Replacing the noisy fan in the PEB
modification hardware PEB
24 replies to this topic
#1 kl99 ONLINE
kl99
    Dragonstomper
  • 804 posts
Posted Tue Jan 6, 2015 2:22 PM
Hi,
I am currently trying to perform the FAN replacement within the PEB.
It is the push button PEB.
So far I have managed to disassemble everything and removed the original 110v fan.
http://www.mainbyte....ox_project.html
Attached File  IMG_2040.JPG   2.35MB   4 downloads
Attached File  IMG_2041.JPG   2.65MB   4 downloads
But what to do with the wires that went into that fan?
How to best isolate those 110V wires?
Attached File  IMG_2043.JPG   2.34MB   4 downloads
And instead of soldering the power connector of the new 12V fan to the internal power supply I would prefer to connect it to the 12V MOLEX connector that goes to the disk drives. I have an adapter like this:
adapter-molex-4pin-f-molex-4pin-m-fan-2p
Thanks for any replies.
I hope to finish this before going to sleep...
#2 kl99 ONLINE
kl99
    Dragonstomper
  • 804 posts
Posted Tue Jan 6, 2015 2:25 PM
Here you can see how the Push-Button PEB isolates the wires of the unused voltages:
Front View:
Attached File  IMG_2045.JPG   2.13MB   4 downloads
Top View:
Attached File  IMG_2046.JPG   2.33MB   4 downloads
Below Fan View (don't know if helpful):
Attached File  IMG_2047.JPG   1.69MB   4 downloads
#3 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 11,687 posts
Posted Tue Jan 6, 2015 3:09 PM
You could easily avoid the extra cables if you don't mind soldering two little connections.
The photo below (ripped off of the Mainbyte site) shows where you connect the 12v leads.
As for the left over AC leads you could terminate them with electrical tape... or add a power tap for a low powered item you want to come on at the same time you turn on the P-Box.
#4 kl99 ONLINE
kl99
    Dragonstomper
  • 804 posts
Posted Wed Jan 7, 2015 8:26 AM
This is how I have isolated the wires that did go to the original 110V fan, the blue isolation tape was done 3 times just to be sure.
Attached File  IMG_2062.JPG   2.22MB   5 downloads
Here is the fan. I didn't reuse the nuts from the original fan because my smallest wrench was size 6 and that was slightly too wide. Will try to get better tools next time.
Maybe its an interesting note that the "screws" that hold the nuts are fixed on the PEB, you can not replace them by other stuff (plastic ones or whatever comes with your fan).
Attached File  IMG_2061.JPG   2.19MB   4 downloads
Attached File  IMG_2055.JPG   1.98MB   4 downloads
My fan came with a 3 pin Molex connector. Instead of soldering it directly to the internal power supply, I chose to use one of the many adapters that were lying around in my appartment from PC tooling.
The adapter is shown above. It is 2 pin only, but relax the 3rd pin is only sending optional feedback data like RPM to the mainboard. The 3rd pin is never used to control the speed of the fan.
You can see nicely how I wired the fan power connector to the big molex connector that goes to the disk drive(s).
Attached File  IMG_2057.JPG   1.85MB   2 downloads
The project is almost done, the PEB is closed already and the new fan was running fine on first tests, although I can barely hear it.
This new fan runs below 10db.
Thx to everyone who supported me, kl99
#5 Asmusr OFFLINE
Asmusr
  • 2,666 posts
Posted Thu Jan 8, 2015 3:07 PM
Is it a standard 80 mm fan?
#6 kl99 ONLINE
kl99
    Dragonstomper
  • 804 posts
Posted Fri Jan 9, 2015 2:07 AM
standard 8cm fan, 12V.
I chose this model because it was on stock in the conrad shop I went:
http://www.blacknois...0x25mm.php#tab5
#7 Asmusr OFFLINE
Asmusr
  • 2,666 posts
Posted Fri Jan 9, 2015 1:05 PM
Thank you, I have also replaced my fan now. It really makes a big difference.
#8 conmee OFFLINE
conmee
    Space Invader
  • 34 posts
Posted Mon Feb 2, 2015 3:55 AM
I followed the same process as kl99 and the fan replacement I'm using draws power via a similar adapter to the one kl99 posted (it is connected in line between the floppy power and floppy drive). Didn't recall just how loud the original PEB was until I set up my system a few weeks ago. Using an iPhone app (I don't vouche for it's accuracy), the noise level in my home office is ~38db with all electronics turned off. With the original PEB running the noise level rose to ~84db. After changing the fan, the noise level with the PEB running is ~42db with the new brushless fan. Makes a huge difference, and now the dog no longer runs off when I fire up the TI...  :thumbsup:
Thanks to the Mainbyte site, kl99, and the helpful community here as this is definitely a worthwhile upgrade.
#9 Schmitzi OFFLINE
Schmitzi
  • 4,260 posts
  • ToXiC
Posted Wed Feb 11, 2015 12:35 PM
Hi,
here are some pics from different mods I did
#10 retroclouds ONLINE
retroclouds
  • 1,591 posts
Posted Sun Dec 18, 2016 2:20 PM
ok, I have 2 PEB's where I want to change the fans.
Incredibly how loud these things are. What was TI thinking? Might have been ok for the server room, but surely not to have one on your desk.
Both PEB's are in the toggle version, not the push button version (does that matter?)
How much time does this take? Anything else that would make sense doing while the PEB is dismantled?
#11 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,466 posts
  • Distracted at the Keyboard
Posted Sun Dec 18, 2016 3:47 PM
It takes 500 hours to get to the fan.
2 minutes to replace it and 600 hours to put everything back.
4962 screws.
#12 jstimson OFFLINE
jstimson
    Star Raider
  • 76 posts
Posted Sun Dec 18, 2016 8:10 PM
I may be odd, but off all the mods I could do to my TI setup, this would be last on my list.  I grew up with the loud fan as background noise to much of my childhood.  I find it oddly comforting now and think I would actually miss it if it went away.
#13 OLD CS1 OFFLINE
OLD CS1
  • 4,918 posts
  • Technology Samurai
Posted Sun Dec 18, 2016 9:08 PM
At my age I just want quiet.
  • jhd likes this
#14 InsaneMultitasker OFFLINE
InsaneMultitasker
  • 1,962 posts
Posted Sun Dec 18, 2016 11:29 PM
There is one "advantage" to the loud/audible fan:  it helps to remind you the PEB is turned on.
Back when the quiet fan replacement was 'all the rage', there was an uptick in peripheral card repairs, often because someone forgot to turn off the now-silent PEB before removing or inserting a card.  A visible warning aid, such as one or more top-down visible LEDs, is a good idea to round out the fan replacement.
Edited by InsaneMultitasker, Sun Dec 18, 2016 11:30 PM.
#15 Sinphaltimus OFFLINE
Sinphaltimus
  • 2,466 posts
Posted Mon Dec 19, 2016 4:50 AM
Or a kill switch attached to the cover.
#16 Vorticon OFFLINE
Vorticon
  • 3,103 posts
Posted Mon Dec 19, 2016 5:01 AM
I second that. With my ATX PSU replacement in the PEB, it's really hard for me to tell if the PEB is on at all, and I frequently have to look at the switch position to verify...
#17 Schmitzi OFFLINE
Schmitzi
  • 4,260 posts
  • ToXiC
Posted Mon Feb 13, 2017 5:01 PM
yes, a silent fan is very nice :)
Attached File  TI-Potpourri-PEBs.jpg   210.57KB   2 downloads
Attached File  TI-Potpourri-Pebs2.jpg   176.74KB   2 downloads
#18 Casey OFFLINE
Casey
    Chopper Commander
  • 213 posts
Posted Mon Feb 13, 2017 7:56 PM
ok,Incredibly how loud these things are. What was TI thinking? Might have been ok for the server room, but surely not to have one on your desk.
You must have never been around an actual IBM PC of the same vintage then.  The public library I worked at for my first job had a genuine IBM PC XT as the main circulation desk computer and it sounded like a jet engine starting up when you turned it on.  It was later replaced with a much quieter IBM PS/2 - but I suspect the loudness of the TI fan is just a product of the time it was made.
#19 --- Ω --- OFFLINE
--- Ω ---
    --- Ω ---
  • 11,687 posts
Posted Mon Feb 13, 2017 9:29 PM
I made a blog entry when I replaced the fan with a 'whisper quiet' version in my backup Box back in May of 2015 and have not used it or turned it on since.  I really should sell it, but I don't want to go through the hassle of shipping it.
#20 Opry99er OFFLINE
Opry99er
  • 9,294 posts
Posted Wed Feb 14, 2018 2:35 AM
Thinking of doing this mod....  This could be an interesting solution??  Will it work?
https://www.amazon.c...eywords=8cm fan
#21 arcadeshopper OFFLINE
arcadeshopper
  • 3,164 posts
Posted Wed Feb 14, 2018 4:07 PM
I ended up using a ac voltage fan as they can run off the same power the old fan did.. and I don't have to jerryrig anything to the 12/5v lines got them at frys https://www.frys.com...CH:MAIN_RSLT_PG
Greg
#22 Ed in SoDak OFFLINE
Ed in SoDak
    Moonsweeper
  • 391 posts
Posted Wed Feb 14, 2018 5:31 PM
The easy way to isolate those power-bearing wires is with a bit of heatshrink over the connector. Easily cut off and it won't fail over time or leave residue like tape.
Like Greg, I went with an AC fan, mostly because I had several 120v fans on hand when I did the swap some three decades ago. 12v fans were not as common back then and 120v AC fans were plentiful and cheap in surplus. Rather than have the big PEB hogging the desktop, I had it on a low platform next to the desk. That kept the fan noise level even lower. A power bar handled the whole system with one switch.
My dual-in-the-PEB drives were already taxing the 12v line, so I ended up powering only one drive at a time from the PEB supply.
My "stock" TI had four drives, though the TI controller only allows three. The two in the PEB were drives A(1) and A(2), with a simple SPDT switch to send the 12v line to enable either drive singly. Drives B and C were outboard with their own beefy supply. Worked great to have two boot disks to choose from with B & C used for data, files or more programs. I tended to keep the same disks in each drive, which made it more of habit to know which one I wanted to boot with. It helped a lot with eliminating disk swapping to run another program for some little thing, then returning to the main task at hand. When writing programs, a flip of the switch and I could make a backup copy on another drive and floppy without changing the DSK# or filename.
The switched power concept could be extended to have B(1), B(2) drives and so on. In my stash was a long ribbon cable already made up that held more drive connectors than I ever needed. All I needed to do was wire up the switch for the 12 v lines to the drives.
-Ed
Edited by Ed in SoDak, Wed Feb 14, 2018 5:49 PM.
#23 sixsevenco OFFLINE
sixsevenco
    Star Raider
  • 50 posts
Posted Tue Feb 27, 2018 10:44 AM
Greg
Just to confirm, with an AC Fan, I wouldn't need to solder anything.  I can just use the push-connector terminals that the current fan attaches to?
#24 arcadeshopper OFFLINE
arcadeshopper
  • 3,164 posts
Posted Tue Feb 27, 2018 10:48 AM
Correct and it will not be silent there is no such thing as a fan that moves good amount of air quietly that is that size it will be about 40% quieter which is a distinct Improvement.
Sent from my LG-H830 using Tapatalk
#25 OLD CS1 OFFLINE
OLD CS1
  • 4,918 posts
Posted Tue Feb 27, 2018 12:41 PM
I just received that very fan.  Holy cow that thing is heavy!  Gives me the notion it might last a while longer than those 2oz plastic fans :)
