable. (confirmed by "I'm Hit!" audio)
75 Credits:
Pause during gameplay and hold 3+1+6. Release and sound confirms
Rapid Fire:
Pause during gameplay and hold 6+7+8. Release and sound confirms
Insane Wave:
Beat the 10 Easy Waves. Can be selected in Options screen.
Was playing Painter again recently and am posting the level passwords. These are for the original unencrypted CD release in 2003:
1. SNARED
2. MAGIC
3. SPEEDY
4. LEWIS
5. KERMIT
6. THUMPER
7. SNEAKY
8. SYMBOL
9. DOROTHY
10. HUBBLE
11. GELLER
12. HOPPER
13. INVADERS
14. BUSHNELL
15. WILLIAMS
16. JAGLIVES
17. MUSHROOM
18. ASTEROID
19. DECK13
20. TWOOFEM
21. TOOEASY
22. FASTER
23. WILLOW
24. VOGON
25. GATES
26. TRUEGRUE
27. BBWOLF
28. GOOGRIEF+
29. SCALY
30. CREEPER
31. JONAH
32. FORTYTWO
33. SLIMY
34. BIGSHIP
35. WINDY
36. DEGAS
37. CRIPES
38. HITMARK
39. XVIII
40. HEAVYMAN
41. MINTER
42. FOOFOO
43. HIRST
44. NITEWALK
45. SKETCH
46. SPIKEY
47. MILKYWAY
48. LOPSIDED
49. SEMIDONE
50. SMILEY
51. BANDERAS
52. GORT
53. SALMON
54. DUNNO
55. PINFIVE
56. DANCING
57. LURKING
58. INTERMIX
59. PRINCE
60. CRIMINAL
61. SWOOPER
62. COLORFUL
63. FAIREST
64. BIGEYE
65. UGHFEST
66. ROUTE
67. SILKY
68. WOAHBABY
69. SEALAND
70. ENOLAGAY
71. GRUMPY
72. MOSQUITO
73. REALSLOW
74. THISTLE
75. GRIDMARE
76. SEEKER
77. BEATLES
78. THEWALL
79. DAISIES
80. NASTYBOX
81. DARKHERE
82. NOUVEAUX
83. VEGAS2K3
84. DAGGERS
85. SLANTED
86. GLUGGLUG
87. MYSTERY
88. EYEEYE
89. BIGGAPS
90. BINARY
91. JUMPGATE
92. TURNFAST
93. ENDNEAR
94. CHEAPROM
95. FASTPATH
96. CUCUMBER
97. SUCKER
98. WHEREAMI
99. SINIPEDE
I have passwords for the DEMO levels but it's incomplete atm. If I can get past them I'll post all at once, since you can't edit here.
These levels get hard quick though :0
Mad Bodies:
(More of a tip since they apparently removed all cheats from the final release)
If you want to rack-up your points and 1 UPS quickly in MB, do the following:
1st Collect all astronauts
2nd put them on the satellite (space station) as soon as it appears
3rd destroy the satellite quickly by shooting until it is destroyed.
4th make sure your paddle lines up directly under the astronauts
5th juggle them as long as possible on the paddle (hint: you know you’re doing it correctly when you hear them fuss about it)!
These belong to and were rendered by Scott Bigham. I saved them before his page was removed (or abandoned) at:
http://metalstuff.com/area64/jaguar/Codes/avpmaps.htm
