pixelmischief Posted January 30, 2015 Share Posted January 30, 2015 (edited) I have an Aranym configuration running TOS 4.04 and MultiTOS. I've got Pure C working and can "Make All" the "HELLO.PRJ" sample. Next order of business is to get Reservoir Gods' GodLib up and running. I've copied the library into the "INCLUDE" path under "GODLIB". But when I try to "Make All" the "BOX.PRJ" sample, Pure C appears to compile all the C stuff, but crashes back to GEM when it gets to the .S stuff. The following error is offered by MultiTOS: AranymGodLibBoxCompileFail.bmp I've tried booting Aranym with no "AUTO" folder execution, which means no MultiTOS, screen enhancer, or anything else that might be in the way, but the "Make All" still just bombs out. Any ideas? Edited January 31, 2015 by pixelmischief Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2015 Author Share Posted January 31, 2015 (edited) I noticed an object file for the GEMDOS library in my INCLUDE folder where one does not exist in the original library. So recopied the library back into INCLUDE and tried the compile again, this time using "Make" instead of "Make All". Now the process hangs at the assembly phase on GEMDOS_S.S. Edited January 31, 2015 by pixelmischief Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted January 31, 2015 Share Posted January 31, 2015 I hope you get this figured out. I am interested in setting up that environment also. Keep us posted! Quote Link to comment Share on other sites More sharing options...
Christos Posted January 31, 2015 Share Posted January 31, 2015 Why don't you try hatari? Aranym isn't a falcon emulator Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2015 Author Share Posted January 31, 2015 Why don't you try hatari? Aranym isn't a falcon emulator Hmmmm. Ok! Hatari, coming up. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2015 Author Share Posted January 31, 2015 Still going to try Hatari, but... - hatari_falcon.exe is an experimental version using a new cpu emulation that adds better support for 68030 and DSP. In most cases, it should give better results that hatari.exe if you want to run Falcon's programs. But it's still work in progress, so some programs will not run correctly yet. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2015 Author Share Posted January 31, 2015 Got Hatari up and running. Thanks Uwe for helping me disable SCSI checking on bootup. And... Same problem. The "Make" crashes. This sucks. Any takers? Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted January 31, 2015 Share Posted January 31, 2015 I going to set up now and check it out. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted January 31, 2015 Share Posted January 31, 2015 I thought you had the sample source attached to this thread? Now I don't see it. I am running hatari pure_c now if you want me to try the source. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted January 31, 2015 Author Share Posted January 31, 2015 I thought you had the sample source attached to this thread? Now I don't see it. I am running hatari pure_c now if you want me to try the source. OK. Go to the link below. There you will find the library and the BOX sample. Give it a shot. Would love to know what you get. http://rg.atari.org/source.htm Quote Link to comment Share on other sites More sharing options...
lp060 Posted February 1, 2015 Share Posted February 1, 2015 (edited) I have a few huge projects with lots of assembler files in PureC. Using NAES here. My biggest problem is 'C' itself, make all typically ends with an window full of error messages, but never a crash. I use Hatari, but only for testing builds. Being stuck in SingleTOS is a work flow killer. I have aranym and hatari pointing at the same host filesystem directory. Hit 'make all' in aranym, then switch to hatari and refresh the directory and run the build. Originally I had PureC setup in hatari because the rumor was it would not run in MiNT, but I moved all my PureC dev to aranym after researching that and found it runs fine under MiNT. When I was using hatari it didn't crash either. I really have no clue what you could be doing wrong. During my search for PureC, I found several archives and not one them original. It seems like every PureC archive you find is someone's used installation that they decided to just zip up. Perhaps you managed to get hold of a faulty archive of PureC itself? Edited February 1, 2015 by lp060 Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 1, 2015 Author Share Posted February 1, 2015 During my search for PureC, I found several archives and not one them original. It seems like every PureC archive you find is someone's used installation that they decided to just zip up. Perhaps you managed to get hold of a faulty archive of PureC itself? This is a good possibility. I don't remember now where I got the copy of PureC I am using, but I don't remember mounting disk images and performing an install. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted February 1, 2015 Share Posted February 1, 2015 (edited) Well it compiled fine for me. I used standard Hatari and used a regular windows folder as a pseudo-drive C. Used tos4.04 rom image. I put pure_c in the root and put the godlib into pure_c\include\ and box directory into root. I loaded the project box.prj and then make all. It compiled and then I chose 'run' and it showed a black box on the screen. Here is the Pure_C I used http://www.filehosting.org/file/details/471719/Pure_C.7z If it is a problem for me to put that link here, admin can let me know and I will remove it. Edited February 1, 2015 by TheNameOfTheGame Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 2, 2015 Author Share Posted February 2, 2015 This link is requiring me to provide my email address to get a download link. I appreciate the help. TRULY, I do. But I'm not giving my email address away so that spambots all over the planet can inundate me with unwanted emails. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 2, 2015 Author Share Posted February 2, 2015 Mr. Pink at Reservoir Gods has been kind enough to discuss the matter with me a bit. He has informed me of the following: I've started to put the latest version of GodLib and a bunch of example code onto GitHub. You can find the code here: https://github.com/ReservoirGods The "GodLib" repository contains the latest version of GodLib, and should be copied into your PURE_C INCLUDE directory (or set a symbolic link here to it). The GODLIB.SPL repository contains some simple examples. The library is cross platform, and will compile on PC if you have visual studio. You will need the DirectX 9 SDK installed for it to work on PC. You don't have to use GIT to get all this code, GitHub provides links to ZIPs of all the sourcecode if that is easier to work with. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted February 2, 2015 Share Posted February 2, 2015 This link is requiring me to provide my email address to get a download link. I appreciate the help. TRULY, I do. But I'm not giving my email address away so that spambots all over the planet can inundate me with unwanted emails. Crap, sorry, didn't think of that. Just picked the first file hosting result from google and pasted it in haha. Here is one that doesn't require your email. http://www.megafileupload.com/en/file/605086/Pure-C-7z.html Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 2, 2015 Author Share Posted February 2, 2015 Here is one that doesn't require your email. Much better. Many thanks. Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 3, 2015 Author Share Posted February 3, 2015 For those who may have downloaded the zip files for GodLIB from GitHub and found the line-endings to have been converted to UNIX style line-endings, this has been fixed. Thanks again, Mr. Pink. Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted February 3, 2015 Share Posted February 3, 2015 Btw, here are the English help files for Pure C in case anyone needs them. http://www.megafileupload.com/en/file/605534/PUREC-UK-ZIP.html Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 6, 2015 Author Share Posted February 6, 2015 Team! I have Pure C with help files up and running in Aranym. I am able to include the Reservoir Gods library and build their "BOX.PRJ" sample. Many, many thanks to everyone who helped me get this up. Mr. Pink and RG for the library and for publishing the latest iteration on GitHub. TheNameOfTheGame for a nice clean Pure C distro with English help files. Ip060 for testing configurations and reporting back. Henk of AHCC fame for working with me to understand why AHCC doesn't play nice with SpeedoGDOS and for offering an alternative, actively maintained C development environment and compiler/linker. Here begins the next stage of my journey. I'll keep you posted. 2 Quote Link to comment Share on other sites More sharing options...
sh3-rg Posted February 8, 2015 Share Posted February 8, 2015 Will be watching, glad you got set up and that pinky put out the current godlib stuff. So the fun begins? Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted February 9, 2015 Author Share Posted February 9, 2015 (edited) So the fun begins? Indeed it does. The Falcon is a beautiful machine and I look forward to contributing to its ongoing enjoyability. Edited February 9, 2015 by pixelmischief 2 Quote Link to comment Share on other sites More sharing options...
TheNameOfTheGame Posted March 7, 2015 Share Posted March 7, 2015 (edited) Found this file on my hard drive. It is a Pure C Overview in English by Dan Wilga. http://www.megafileupload.com/en/file/615974/Pure-C-English-Overview-jlg1-1-pdf.html and here is English documentation in the ST-Guide HYP file. http://www.megafileupload.com/en/file/615975/purec-english-hyp.html Edited March 7, 2015 by TheNameOfTheGame Quote Link to comment Share on other sites More sharing options...
pixelmischief Posted March 7, 2015 Author Share Posted March 7, 2015 Thank you!! Quote Link to comment Share on other sites More sharing options...
