intvdave Posted May 31, 2015 Share Posted May 31, 2015 me personally i would want coleco flashback as default cause those are what i would use on the flashback most. (Always) I hear you but the idea is to promote the use of the steering wheel, rollerball, and super action controllers. The ultimate interface exists to support the hardware that requires two inputs such as the Intellivision keyboard, piano, and the Coleco rollerball. If all you cared about was 2 joysticks, you could use 2 vision'daptors. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted May 31, 2015 Share Posted May 31, 2015 I hear you but the idea is to promote the use of the steering wheel, rollerball, and super action controllers. The ultimate interface exists to support the hardware that requires two inputs such as the Intellivision keyboard, piano, and the Coleco rollerball. If all you cared about was 2 joysticks, you could use 2 vision'daptors. but i love the ultimate pc interface cause i can also use all the other controllers. Quote Link to comment Share on other sites More sharing options...
Supraeon Posted May 31, 2015 Share Posted May 31, 2015 Again, thanks for the suggestions. force_edid_audio makes no difference. I tried the Pi on another TV and everything works. So there is some incompatibility between Raspbian/Retropie/EmulationStation/JZIntv and a Dell U2414. The Dell works fine with Chromecast and a Bluray player. Huh. i fixed the problem. add this line of code to your config.txt file: hdmi_force_edid_audio=1 i do not have Hdmi_drive=2 turned on i do have the following ones turned on: config_hdmi_boost=4 hdmi_mode=1 Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted May 31, 2015 Share Posted May 31, 2015 Again, thanks for the suggestions. force_edid_audio makes no difference. I tried the Pi on another TV and everything works. So there is some incompatibility between Raspbian/Retropie/EmulationStation/JZIntv and a Dell U2414. The Dell works fine with Chromecast and a Bluray player. Huh.yeah the tv i bought today had no audio and that fixed it when the other audio option wouldnt. Not sure your solution then. Cant really help you further as my trouble shooting has been solved. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted June 10, 2015 Author Share Posted June 10, 2015 Here's another potential option for a retrogaming device - a $9 computer called C.H.I.P. It's got built-in wifi and Bluetooth! Just preordered mine here. Quote Link to comment Share on other sites More sharing options...
Rev Posted June 28, 2015 Share Posted June 28, 2015 Ill soon be in the Pi club! Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 28, 2015 Share Posted June 28, 2015 Ill soon be in the Pi club! Quote Link to comment Share on other sites More sharing options...
nebbo Posted June 30, 2015 Share Posted June 30, 2015 Hi This place is a great source for information and inspiration. However I have som trouble with setting up my Ultimate INTV Flashback. Everything is working except my controllers. I use flashback controllers with vision daptors. Controllers and daptors check out great. The problem is i can't use the dial buttons 1-9. I can use the controllers as a normal gamepad with the side buttons. 2 player game doesn't work either. I run Retropie 2.6 I have transfered allt the files in the folder from intellivision.us What is the next step in order to get all the buttons and 2 player game work with second controller? Would be very grateful for help jam trying to set this up for my kids Birthday on saturday. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 30, 2015 Share Posted June 30, 2015 (edited) I didnt use vision adapters, i used the ultimate pc interface but that should have been all you needed to do as far as i am aware. Did you transfer the hackfile as well?? Edited June 30, 2015 by pimpmaul69 Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted June 30, 2015 Share Posted June 30, 2015 (edited) Double post Edited June 30, 2015 by pimpmaul69 Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted July 11, 2015 Share Posted July 11, 2015 I remember putting just one space before and after the equals sign in this file: Classic.Dpad.X = ABS_X Classic.Dpad.Y = ABS_Y Classic.LStick.X = ABS_HAT0X Classic.LStick.Y = ABS_HAT0Y Classic.RStick.X = ABS_HAT1X Classic.RStick.Y = ABS_HAT1Y Classic.A = BTN_A Classic.B = BTN_B Classic.X = BTN_X Classic.Y = BTN_Y Classic.Minus = BTN_SELECT Classic.Plus = BTN_START Classic.Home = BTN_MODE Classic.L = BTN_TL Classic.R = BTN_TR Classic.ZL = BTN_TL2 Classic.ZR = BTN_TR2 Wiimote.A = BTN_A Wiimote.B = BTN_B Wiimote.Dpad.X = -ABS_Y Wiimote.Dpad.Y = ABS_X Wiimote.Minus = BTN_SELECT Wiimote.Plus = BTN_START Wiimote.Home = BTN_MODE Wiimote.1 = BTN_X Wiimote.2 = BTN_Y i solved the classic controller analog issue by ditching the bluetooth and going with a mayflash dual classic controller pro adapter. Nothing needed to set it up. I can post all my configs for it if you like. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted July 28, 2015 Share Posted July 28, 2015 My latest modded intellivision. I also did a sweet nes. I can post pics if anyone wants to see it. 1 Quote Link to comment Share on other sites More sharing options...
dave1dmarx Posted August 18, 2015 Share Posted August 18, 2015 My latest modded intellivision. I also did a sweet nes. I can post pics if anyone wants to see it. image.jpg image.jpg That looks fantastic! I am hopelessly inept when it comes to making these type of mods. If anyone has an extra modded Intellivision that they wouldn't mind selling, please PM me!! Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted August 19, 2015 Author Share Posted August 19, 2015 That looks fantastic! I am hopelessly inept when it comes to making these type of mods. If anyone has an extra modded Intellivision that they wouldn't mind selling, please PM me!! Thanks in advance. PM sent! Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted August 23, 2015 Share Posted August 23, 2015 I can pull up my list of games but nothing plays - black screen with any file. Sometimes it's flash past the green tritle screen but usually just goes straight to black. I put the grom and exec file in bios. Is that wrong? Am I missing something else? Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted August 24, 2015 Share Posted August 24, 2015 Bios folder in the intellivision folder. Also make sure you arent using the mini exec and mini grom that came with jzintv. You need the real ones. Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted August 24, 2015 Share Posted August 24, 2015 Thank you, sir. Quote Link to comment Share on other sites More sharing options...
yell0w_lantern Posted August 27, 2015 Share Posted August 27, 2015 Mostly working now except for some of the Homebrews. The ones I actually care about are D2K and Ms Pacman. Has anyone gotten those working? My JZIntv is from the Retropie 3 release for Pi2. Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted August 27, 2015 Author Share Posted August 27, 2015 Mostly working now except for some of the Homebrews. The ones I actually care about are D2K and Ms Pacman. Has anyone gotten those working? My JZIntv is from the Retropie 3 release for Pi2. These games work fine with the latest version of jzintv for the Pi, which I don't believe is up on Joel's site yet. I sent you a PM with the latest version. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted August 27, 2015 Share Posted August 27, 2015 Mostly working now except for some of the Homebrews. The ones I actually care about are D2K and Ms Pacman. Has anyone gotten those working? My JZIntv is from the Retropie 3 release for Pi2.i sent you everything needed to have a sweet setup. Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted September 9, 2015 Share Posted September 9, 2015 My latest pi mod i did for a buddy of mine. 1 Quote Link to comment Share on other sites More sharing options...
mthompson Posted September 9, 2015 Share Posted September 9, 2015 My latest pi mod i did for a buddy of mine. Nice! Quote Link to comment Share on other sites More sharing options...
Byte Knight Posted September 10, 2015 Author Share Posted September 10, 2015 Very nice! You should sell those. I imagine you've got MAME running on the Pi? Quote Link to comment Share on other sites More sharing options...
pimpmaul69 Posted September 10, 2015 Share Posted September 10, 2015 Very nice! You should sell those. I imagine you've got MAME running on the Pi?yes. Plus neo geo and capcom cps1 & 2 seperately Quote Link to comment Share on other sites More sharing options...
+BBWW Posted September 10, 2015 Share Posted September 10, 2015 (edited) I've yet to be able to get jzintv to work on my Macbook Pro but it may be that I give up to easily in my frustration. I have all the Games on my Cuttle Cart 3. I just need to take the time to do it I think. Fortunately, we get to use the best emulator out there - jzintv! The sound output is near perfect as far as I can tell. To not have the famous Intellivision buzz with the Flashback is very disappointing. Don't get me wrong, I'll still buy every version of the Flashback that comes out... Edited September 10, 2015 by BBWW Quote Link to comment Share on other sites More sharing options...
