Atari 8-bit Software Preservation Initiative
1118 replies to this topic
#926 Farb OFFLINE
Farb
    Dragonstomper
  • 587 posts
Posted Tue Mar 6, 2018 9:11 AM
Any of these disks need archiving?
Hi @Nezgar, thanks for posting the images. Here is what we could use:
Titles for which we have no dump:
Andromeda Conquest
Candy Factory
Computer War
Eastern Front 1941
Home Financial Management
Pool 1.5
Titles for which we have one flux dump but could use another for verification purposes:
BC's Quest for Tires
Choplifter!
Crush, Crumble and Chomp!
Gorf
Hellcat Ace
Hitchhiker's Guide to the Galaxy
Molecule Man
Mouskattack
MovieMaker
Preppie! (based on the protection description on the disk sleeve, I think this may be version 2.0)
S.A.G.A. #1
Seven Cities of Gold (grey disk)
Suspended
Temple of Apshai
Track Attack
Wizard of Wor
Zaxxon
Zombies
Zork I
Zork II
Shoot me a PM if you are interested in letting us dump them!
Does the list show how many kryo/scp dumps have been made for each? last I remembered it just said if one was done or not...
The database does track this but I haven't exposed it on the website. I will add it to the list of things to implement since it sounds like it would be helpful.
Edited by Farb, Tue Mar 6, 2018 10:09 AM.
#927 Nezgar OFFLINE
Nezgar
    Dragonstomper
  • 748 posts
Posted Tue Mar 6, 2018 10:21 AM
thanks, I'll PM you Farb. I have many 1050's with various enhancements but no Kryoflux, and I don't want to get a kryoflux for 1 time use. I'll PM you as I'd be happy to send them to you to ensure they're imaged properly.
#928 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 292 posts
Posted Tue Mar 6, 2018 1:04 PM
Pinball is the same on real hardware. This one ok on 810 only, bad on 1050. OS-B only and the torrent one the same as above also.
I noticed that the skew was missing from mine so added the torrent one. Now it loads from either drive but still OS-B only of course.
attachicon.gifSolo Flight.zip
attachicon.gifPBall Skewed.zip
Thanks.
The ATX of Solo Flight does not have duplicate sectors. So it already was just a sector copy back then.
Unfortunately the game apparently runs with no protection because it only flips one bit if the protection was OK. Later on it does "something".
Your Pinball has at least a different loader than the one in the torrent. In-memory they differ in a few locations <$700 and for ~3kB >$b200.
It loads on an XL but only if you press OPTION quite long (until after sector 3 or 4). Otherwise it seems to switch on BASIC and then complains that you must remove the cartridge.
The version in the torrent behaves "usual" and accepts a short press of OPTION.
Do we have a raw low level dump? If so it might give some hints about the reason of that track with 19 sectors. Might be a conversion/imaging error.
Note that even if both dup sectors are identical, the timing is affected. Probably not checked in this case, and I don't remember for sure if there is any case that something like this is actually checked.
Yes, we do. See posting #907 above for most images and posting #914 for the remaining images of WO 88.
In addition to Farb's answer:
If your handwritten labels are correct, the torrent contains different versions of Temple of Apshai and Crush, Crumble and Chomp because these disk have NO copy protection.
#929 FULS OFFLINE
FULS
    Moonsweeper
  • 328 posts
Posted Tue Mar 6, 2018 3:29 PM
Thanks.
If I remember correctly, Solo Flight would only run at half speed without the protection on the disk.
#930 Zarxx OFFLINE
Zarxx
    Chopper Commander
  • 100 posts
Posted Tue Mar 6, 2018 3:48 PM
eBay Collection 2
A few originals this time, some protected backups, lots of menu games. It looks like there are a few in this bunch we are missing.
https://drive.google...iew?usp=sharing
#931 _The Doctor__ ONLINE
_The Doctor__
  • 4,024 posts
Posted Tue Mar 6, 2018 4:03 PM
and boy did that take the fun out of it. many thought it was that slow and didn't buy it, as many tried before they bought back in the day ;)
#932 Nezgar OFFLINE
Nezgar
    Dragonstomper
  • 748 posts
Posted Tue Mar 6, 2018 5:17 PM
it's quite possible the disks are failing due to age, and those errors are just from bad reads. I added those labels with notes a month or 2 ago when I was inspecting some of the disk layouts with the speedy analyzer. I did not actually make any copies and test.
#933 Farb OFFLINE
Farb
    Dragonstomper
  • 587 posts
Posted Wed Mar 7, 2018 7:15 AM
This change is now live and is shown on the dump details page a count of "identical dumps".
#934 Zarxx OFFLINE
Zarxx
    Chopper Commander
  • 100 posts
Posted Wed Mar 7, 2018 5:21 PM
Fresh copy arrived today.
Attached File  Spitfire 40 (1986)(Mirrorsoft)(GB).zip   4.06MB   36 downloads
Attached File  Spitfire 40 Manuals.zip   29.68MB   32 downloads
Also this, but it requires a dongle
Attached File  Keywriter-1 (1982)(Amazon Systems)(GB)req dongle.zip   4.93MB   30 downloads
#935 Zarxx OFFLINE
Zarxx
    Chopper Commander
  • 100 posts
Posted Wed Mar 7, 2018 5:51 PM
Just a few things I noted about the torrent files. If someone wants to check.
Skew Alignment protection, ATX only and normal drive speed required - Confirmed
Battalion Commander (1985)(SSI)(US)
Colonial Conquest v1.0 (1985)(SSI)(US)
Computer Ambush v1.2 (1984)(SSI)(US)
Computer Quarterback v2.0 (1981)(SSI)(US)
Kampfgruppe v1.0 (1985)(SSI)(US)(Side A)(Scenario)
Microsoft BASIC v1.0 (1981)(Microsoft)(US)(Atari Internal 1981-09-04 - Serial Number 140) - Discovered these are fine when atr'd, just didn't like the Speedy mode.
Microsoft BASIC (1981)(Atari)(US)
NAM v1.0 (1985)(SSI)(US)(Side A)(Game)
Quest, The (1984)(Penguin Software)(US)(Side A) ** 810 only
Quest, The (1984)(Penguin Software)(US)(Side B) ** 810 only
Star League Baseball (1983)(Gamestar)(US)
Manual/code required
Conflict in Vietnam (1986)(MicroProse Software)(US)  ** Code required. Manual included
Decision in the Desert (1985)(MicroProse Software)(US)  ** Code required. Manual included
Essex (1985)(Synapse Software)(US)(Disk 1 of 2 Side A)(Disk 1, Side 1)[!]  ** Code required. Manual included
Mindwheel (1984)(Synapse Software)(US)(Disk 1 of 2 Side A)(Side A Drive 1)  ** Code required. Manual included
BASIC required
Colleen Music Compendium, The (1988)(No Frills Software)(US)(Side A)
Phrase Challenger (198x)(Acorn Software)(US)
Starquest - Star Warrior (1981)(Automated Simulations)(US)[OS-B]
SynFile+ v1.01 (1983)(Synapse Software)(US)(Side B)(Tutorial)[!]
Non XL/XE
Dr. Mindwarp (1983)(ALA Software)(US)[BASIC]
Family Cash Flow v2.0 (1981)(APX)(US)[!][BASIC]
Hydraulic Program (HYSYS) (1982)(APX)(US)[BASIC]
Keyboard Organ (1982)(APX)(US)
Matchmaker - Biology (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - French Vocabulary (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - Spanish Vocabulary (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - U.S. Geography Facts (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - U.S. Government Facts (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - Vocabulary Word Builder (1984)(American Educational Computer)(US)[BASIC]
Matchmaker - World Geography Facts (1984)(American Educational Computer)(US)[BASIC]
Original Adventure (1982)(LotsaBytes)(US)[BASIC]
Quest of the Space Beagle, The (1984)(Avalon Hill)(US)(Side A)[!][BASIC]
Real Estate Cash Flow Analysis (1982)(APX)(US)[BASIC]
Space Games (1982)(Educational Software, Inc.)(US)[BASIC]
Misc
Super Hangman (198x)(Main Street Publishing)(US)[b][BASIC] = My Spelling Easel (1983)(Main Street Publishing)(US)[BASIC]
Sons of Liberty v1.0 (1987)(SSI)(US)(Disk 1 of 2 Side A)(Scenario)  ** labelled incorrectly as 2 of 2 Game. Correct files attached.
Sons of Liberty v1.0 (1987)(SSI)(US)(Disk 2 of 2 Side A)(Game)
Repaired & ATR
Avalanche (1982)(APX)(US) ** bad ATR, repaired
Factory, The (1983)(HesWare)(US)[BASIC] ** bad ATR, repaired
Smasher (1983)(Hardwood Software)(US)  ** bad ATR, repaired
Space War (1983)(APX)(US)  ** bad ATR, repaired
Repaired & ATX
Adventure in Time (1983)(Phoenix Software)(US) ** T39 corruption, just blank. repaired.
Najemnik - Powrot (1993)(Krysal Software)(PL) ** Was checking s720 then crashing. Added a CRC error and now loading fine. Game will ask for a code, word x in line x. Manual included.
U.S.A.A.F. v1.1 (1985)(SSI)(US)(Side A)(Scenario) ** CRC error on T33, repaired sector from a ATR whilst retaining Skew format.
Attached File  Fixes.zip   39.77MB   44 downloads
Attached File  Conflict in Vietnam.zip   35.26MB   29 downloads Manual
#936 hueyjones70 OFFLINE
hueyjones70
    Chopper Commander
  • 177 posts
Posted Wed Mar 7, 2018 6:02 PM
If I were to find one of the missing programs either original or a copy, how would I submit it for the good of the group?
#937 Mclaneinc OFFLINE
Mclaneinc
  • 5,616 posts
Posted Thu Mar 8, 2018 6:11 AM
Any ideas what the dongle code  is for Altirra's dongle emulation?
#938 Farb OFFLINE
Farb
    Dragonstomper
  • 587 posts
Posted Thu Mar 8, 2018 9:30 AM
Thanks for the additional dumps and the feedback, I will incorporate the information into the database. You have been on a roll lately finding interesting stuff to dump!
It depends what we're talking about. If it is a cracked copy, a standard ATR dump is fine. There's information on the a8preservation website for ways you can do that yourself. If it is an original disk, a backup of an original that retains copy protection, or you don't have the means to dump a cracked disk yourself, I would suggest mailing it to someone to create a dump. Feel free to PM me to coordinate that if needed.
#939 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 292 posts
Posted Thu Mar 8, 2018 2:24 PM
It will not work because the dongle is not digital but contains two resistors.
2900 IF PADDLE(F)-PADDLE(L)>K AND PADDLE(L)>K AND PADDLE(L)<BF*K THEN RETURN
Crack attached (paddle returns 228 when nothing is plugged in).
2900 IF PADDLE(F)[u][b]+[/b][/u]PADDLE(L)>K AND PADDLE(L)>K AND PADDLE(L)[u][b]>[/b][/u]BF*K THEN RETURN
Updated crack because I found a second check for the dongle.
Edited by DjayBee, Thu Mar 8, 2018 2:59 PM.
#940 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 292 posts
Posted Thu Mar 8, 2018 3:35 PM
Argh, too late for editing.
Cracked code should have looked like this:
2900 IF PADDLE(F)+PADDLE(L)>K AND PADDLE(L)>K AND PADDLE(L)>BF*K THEN RETURN
Edited by DjayBee, Thu Mar 8, 2018 3:37 PM.
#941 Mclaneinc OFFLINE
Mclaneinc
  • 5,616 posts
Posted Fri Mar 9, 2018 4:12 AM
Thanks Djaybee..
You work is always appreciated!.
#942 _The Doctor__ ONLINE
_The Doctor__
  • 4,024 posts
Posted Fri Mar 9, 2018 6:19 AM
you might be able to yank the file in your profile management system then post another post with the new file with the change... not sure... but it might still work that way.
That would make the old download fail and will stop it's spread and people can go to the new one... or you can always request the ability to edit your post from the powers that be... that would make it nice and clean...
Edited by _The Doctor__, Fri Mar 9, 2018 6:19 AM.
#943 Farb OFFLINE
Farb
    Dragonstomper
  • 587 posts
Posted Fri Mar 9, 2018 8:52 AM
Repaired & ATX
This one is interesting - we have two raw dumps of this that are identical. But clearly the verified ATR in the torrent doesn't boot and your new one does. Could this release have been broken when it originally shipped?
#944 _The Doctor__ ONLINE
_The Doctor__
  • 4,024 posts
Posted Fri Mar 9, 2018 9:39 AM
Not likely,  1995 was when I saw the game and it worked... would you buy a game and have it not work and then keep it? Something is weird...
#945 DjayBee OFFLINE
DjayBee
    Moonsweeper
  • 292 posts
Posted Fri Mar 9, 2018 10:57 AM
The download is OK because I edited my post at the right time. I only found out too late that the code snipped was mangled.
Thanks anyway
#946 _The Doctor__ ONLINE
_The Doctor__
  • 4,024 posts
Posted Fri Mar 9, 2018 11:46 AM
oh okay, the file is good but you ran out of time to edit the explanation in the forums snippet text box of your post. got it.
Edited by _The Doctor__, Fri Mar 9, 2018 11:47 AM.
#947 Zarxx OFFLINE
Zarxx
    Chopper Commander
  • 100 posts
Posted Fri Mar 9, 2018 6:39 PM
One from today.
Attached File  Boulder Dash II (1985)(Databyte)(GB)(PAL).zip   4.46MB   41 downloads
#948 Farb OFFLINE
Farb
    Dragonstomper
  • 587 posts
Posted Sat Mar 10, 2018 12:52 AM
One from today.
Thanks, Zarxx. We have one other dump of Databyte's Boulder Dash II that advfan donated. Unfortunately, a8rawconv couldn't generate a entirely correct ATX file from it and @ijor had to create one manually. It seems like this dump may have the same problem. I'll have to defer to him to do a verification.
#949 _The Doctor__ ONLINE
_The Doctor__
  • 4,024 posts
Posted Sat Mar 10, 2018 8:21 AM
it's weird certain disk take like 5 tries to get it to image if at all... is this because of the floating splice on disks... is there a mod to do away with the use of the d*mn index circuit on these flipping things? Maybe a bit writer really is a good move.....
Edited by _The Doctor__, Sat Mar 10, 2018 8:21 AM.
#950 Zarxx OFFLINE
Zarxx
    Chopper Commander
  • 100 posts
Posted Mon Mar 12, 2018 6:38 PM
It looks like I've found a rare one.
Attached File  Birth of the Phoenix (1981)(Phoenix Software)(US).zip   13.81MB   48 downloads
Manual
1 user(s) are browsing this forum
0 members, 1 guests, 0 anonymous users
