David Baldwin Posted August 29, 2014 Share Posted August 29, 2014 I got my Atari 520STe working at last and its new for me but now when i tern on the STe there is no video output to the tv set. But the STe boot up ok and runs good but no video can i have some help in getting the video output working. David B Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted August 30, 2014 Share Posted August 30, 2014 How you know that it boots up OK ? What cable, connectors you use, on what TV input ? Just to mention that you need to tune TV on VHF low, aprox. channel 2 for Atari, if use RF cable (antenna cable). Quote Link to comment Share on other sites More sharing options...
Rybags Posted August 30, 2014 Share Posted August 30, 2014 The analog channel can vary depending on country of sale of the machine. You could verify the machine works by outputting the RCA audio to some powered speakers - fairly sure the standard ST audio is also piped out. Once the desktop is active (takes almost a minute if no floppy inserted), you should get key clicks. Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted August 30, 2014 Author Share Posted August 30, 2014 How you know that it boots up OK ? What cable, connectors you use, on what TV input ? Just to mention that you need to tune TV on VHF low, aprox. channel 2 for Atari, if use RF cable (antenna cable). So I tune the tv to the atari i dont press av on the tv set then, I plug into the antenna socket, And it boots fine i made a lang disk it started up fast and with out the disk in it boots longer thanks for the info. David B Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted August 30, 2014 Author Share Posted August 30, 2014 So I tune the tv to the atari i dont press av on the tv set then, I plug into the antenna socket, And it boots fine i made a lang disk it started up fast and with out the disk in it boots longer thanks for the info. David B My Atari STE dont have Lo/HI at the back of it looking at the book that came with the atari STE is for ST model it has televion and lo/hi. On my STE it only has the video plug but the kind you wood use for a video connecter not tv. is more help for you exerts out there. Quote Link to comment Share on other sites More sharing options...
David Baldwin Posted August 30, 2014 Author Share Posted August 30, 2014 My Atari STE dont have Lo/HI at the back of it looking at the book that came with the atari STE is for ST model it has televion and lo/hi. On my STE it only has the video plug but the kind you wood use for a video connecter not tv. is more help for you exerts out there. Thanks i did a scan and i now have atari on my tv set cool. Quote Link to comment Share on other sites More sharing options...
