Mastermind for INTV
18 replies to this topic
#1 vprette OFFLINE
vprette
  • 1,585 posts
Posted Fri Nov 7, 2014 6:08 AM
my next project :-)
early stage
M1
Edited by vprette, Fri Nov 7, 2014 6:10 AM.
#2 Rev OFFLINE
Rev
    IntellivisionRevolution
  • 16,407 posts
Posted Sat Nov 8, 2014 10:22 AM
Will this have an ICE level?
#3 vprette OFFLINE
vprette
  • 1,585 posts
Posted Sat Nov 8, 2014 10:27 AM
probably not
#4 vprette OFFLINE
vprette
  • 1,585 posts
Posted Sat Nov 8, 2014 10:28 AM
title screen
M2
#5 freewheel ONLINE
freewheel
  • 3,121 posts
Posted Sat Nov 8, 2014 12:58 PM
I already gave you one and I don't recall any thanks. :(
Although your persistence did give me the inspiration for an entire game framework, so I can't give you too much grief. :P
#6 Rev OFFLINE
Rev
  • 16,407 posts
Posted Sat Nov 8, 2014 1:11 PM
Wha???    Did I miss it?    My memory must be going!!!!!
Link?
#7 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
  • The P-Machinery AGE is almost here!
Posted Sat Nov 8, 2014 3:57 PM
Link?
Check it out.
#8 vprette OFFLINE
vprette
  • 1,585 posts
Posted Mon Nov 10, 2014 9:04 AM
something strange:
I try to read 4 inputs (limited to 1-6 range) from the controller, but as soon as I hit the keypad first time, all the 4 values on the matrix seqpo(ii) are filled by this unique value and the program call "exit"
ii=1
leggi_seq_orig:
gosub hit2
if tasto <7 then seqpo(ii)=tasto:ii=ii+1
wait
rem if ii>4 goto exit
goto leggi_seq_orig
hit2: procedure
tasto=15
wait
IF CONT2.KEY=1 or CONT1.KEY=1 THEN tasto=1
IF CONT2.KEY=2 or CONT1.KEY=2 THEN tasto=2
IF CONT2.KEY=3 or CONT1.KEY=3 THEN tasto=3
IF CONT2.KEY=4 or CONT1.KEY=4 THEN tasto=4
IF CONT2.KEY=5 or CONT1.KEY=5 THEN tasto=5
IF CONT2.KEY=6  or CONT1.KEY=6 THEN tasto=6
IF CONT2.KEY=7  or CONT1.KEY=7 THEN tasto=7
IF CONT2.KEY=8 or CONT1.KEY=8 THEN tasto=8
IF CONT2.KEY=9 or CONT1.KEY=9 THEN tasto=9
return
end
Edited by vprette, Mon Nov 10, 2014 9:05 AM.
#9 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Mon Nov 10, 2014 9:14 AM
Is it because you're not waiting for the key to be released?
#10 catsfolly OFFLINE
catsfolly
    Dragonstomper
  • 740 posts
Posted Mon Nov 10, 2014 9:25 AM
something strange:
ii=1
leggi_seq_orig:
gosub hit2
wait
goto leggi_seq_orig
hit2: procedure
tasto=15
wait
return
end
Like 5-11under said, you need to wait for a key release.
Add a routine like this:
wait_for_release: PROCEDURE
  release_count ~ 0
wr_loop:
  WAIT
   IF CONT2.KEY=12 AND CONT1.KEY=12 THEN release_count = release_count+1 ELSE release_count= 0
   if release_count < 20 then goto wr_loop
 END
And then call it from here:
leggi_seq_orig:
gosub hit2
gosub wait_for_release
wait
I haven't tested this...
Catsfolly
Edited by catsfolly, Mon Nov 10, 2014 9:27 AM.
#11 5-11under OFFLINE
5-11under
  • 3,396 posts
Posted Mon Nov 10, 2014 9:41 AM
Sometimes I do the wait-for-keypress-release routine just before going into the wait-for-keypress routine.
#12 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Mon Nov 10, 2014 9:51 AM
That's a good pattern to follow if you need to ensure new input from the player. For instance, in menu selection, where you want to guarantee a new selection and discard any current buffered value from a previous input.
#13 vprette OFFLINE
vprette
  • 1,585 posts
Posted Tue Nov 11, 2014 8:40 AM
  release_count ~ 0
wr_loop:
  WAIT
 END
leggi_seq_orig:
gosub hit2
wait
Catsfolly
many many thanks
#14 vprette OFFLINE
vprette
  • 1,585 posts
Posted Tue Nov 11, 2014 10:53 AM
game is now 50%
when you guess the sequence, you will have black * = number or correct pawn in correct position and white * = correct pawn in wrong position
I know of a bug that miss the calculation after 3rd sequence and always show 0 and 0.. working on that
M3
Edited by vprette, Tue Nov 11, 2014 11:08 AM.
#15 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Tue Nov 11, 2014 11:59 AM
Here's my feedback:
  • Sometimes key presses are not registered and I have to press the key multiple times for it to be detected.  This is especially so when I want to use the same colour peg multiple times.
  • The input is so flakey, it gets in the way of playing.
  • I don't understand the key peg sequences, I think they are wrong.  Take a look at the attached screenshot:  the same sequence repeated multiple times yields different key peg combinations.
  • Shouldn't there be 4 key pegs, one for each position?  I guess it shows the number of either black or white pegs.
#16 vprette OFFLINE
vprette
  • 1,585 posts
Posted Tue Nov 11, 2014 12:41 PM
Here's my feedback:
for some reason that I need to find from the 3rd sequence the values are miss calculated, so only seq 1 and 2 work for now :-)
for the buttons I notice the same: it started when I introduced the gosub wait_for_release from above, so something must be optimized
you need to find the sequence of 6 possible colors
key pegs on the right show: right color in right position (black) and right color in wrong position (white)
Edited by vprette, Tue Nov 11, 2014 12:42 PM.
#17 vprette OFFLINE
vprette
  • 1,585 posts
Posted Tue Nov 11, 2014 1:57 PM
fixed!!
the slow button feedback is still there, but the game logic is in now
70% ready
Edited by vprette, Tue Nov 11, 2014 1:58 PM.
#18 vprette OFFLINE
vprette
  • 1,585 posts
Posted Tue Nov 11, 2014 4:01 PM
I also fixed the button response
and this is the final version I distribute to all
instructions:
find a sequence of 4 colors
each choice is between 6 colors(keypad 1-6)
at the right side you see a black * = number of correct colors in correct position
and a white * = number of correct colors in wrong position in the sequence
game also store the record (less sequences used before finding the solution
hit disc at the end to restart
I hope you like the game
#19 DZ-Jay OFFLINE
DZ-Jay
  • 12,114 posts
Posted Tue Nov 11, 2014 6:25 PM
I managed to beat it once.  But I think there's still a problem with the key pegs code:  sometimes the responses to consecutive inputs is not congruent.  The input problems were corrected, though.
I'll keep playing to see if I can find a specific pattern that doesn't work.
