Found unknown (Dutch) ROM (R.OS v2 5-1990)
130XE ROM
15 replies to this topic
#1 SenorRossie OFFLINE
SenorRossie
    Star Raider
  • 69 posts
  • Rediscovering the atari 8bit after 30 orso years
  • Location:Virgo Supercluster, Local Group, Milky Way, Solar System, Earth, Europe, The Netherlands, Flevoland, Almere
Posted Wed Dec 31, 2014 12:11 PM
A couple of weeks ago I purchased a beaten set of 8bit machines. One of them, a 130XE, booted into an unknown (to me that is) OS:
After booting the ROM, the machine doesn't respond to anything, but the RESET button.  I've contacted a couple of folks that could know more about this, but that came up empty, hence this post.
A couple more shots of the inside of the system with things that stood out (to me):
Anyone got some more info on this?
I plan on creating a dump somewhere next week, but any info on the ROM is welcome.
Kind regards,
Senor Rossie
P.S. Happy New Year !
#2 TXG/MNX OFFLINE
TXG/MNX
  • 3,633 posts
Posted Wed Dec 31, 2014 4:27 PM
Yes dump nice find :-)
#3 David_P OFFLINE
David_P
    Dragonstomper
  • 929 posts
Posted Wed Dec 31, 2014 4:46 PM
Have you tried swapping out the keyboard?  The boot prompt suggests that START and SELECT should be active - maybe the keyboard on that unit is bad?
#4 SenorRossie OFFLINE
SenorRossie
    Star Raider
  • 69 posts
Posted Fri Jan 2, 2015 7:13 AM
I tested the hardware with a known working ROM and except for the HELP key, the keyboard worked fine.
#5 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Fri Jan 2, 2015 5:53 PM
Groningen is a city in The Netherlands for sure.....but never heard of this....maybe it was for some dedicated purpose ?
#6 adam242 ONLINE
adam242
  • 1,002 posts
Posted Fri Jan 2, 2015 6:19 PM
Maybe START or SELECT needs to be held down at power up?
(Grasping at a straw)
#7 flashjazzcat OFFLINE
flashjazzcat
  • 14,327 posts
Posted Fri Jan 2, 2015 8:06 PM
Or while Reset is pressed?
#8 Sikor OFFLINE
Sikor
  • 1,451 posts
Posted Fri Jan 2, 2015 11:58 PM
I think, that not only OS ROM was change. I think, that also BASIC ROM must be read. With START you can go to Atari Basic, with Select - to other ones, user defines (and write into eprom with language - for example: Action!, Basic XE, or any tool). So, I think - both must be read: OS ROM i BASIC/otherone ROM.
#9 SenorRossie OFFLINE
SenorRossie
    Star Raider
  • 69 posts
Posted Sat Jan 3, 2015 2:42 PM
Thanks to Frankenstein's romsaver utility (http://atariage.com/...-rom-basic-rom/), I was able to dump the ROM.
I started with running the romsaver atr from a MyIDE][ cart, but that ended up in 'BOOT ERROR', so I tried to use my SIO2PI setup to boot the ATR, which again resulted in a 'BOOT ERROR' message. So, I opted for another route: I booted a DOS2.0s atr from the SIO2Pi D1, and added the romsaver.atr as D2. I ran the romsaver.com from D2: and swapped D1 with a blank formatted disk (Attached File  R_OS_v2.atr   90.02KB   179 downloads).
#10 phaeron OFFLINE
phaeron
  • 2,674 posts
Posted Sat Jan 3, 2015 2:59 PM
BASIC ROM is vanilla rev C.
Besides the startup change, looks like the OS also has mods to the cassette tape routines, probably for turbo. Other than that it's mostly the same as the XL/XE OS.
#11 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Sun Jan 4, 2015 5:29 AM
Is that a 100% reliable way of dumping the ROM ? I've got an EPROM programmer that can read the ROM if needed.
#12 AtariGeezer ONLINE
AtariGeezer
  • 2,874 posts
Posted Sun Jan 4, 2015 5:17 PM
I don't see the attachment in that blog,  can you re-post?
#13 F#READY OFFLINE
F#READY
    Star Raider
  • 99 posts
Posted Mon Jan 5, 2015 1:26 AM
Oops! Added now:
Will upload the source code later...
#14 SenorRossie OFFLINE
SenorRossie
    Star Raider
  • 69 posts
Posted Mon Jan 5, 2015 5:10 AM
I don't know wether it is a 100% reliable way of dumping the ROM. But if you can bring the EPROM programmer to Maarssen in two months, I'll bring the 130XE with me ;)
#15 SenorRossie OFFLINE
SenorRossie
    Star Raider
  • 69 posts
Posted Tue Oct 10, 2017 1:19 PM
Apologies for (necro)bumping this topic, but I found some additional info on the R.OS ROM while searching for ROMS to flash on my Antonia card.
Seems it contains an, ATARI compatible, modified OS with 2400baud cassette interface as Phaeron pointed out already.
When I dig up the machine again, I'll see if it contains the 16k BASIC EEPROM and will have a go at dumping its contents, but for now: Case closed.
#16 Level42 OFFLINE
Level42
  • 2,602 posts
Posted Wed Oct 11, 2017 3:01 AM
Hope to make it to Maarssen next Atari event !!!!
Also tagged with one or more of these keywords: 130XE, ROM
