Starting with programming.
RHillFake
newcoleco's devkit has lots of samples and some good documentation in C:
http://ccjvq.com/newcoleco/
Look at Software->Programming Tools. It uses the good work from PKK on SDCC, but with Daniel's libraries and stuff that is based on the original C library by Marcel de Kogel, as updated and changed by Daniel.
Or I have a little about making a SuperGAME in assembly at:
http://www.adamcon.org/~dmwick/mayan/
Although much of what I do would work fine for ColecoVision programming using the OS7 BIOS functions.
  • 1 month later...
  • 2 weeks later...
Since this thread is about getting started with programming, I might as well ask my stupid questions here...
I went to Sebastian Mihai's website to get the Coleco C dev kit and put it in C:\z80 as instructed. I saw that he included his Mowleco game, so I duplicated the directory and renamed it "learning," with the intent of fiddling around with it until I get an idea of how stuff works.
I run CCI3.exe and "learning" shows up as expected. I click "Compile All" then "Link" then "Run." The emulator pops up, though I have to select the result.ROM file by hand (mildly annoying). It works... but it doesn't actually reflect any changes I made to mowleco.c. Likewise when I try make.bat from the "learning" directory and press Default (as instructed) then Compile, Link, and Run. At least CCI2 will open the game in the compiler when I press Run, but, again, the game doesn't reflect any changes I make to the .c file.
What am I doing wrong?
Are you sure you saved the C file after your changes and before compiling.
Yeah, but I think I was doing something else wrong.
I just went back to things again. This time, I tried something different:
1. I deleted all files from the project directory except for mowleco.c, tiles.c, and the run.bat and make.bat files
2. I switched to view files by Date Modified, so I can see the most recent files as they're created at the top.
After that, I tried CCI3 first:
1. I opened CCI3
2. The "learning" folder was selected by default, so I clicked mowleco.c and then Compile:
Files created: mowleco.sym, mowleco.rel, mowleco.lst, mowleco.asm
3. I then chose tiles.c and hit Compile again:
Files created: tiles.sym: tiles.rel, tiles.lst, tiles.asm
4. Next, I clicked Link:
Files created: result.rom, crtcv.noi, crtcv.noi, crtcv.map, crtcv.lk, crtcv.ihk
5. Finally, I clicked Run. However, since that doesn't automatically open the ROM (for some reason), I had to navigate to it and select it.
6. This time, I saw a change, which is great!
That worked! Maybe I hadn't clicked on each of the files (mowleco.c and tiles.c) and compiled both before linking.
Alternately, after deleting all but the bat and c files, I tried CCI2 through make.bat:
1. I opened make.bat, which opens CCI2
2. I clicked "Default" as advised, which selects crtcv.rel, cvlib.lib, and getput.lib
3. Next, I clicked Compile All:
Files created: mowleco.rel, c.bat, and tiles.rel
4. Then, I clicked Link:
Files created: result.rom, l.bat, crtcv.noi, crtcv.map, certcv.lk
5. Finally, I clicked Run (which works) and saw the expected change. Woo!
So maybe I was just doing something stupid and not realizing it.
Is there any reason to use CCI3 over CCI2? Why do such a different set of files get created? Why does the Run option in CCI3 not work correctly?
Edited by Cybearg
