XF351 for sale on ebay
145 replies to this topic
#126 Caterpiggle OFFLINE
Caterpiggle
    Dragonstomper
  • 747 posts
Posted Fri Nov 21, 2014 10:12 PM
Hello Sup8pdct,
That item had been sold to the buyer just a few hours.
D48 application for PC ?
I recently checked web site for "D48" application, would not find on web sites. Please more specific full number included version number. It would be help.
Edited by Caterpiggle, Fri Nov 21, 2014 10:21 PM.
#127 Defender II OFFLINE
Defender II
  • 1,165 posts
Posted Fri Nov 21, 2014 11:25 PM
This is a facinating topic and piece of Atari history.
 Just a few questions to see if making a MOD kit for SF354's or SF314's would be possible...
Hello Jon
flashjazzcat, on 10 Nov 2014 - 12:40 PM, said:snapback.png
Someone needs to clone that controller board so we can mod our otherwise useless ST floppy drives. :)
Dropcheck?
Sincerely
Mathy
PS I read on her site that's she's back in business.  And she could add the second SIO port.
Yes, someone making PCBs would be great use for the ST drives out there to convert them to 8-bit use rather than changing our XF551's!
Even modifying the controller PCB to handle DS-DD for ST SF314's in stead or just copy it and make MOD kits for SS-DD for a ST SF354's mod kit.
I think the expectation is that we can learn what command puts it into DD mode. That would give us a 320K drive.
Obviously, engineering wasn't quite done with the design... not ready for PrimeTime at the FCC.
This is really a collector's item - you shouldn't hack it.
Bob
I agree, but fixing the ROM so we could modify SF354's would be great!
Quick look at the code, it has commands R, r, P, W, S, !, N, O, H, ". There a couple of others but am going to bed as am falling asleep at keyboard. will try and figure out what some do latter.
James
The other 3 commands are R, P, W with high bit set. It doesn't appear that high bit set means anything at this point. The H command appears to set high speed sio, a similar speed to the XF551. All bytes sent/returned after the H command is issued with a $01 in one of the aux bytes will be at high speed except for the command frame. Once high speed is set, Instead of A (ack) returned for command Acknowledge, a H is returned. To turn off, issue a H command with 0 in aux bytes.
A custom dos required for this baby.
James
How hard would it be to patch the ROM so it doesn't need a custom DOS if we wanted to make a mod kit for SF354's?
Digging a bit more, it appears the full single sided 80 track disk is treated as a double sided 40 track disk.
Also the percom block can return either 26, 18 or 16 sectors per track. Need to dig more to see which densitys do what.
The percom block aux byte returns $48 (H) if in high speed mode or $41 (A) in normal speed mode. The XF551 returns $41 always.
James
Edit:   It won't work on PAL computers. The sio routines are not patched.
"the full single sided 80 track disk is treated as a double sided 40 track disk" Do you think that is to keep be compatible with the XF551 for the software already out there as Bryan suggests?
How does that compare with
Could the ROM sio routines be patched so we could modify SF354's for PAL 8-bitters as well?
Wow, that's kinda clever as it would have made it completely compatible with software for the XF551.
Bob.
Could you please try to format a disk DS DD 40 tracks, 16 sectors per track. This should get a working format of 1280 odd sectors with the XF351.
The single density format you done, does dos think it was successful but it wasn't? Only way to tell is to read beyond sector 720 and see what happens.
James
 Bob were you able to test beyond sector 720 to see if it really was successful?
Edited by Defender II, Fri Nov 21, 2014 11:28 PM.
#128 bob1200xl OFFLINE
bob1200xl
  • 2,522 posts
Posted Sat Nov 22, 2014 9:49 AM
After a SD format, I can read out to sector 1280.
What is the advantage to starting with an XF351 rather than an XF551 if we want to make an 8-bit drive out of an SF354? If you use an external power supply, there isn't much left of an XF551 to fit into the SF354 case, is there?
Bob
#129 R4ngerM4n OFFLINE
R4ngerM4n
    Moonsweeper
  • 397 posts
  • Beware of my friends!
Posted Sat Nov 22, 2014 11:58 AM
Wow, it's gone for $1800.
#130 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Sat Nov 22, 2014 10:41 PM
I found D48 hidden in here.  http://cd.textfiles....GMMING/DOS/ASM/
as part of another archive.
Where i originally got it from, i cannot remember.
attached is D48. run from winblows command prompt or dosbox for PC
James
  • Attached File  d48.zip   13.18KB   96 downloads
#131 TXG/MNX OFFLINE
TXG/MNX
  • 3,630 posts
Posted Mon Nov 24, 2014 2:55 AM
Hi,
The XF351 has the same cpu as the XF551 does this mean when I burn this rom and connect a 3.5" my XF551 I got a XF351 ?
#132 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Mon Nov 24, 2014 3:54 AM
The code is very similar with all 8040 pins appearing to have the same function between the 2. My guess is the XF351 was done first then the XF551 was done latter using the code from the 351 as a start point. Many routines are the same, some even in the same location.  So i would say yes. BUT, it wont work on PAL computers.
James
#133 TXG/MNX OFFLINE
TXG/MNX
  • 3,630 posts
Posted Tue Nov 25, 2014 3:45 AM
? Why doesn't it work on PAL..
#134 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Tue Nov 25, 2014 5:13 AM
Its sio code is same as early xf551. It wouldnt work on pal. Atari patched the code to make it work by adding one machine cycle to the timing routines. I can show you if you like.
James
#135 TXG/MNX OFFLINE
TXG/MNX
  • 3,630 posts
Posted Tue Nov 25, 2014 5:55 AM
Yep show us ;) pleaze
#136 _The Doctor__ ONLINE
_The Doctor__
  • 4,270 posts
Posted Tue Nov 25, 2014 9:25 AM
Pretty much drop in a rom and replace the mech, That's what I have on the top of my stack a 3.5 XF hack.
#137 Larry OFFLINE
Larry
  • 3,970 posts
Posted Tue Nov 25, 2014 10:31 AM
If someone tries this rom transplant, please let us know how it does.  I suspect there are better XF 3.5" alternatives (such as Hyper-XF).  The best I've used is the CSS/Puff one- and two-drive conversions.  (Actually the best is the Floppy Board, but that doesn't count.)
Would an XF551 pcb fit into an SF314/354 case?  Dropcheck's?   I've got an "XF2" pcb that I need to check, but my guess is -- too wide.
-Larry
#138 pixelmischief OFFLINE
pixelmischief
  • 1,049 posts
Posted Tue Nov 25, 2014 11:09 AM
It does not fit. I have been waiting for this for years and on occasion bang on the hardware gods for a miracle. MetalGuy and Candle in particular. I've also been in contact for a couple of years with a guy here about something called an XF551B board that would fit, but he's had RL to deal with. Picture below.
#139 Larry OFFLINE
Larry
  • 3,970 posts
Posted Tue Nov 25, 2014 3:17 PM
Thanks.  Too bad, but I suspected it.  Also unfortunate that Dropcheck didn't have input early enough to possibly make a board that would fit in either style case.  But even if it did fit, there is the problem with the round vs. trapezoidal connector openings.  Would have taken some "body work" to get it usable.
-Larry
#140 kheller2 OFFLINE
kheller2
  • 1,140 posts
Posted Tue Nov 25, 2014 3:24 PM
I thought someone in the US had built an XF551 board that was maybe 1/3 in size that replaced the same board in an XF551 case.  It would probably fit into the SF.  I just can't remember where I saw it.  Something about XF551 re-imagined ..
Edited by kheller2, Tue Nov 25, 2014 3:24 PM.
#141 Larry OFFLINE
Larry
  • 3,970 posts
Posted Tue Nov 25, 2014 3:30 PM
You might be thinking of this?
http://www.bitsofthe...rn-power-supply
But the width looks to be the same, even though the length might be less.
-Larry
#142 kheller2 OFFLINE
kheller2
  • 1,140 posts
Posted Tue Nov 25, 2014 5:26 PM
-Larry
Yeah that's it.  It might fit sideways.. didn't know we were looking for an elegant  solution.   ;-)
#143 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Wed Nov 26, 2014 1:48 AM
Below is a small snippet of code from similar locations in each rom. Apart from address difference of the 351 code , It does the same thing.
XF351...
    mov    a,#80h
    nop
    nop
    nop
    nop
      jf0    X025f
         nop
            nop
X024c:    nop
             nop
          nop
       jf0    X025f
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
       nop
          nop
            nop
X025f:    clr    c
XF551 1st version, worked for ntsc, not PAL
    mov    a,#80h
    nop
    nop
    nop
    nop
       jf0    X0259
          nop
             nop
X0246:    nop
             nop
          nop
      jf0    X0259
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
    nop
       nop
         nop
           nop
             nop
X0259:    clr    c
XF551 Patched to work on PAL
        MOV     A,#80H
        NOP
        NOP
        NOP
        NOP
        JF0     A259
         NOP
           NOP
A246    NOP
           NOP
         NOP
        JF0     A259
        NOP
        NOP
        NOP
        NOP
        NOP
         JMP     A2EE
           NOP            ;never gets here
A253    NOP
          NOP
        NOP
        NOP
          NOP
            NOP
A259    CLR     C
A2EE    JMP     A253    "
As you can see, the PAL version (which works on ntsc as well) has a JuMP to end of that pages code then jumps back. The affect is to add one machine cycle to the timing of receiving of each bit. There are 3 locations where one machine cycle had to be added. The above code is 1/2 of what is used to receive data frames. Command frames use very different code but it too has been patched to add in one cycle.
James
#144 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Fri Nov 28, 2014 2:32 AM
Digging through the code more, It would appear the format code and sector divide for read/write is fixed at 1280 sectors, 16 sector per track, despite status bits supporting 26 and 18 sector per track and support for 128/256 byte sectors.  Wondering if it is work in progress and this is a proof of concept version.
James
Edited by sup8pdct, Fri Nov 28, 2014 2:32 AM.
#145 Defender II OFFLINE
Defender II
  • 1,165 posts
Posted Fri Jan 23, 2015 1:59 PM
James
It is great that you have been able to dig into the code and figure these changes out.  Do you have a copy of the anotated XF551 code for the ROM from Atari? I remeber some thread that mentioned they had it but lost it due to a mishap, but I can't find the thread anymore.
I am still interested in getting an ST drive and modifying it to work with the 8-bits. I like the smaller cases and don't want to modify any of my XF551s.
#146 sup8pdct OFFLINE
sup8pdct
    Dragonstomper
  • 882 posts
Posted Fri Jan 23, 2015 4:39 PM
check out this thread
http://atariage.com/...51#entry2825432
james
