metzger130 Posted September 30, 2014 Share Posted September 30, 2014 I was wondering what you use to clean the outside of the colecovision and the expansion module 1. I don't want to hurt the system or make any scratches or anything like that. Thank you Quote Link to comment Share on other sites More sharing options...
Oldschool80skid Posted October 2, 2014 Share Posted October 2, 2014 (edited) I recently purchased both a colecovision and module 1 myself. I took apart both and the cleaned the shells with dish washing liquid and a soft bristle tooth brush. I used compressed air to clean the circuit boards. I also cleaned the cartridge ports with rubbing alcohol and a credit card wrapped in a cotton cloth. After putting everything back together, I wiped down the shells with armor all wipes. There are some good you tube videos showing how to as well. That is how I learned. Edited October 2, 2014 by Oldschool80skid 1 Quote Link to comment Share on other sites More sharing options...
ValkerieSilk Posted October 3, 2014 Share Posted October 3, 2014 New toothbrush and electronics cleaner and compressed air to finish up... Outside, as Oldschool80skid mentioned Armor All wipes give it a pretty good shine... I usually spray down the screws with anti-seize spray so the second time is a cake walk. http://www.amazon.com/CRC-05101-QD-Electronic-Cleaner/dp/B000CCMLD0/ref=sr_1_2?ie=UTF8&qid=1412360370&sr=8-2&keywords=Electronics+Cleaner Quote Link to comment Share on other sites More sharing options...
Rik Posted October 7, 2014 Share Posted October 7, 2014 (edited) The 1st thing i do when buying ANYTHING at the flea or thrift shop is NOT take it inside my house right away. WHY? because last time i brought a 2600 home from Value Village, a little cockroach crawled out the top while i was playing to say hello, same thing happened with PC speakers i brought back from there. I open up the console outdoors, take out the motherboard, cut a piece of plastic transparency to size and place over any labels and seal edges with duct tape to keep water away. Then i soak the casing halves in warm soapy water for a minute or 2 and scrub anything stubborn with a tooth brush. This method cleans everything out of tiny cracks where roach eggs and such can hide. Edited October 7, 2014 by Rik 1 Quote Link to comment Share on other sites More sharing options...
HkryCrkStudio Posted October 7, 2014 Share Posted October 7, 2014 The 1st thing i do when buying ANYTHING at the flea or thrift shop is NOT take it inside my house right away. WHY? because last time i brought a 2600 home from Value Village, a little cockroach crawled out the top while i was playing to say hello, same thing happened with PC speakers i brought back from there. I open up the console outdoors, take out the motherboard, cut a piece of plastic transparency to size and place over any labels and seal edges with duct tape to keep water away. Then i soak the casing halves in warm soapy water for a minute or 2 and scrub anything stubborn with a tooth brush. This method cleans everything out of tiny cracks where roach eggs and such can hide. Nice... and I was just about to raid the fridge for a late night snack. Quote Link to comment Share on other sites More sharing options...
