wonky playfield behavior with CTRLPF = $10
9 replies to this topic
#1 BenMcLean OFFLINE
BenMcLean
    Space Invader
  • 38 posts
Posted Tue Aug 12, 2014 12:21 PM
The playfield goes all wonky and doesn't match what I put in visually when I use CTRLPF = $10 with " set kernel_options player1colors playercolors pfcolors". Any idea why that's happening? I've attached a test case.
Attached File  default.bas   1.06KB   106 downloads
Also, I am going to need to use pfread with those kernel options if possible. Does this mean I need to add a module? Random Terrain's site seems to indicate this, but doesn't really explain whether one should use the official pfread_msk.asm or bogax's version.
#2 Gemintronic OFFLINE
Gemintronic
    Jason S. - Lead Developer & CEO
  • 8,910 posts
Posted Tue Aug 12, 2014 12:24 PM
$10 doesn't seem like a valid option according to R.T.s chart.  Have you tried $11 instead?
Update:  Also, I vagualy remember not having great success with the old pfread_msk.asm.  I'd go for whatever bogax did.  Remember: it's only for the multi-sprite kernel.
Update update:  Meaning, pfread is built-in for the other kernels.
#3 bogax ONLINE
bogax
    Dragonstomper
  • 761 posts
Posted Tue Aug 12, 2014 12:37 PM
 I don't think it matters.
 IIRC
 Someone said pfread didn't work
 so I threw out a little bit of code
 that did work
 but when I got around to looking at
 original msk pfread I didn't find anything
 wrong with it, it worked fine.
#4 BenMcLean OFFLINE
BenMcLean
    Space Invader
  • 38 posts
Posted Tue Aug 12, 2014 12:40 PM
The chart says $1x, where (x = don't care). But I can try $11, sure.
#5 BenMcLean OFFLINE
BenMcLean
    Space Invader
  • 38 posts
Posted Tue Aug 12, 2014 12:41 PM
Apparently, all I needed to do was say $11 and it works now. Great! Thanks! I'm gonna message RandomTerrain to suggest that his chart should say $11 instead of $1x
Then I've got to figure out that inline command
Edited by BenMcLean, Tue Aug 12, 2014 12:42 PM.
#6 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,211 posts
  • Medieval Mayhem
Posted Tue Aug 12, 2014 12:45 PM
If you check the Stella Programmer's Guide over at MiniDig you'll see that D0 of CTRLPF controls whether the playfield is Reflected or Repeated.
bB kernels are designed for a Reflected playfield, which means D0 must be set to 1 (that's why all the listed values are odd).
CTRLPF
This address is used to write into the playfield control register (logic 1 causes action as described below)
D0 = REF (reflect playfield)
D1 = SCORE (left half of playfield gets color of player 0, right half gets color of player 1)
D2 = PFP (playfield gets priority over players so they can move behind the playfield)
D4 & D5 = BALL SIZE
#7 Gemintronic OFFLINE
Gemintronic
  • 8,910 posts
Posted Tue Aug 12, 2014 12:48 PM
 IIRC
 that did work
I was probably the one having issues with the pfread_msk.asm and the multi-sprite kernel.   It's a quirky beast.  I'm not surprised pfread works for some people and not others.
#8 SpiceWare OFFLINE
SpiceWare
    Draconian
  • 12,211 posts
  • Medieval Mayhem
Posted Tue Aug 12, 2014 12:54 PM
$13, $15 and $17 will also work.   That section should probably be revised along the lines of:
CTRLPF
Changes properties of the playfield and ball.
Use value $bp where b is the ball setting and p is the playfield setting.
b = 0 for a 1 pixel wide ball
b = 1 for a 2 pixel wide ball
b = 2 for a 4 pixel wide ball
b = 3 for an 8 pixel wide ball
p = 1 for a "normal" bB playfield
p = 3 for "special color" playfield where left half of PF gets player0 color, right half gets player1 color
p = 5 for players move behind playfield
p = 7 for both "special color" and "payers behind" playfield
For example, $25 will set a 4 pixel wide ball and make the players move behind the playfield
Note that ball and playfield properties are both set with a single write.
Edited by SpiceWare, Tue Aug 12, 2014 12:55 PM.
#9 Random Terrain OFFLINE
Random Terrain
    Visual batari Basic User
  • 28,682 posts
  • Controlled Randomness
    Replay Value
    Nonlinear
Posted Wed Aug 13, 2014 7:19 PM
That section should probably be revised along the lines of . . .
How is this:
randomterrain.com/atari-2600-memories-batari-basic-commands.html#ctrlpf
#10 Gemintronic OFFLINE
Gemintronic
  • 8,910 posts
Posted Wed Aug 13, 2014 10:42 PM
I think CTRLPF = $x0 should be mentioned as a valid option.  I've used the playfield reversing effect on my Uppa Creek! homebrew.  Also, in the multi-sprite kernel, it seems to repeat the orientation of the left side instead of mirror it.
Sounds like an unintended feature :)
