Ray Casting Engine Demo
34 replies to this topic
#26 YANDMAN OFFLINE
YANDMAN
    Dragonstomper
  • 509 posts
Posted Sun Nov 16, 2014 9:15 AM
Bring on Doom
#27 Wickeycolumbus OFFLINE
Wickeycolumbus
    Red Sea Crosser
  • 5,149 posts
Posted Sun Nov 16, 2014 9:46 AM
This looks amazing, nice work :thumbsup:
Would you say it's nearly impossible to do something similar without the ARM code, retaining DPC+?  Even if it was painfully slow or lower resolution?
#28 Joe Musashi OFFLINE
Joe Musashi
    Moonsweeper
  • 307 posts
Posted Sat Nov 22, 2014 10:32 AM
Merlin's Wall has shown that it is in principle possible without an ARM. However, AFAIK it requires a tilted screen so that it can use a symmetric playfield. A not-tilted version would have to use an asymmetric playfield which would then have to be updated in every line.
A 32 bit wide playfield with coarse vertical resolution may be doable, but it would probably be much slower than Merlin's Walls.
#29 iesposta OFFLINE
iesposta
  • 3,620 posts
  • Retro-gaming w/my VCS
Posted Thu Mar 30, 2017 11:11 PM
Anyone know who programmed this Raycasting demo?
The YouTuber just says, "He.."
At 6:56 min mark!
#30 Thomas Jentzsch OFFLINE
Thomas Jentzsch
    Thrust, Jammed, SWOOPS!, Boulder Dash, THREE·S, Star Castle
  • 23,086 posts
  • Always left from right here!
Posted Fri Mar 31, 2017 12:54 AM
[deleted]
Edited by Thomas Jentzsch, Fri Mar 31, 2017 12:59 AM.
#31 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 643 posts
Posted Fri Aug 18, 2017 10:28 AM
I did. It uses the display kernel that I discussed here.
#32 Thomas Jentzsch OFFLINE
Thomas Jentzsch
  • 23,086 posts
Posted Fri Aug 18, 2017 10:48 AM
Did you post a ROM for that demo somewhere?
#33 ZackAttack OFFLINE
ZackAttack
    Dragonstomper
  • 643 posts
Posted Fri Aug 18, 2017 7:50 PM
No, I haven't posted a ROM for it yet.
#34 Mr SQL OFFLINE
Mr SQL
  • 1,851 posts
Posted Sun Aug 20, 2017 9:22 PM
That is an awesome rendering engine, you should make a FPS or 3D pacman :)
#35 8-bit_d-boy OFFLINE
8-bit_d-boy
    Star Raider
  • 53 posts
Posted Mon Aug 21, 2017 2:22 PM
Excellent work! This runs very smooth in Stella. My only suggestion would be to make the Color/BW switch switch between rendering modes.
Now to make Tunnel Runners 2!
