ballyalley Posted November 7, 2014 Share Posted November 7, 2014 I'm using MAC/65, version 4.20. This is the disk version of the assembler. I want to change the default screen colors to those that Atari BASIC uses. I wrote a short program in Atari BASIC to show me the default colors (in decimal). Here's a screenshot of the program and the results: The disk version of MAC/65 allows the user to display and change memory locations. These are two functions that are not part of the cartridge version of MAC/65. Changing the text and screen color has no effect; I'm only able to change the color of the border. The following screenshot is an example of me trying to change the text color (location $2C5) to the same color as used in BASIC: First I display the contents of $2C6 (it holds a $06). Next I try to change the contents to $CA (202 in decimal). Then I show the contents of $2C6 again. The contents have not been changed. Changing location $2C8 (the border) does work-- so the method that I'm using is sound. How do I properly change the text and screen colors in MAC/65? Quote Link to comment Share on other sites More sharing options...
russg Posted November 8, 2014 Share Posted November 8, 2014 I'm using MAC/65, version 4.20. This is the disk version of the assembler. I want to change the default screen colors to those that Atari BASIC uses. I wrote a short program in Atari BASIC to show me the default colors (in decimal). Here's a screenshot of the program and the results: BASIC - Color Program.png The disk version of MAC/65 allows the user to display and change memory locations. These are two functions that are not part of the cartridge version of MAC/65. Changing the text and screen color has no effect; I'm only able to change the color of the border. The following screenshot is an example of me trying to change the text color (location $2C5) to the same color as used in BASIC: Mac-65 - Color Change.png First I display the contents of $2C6 (it holds a $06). Next I try to change the contents to $CA (202 in decimal). Then I show the contents of $2C6 again. The contents have not been changed. Changing location $2C8 (the border) does work-- so the method that I'm using is sound. How do I properly change the text and screen colors in MAC/65? I think 709 ($2C5) to 202 and 710 ($2C6) to 148 gets you to BASIC blue and white. $2C5 is the color and luminance of the text and $2C6 the background. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 8, 2014 Share Posted November 8, 2014 I think the disk version will change the colours every time a new line entry is started - so anything you change will soon revert back. The solution would be to just patch the program to remove that. Quote Link to comment Share on other sites More sharing options...
ballyalley Posted November 8, 2014 Author Share Posted November 8, 2014 I think the disk version will change the colours every time a new line entry is started - so anything you change will soon revert back. The solution would be to just patch the program to remove that. I can't change the colors on the disk version of MAC/65? Wow. There is nothing like taking away power from the user. That seems like an unusual decision coming for OSS, Inc., a company that is about giving power to the user. Ah, well. It looks like I'll have to live with a black background and border with gray text while I'm working my way through "Atari Roots." I really thought that it would be easy to change the colors. Quote Link to comment Share on other sites More sharing options...
Rybags Posted November 8, 2014 Share Posted November 8, 2014 Load into the emulator, you can find the addresses needing change within seconds. It becomes a one-off thing but you could just as easily patch the executable. I grabbed the disk based Mac/65 4.20 from http://www.umich.edu/~archive/atari/8bit/Languages/Assembly/m65v42.zip Using change command within Mac/65 for background/text colours: C 8B3F<82 C 8B44<0A 1 Quote Link to comment Share on other sites More sharing options...
ballyalley Posted November 8, 2014 Author Share Posted November 8, 2014 Using change command within Mac/65 for background/text colours: C 8B3F<82 C 8B44<0A Worked great for me! Thanks very much. Quote Link to comment Share on other sites More sharing options...
