Atari 8-bit Software Preservation Initiative
970 replies to this topic
#626 walter_J64bit OFFLINE
walter_J64bit
  • 5,109 posts
Posted Thu May 18, 2017 7:02 PM
I'll just keep my PC running.
#627 Farb OFFLINE
Farb
    Dragonstomper
  • 556 posts
Posted Thu May 18, 2017 9:05 PM
It seems I had a network misconfiguration that was not allowing peers to connect. I think it's fixed now so we'll see if things start working for folks.
#628 _The Doctor__ OFFLINE
_The Doctor__
  • 3,958 posts
Posted Thu May 18, 2017 9:06 PM
okay... what's the IP   I perma banned people who sat a zero for more that 48 hours
still got nothing coming
I will manually add the peer ip and port   I leach at 330MiB down and feed at 25 MiB up
Edited by _The Doctor__, Thu May 18, 2017 9:12 PM.
#629 AtariGeezer ONLINE
AtariGeezer
  • 2,624 posts
Posted Thu May 18, 2017 9:23 PM
Looks okay to me,  there are files that are bigger than 3 MB and conversational German at 271 MB which leaves 184 MB for all the rest which are less than 1 MB and most of those are less than 100k...
#630 _The Doctor__ OFFLINE
_The Doctor__
  • 3,958 posts
Posted Thu May 18, 2017 9:39 PM
cool, the numbers are good but the torrent is still stalled correct?
#631 Farb OFFLINE
Farb
    Dragonstomper
  • 556 posts
Posted Thu May 18, 2017 9:42 PM
Ok, I was trying to be clever and set up a torrent server so there was always a seed. That seems to have failed miserably, so here's a torrent file created the same way I've done the previous ones...
#632 AtariGeezer ONLINE
AtariGeezer
  • 2,624 posts
Posted Thu May 18, 2017 9:43 PM
Yep,  no peers are currently downloading ...
New torrent downloaded 100% and now seeding...
Edited by AtariGeezer, Thu May 18, 2017 9:54 PM.
#633 Clay Cowgill OFFLINE
Clay Cowgill
    Star Raider
  • 99 posts
Posted Thu May 18, 2017 10:38 PM
I'm at 100% now, I cranked up my upstream limit and will leave it seeding for overnight and some time tomorrow.  Thanks for all the work on thie Farb!
#634 _The Doctor__ OFFLINE
_The Doctor__
  • 3,958 posts
Posted Thu May 18, 2017 10:40 PM
it is rolling along but rather slowly.... only 300 KiB/s   I sure hope everyone delete all parts and files of the failed torrents as the name and folders may resend whatever was part of the old torrent
2 seeds found
I am currently uploading 3x more than I am getting...
Edited by _The Doctor__, Thu May 18, 2017 10:41 PM.
#635 Clay Cowgill OFFLINE
Clay Cowgill
    Star Raider
  • 99 posts
Posted Thu May 18, 2017 10:45 PM
I turned my upstream throttling off entirely, but it's not going above ~500kB/s. Probably Comcast choking off torrent traffic or something...
#636 Kyle22 OFFLINE
Kyle22
  • 3,277 posts
  • Call my BBS! telnet://23.25.83.98
Posted Thu May 18, 2017 10:57 PM
480K here, also Comcast.
#637 Clay Cowgill OFFLINE
Clay Cowgill
    Star Raider
  • 99 posts
Posted Thu May 18, 2017 11:51 PM
Very suspicious... ;-)
#638 _The Doctor__ OFFLINE
_The Doctor__
  • 3,958 posts
Posted Fri May 19, 2017 12:01 AM
I was able to feed someone at 1MiB I could feed 25 more at that rate....
#639 xdslx OFFLINE
xdslx
    Star Raider
  • 61 posts
Posted Fri May 19, 2017 2:52 AM
two peers except me  , both are stuck at %70.7 . one is from us other uk.
#640 xdslx OFFLINE
xdslx
    Star Raider
  • 61 posts
Posted Fri May 19, 2017 2:54 AM
its so small , can somebody upload it to mega instead of torrent ?
#641 Mclaneinc OFFLINE
Mclaneinc
  • 5,439 posts
Posted Fri May 19, 2017 3:42 AM
The new torrent was full speed for me and now seeding...
Thanks Farb etc...
#642 remowilliams OFFLINE
remowilliams
  • 10,370 posts
Posted Fri May 19, 2017 8:05 AM
EDIT:  link updated
https://mega.nz/#F!U...W4_zbYBWyHElfvw
#643 sargie OFFLINE
sargie
    Star Raider
  • 83 posts
Posted Fri May 19, 2017 8:35 AM
Not having much luck with the torrent - Stuck at 70 odd percent now for 12 hours :(
#644 remowilliams OFFLINE
remowilliams
  • 10,370 posts
Posted Fri May 19, 2017 8:38 AM
Use the new torrent file from this post  http://atariage.com/...26#entry3764564
It is active and seeded.
#645 Triads OFFLINE
Triads
    Moonsweeper
  • 281 posts
Im seeding the previous torrent now
#646 sargie OFFLINE
sargie
    Star Raider
  • 83 posts
Posted Fri May 19, 2017 9:05 AM
Thanks! Is working now - almost done!
Will leave it seeding until the next one!
#647 xdslx OFFLINE
xdslx
    Star Raider
  • 61 posts
Posted Fri May 19, 2017 11:49 AM
thank you very much , theperhim gary kach
#648 ijor OFFLINE
ijor
  • 1,983 posts
Posted Sun May 21, 2017 2:32 PM
Here is a clean working dump of Zeppelin. As the name of the file implies, this title works only on an 810 drive. It will randomly fail on a 1050 and probably on everything else as well. So if using Altirra, make sure the drive is configured as 810. Will elaborate later ...
I wanted to make a detailed article about this because it is quite interesting. But never found the time. So I am posting here the main concept "as headlines" without much of a redaction. Technically oriented people will probably understand, I hope :)
- Zeppelin uses the so called skew align as one of its protections.
- Skew align refers to a specific angular alignment of the sectors across different tracks.
- Most titles with this protection were formatted aligned with the index hole.
- So that the same physical sector number is located at almost the same angular position in all the tracks.
- The typical protection check performs something like reading physical sector one of a track, then sector one of an adjacent track, and measures the total time taken. It should be one full revolution.
- Some protections measure the actual RPM before, others assume a nominal value.
- The specific drive and firmware timings, such as seek time and settle delay, are not relevant. It always takes one full revolution because the revolution time is much bigger.
- The total time since the drive starts reading the first sector until being ready to read the other one in the adjacent track is in the order of 150 ms; while a full revolution takes 208 ms.
- So the drive always needs to wait one full revolution disregarding if it was ready 20 ms earlier or later.
- Zeppelin disks are is not aligned to the index hole. The skew align was achieved likely using timing.
- That means that sectors with the same physical number in different tracks are not at the same angular position.
- It also makes the formatted alignment not that accurate because it is more influenced by the drive RPM.
- The angular distance between specific sectors on adjacent tracks is not constant. This is probably on purpose to make reproduction of the alignment more difficult.
- But note that yet the alignment across multiple copies is, of course, (more or less) constant for a given pair of tracks.
- Protection is checked similarly as the typical case, measuring the elapsed time since reading physical sector one of a random track, until reading also physical sector one on an adjacent track.
- But because of the not constant alignment, it doesn’t always take one revolution. The software has a table for the expected time for each track.
- And because now in some tracks it takes less time than one revolution, the internal drive timings become relevant and significant.
- The protection assumes the timing matches a standard 810 drive. Just about any other drive would randomly fail the protection.
#649 Farb OFFLINE
Farb
    Dragonstomper
  • 556 posts
Posted Mon May 22, 2017 2:11 PM
This is fantastic information - thanks, Ijor. I've updated the information for the Zeppelin dump on the preservation website with this info.
#650 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 277 posts
Posted Mon May 22, 2017 4:13 PM
Slight correction: It's actually two tables to diffenrentiate between PAL and NTSC.
