jimbox114 Posted November 11, 2014 Share Posted November 11, 2014 Hello I have been trying to get Visual bB set up. I followed the instructions and found the FAQ page but I am still getting the can't find default.bas.bin error when I try to compile. I found in the FAQ it says the most common problem is a space in the settings however that does not seem to be the case. I am using Windows 7 64-bit. The directory I keep Batari Basic at first was h:\bbasic. I even tried moving it to c:\bbasic see if it worked better on c drive but still the same. I am using build 554 of Visual Bb and whatever the most up to date version is of Stella and bbasic. Any idea why I might be getting this error still? Quote Link to comment Share on other sites More sharing options...
+Random Terrain Posted November 11, 2014 Share Posted November 11, 2014 Are you sure you're using the latest version of bB? randomterrain.com/atari-2600-memories-batari-basic-commands.html#gettingstarted It looks like it's complaining that you don't have sed.exe in the bB folder, but if you are using bB.1.1d.reveng36.zip, you shouldn't be having that problem. 1 Quote Link to comment Share on other sites More sharing options...
jimbox114 Posted November 11, 2014 Author Share Posted November 11, 2014 I hadn't run install_win.bat and it didn't have the path set. I have it up and running now. I don't think I have the latest version either I went ahead and downloaded the file you listed. Thanks for the info Quote Link to comment Share on other sites More sharing options...
