CrazyBoss Posted August 14, 2014 Share Posted August 14, 2014 Hi Can I used read of byte 0x1988 to detect the SGM ? ld a,($1988) has value $7 when SGM is plugged. Dont know if that is a safe way to detect the module or there is another way is better ? Should there be a forum for Programming SGM ? or should this tread be moved to Programming Forum ? Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 14, 2014 Share Posted August 14, 2014 Your Colecovision is failing!!! The BIOS is contained in $0000-$1FFF and the bytes contained shouldn't change NEVER. The best method is as Opcode outlined in http://atariage.com/forums/topic/203851-super-game-module-technical-forum/ you should add only a memory test after enabling SGM memory. It's what I've done in my SGM test program http://atariage.com/forums/topic/211871-sgm-test-rom/?do=findComment&comment=2748035 Let me repeat my answer to your previous topic about same subject http://atariage.com/forums/topic/228697-sgm-ram-vs-the-cv-1k-build-ram/?do=findComment&comment=3051929 1 Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 14, 2014 Author Share Posted August 14, 2014 Nanochess are you sure about this ? It seems like the SGM replace the build-in bios by the one in the SGM. The original bios set $F to VDP Register 4, and the SGM bios change that byte to $7 - I do believe cause of the Extra (or replaced) charset used in the SGM Colecovision "load" screen. At least its what happends in BLUEMSX with SGM support, but its an EMULATOR, cant test on real hardware. By the way in bluemsx when run your SGM test rom, it thinks its an ADAM The Memory $2000-$7FFF is enabled from the start. And also in bluemsx, I didn not have any sucess out'ing to port $7F (to enable the memory from $0000-$1FFF) Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 14, 2014 Share Posted August 14, 2014 There is no BIOS inside the SGM. The only thing you can do with the SGM is replace the BIOS with pure RAM in the 0x0000F to 0x1FFF range. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 14, 2014 Share Posted August 14, 2014 Nanochess are you sure about this ? It seems like the SGM replace the build-in bios by the one in the SGM. The original bios set $F to VDP Register 4, and the SGM bios change that byte to $7 - I do believe cause of the Extra (or replaced) charset used in the SGM Colecovision "load" screen. I'm sure about it. As Pixelboy said, the SGM doesn't have a BIOS. At least its what happends in BLUEMSX with SGM support, but its an EMULATOR, cant test on real hardware. By the way in bluemsx when run your SGM test rom, it thinks its an ADAM The Memory $2000-$7FFF is enabled from the start. And also in bluemsx, I didn not have any sucess out'ing to port $7F (to enable the memory from $0000-$1FFF) It's because BlueMSX doesn't have full support for Super Game Module, specially the port $7f for mapper. It includes only the Opcode PSG module for the PSG sound, and you adjust manually the machine config to enable $2000-$7fff RAM like in ADAM. So my test shows it as an ADAM because the RAM is active from start. In real hardware, the SGM memory doesn't appear until you activate it writing $01 to port $53, and the BIOS isn't changed to RAM until you write to port $7F. I know it because I've bought one SGM unit. Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 14, 2014 Author Share Posted August 14, 2014 (edited) Maybe I am stupid, but where do the New charset and the improved charset at the boot screen come from ? There must be some data or rom inside the SGM. Is it possible that there is a patched bios rom inside the SGM and the SGM disable the original bios in the Colecovision. Or maybe there is a normal rom which in run before the cartrigde, and this rom have will boot the cartrigde and showing the new bootscreen.? see attached screen shot. Or maybe this is only true for Bluemsx not for a real Colecovision with SGM? Edited August 14, 2014 by CrazyBoss 1 Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 14, 2014 Share Posted August 14, 2014 Maybe I am stupid, but where do the New charset and the improved charset at the boot screen come from ? There must be some data or rom inside the SGM. Is it possible that there is a patched bios rom inside the SGM and the SGM disable the original bios in the Colecovision. Or maybe there is a normal rom which in run before the cartrigde, and this rom have will boot the cartrigde and showing the new bootscreen.? see attached screen shot. Or maybe this is only true for Bluemsx not for a real Colecovision with SGM? Ooooooohhhh, what version of BlueMSX are you using? or how you configurate it? I would like to give a look BTW, the real SGM doesn't show anything of this. Probably it's only BlueMSX. Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 Ooooooohhhh, what version of BlueMSX are you using? or how you configurate it? I would like to give a look BTW, the real SGM doesn't show anything of this. Probably it's only BlueMSX. I do believe I used a guide made by you from this forum it contain a file called bios_xp.rom which basicly is the coleco.rom but but the coleco.rom is moved to $2000, and byte $1988 is $07 instead of $0F, and the range from $0000-$1fff contains other data, a good guess must be the enhanced charset + the "COLECOVISION" logo. I might be that ealier SGM ment to be like this, and it was dropped by opcode, in the final product ? at www.colecovision.dk OLE mention: "This picture shows you first a 3-second start-up sequence for the SGM. Nicely animated. This start-up sequence will be used every time you turn on your ColecoVision with SGM plugged in. The start-up sequence is removed from the final module and will probably instead be showed in all new upcoming Super Games from OpCode Games." so that is the answer so the rom is removed from the final product. So a Super Game Module (Light) could be created - only for use with ADAM. Which only have the PSG inside. No need to have the Memory on the module. Can the ADAM also disable the CV rom and use $0000-$1FFF for Memory ? So the Easy way could be: 1) Check for a AY-3-8910 CPU - if found continue else exit. 2) Write two different bytes to $6000 and $6400. 3) Check if value of $6000 and $6400 are different, if so is an ADAM - jump to 5. 4) Enable the SGM ram by write 1 to port $53 5) write some data to $2000 and check if its written as it should. If not something is wrong - exit. 6) Continue the game code. 1 Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 15, 2014 Share Posted August 15, 2014 So a Super Game Module (Light) could be created - only for use with ADAM. Which only have the PSG inside. No need to have the Memory on the module. The SGM is already 100% compatible with the ADAM. If I remember correctly, when the SGM is plugged into an ADAM, it uses the RAM in the ADAM instead of using its own RAM, in order to avoid hardware conflicts. Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 15, 2014 Share Posted August 15, 2014 Can the ADAM also disable the CV rom and use $0000-$1FFF for Memory ? So the Easy way could be: 1) Check for a AY-3-8910 CPU - if found continue else exit. 2) Write two different bytes to $6000 and $6400. 3) Check if value of $6000 and $6400 are different, if so is an ADAM - jump to 5. 4) Enable the SGM ram by write 1 to port $53 5) write some data to $2000 and check if its written as it should. If not something is wrong - exit. 6) Continue the game code. Yep, it's just right and reasonable Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 The SGM is already 100% compatible with the ADAM. If I remember correctly, when the SGM is plugged into an ADAM, it uses the RAM in the ADAM instead of using its own RAM, in order to avoid hardware conflicts. You are right, when using on ADAM you dont enable the SGM ram, but use ADAM's own ram - But I dont know if its possible to disable the CV bios in order to get ram area $0000-$1FFF ? SGM dont do anything but provide the AY-3-8910 chip, until you enable the memory (which you should not do at an ADAM computer). But strange why Opcode dropped the enhanced charset and Colecovision logo, it looks way better than the standard CV bootscreen, and also had "Skip by pressing fire" function Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 15, 2014 Share Posted August 15, 2014 You are right, when using on ADAM you dont enable the SGM ram, but use ADAM's own ram - But I dont know if its possible to disable the CV bios in order to get ram area $0000-$1FFF ? Yes it is. I don't remember how to do it, but nanochess knows how. But strange why Opcode dropped the enhanced charset and Colecovision logo, it looks way better than the standard CV bootscreen, and also had "Skip by pressing fire" function It was mostly a question of cost, and also to make the SGM electronics fit into the ADAM Auto-Dialer casing. Quote Link to comment Share on other sites More sharing options...
opcode Posted August 15, 2014 Share Posted August 15, 2014 Maybe I am stupid, but where do the New charset and the improved charset at the boot screen come from ? There must be some data or rom inside the SGM. Is it possible that there is a patched bios rom inside the SGM and the SGM disable the original bios in the Colecovision. Or maybe there is a normal rom which in run before the cartrigde, and this rom have will boot the cartrigde and showing the new bootscreen.? see attached screen shot. Or maybe this is only true for Bluemsx not for a real Colecovision with SGM? Who made my enhanced BIOS publicly available? I don't remember releasing it... That is why 1988h is different, because that was a bug in the original and I fixed that for the V9958. Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 This routine should enable the SGM ram if its not an Adam computer. ;Enable SGM ;modify AF,$6000,$6400 ; ld a,254 ld ($6000),a cpl ld ($6400),a ld a,($6000) cp 254 ret z out ($53),a ret 1 Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 15, 2014 Share Posted August 15, 2014 This routine should enable the SGM ram if its not an Adam computer. ;Enable SGM ;modify AF,$6000,$6400 ; ld a,254 ld ($6000),a cpl ld ($6400),a ld a,($6000) cp 254 ret z out ($53),a ret I don't get it, why is this routine useful? Doesn't the SGM itself decide if it's going to use the ADAM RAM instead of its own? Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 take a look here: http://colecovision.dk/sem.htm at the last 1/3th down you will find: "Here are the steps required to initialize a Super Game Module game" Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 15, 2014 Share Posted August 15, 2014 No offense to Ole Nielsen, but his web site is not always completely correct and up to date. I know that the game software can detect if it's being run on an ADAM (RAM test works but no AY-3-8910 sound chip present) but where RAM usage is concerned, can someone please confirm that the game software needs to perform a special extra step when the SGM is plugged into an ADAM? Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 (edited) Opcode mention it here: http://atariage.com/forums/topic/203851-super-game-module-technical-forum/ Not sure it changed even this information is quite old. Edited August 15, 2014 by CrazyBoss Quote Link to comment Share on other sites More sharing options...
Pixelboy Posted August 15, 2014 Share Posted August 15, 2014 Opcode mention it here: http://atariage.com/forums/topic/203851-super-game-module-technical-forum/ Not sure it changed even this information is quite old. Okay, I see... The 2000h to 5FFFh range will already be writable RAM if it's an ADAM, so no need to activate the RAM in the SGM in that case. Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 15, 2014 Author Share Posted August 15, 2014 (edited) Okay, I see... The 2000h to 5FFFh range will already be writable RAM if it's an ADAM, so no need to activate the RAM in the SGM in that case. yes you got it actually Opcode recommend NOT to enable the SGM memory if its an Adam. And since we learned that the Memory at the Adam is not mirrored ($6000-$7FFF) we can do a simple test, by writing a value to $6000 and another value to $6400, if its a ColecoVision, then the byte written to $6400 will be written to $6000 (cause of mirrored ram) This routine should enable the SGM ram if its not an Adam computer. ;Enable SGM ;modify AF,$6000,$6400 ; ld a,254 ld ($6000),a cpl ld ($6400),a ld a,($6000) cp 254 ret z out ($53),a ret Just to explain the routine. 1) We load 254 (decimal) into $6000 2) We inverts all the bits of reg. A using CPL. (Funny enough reg. A will now be 1) 3) We load Reg. A (=1) into $6400 (If its a ColecoVision the ram mirroring means that $6000 will have this Value too) 4) We read the value of $6000 into Reg. A (if its an Adam it will be 254 as we did in STEP 1, else it will be 1 cause of step 3) 5) If the Value is 254 we return the routine. 6) We out value of reg. A to port $53 to enable the SGM RAM - reg. A = 1 and return the routine. After this another routine is needed to check if the ram works, It could look like this: ld hl,$2000 ld a,(hl) inc (hl) cp (hl) jp z,xxxx ;jump to xxxx if its a Colecovision, and the ram is not enabled (maybe no SMG is plugged in, or malfunction). Edited August 15, 2014 by CrazyBoss Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 18, 2014 Author Share Posted August 18, 2014 actually will it work ? Is the ram area $6000-$7fff changed when enable the SMG memory? if so do a call and enable the ram will destroy the stack? or do smg actually "only" enable the memory from $2000-$5FFF ? and $6000-$7fff is the 1k build in mirrored memory? Quote Link to comment Share on other sites More sharing options...
+nanochess Posted August 18, 2014 Share Posted August 18, 2014 actually will it work ? Is the ram area $6000-$7fff changed when enable the SMG memory? if so do a call and enable the ram will destroy the stack? or do smg actually "only" enable the memory from $2000-$5FFF ? and $6000-$7fff is the 1k build in mirrored memory? Yep, activating the SGM memory will deactivate the mirrored memory, so the SGM activation routine should be at start of ROM and NOT in a subroutine. Quote Link to comment Share on other sites More sharing options...
opcode Posted August 18, 2014 Share Posted August 18, 2014 For all information you might need, please refer to this thread: http://atariage.com/forums/topic/203851-super-game-module-technical-forum/ Quote Link to comment Share on other sites More sharing options...
CrazyBoss Posted August 27, 2014 Author Share Posted August 27, 2014 By the way found this information at http://map.grauw.nl/resources/msx_io_ports.php#psg The following table describes the registers of the PSG: Register(s) Description 0-5 Tone generator control 6 Noise generator control 7 Mixer control-I/O enableImportant note: bit 6 must be 0, and bit 7 must be 1. Setting different values can cause damage on some systems. Safest approach is to just not touch them and read them first before writing a new value. 8-10 Amplitude control 11-13 Envelope generator control 14-15 I/O ports A & B Seems like you could do damage to the psg, if you put wrong values to reg.7 I dont know if its only at MSX or it could be the same for the SGM. I even saw MSX games, put a safety routine in there sound routine. where they check for values on reg.7 and make sure those bits are right!!!! Quote Link to comment Share on other sites More sharing options...
opcode Posted August 28, 2014 Share Posted August 28, 2014 By the way found this information at http://map.grauw.nl/resources/msx_io_ports.php#psg The following table describes the registers of the PSG:Register(s) Description 0-5 Tone generator control 6 Noise generator control 7 Mixer control-I/O enableImportant note: bit 6 must be 0, and bit 7 must be 1. Setting different values can cause damage on some systems. Safest approach is to just not touch them and read them first before writing a new value. 8-10 Amplitude control 11-13 Envelope generator control 14-15 I/O ports A & B Seems like you could do damage to the psg, if you put wrong values to reg.7 I dont know if its only at MSX or it could be the same for the SGM. I even saw MSX games, put a safety routine in there sound routine. where they check for values on reg.7 and make sure those bits are right!!!! That is not the case with the SGM, the I/O ports aren't connected. You cannot damage anything... Quote Link to comment Share on other sites More sharing options...
