phoenixdownita Posted December 15, 2014 Share Posted December 15, 2014 Is it possible to craft a PBI or an ECI interface in an XEGS? Duplicating the cartridge connectors won't be that hard, but how about the rest of the PBI makeup or alternatively the ECI? Is anything missing? (apart the Audio in for the ECI) I remember the MPD was kind of messed up on XEGS to allow for Missile Command select (or was that EXTSEL) Quote Link to comment Share on other sites More sharing options...
Rybags Posted December 15, 2014 Share Posted December 15, 2014 Yep, the MMU difference becomes a sticking point. MPD is required for PBI-compliant devices to be able to switch their Rom in. Then there's the physical aspect. You need to breakout the cart signals as well since it'd be kinda pointless doing a vertical ECI port next to the normal cart slot. I would suspect also since you need a normal XL or XE MMU that then creates the need for select logic to handle the ROM since the XEGS Rom is unique in that it's 32K and holds everything. Quote Link to comment Share on other sites More sharing options...
charliecron Posted December 15, 2014 Share Posted December 15, 2014 When Metalguy made the 1200xl PBI Extender Boards http://atariage.com/forums/topic/137612-1200xl-pbi-extender-board-production-run-order-here/ he mentioned it could work in a XEGS... Charlie Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 15, 2014 Share Posted December 15, 2014 Check this out: http://www.atari.org.pl/forum/viewtopic.php?id=9264 Quote Link to comment Share on other sites More sharing options...
phoenixdownita Posted December 15, 2014 Author Share Posted December 15, 2014 (edited) Nice, so Candle added ECI to his XEGS.I guess this picture http://stryker.pigwa.net/xegs/17.jpg is where the 10 ECI connections are supposedly taken from (the 2 small 5 wire ribbon cables). Here's a forum with blown out pics of the MB http://atariage.com/forums/topic/186115-xe-motherboard-revisions/ Wish there was some documentation on what those points are on the motherboard, I'm pretty sure some piggy back on the enhanced MMU of U1MB. Anyway I annotated that pics with the chips name on the relevant parts, it's attached to the post. Looks like: 3 from CPU 1 from Freddie 1 from LS138 4 or 5 from (E)MMU If we exclude +5V/GND/Reserved/AudioIn from the ECI, it seems it found all the rest. Edited December 15, 2014 by phoenixdownita Quote Link to comment Share on other sites More sharing options...
flashjazzcat Posted December 15, 2014 Share Posted December 15, 2014 Use this as a reference: http://www.retrobits.net/atari/pbi.shtml It should be possible to cross-reference the 1200XL design by locating corresponding points on the XEGS mainboard. Quote Link to comment Share on other sites More sharing options...
+Allan Posted December 15, 2014 Share Posted December 15, 2014 When Metalguy made the 1200xl PBI Extender Boards http://atariage.com/forums/topic/137612-1200xl-pbi-extender-board-production-run-order-here/ he mentioned it could work in a XEGS... Charlie If anybody wants one of these extension boards, I still have a couple. Allan Quote Link to comment Share on other sites More sharing options...
Kyle22 Posted December 16, 2014 Share Posted December 16, 2014 Bob Woolley (Bob1200XL here) would also be a good one to ask about this. I know him personally, and he is an Atari8 Guru. Quote Link to comment Share on other sites More sharing options...
