simbalion Posted January 28, 2015 Share Posted January 28, 2015 I have three working model 1 Sega Genesis consoles as well as a working Sega Nomad and a model 2 console. I am wondering if the power supply bricks used with the Nomad and model 2 can be used on the model 1? I noticed the power supply with my model 1 is rated at 9 volts DC, 1.2 amps. The other supplies I have are rated 10 volts DC and less than one amp. Just curious as so far I only have one matched power supply to the three model 1 consoles I have. Quote Link to comment Share on other sites More sharing options...
mkiker2089 Posted January 28, 2015 Share Posted January 28, 2015 Less than 1 amp? I wouldn't try it then. The voltage is ok as most devices down convert it anyway, but don't take that as a given. The amperage is an issue though. You are better off just getting aftermarket supplies as they are probably better anyway. Technology has come a long way in the past 30 years. Quote Link to comment Share on other sites More sharing options...
mickcris Posted January 28, 2015 Share Posted January 28, 2015 (edited) Here is the info you need: http://www.gametrog.com/GAMETROG/How_which_do_i_need_SEGA_AC_Power_Supply_Information_Specs_Model_mk-3025_mk-1602_mk-2103_mk-1479_mk-4122_aa-s95j.html The polarity of the tip and physical size are different between the model 1 and 2: Edited January 28, 2015 by mickcris Quote Link to comment Share on other sites More sharing options...
simbalion Posted January 29, 2015 Author Share Posted January 29, 2015 Here is the info you need: http://www.gametrog.com/GAMETROG/How_which_do_i_need_SEGA_AC_Power_Supply_Information_Specs_Model_mk-3025_mk-1602_mk-2103_mk-1479_mk-4122_aa-s95j.html The polarity of the tip and physical size are different between the model 1 and 2: Thanks! I'll jot those down so I have a list when I am out looking around for games and parts. Quote Link to comment Share on other sites More sharing options...
