Tic Tac Toe for INTV
vprette
I try to practise with intybasic by porting a simple Tic Tac Toe concept.
So far I just started using the Print statement, and defining the variables.
One question: is the INT command implemented? to extract integer from a math expression? I dont see in the manual..
If I compile the line
x=3*INT((m-1)/3)+1
compilation is fine, but when running with jzintv I have error..
Do you like the blinking color yellow/green I use? dont know if it is ok for the title screen..
thanks
tic_v03.rom
Edited by vprette
x=3*INT((m-1)/3)+1
thanks
The blinking effect looks cool. The green on black does not really look appealing for a title screen, at least in my opinion, unless it relates to the game (like a space war). It could be also that it looks much too plain for a title screen.
I would recommend playing with the layout first: center the title horizontally on the screen, and maybe add a simple # grid with x's and 0's below it. You can make the x's and 0's alternate between green and yellow. :)
-dZ.
-dZ.
improved
tic_v04.rom
new version
I use now cont1.xxx to store info about buttons pressed on the controller.
I use to move from title to main screen.
Seems convenient, but I have some strange behaviour, like when going again in the same procedure to check a second time the buttons (say, to move from main screen to second screen) it's like the value of cont1.left is the same of before, so when I press left in the Title screen, everytine I check again, seems like left is pressed forever.. sorery something I check wrong.. have to understand
tic_v05.rom
Edited by vprette
new version
How do i start a game? I tried v04 and could not get off the title screen.
new version
Much better title screen! The only thing I would change is to make the highlight change of the text have an even delay on every change. To me it seems like it does:
One... Two... ThreeOne... Two... ThreeOne... Two... ThreeOne... (etc.)
As if it restarts too fast after the last change.
As for your problem, I don't really understand it. Is "cont1.xxx" a variable you defined? If so, you may need to clear it before waiting for a key.
-dZ.
new version
cont1.xxx returns the "state" of the buttons, rather than a button press.
On your second screen, you should wait until cont1.xxx = 0 (maybe for several times in a row), then check for a pressed value again.
Maybe something like this:
rem draw title screen
check_key: if (cont1.left =1) then goto select_screen
      wait
goto check_key
select_screen:
rem draw select screen
wait_for_key_release:
       if (cont1.left=1) then wait : goto wait_for_key_release
check_key2:
    if (cont1.left =1) then goto game_screen
    wait
goto check_key2
game_screen:
      wait
goto check_key
select_screen:
check_key2:
    wait
goto check_key2
game_screen:
it does not sound very clear to me, bu I will understand testing some code tonight
I'm waiting in the main screen for a hitten button.
I do gosub this procedure
hit: procedure
IF cont1.left THEN tasto=15
IF cont1.right THEN tasto=15
IF cont1.up THEN tasto=15
IF cont1.down THEN tasto=15
IF cont1.button THEN tasto=15
IF CONT1.KEY=1 THEN tasto=1
IF CONT1.KEY=2 THEN tasto=2
IF CONT1.KEY=3 THEN tasto=3
IF CONT1.KEY=4 THEN tasto=4
IF CONT1.KEY=5 THEN tasto=5
IF CONT1.KEY=6 THEN tasto=6
IF CONT1.KEY=7 THEN tasto=7
IF CONT1.KEY=8 THEN tasto=8
IF CONT1.KEY=9 THEN tasto=9
IF CONT1.KEY=10 THEN tasto=10
IF CONT1.KEY=12 THEN tasto=12
return
end
and want to use the value of tasto after then...
but value of tasto is nosense...
Edited by vprette
Sometimes it's difficult to check the true behavior of a subroutine.
I would suggest to create a small program to test your subroutine:
main:
   WAIT
   GOSUB hit
   PRINT AT 40,(tasto/10%10+16)*8+7,(tasto%10+16)*8+7
   GOTO main
Please note that CONT1.KEY and CONT2.KEY are only updated after each WAIT, so if you check them continously, these will be fixed until control passes through a WAIT statement.
hit: procedure
return
end
Maybe you need to initialize tasto at the beginning of the procedure?
hit: procedure
tasto = 0
That way, no buttons are pressed, the tasto is zero.
hit: procedure
tasto = 0
to be honest, it really look like the cont1.left value is buffered for a long time... so no matter if each loop I set tasto=0, it suddendly goes to 15 because cont1.left is still not zero even if I press nothing...
in fact I solved the issue inserting many wait commands
hit: procedure
tasto = 0
wait
wait
wait
wait
BUT this way the pause is too long so maybe I have the opposite: pressing the key again and nothing happend because there is still a wait instance not ended....
so now my sw works but looks like the controller button is broken and you have to hit it 2-3 times :-)
Edited by vprette
Valter,
The WAIT statement pauses execution until the next VBLANK interrupt.
I'm not sure how IntyBASIC reads the controller, but by your description, it sounds like it only does so during the ISR, 60 times a second, so you require a WAIT before reading the controller.
If so, you'll need something like:
hit: procedure
tasto = 0
wait
if cont1.left then tasto = 15
if cont1.right then tasto = 15
Etc.
P.S. Is it me or does "tasto" sound like a brand of canned sauce? "Just add Tast-O and PRESTO! Instant delicious chicken casserole!" :lol:
Small tip - stop reading the controller so many times. Every read of it requires a WAIT, which as you have discovered slows things down tremendously.
Instead try this:
WAIT
c1=cont1
if c1= *magic number that indicates left* then tasto=10
if c1= *magic number that indicates right* then tasto=15
Take the controller 1 input and store it in its own variable. Then do your checks on that variable. I've found that it's the only way to do really fancy work with the keypad - maybe I'm missing something with IntyBASIC. Oh, and the magic numbers? You'll need to work them out. Quick and dirty way, write a loop that does this:
loop:
WAIT
c1=cont1
PRINT AT 20,(c1*16)*8+6
goto loop
That will display the controller 1 value depending on what you press. You can make a quick lookup table that way.
There may be a better way to do this, but I've found that IntyBASIC is not the most efficient way to read keypad input. It works just fine for UDLR and the fire buttons though.
Hello
thanks for you suggestions!
I made an intybasic program that I share to check the hitted keypads, and I shere with you: if you test it and find bugs please tell me
NOTE:
c1 and 2 show the actual value stored by system var cont1 and cont2
1 BUG I already know: form some reason I'm not able to detect the Enter button in the controllers.
keypad V02
keypad_v02.rom
Edited by vprette
and this is the last fixed rom.
I did my best but there is still the Enter bug
according to manual, when pressing Enter, I should have con1.key=12
but for mistery if I check this number it appears to be always pressed: it's like for the compiler the controller Enter is always on... any hint?
My copy of the manual says:
CONT1.KEY Current pressed key (0-9 for numbers, 10-Clear, 11-Enter, 12-Not pressed)
So pressing enter should return the value 11, and pressing no key should return 12.
So far so good. I can't lose!
I think it would be cool if you drew the grid, and used the numbers instead of "E". That way it would be easy to see what buttons to press.
Something like this:
Here is the code I used to draw that:
	REM
	REM TTT grid
	REM Created in IntyBASIC
	REM by Catsfolly
	REM October 2014.
	REM
REM some Intellivision hardware constants
	CONST BACKTAB		= $0200
	CONST CS_GRAM		= $0800				' get picture from gram
	CONST CS_CARD		= $01f8				' gram or grom card number
	CONST MB_X_XPOS		= $00FF				' mask for x pos
	CONST MB_X_INTR		= $0100				' enable collision regs
	CONST MB_X_VIS		= $0200				' make mob visible
	CONST MB_X_XSIZE	= $0400				' double size in x
	CONST MB_Y_YPOS		= $007F				' mask for y pos
	CONST MB_Y_YRES		= $0080				' 16 bits in y
	CONST MB_Y_YSIZ2	= $0100				' double y size
	CONST MB_Y_YSIZ4	= $0200				' 4 times y size
	CONST MB_Y_YSIZ8	= $0300				' 8 times y size
	CONST MB_Y_XFLIP	= $0400				' x flip
	CONST MB_Y_YFLIP	= $0800				' y flip
	CONST MB_A_GRAM		= $0800				' get picture from gram
	CONST MB_A_CARD		= $07f8				' mask for picture no.
	CONST MB_A_PRIO		= $2000				' priority (above/below bkgnd)
REM colors for color stack, border, etc
	CONST C_BLK  = $0              ' Black
	CONST C_BLU  = $1              ' Blue
	CONST C_RED  = $2              ' Red
	CONST C_TAN  = $3              ' Tan
	CONST C_DGR  = $4              ' Dark Green
	CONST C_GRN  = $5              ' Green
	CONST C_YEL  = $6              ' Yellow
	CONST C_WHT  = $7              ' White
	CONST C_GRY  = $8              ' Grey
	CONST C_CYN  = $9              ' Cyan
	CONST C_ORG  = $A              ' Orange
	CONST C_BRN  = $B              ' Brown
	CONST C_PNK  = $C              ' Pink
	CONST C_LBL  = $D              ' Light Blue
	CONST C_YGR  = $E              ' Yellow-Green
	CONST C_PUR  = $F              ' Purple
rem colors for backtab or mob a
	CONST X_BLK  = $0              ' Black
	CONST X_BLU  = $1              ' Blue
	CONST X_RED  = $2              ' Red
	CONST X_TAN  = $3              ' Tan
	CONST X_DGR  = $4              ' Dark Green
	CONST X_GRN  = $5              ' Green
	CONST X_YEL  = $6              ' Yellow
	CONST X_WHT  = $7              ' White
	CONST X_GRY  = $1000           ' Grey
	CONST X_CYN  = $1001           ' Cyan
	CONST X_ORG  = $1002           ' Orange
	CONST X_BRN  = $1003           ' Brown
	CONST X_PNK  = $1004           ' Pink
	CONST X_LBL  = $1005           ' Light Blue
	CONST X_YGR  = $1006           ' Yellow-Green
	CONST X_PUR  = $1007           ' Purple
	CONST GRID_COL = X_YEL
	CONST H_BAR = ( 211 *  + GRID_COL
	CONST V_BAR = (  92 *  + GRID_COL
	CONST TEE   = (  60 *  + GRID_COL + CS_GRAM
title:
	mode 0,C_DGR,C_DGR,C_DGR,C_DGR
	WAIT
        DEFINE 60,1,gramchars ' load the custom character definitions
	WAIT
	cls		' clear the screen
    REM the screen is 20 chars wide so position is 20 * row + col
        print at (20* 3 + 5) COLOR C_WHT,"1"
	print  V_BAR
	print  "2"
	print  V_BAR
	print "3"
   	print at (20* 4 + 5), H_BAR
	print TEE
	print H_BAR
	print TEE
	print H_BAR
   	print at (20* 5 + 5) COLOR C_WHT,"4"
	print  V_BAR
	print  "5"
	print  V_BAR
	print "6"
	print at (20* 6 + 5), H_BAR
	print TEE
	print H_BAR
	print TEE
	print H_BAR
	print at (20* 7 + 5) COLOR C_WHT,"7"
	print  V_BAR
	print  "8"
	print  V_BAR
	print "9"
	WAIT
REM *****************************************************************
REM
REM loop - main gameplay loop
REM
loop:
	WAIT
    goto loop
REM main gameplay loop end *****************************************************************
gramchars:
REM 60
	BITMAP "   ##   "
	BITMAP "   ##   "
	BITMAP "   ##   "
	BITMAP "########"
	BITMAP "########"
	BITMAP "   ##   "
	BITMAP "   ##   "
	BITMAP "   ##   "
Catsfolly
Edited by catsfolly
I have a running rom now, but some bug make the intellivision freeze when 2nd cell is occupied, and in some configuration it pass the turn without chosing a cell... so I think I will write the logic from scratch myself (I was using Ahl tic tac toe algorithm)
If I could work on it every day I guess I would deliver this rom in 3 weeks... need to find time in fact during night :-)
Valter,
If you post your code, I may be able to help you find out the problem. If you don't want to share your source publicly, you can send me a PM.
