Keatah Posted August 30, 2014 Share Posted August 30, 2014 https://github.com/AppleWin/AppleWin/releases/tag/v1.25.0 1.25.0 - 28 Aug 2014 Changes:. Changed the AppleWin project host from BerliOS to GitHub.. Dropped support for Win98/ME, as AppleWin now built with VS2008 Express:So AppleWin will only work under Windows 2000 and later.. [Feature #221] Restored F6 original behavior that was changed in v1.22.0. F6 Toggle full-screen / windowed mode. Ctrl-F6 Toggle windowed 1x/2x zoom. . Ctrl-PrintScreen will copy the text screen (auto detect 40/80 columns) to the clipboard.. [Feature #198] Alt-Return toggles full screen.. [Feature #199] Added a configuration option "Confirm reboot" to skip the F2 reboot confirmation.. [Feature #201] Added display of current Track/Sector for the floppy drives. In 2x window mode the status is displayed below the drive LEDs. In full screen mode the status is displayed above the drive LEDS. The track/sector is shown only for the last drive accessed. Note: DOS3.3 Track/Sector status should be accurate. ProDOS support is preliminary -- the track/sector may show zero after an operation. . Memory initialization defaults to even pages FF, odd pages 00.. Added command line switch to specify the type of memory initialization pattern -memclear # where # ranges from 0 to 7. -memclear 0 initializes memory to zero, -memclear 1 initializes memory to random values, -memclear 2 initializes memory to 4 byte pattern: FF FF 00 00, -memclear 3 initializes memory to even pages FF, odd pages 00, -memclear 4 initializes memory to first half page 00, last half page FF, -memclear 5 initializes memory to first half page FF, last half page 00, -memclear 6 initializes memory to byte offset of that page (current memory address low byte): i.e. 00:00 01 02 03 ... for page $20, -memclear 7 initializes memory to page address (current memory address high byte): i.e. 00:20 20 20 20 ... for page $20. NOTE: -memclear 6 can cause a few programs to NOT function correctlydue to hidden bugs of programmers not correctly initializing memory orusing uninitialized memory. RNDL/RHND and $620B are initialized toallow Pooyan, and the Beautiful Boot game launcher to run, along with$BFFD..BFFF to allow Copy ][ v5 to boot correctly. . Debugger (v2.8.0.0): Added: TSAVE "filename" to save the text screen to a file. It will auto-detect the current video mode: 40/80 columns. Default filename for 40 columns is: AppleWin_Text40.txt Default filename for 80 columns is: AppleWin_Text80.txt Changed: DS to ASC because DS is used as a common "Define Space" assembler directive Added: Experimental "ASC" command to mark up data as Apple text.Using Castle Wolfenstien.DSK as an example: BLOAD ^VOCABASC name1 17DA:17F5 Fixed: DB address now auto-defines the symbol D_#### if no symbol is given. Fixed: DW address now auto-defines the symbol W_#### if no symbol is given. Fixed: ASB address now auto-defines the symbol T_#### if no symbol is given. Added: Help for DB and DW. Fixes:. [bug #206] Pooyan would freeze due to RNDL/RNDH not initialized to non-zero values ona cold boot.. [bug #177] Full-screen under Windows8/8.1 would show a corrupt, pastel color palette.. Debugger: Hang with Memory Fill when memory ends at FFFF, i.e. F D000:FFFF 0 Hang with Memory Move when memory ends at FFFF, i.e. 2000<FFFE.FFFFM Quote Link to comment Share on other sites More sharing options...
