+eebuckeye Posted November 14, 2014 Share Posted November 14, 2014 Where can I download demos that really show off the ST power (I have 4MB of memory) that work with hard drives (Cosmos Ex)? Thanks! Quote Link to comment Share on other sites More sharing options...
Christos Posted November 14, 2014 Share Posted November 14, 2014 (edited) Try pouet.net and demozoo.org . Most recent demos will work with HD. Older ones will probably not. Dbug have patched some demos for harddisk though Edited November 14, 2014 by Christos Quote Link to comment Share on other sites More sharing options...
+eebuckeye Posted November 15, 2014 Author Share Posted November 15, 2014 Thanks! I downloaded some demos and some work - some do not. The ones that do not scroll the picture on my display. Is that because it is PAL? Is there any way to stop the scroll with my NTSC machine? Quote Link to comment Share on other sites More sharing options...
ParanoidLittleMan Posted November 15, 2014 Share Posted November 15, 2014 There is many demo which can work only at 50 Hz refresh rate because of used shifter tricks. It depends from monitor/TV will you be able to watch 50 Hz demos. And even some games may working only at 50 Hz. Any Atari can work at 50 and 60 Hz, but not all monitors. Quote Link to comment Share on other sites More sharing options...
TwiliteZoner Posted November 15, 2014 Share Posted November 15, 2014 Thanks! I downloaded some demos and some work - some do not. The ones that do not scroll the picture on my display. Is that because it is PAL? Is there any way to stop the scroll with my NTSC machine? I bought many games mail order in the 80s that were from the UK. On both of my Atari color monitors (Goldstar & Hitachi) all I had to do was adjust the vertical/horizontal hold on the back of the monitor. I believe some demos require that you run the file (50.PRG) I have attached for them to run correctly. I know Acid Burn does. acid_burn.zip Quote Link to comment Share on other sites More sharing options...
