metzger130 Posted September 27, 2014 Share Posted September 27, 2014 I was at a show today and saw an expansion module 1 that I was looking for and it was $10. Naturally I asked if it works and he said yes it does, and he would take 5 for it. I then saw that they had a system with 2 controllers and power supply that said "dead system" so I asked and he said it doesn't power up and he'd give me it plus the exp module 1 for $10. I went for it as 2 controller and a power supply are worth more than 10, well he ended up putting a 2nd power supply in and 2 more controllers for the $10. I got home and tested the exp module 1 and it works. I then wondered about the system, so i plugged my power supply that I knew works into it and after playing with the power button some I got picture and sound, so IT WORKS! The 4 controllers also work, but need cleaned up as a button on 1 sticks and thre is a delay when you hit the buttonor move the stick before the character moves on the screen. I plugged in the 1 power supply and it didn't work, bumped the cord and noticed that I had a part picture so I played with the cord some and eventually got a picture so it must be a wire in it that doesn't work great. the other power supply works flawlessly. so I think I got a steal of a deal on this. Do have to ask to fix the power issue do I just open it up and clean it up and it would fix it? I did notice that after it worked the once it did work better turning it back on again so just might need a little movement to get it to work again correctly. Not sure the reset button works though, I hit it and it didn't do anything, but I didn't play with it at all so it just might need a little working too. 2 Quote Link to comment Share on other sites More sharing options...
Hyperboy Posted September 27, 2014 Share Posted September 27, 2014 Great score! Quote Link to comment Share on other sites More sharing options...
ValkerieSilk Posted October 2, 2014 Share Posted October 2, 2014 Nice man! Quote Link to comment Share on other sites More sharing options...
