Problem with pokey sound channels 3+4
bugbiter
Hi everyone,
I'm doing 4 channel sound in Assembler for the first time.
It's quite easy actually, you've got AUDF1-4 for the pitch,
AUDV1-4 for sound type (bits 4-7) and volume (bits 0-3)
Then, you've got AUDCTL where you can pair chan 1+2 or 3+4 to 16bit resolution, and other freaky stuff. I have that set to zero.
Now, in Altirra everything works fine. But on my real 130XE channels 3+4 seem to be muted - all you can hear are the buzz of the volume steps going up and down.
At first I thought there was something wrong with my code for chan3+4 but when I simply reversed the equate numberings for AUDF and AUDV (4 to 1, 3 to 2, 2 to 3, 1 to 4) so chan 3+4 play the sound code for chan 1+2, it is still channels 3+4 that are silent.
As I said, AUDCTL is zero, so there is no fancy stuff involved and all channels should work the same.
I tried another program of mine which uses only sound channel 1. If I set it to channel 4 there's no sound! WTF?
I don't get it - is there some other register that does something strange to chan 3+4 on default?
It's probably thanks to a bug in the XL OS. After SIO it doesn't set things quite right which can affect audio.
In your program, set SKCTL to 3 - also set SSKTCL (the shadow) - addresses are $D20F and $232.
Also set AUDCTL to 0 ($D208) - probably just easist to clear all the sound related registers first, just put zeroes in $D200-$D208 at the start of your program.
