_The Doctor__ Posted November 15, 2014 Share Posted November 15, 2014 if you can work out where you went wrong before the timer runs out that is Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 15, 2014 Share Posted November 15, 2014 Hard, L6 - 716,400. I'd spent so much time away from the last levels I'd practically forgotten the order of battle and made a bunch of mistakes there. Another strategy thing for points - it seems you get 600 per second remaining so it becomes a case of just leave some items behind if they take too long to get to. Plus in some levels you get the luxury of doing it in whatever order you want so it makes sense to get the ones that drop stuff earlier. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 16, 2014 Share Posted November 16, 2014 Still L6, a bit further though - 777,400. Quote Link to comment Share on other sites More sharing options...
Level42 Posted November 16, 2014 Share Posted November 16, 2014 ESC aborts the game. I'd rather see more levels than the burden of extra code to work out if you're at stalemate. Besides that, you can still explore and maybe work out where it went wrong. AH.....why didn't I think of that.... You're right ! Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 3, 2015 Share Posted January 3, 2015 Discovered a couple of bugs. If you let off a shot then change colour before it hits an enemy, the shot inherits the new colour. Unsure if it's also the case if you change manually at a station (and it would probably require lightning speed to do so). Recent game, picked up a colour change pill at the same time as being shot by an enemy. A couple of pixels of the colour change pill remained on the left side, running it over later registered the pill again. Quote Link to comment Share on other sites More sharing options...
MaPa Posted January 3, 2015 Share Posted January 3, 2015 The first one is a "feature" not a bug But the second one is a bug of course. I will look into it when I have some time. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 4, 2015 Share Posted January 4, 2015 (edited) Finished Hard from start to finish in one go at last. I can generally do Levels 0-4 in an "optimal" sense where I'm getting near the highest possible score every time. 5 thru 7 is very different though. In general you can lose 20+ seconds per level just waiting around for shoot/avoid opportunities. On the lower levels you can usually just rush through with little regard of being shot - so long as you do the level in the proper order you almost always get away with it. Edited January 4, 2015 by Rybags 2 Quote Link to comment Share on other sites More sharing options...
MaPa Posted January 4, 2015 Share Posted January 4, 2015 Damn.. you have better score than I had Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 4, 2015 Share Posted January 4, 2015 Also there's that second last time bonus in Level 5 - in getting it you have to lose energy via the falls, and you only end up gaining 12 seconds or so because you've backtracked. But the last 3 levels as I said - the best laid plans are often quashed, so easy to get screwed over in a big way through just 1 or 2 seemingly small mistakes. Quote Link to comment Share on other sites More sharing options...
pseudografx Posted January 5, 2015 Author Share Posted January 5, 2015 Also there's that second last time bonus in Level 5 - in getting it you have to lose energy via the falls, and you only end up gaining 12 seconds or so because you've backtracked. But the last 3 levels as I said - the best laid plans are often quashed, so easy to get screwed over in a big way through just 1 or 2 seemingly small mistakes. I don't really remember if it applies to the situation you describe, but I do remember that there is a place where you can collect a bonus when falling down several floors, which indeed costs quite a bit of energy. However, if you time your fall so that you land on an enemy, you will lose less energy than by falling. Quote Link to comment Share on other sites More sharing options...
Rybags Posted January 5, 2015 Share Posted January 5, 2015 Level 4, you have that energy where you have to fall - it's shortly after an invincible pill but unsure if the duration is enough. I usually just cop the full energy loss there - there's a slight net gain. Might have to try dropping onto the enemy to see if the loss is lesser. Quote Link to comment Share on other sites More sharing options...
pseudografx Posted January 5, 2015 Author Share Posted January 5, 2015 Might have to try dropping onto the enemy to see if the loss is lesser. Believe me, it is. That's why I designed that part of the level this way :-) Quote Link to comment Share on other sites More sharing options...
pseudografx Posted January 5, 2015 Author Share Posted January 5, 2015 (edited) To explain this: Touching an enemy costs 1 point of energy on Easy and 2 points on Hard. Falling down 2 whole floors costs 3 points. The formula for calculating energy loss for falling is like this: falling by less than a whole floor is always harmless. After that each half a floor costs one point of energy. Edited January 5, 2015 by pseudografx Quote Link to comment Share on other sites More sharing options...
