SIO2BT
TheMontezuma
Waiting on mine :) is anyone using a cheap tablet and the app? Or is everyone using laptops or phones?
The SIO2BT app is compatible with all Android devices starting from Android 2.1.
If only your tablet has a bluetooth on board, everything should work well.
If your tablet is newer (Android 4.0.3 and up) you may also give a try to the Android AspeQt port by Greblus:
https://play.google.com/store/apps/details?id=org.qtproject.example.AspeQt&hl=en
I'm not the best speaker, but I hope this will give you the idea:
Apple didn't want to support serial port profile: https://support.apple.com/en-us/HT204387
Nice setup you have there. SIO2SD on the left I assume. What is the LCD screen on the right (it was showing the OS)?
Thanks.
The display on the right side belongs to Bios4Config extension.
It is basically a OS switch which additionally controls STEREO (enable/disable) and RAM (64kB/512kB/1MB).
You get the same and more with Ultimate 1MB.
Thanks. I love my U1MBs, but they don't give me that awesome LCD display :)
Thanks. My english is not that good to say if it was ironic or not, but anyway you have a PM :)
Since it is easier to create a SIO2BT in a 3D printed plug, the price goes down to 30€ for a complete unit.
To save your time (if are interested and do not want read through several pages),
here is a small summary about the current status of the project:
I am kind of interested. I just... need to get one of those other thingies to make it work the best? The big Q then becomes will it be then cheaper than just getting a Lotharek?
If you are fine with 19200 (standard ATARI disk baudrate) then SIO2BT + a customized OS (EPROM) is a pretty good solution.
For 57600, you would need other "thingies" ;-)
Lotharek offers several solutions for ATARI (SIO2PC, SIO2SD, SIDE2, etc.).
I personally use SIO2BT most of the time, but if you just begin your adventure with new accessories I would go for SIO2SD from Lotharek.
For those who like to use MyBIOS, here is a link to my wip-folder.
http://www.mr-atari.com/MyBIOS/BETA_wip/
The BIOS fully support SIO2BT and (should) run as stand-alone OS perfectly fine.
Features:
Fully XL/XE-compatible
Fully 400/800-compatible
Fast mathpack routines
SIO2BT-tools can stil be found here:
Thanks, Sijmen.
  • Like 5
Features:
Thanks, Sijmen.
Hi Sijmen,
Could you please write some background information about the MyBIOS and MyIDE II firmware development? Especially:
1) I understand that MyIDE II devices shipped by Steve come with an older firmware version, is it correct? Was the "original" firmware developed by you?
2) Are there any "official" recommended (stable) releases since this older firmware or there is only the latest and greatest firmware available from you (what is the current version)?
3) MyIDE-][.bin is the 512kB firmware for MyIDE II and MyBIOS-ROM-FMP.ROM is the 16kB MyBios ROM which can be used even without MyIDE II, is it correct ?
4) What means "FMP" in the name of the MyBIOS ROM?
Good questions:
1/ MyIDE 4.8.01 was the original shipping firmware, upgraded to 4.8.06.
This is the shipping firmware. Yes I made this, FAT-loader is by Steve.
2/ All releases, manuals and stuff are on the user forum, hosted by atarimax.com
4.8.06 is the latest stable and official version, but there have been many beta's that are quit stable.
Last released and stable beta is 4.9.B16 (found on the forum).
After B16, there are only wip-versions, now available as download, to generate some feedback.
3/ yes
4/ Fast Math Pack :-)
I forgot to mention that the current upload only has the stand-alone MyBIOS.
With MyIDE-][ support and SiO2BT.
The RAM version loaded from MyIDE is not on it yet.
The bootloader was broken, redoing that at the moment.
So, perhaps, soon, you can download both.
I will include a change log.
Fixed.....
MyBIOS-RAM now included on the MyIDE-][ content.
SIO-supports 19k2, 38k4 and 57k6 to any device.
SIO2BT-support is default ON.
You can change this to OFF during "power-up".
This will speed-up serial IO when you try to access a not present device.
The new BIOS has a check-summed configuration-byte.
If this is corrupted by any (ab)using software, it tries to recover or reset to default.
System Defaults are:
BASIC off
HSIO on
SIO2BT on
  • 1 month later...
MyBIOS update #3, 27-05-2017 !
http://www.mr-atari....yBIOS/BETA_wip/
Change-log:
http://www.mr-atari.com/MyBIOS/BETA_wip/change-log.txt
Features:
Also very good to use as alternative OS in Altirra and other emulators.
  • Like 4
  • 1 month later...
FYI, I am getting a DOS Average of 3798.70175 B/sek @ 57600bps, and 2810.505787 B/sek @ 38400bps using a SIO2PC.
Yeah, sure.
But Bluetooth has a transponder delay of about 50 ms on each IO-command.
So knowing this 3 kB/s is not bad at all.
On SIO2PC I get 4.2 kB/s (57k6)
On SIO2PC(USB, atarimax) roughly 6.7 kB/s (128k)
