emkay Posted September 16, 2014 Share Posted September 16, 2014 (edited) Here are just some demonstrations of sound creation, just using the Pulse Width Modulation feature of POKEY. ">" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350"> This one uses the direct output in RMT , filter and 15kHz. It plays always the same Note. And this one uses a higher note, same settings and directly recorded from A800, as Altirra cannot handle this correctly. It varys between a high noise but low energy tone and a low noise high energy tone. Edited September 16, 2014 by emkay 2 Quote Link to comment Share on other sites More sharing options...
emkay Posted September 17, 2014 Author Share Posted September 17, 2014 What it exactly means to have this modulation abilities, shows this video: Have a look at the wave indicator, due to the raw manipulations possible in RMT, it show only a part of what is really possible. The modulation turns the double squares sometimes into a sawtooth wave. And, also , the video shows that the sound gets never to the cancelling point of the generators, which shows that the modulations really can be repetetively handled. It could be interesting to have a tool that allows the manipulations in some CPU cycles, instead of VBI cycling. Quote Link to comment Share on other sites More sharing options...
emkay Posted September 17, 2014 Author Share Posted September 17, 2014 And a last one for comparision Altirra 64khz mode. Just some notation steps from on octave into another. Different frequency ranges need different modulation setups. Sounds very melancholic Quote Link to comment Share on other sites More sharing options...
analmux Posted September 17, 2014 Share Posted September 17, 2014 What's the purpose of these tests? Quote Link to comment Share on other sites More sharing options...
emkay Posted September 17, 2014 Author Share Posted September 17, 2014 Showing that 8 bit resolution , 4 bit volume and "Square-Waves" weren't the limits . The sounds are based on "OPL 2" and "OPL 3" , just using the offset programming, aka Pulse width modulation + Ring Modulation... name it as you like. If , probably, someone wants to create a fully working POKEY Tracker, he , probably, considers to add the features... Quote Link to comment Share on other sites More sharing options...
analmux Posted September 17, 2014 Share Posted September 17, 2014 OK, then search details here: Find words: pokey reset offset Find author: analmux (as posts) atariage.com/forums/topic/195085-complex-pokey-thread/page-6#entry2484011 atariage.com/forums/topic/68283-hardsynth/?p=1460512 atariage.com/forums/topic/159104-some-information-please/?p=1962220 atariage.com/forums/topic/177615-hardsynth-what-is-it-exactly/ atariage.com/forums/topic/175965-hardsynth-tracker-brainstorm/ To me many of the extended PoKey sound possibilities are clear. 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted September 18, 2014 Author Share Posted September 18, 2014 To me many of the extended PoKey sound possibilities are clear. Ofcourse you know it. But others don't , as I had to read again here in the forums that POKEY only can produce simple square waves. Thanks, for the links btw. Quote Link to comment Share on other sites More sharing options...
emkay Posted September 18, 2014 Author Share Posted September 18, 2014 Could it be possible to have a tracker that is able to create those instruments that fit better to a tune? A Piano, a Guitar ... and so on... you press a key and the tracker is playing the predefined instrument and settings...? This is one of my "most wanted" "most original" playback tunes. The "piano" has a touch of a "piano" and the Guitar has a "guitar" flanger effect. I put a more obvious different "face" into the guitar, to show that the variations were stable. Those programmed variation can also get an "AA" "EE" "II" "OO" "UU" touch. With the same note being played... Also, the Guitar uses only one setup of "corrections" and it shows a well stability from the lowest to the highest notes. And, even the highest notes have some stable variations ... 1 Quote Link to comment Share on other sites More sharing options...
Heaven/TQA Posted September 18, 2014 Share Posted September 18, 2014 I love the first 2 tests with the PWM.... how did you create them? Quote Link to comment Share on other sites More sharing options...
+Stephen Posted September 18, 2014 Share Posted September 18, 2014 Could it be possible to have a tracker that is able to create those instruments that fit better to a tune? A Piano, a Guitar ... and so on... you press a key and the tracker is playing the predefined instrument and settings...? This is one of my "most wanted" "most original" playback tunes. The "piano" has a touch of a "piano" and the Guitar has a "guitar" flanger effect. I put a more obvious different "face" into the guitar, to show that the variations were stable. Those programmed variation can also get an "AA" "EE" "II" "OO" "UU" touch. With the same note being played... Also, the Guitar uses only one setup of "corrections" and it shows a well stability from the lowest to the highest notes. And, even the highest notes have some stable variations ... These are cool sounding. Quote Link to comment Share on other sites More sharing options...
emkay Posted September 19, 2014 Author Share Posted September 19, 2014 (edited) I love the first 2 tests with the PWM.... how did you create them? 15khz mode Filter and the pitch at the main channel one "up" or "down" and back. As pokey stores the last position of a wave, which results in a different position for the same frequency, you get the resulting pulse width. Edited September 19, 2014 by emkay Quote Link to comment Share on other sites More sharing options...
emkay Posted September 19, 2014 Author Share Posted September 19, 2014 These are cool sounding. These a really cool. Particular the big frequency range, the guitar is following, it's never yelling. Have you realized how high the sounds get without a disturbing noise? btw. the "octaves" tune plays the similar high "sawtooth" sound at 64khz. The 1st "filter" sound is standard filter, the 2nd filter sound uses Ringmodulation to enhance the background. At least RMT helps to show many of the possibilities. And, I'm pretty sure, we could let POKEY "sing" without using all CPU cycles Quote Link to comment Share on other sites More sharing options...
Creature XL Posted September 19, 2014 Share Posted September 19, 2014 Sounds great. Is that what you did the last months when you weren't posting here? 1 Quote Link to comment Share on other sites More sharing options...
Creature XL Posted September 20, 2014 Share Posted September 20, 2014 I might use this thread to show (again) my little tool to experiment with the "new sounds" You can try out some pulse waves with different duty cycles (5% - 55%). it also features a (VBI based) ADSR envelope for the volume (hold keys down longer) Downside is, you have to play the notes your self with the keyboard. Maybe I try to add the modulations emkay used here, however, it is maybe difficult to make it editable with the simple GUI sdesi.xex 2 Quote Link to comment Share on other sites More sharing options...
Xuel Posted September 20, 2014 Share Posted September 20, 2014 (edited) CreatureXL, can you describe how the following sequence works? STX AUDF1 STA AUDF3 STA STIMER STX AUDF3 I'm guess that X contains the frequency you want to play and A contains an appropriate value to create the desired phase offset between channels 1 and 3 after resetting the POKEY counters with STIMER. Am I right? How do you calculate the value for A? Edited September 20, 2014 by Xuel Quote Link to comment Share on other sites More sharing options...
analmux Posted September 20, 2014 Share Posted September 20, 2014 CreatureXL, can you describe how the following sequence works? Look over here: http://atariage.com/forums/topic/159104-some-information-please/?p=1962220 Quote Link to comment Share on other sites More sharing options...
Xuel Posted September 20, 2014 Share Posted September 20, 2014 Look over here: http://atariage.com/forums/topic/159104-some-information-please/?p=1962220 Cool, so if you want duty cycle D, then A=X*D, yes? I'm still curious about the actual mechanism. How does writing the registers in that sequence cause the phase difference? Quote Link to comment Share on other sites More sharing options...
Creature XL Posted September 21, 2014 Share Posted September 21, 2014 (edited) Cool, so if you want duty cycle D, then A=X*D, yes? I'm still curious about the actual mechanism. How does writing the registers in that sequence cause the phase difference? It's unfair to ask this of me. I just checked the timestamp sof the code. Last i touched it was 16th of September 2012 However, I am pretty sure I got eh information from the thread Analmux posted ( or one of his other posts). When I remember correctly I had to think for a moment abou tit and asked him for conformation if I understood it correctly. What I am saying, if you do not get it at once it's fine. If I recall how it works I post again. Now I will try to add some modulations to teh pulse width. I curious how they sound... EDIT: FYI, in my code I use pre-calced tables. For example: notes_15lll: .byte 255,255,255,255,255,255,255,255,255,255,255,242 notes_15ll: .byte 229, 216, 204, 192, 182, 171, 162, 153, 144, 136, 128, 121 notes_15l: .byte 114, 108, 102, 96, 91, 85, 81, 76, 72, 68, 64, 60 notes_15: .byte 57, 54, 51, 48, 45, 42, 40, 38, 36, 34, 32, 30 notes_15h: .byte 28, 27, 25, 24, 22, 21, 20, 19, 18, 17, 16, 15 notes_15hh: .byte 14, 13, 12, 12, 11, 10, 10, 9, 9, 8, 8, 7 notes_15hhh: .byte 7, 6, 6, 6, 5, 5, 5, 4, 4, 4, 4, 3 notes_pulse05: .byte 44,42,40,38,36,34,32,30,28,26,24,23 ; 15ll / 5 .byte 23,22,20,19,18,17,16,15,14,13,12,11 ; 15l / 5 .byte 11,10,10,9,9,8,8,7,7,6,6,6 ; 15 / 5 .byte 5,5,5,4,4,4,4,3,3,3,3,3 ; 15h/5 .byte 3,2,2,2,2,2,2,1,1,1,1,1 ; 15hh / 5 So yeah you are right. And i just remembered the thing which makes the phase shift work It is the fact that POKEY changes the frequency AFTER its current rectangle-cycle is over. So that is how you get the phase shift. Edited September 21, 2014 by Creature XL 1 Quote Link to comment Share on other sites More sharing options...
emkay Posted September 21, 2014 Author Share Posted September 21, 2014 (edited) I'm still curious about the actual mechanism. How does writing the registers in that sequence cause the phase difference? POKEY'S generators start at the same phase, when the chip gets powered. Doing the start of two different channels at a defined time difference, makes them play the waves at the defined time difference. Running two channels with the filter at the same phase, makes them fully cancelling the sound. The time offset creates a "later cancelling effect" , resulting in a variable pulse width signal. The problem with resetting POKEY timers is that it doesn't make you happy, because it resets all registers. So once the tune gets started, a reset is useful. Then we can use the pitch correction to keep the sound as stable as possible. Many sound combinations vary when the tune gets restarted, so the pokey timer reset helps well there. Well, another scenario would be to have POKEY with Digis and the main voice is intended to play as good as possible. So 16 bit filter with 100% stable instrument start ... well, do the math Edited September 21, 2014 by emkay Quote Link to comment Share on other sites More sharing options...
analmux Posted September 21, 2014 Share Posted September 21, 2014 I'm still confused about the "high pass filter", mentioned in the ATARI book and WikiPedia. IMHO there isn't any at all. Cool, so if you want duty cycle D, then A=X*D, yes? Exactly. F.e. using AUDCTL = 4, thus when AUDF3 clocks AUDF1, and we have base clock 64 kHz. Let now P be the desired 'phase' or 'duty cycle', thus 0 <= P < 1. Then A = INT(P*(X+1))-1 after calculating a numerical approximation. We can redefine A'=A+1 and X'=X+1, so that A' = INT(P*X'). Now, for example, if we chooce an AUDF1 pulse running 10 cycles (w.r.t. base clock 64 kHz), and with phase 30%, then the A':X'-ratio equals A = INT(3*(X+1)/10)-1. Thus 10 = X' = X+1 so that X=9 and A = INT(3*10/10) = INT(3)-1 = 3-1 = 2. Thus X=9 and A=2: LDX #9 LDA #2 STX AUDF1 STA AUDF3 STA STIMER STX AUDF3 I'm still curious about the actual mechanism. How does writing the registers in that sequence cause the phase difference? More about the countdown timers: AUDF1 Pulses: |---------|---------|---------|---------|--------- ... AUDF3 Pulses: |--|---------|---------|---------|---------|------ ... Countdown Timer 1: 98765432109876543210987654321098765432109876543210 ... Countdown Timer 3: 21098765432109876543210987654321098765432109876543 ___ ___ ___ ___ ___ Resulting Signal: _______ _______ _______ _______ _______ 11100000001110000000111000000011100000001110000000 Now note that it really works like a binary 'ring mod'. The flip-flop of the filter output is caused by both AUDF1 and AUDF3. Any AUDF1 pulse generates a flip-flop 0 -> 1 or 1 -> 0. AUDF3 ONLY generates flip-flop 1 -> 0. 1 Quote Link to comment Share on other sites More sharing options...
sack-c0s Posted September 21, 2014 Share Posted September 21, 2014 Sounds good but one quick question: Where does this leave us in terms of run time to do everything else? Does it just update the music player same as always, need multiple updates per frame, need handholding throughout the entire frame, etc.? Quote Link to comment Share on other sites More sharing options...
emkay Posted September 21, 2014 Author Share Posted September 21, 2014 (edited) Sounds good but one quick question: Where does this leave us in terms of run time to do everything else? Does it just update the music player same as always, need multiple updates per frame, need handholding throughout the entire frame, etc.? It mostly can run in a standard VBI player. It's just the granted start of a wave that is missed in "all" players. Just a command "here and there" for resetting the timers, and a short routine for updating the pitch correction in one VBI cycle instead of 3 VBI cycles. The offset for the pulse width is only limited by the available wavelength. All of my tests use 8 bit, but 16 bit is also possible. Edited September 21, 2014 by emkay Quote Link to comment Share on other sites More sharing options...
Xuel Posted September 26, 2014 Share Posted September 26, 2014 (edited) I tried sweeping the duty cycle but it sounds really choppy: dutycycle.xex I'm reseting STIMER every 3 frames. If I pull up the Audio Monitor in Altirra I can see a long pulse on the frames where STIMER is reset. I guess this is unavoidable? It seems like it really limits the musical potential if you can't sweep the duty cycle cleanly though. EDIT: Source on github. EDIT2: Fixed duty cycle offset. Now when the line is on the right hand of the screen, the duty cycle is 100% and when on the left it's 0%, and the duty cycle is 50% when the line is in the middle. Edited September 26, 2014 by Xuel Quote Link to comment Share on other sites More sharing options...
Xuel Posted September 26, 2014 Share Posted September 26, 2014 Also, resetting STIMER will cause choppiness in the tones that are playing on the other two channels as well, right. So it seems like you'd never want to do it in the middle of a long note. Quote Link to comment Share on other sites More sharing options...
emkay Posted September 27, 2014 Author Share Posted September 27, 2014 Also, resetting STIMER will cause choppiness in the tones that are playing on the other two channels as well, right. So it seems like you'd never want to do it in the middle of a long note. Reducing the volume in the "click" time could help. This "start of a long note is the real handycap. In RMT it takes up to 3 VBI cycles, to have a clean start. This STIMER programming would give a better stability to the sound generating and thus more variable sound programming. On the envelop of an instrument, the pitch correction is the solution. You only hear "clicks" in the long note, when you want them there . 1 Quote Link to comment Share on other sites More sharing options...
