McKong Posted November 18, 2014 Share Posted November 18, 2014 looks like you might have extra overscan on your emulator [on Altirra: View Overscan Normal] this will make the screen more similar to the real hardware I'll have another bash on the Dragon later Thank, I'll have a look! Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted November 18, 2014 Author Share Posted November 18, 2014 Had another 30K+ go but still crashed by moving the stick in the wrong direction under pressure too many times. Has anyone gone to the top for air at the end screen? I haven't as you can just about fluke It if you go in close to the first barrier and zap away then move in 1 and then go to the middle as the air gauge turns purple. Had a go on Admiral 20,600 - the scoring may be slightly flawed as you can possibly crash towards the end of a section and repeat it for more points rather than making progress so we'll skip this bonus point. Still time to vote for "T" Games *HERE* pick a few games in A and B we'll play the two winners in the next round Quote Link to comment Share on other sites More sharing options...
CapitanClassic Posted November 19, 2014 Share Posted November 19, 2014 Sea Dragon - 18,000 (ish) I saw the end of the level and died. So, the next time I played I cheated just to see what happens (i.e. not much). It just restarts on the next difficulty setting (points doubled for objects) It is true that in Sea Dragon, you could die at the last section and make quite a few points shooting the barriers (10 per block), but I I am not sure that is the optimal strategy. You are probably just better off killing the bomb boss ( 2k points I think) and then starting the next section at a slightly faster speed. It seemed that the points in the first section were worth 3k (6k doubled), which I think makes up for the two barriers that you can wipe out. Quote Link to comment Share on other sites More sharing options...
McKong Posted November 19, 2014 Share Posted November 19, 2014 Had another 30K+ go but still crashed by moving the stick in the wrong direction under pressure too many times. SD-Yeoman.jpg Has anyone gone to the top for air at the end screen? I haven't as you can just about fluke It if you go in close to the first barrier and zap away then move in 1 and then go to the middle as the air gauge turns purple. Had a go on Admiral 20,600 - the scoring may be slightly flawed as you can possibly crash towards the end of a section and repeat it for more points rather than making progress so we'll skip this bonus point. Yeah I did consider that, you could get about 5k and then crash I think, and just repeat without having to go onto the more difficult sections Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted November 19, 2014 Author Share Posted November 19, 2014 Ok that's it for round 20 and despite the efforts of McKong and myself 8bit 1337 holds on for victory (you know the HSC'er formally known as "nature boy") Sea Dragon is a good game I was a little disappointed that there was no underwater Dragon to slay at the end, but I guess we are the Dragon, so destroying a little mine that's probably blocking something important will have to do I suspect to beat the 2nd level onwards you'll need to get to that air pocket on the end section. I liked the slow first level, Admiral seems way too fast to play again I think a stiff joystick is required for this one. Checkout Sabotage when you get some time, it's ok for a couple of goes, thanks for sharing playermissile and thanks for playing all you Atari die hards Final Tables Sea Dragon (Yeoman) 1st 8Bit 1337 (n) 38,730 13pts* 2nd McKong (p) 35,790 12pts* 3rd therealbountybob (p) 34,890 11pts* 4th CaptainClassic (p) 18,000 9pts 5th JK40001 (p) 11,300 9pts 6th Gury (p) 7,300 8pts 7th firestorm (n) 6,300 7pts 8th adam242 (n) 4,600 6pts 8th atariron82 (n) 4,600 6pts 10th playermissile (n) 4,350 4pts 11th Bunsen (p) 4,150 3pts 12th Sikor (p) 4,100 2pts 13th roadrunner (n) 2,400 1pts *HSC record bonus point Fun Bonus Challenge Sea Dragon: Admiral 1st therealbountybob (p) 20,600 2nd McKong (p) 13,800 3rd 8Bit 1337 (n) 10,400 4th Bunsen (p) 4,400 5th roadrunner (n) 2,400 Bonus Game Sabotage (details on post #10) 1st therealbountybob (p) 146 1pt 2nd playermissile (n) 49 3rd roadrunner (n) 11 1 Quote Link to comment Share on other sites More sharing options...
McKong Posted November 19, 2014 Share Posted November 19, 2014 Yep I got into this game after a few goes, initially I thought the sub was not manoeuvrable enough to make the game playable but I got used to it. I can't believe that it's possible to make your way through those caves on Admiral, seems too fast. I think it would be difficult even without the mines! 1 Quote Link to comment Share on other sites More sharing options...
+therealbountybob Posted December 6, 2014 Author Share Posted December 6, 2014 I got the technical details from AA user Shamus so I'm going to do a bit of an in-depth look at how the Apple ][ code was modified to run on the 8-bit hardware. Done 5 episodes so far; still looking at 1981 games. I'm looking forward to starting 1982, that's when more variety starts to appear. Link to the show notes in my sig. Without guided shells sounds good. Paddles do make the game easier on the a2 but I asked about the paddle code and Shamus said that Apple and Atari paddle handling was too different so only keyboard is supported Woohoo! One point for me! Maybe eventually I'll set my sights really high and aim for two. Just listened to the pod cast http://www.playermissile.com/ while (still) working on Ramp Rage. Was interesting hearing about the conversion of Sabotage. I'm sure Shamus could get someone on the programming forum to help out with adding paddles or joystick support which would perhaps be easier, this would Sabotage more accessable Check out the pod cast and Sabotage guys; you still can post scores here for fun too Thanks for giving the HSC a plug Jason Quote Link to comment Share on other sites More sharing options...
Shamus Posted December 7, 2014 Share Posted December 7, 2014 Second try, got killed by the second jet fighter's bomb. I know it's too late for this round, but oh well. It probably wouldn't be too difficult to bodge in joystick support; it's just a matter of finding where the paddle reading code is and patching it. 1 Quote Link to comment Share on other sites More sharing options...
playermissile Posted December 8, 2014 Share Posted December 8, 2014 On my to-do list is to try to look around in the code and hack in support for the paddles. I remember being able to aim much better that way. 1 Quote Link to comment Share on other sites More sharing options...
