erichenneke Posted December 6, 2014 Share Posted December 6, 2014 Working on a program using the paddle control. The idea was for it to have access to all 0-288 positions for very quick response. Everything was fine working in emulation, but when I tested it on the A8 hardware it is terrible! The actual A8 hardware paddle never seems to actually stay still/static. The values are constantly changing even when the control isn't being touched. As a result, the player on the screen is unacceptably jittery, jumping around constantly. I even tried two other paddle controllers thinking it had gone bad over the years, but all three paddle controllers do the same thing. Has anyone run into this? I am thinking there must be a simple way to handle this in the program but my attempts so far have only helped a little but not eliminated the jitter. Thanks! -Eric Quote Link to comment Share on other sites More sharing options...
kenjennings Posted December 6, 2014 Share Posted December 6, 2014 Real pots have that jitter. Since the paddle is an analog reduced to a digital value there are potentially a lot of places where the paddle is on the edge of two values. How much jitter? +/- 1 or 2 is typical. Average the value of the paddle across a couple frames (or more frames depending on the need for speedy movement) and that should reduce the shaking. Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted December 6, 2014 Share Posted December 6, 2014 Working on a program using the paddle control. The idea was for it to have access to all 0-288 positions for very quick response. ...Has anyone run into this? I am thinking there must be a simple way to handle this in the program but my attempts so far have only helped a little but not eliminated the jitter. ... Range is 0-228. Jitter is typical and depending on device more or less worse (old pots tend to jitter terrible, remember that scratching sound when trying to adjust the volume of an old radio). In case of 'fresh' devices averaging samples helps to get the desired result: http://atariage.com/forums/topic/169554-untangle-minimal/?do=findComment&comment=2100486 Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 6, 2014 Share Posted December 6, 2014 With my old paddles, I sometimes have to turn them hundreds of times to get them to operate well again. The only other solution is to upgrade them with high-quality pots. For Castle Crisis, I implemented a little bit of jitter control. I keep track of which direction the paddle is currently moving, and don't allow it to reverse unless the step is large enough. This means jitter can advance the position a little, but not reverse it so there's no twitching. ;********************************************************** ;**** Read Paddles *************************************** ;********************************************************** pots #IFDEF debug lda #$58 ;Light Purple sta COLBK #ENDIF ;Update the Paddle Values ldx #$03 ;Read 4 Pots potloop lda POT0,x ;Adjust for a Paddle offset value (adjust where the active ;portion of the paddle is). sec sbc #POFFSET ;Subtract an offset value (26 or less) ;Did this generate a less-than-zero result? bcs potskip1 ;No, no adjustment needed lda #00 ;Yes, <0 becomes 0 bcc potskip2 ;skip the next test ;Did this generate a greater than 160 result? potskip1 cmp #161 ;In range? bcc potskip2 ;Yes, skip down lda #160 ;No, adjust to 160 clc ;We got here because Carry was set potskip2 sta temp0 ;Save the final value ;Take the new value and modify it to +1 if the momentum is forward adc paddir0,x ;Get "resistance" direction (0 or 1) ;Now subtract the old value sec sbc pad0,x ;Subtact the old value ;Carry is clear if the old value was bigger (we're going backwards) ;Move the result to Y so we can use A tay ;Copy of the result in Y lda #0 ;Clear A rol a ;A = 1 if new value is larger, 0 if not (Clears Carry!) ;A contains the new "paddir" ;Now see if the change is outside of the filter zone cpy #2 ;Subtraction result greater than 3? bcc nextpot ;No, ignore this change ;Okay, this change is valid. Save A as "paddir" and ;save the new POT value sta paddir0,x lda temp0 sta pad0,x lda #$50 sec sbc temp0 sta shldpos,x nextpot dex bpl potloop ;Do all 4 sta POTGO ;Restart Pots! #IFDEF debug lda #$00 ;Black sta COLBK #ENDIF rts Quote Link to comment Share on other sites More sharing options...
erichenneke Posted December 8, 2014 Author Share Posted December 8, 2014 thanks ! I will definitely try both of the approaches. averaging the last few cycles and also limiting the single step movement to "forward". Working on some other logic in the program right now, so will get back to the paddle control logic again next. Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 8, 2014 Share Posted December 8, 2014 My gut feeling is that averaging will cause the motion to feel sluggish unless the project doesn't need fast response. Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 8, 2014 Share Posted December 8, 2014 Filtering jitter will absolutely impact response. The beginning of a quick turn is indistinguishable from the start of a jitter. If you're going to filter jitter, using an averaging technique will leave the jitter "noise" in the signal, but reduce+smear it. Using median filtering (on the current and last 2 samples) will do a much better job of removing the noise, provided the jitter event lasts for just 1 sample period. If a jitter event lasts for more than 1 sample period, I fear no filtering method will remove it without destroying the paddle response. (though your method will mask it for smaller jitters, or potentially impact subtle turns.) Plan B: clean the paddle contacts, and anticipate others will do the same with jittery pots. Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 8, 2014 Share Posted December 8, 2014 Working paddles will either be stable or will toggle between two adjacent values. Anything worse than that probably means dirty pots. 3 Quote Link to comment Share on other sites More sharing options...
+JAC! Posted December 8, 2014 Share Posted December 8, 2014 >For Castle Crisis, I implemented a little bit of jitter control. I keep track of which direction the paddle is currently moving, and don't allow it to reverse unless the step is large enough. That is a very good idea. And I can confirm that the paddle control in Castle Crisis is excellent. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted December 8, 2014 Share Posted December 8, 2014 Can't you just AND off the low few bits? Quote Link to comment Share on other sites More sharing options...
+David_P Posted December 9, 2014 Share Posted December 9, 2014 Can't you just AND off the low few bits? Drop one bit and your potential resolution is halved; drop two bits and your potential resolution is quartered. Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted December 9, 2014 Share Posted December 9, 2014 Drop one bit and your potential resolution is halved; drop two bits and your potential resolution is quartered. And so is your jitter. Quote Link to comment Share on other sites More sharing options...
RevEng Posted December 9, 2014 Share Posted December 9, 2014 We have a total of 228 positions. Dividing by 2 will give you 114 positions on the screen, won't block jitter that's larger than a single position, and might look a little rough if the full horizontal range of the screen is to be covered by the paddle movement. Dividing by 4 and providing only 57 positions will be a non-starter for most games. 1 Quote Link to comment Share on other sites More sharing options...
Bryan Posted December 9, 2014 Share Posted December 9, 2014 Anding off bits won't help you at all if the value is twitching between $2F and $30. 3 Quote Link to comment Share on other sites More sharing options...
+CyranoJ Posted December 9, 2014 Share Posted December 9, 2014 Anding off bits won't help you at all if the value is twitching between $2F and $30. Good point Oh well, was a quick, dirty solution if it worked. Quote Link to comment Share on other sites More sharing options...
Irgendwer Posted December 9, 2014 Share Posted December 9, 2014 My gut feeling is that averaging will cause the motion to feel sluggish unless the project doesn't need fast response. ...doesn't seem so... Quote Link to comment Share on other sites More sharing options...
